head gasket?
head gasket?
I fix all my wiring issues and now my car runs great, but one problem normal driving my car runs excellent, but as soon as i crack vtec coolant over flow fills up. i change the radiator cap so far no success. the car has no white smoke driving or at idle, no oil in the coolant, no bubbles when i take off the cap. I do have black smoke at top end though gas milage is at 235 to a tank of gas. its a b16 with skunk2 cams, aem fpr, rc 310 injector p28 ecu.
Re: head gasket?
black smoke would mean your running too rich so u might need to tune it since u got bigger injectors otherwise put stock ones back in and see if it fixes ur black smoke, but don't think its ur head gasket
Re: head gasket?
did you mess with the fpr cause they come from the factory set up for your engine and i agree with tundra2000 about tuning its always a good idea to tune a engine when you came it or add something electronically controlled
Re: head gasket?
Stop guessing at what it could be! Rent or buy a compression tester follow the instructions with the tester a low compression points to a bad head gasket. Better yet have the coolant tested for exhaust gas this is a no BS test to tell you if the headgasket is leaking. Without running a few simple test it is easy for people to give you a buch of guesses but no real fix to the problem
