View Full Version : Honda Civic / Del Sol (1992 - 2000)
- installing a y8 head on z6 block.
- fuel filter...where is it and how do i replace it?
- what spark plugs does everyone use for your swap
- uhh windows stopped moving up or down ?
- Flywheel
- can a modirator make this topic permanent. It's use full.
- Let us play "Will this work?"...
- engine swap help!!!
- Shocks
- JDM D15B ECU
- B20 vtec help!!!!
- Intake Mani Swap. Need Help
- Halo Headlight problems
- B series mounts for a 94 eg hatch? what is needed? spacer?
- shock problem
- just need to know where the speakers are...
- Main relay
- j's racing engine dampener need help
- Ignition Problem
- b20-vtec...What head is best
- GSR Armrest on EK coupe?
- rear rubber moldings on fenders
- Buddy club spec 2 exhaust question?? yes i did search
- EG Gas tank interchangability???
- Has anyone seen this eacv before?
- Need some knowledgable/experienced help, timing troubles.
- HELP: SWAPPING D16Y8 (OBD2A) MOTOR IN 95 HATCH (OBD1)
- blue wire???
- want to use OEM 96 civic seat brackets w/ new seats, problem!
- How to remove door handle?
- What are all the rear seats that will fit into a 96-00 Civic coupe?
- confused about throttle cable swap for B16A swap
- 2000 Honda Civic Instrument Panel Questioin
- bad compression??
- CEL Light
- **STOLEN 1993 RED HATCHBACK***
- hot tanking intaking manifold (getting rid of carbon)
- is this my cat?
- Honda center caps for wheels
- City lights bulbs colors
- What should I do next? b16a2 ideas
- D15B, Would you swap a Y8 head on it?
- Is it possible????? Vtec
- time for a new motor.
- exhaust help?
- NEW PLAYA TO DA GAME
- abs and k20
- I need an electrician for my Civic
- O2 sensor Question
- lifter taping at start.
- gsr into civic
- What are some good (relatively cheap) upgrade i can do to my del sol?
- Need Some Help. I already searched.
- Mystery plug!!!! The brown plug top right
- Cheap horsepower
- 00' si swap question.....
- Few questions about H22 swaps
- How many bolts or clips on the splash guard?
- is it safe to run..
- Starting car issues.
- No thrid gear Help!
- exhaust question
- y7 swap into 94 ex
- Tail lights
- type r back seats
- car overheated... changed stat... now everyhthing is just hot!!!
- HELP! CAR WON'T START AFTER ACCIDENT
- sunroof civic sedan???
- Odd Headlight/HID issue... Ideas are appreciated.
- HID
- b16 cams for sale
- Engine swap for a 99 civic ex
- EK engine mount Question
- oil pan removal
- Leaking coolant out of a hose(D15b7)
- ratteling ceramic..Please..any ideas.
- p06 auto to manual mod!
- EG8 bitch pin problem
- civic type r t-belt
- Stripped bolt for ac belt tensioner pulley
- del sol help
- Spyder Headlights
- Need some questions answered with my hatch and swap
- eg susp. fix ek?
- fog lights
- D15Z1 Block + D15B7 Head = Stumped on timing belt/Cam Gear....Pictures
- wire harness for b18c type r swap
- which springs?
- I lost on what to do next
- CTR cams
- D16z6 TURBO Problems Need Help
- searched but couldnt find anything h2b e.t. with ls tranny.
- problem with door locks....please help
- ECU question
- your opinion on on these rims for an ek
- 1998 CIVIC EX SEDAN...
- Suggestions welcome please
- ok what does that click sound when you turn your car on mean? and a solid cel
- hit a gard rail on my civic and i need some help
- white smoke?
- Rough jerking around 2000rpms?
- Fun times with high mileage - the clock spring/cable reel/brake light/horn issue.
- b16 blinking lights.... unusual problem
- Starter Solenoid or Car Alarm
- overheating!
- tail light wiring....
- Need help on delsol intake
- B16 or Ls/vtec?
- whats the right ecu for a
- Help/Advice on swaping D16z to D15b2
- Cold start problem, help me diagnose!
- No power to injectors HELP
- civic exhaust
- Modifying s2000 steering wheel hub to fit 92-95 eg civic sk2
- Antenna removal question
- Head Lights
- Civic motor problems
- D16Y8
- Civic cat converter
- Importing
- Misfire Problems Need Help
- dual din delete!
- air conditioner removal?????
- ctr cloth?????
- B18c SC ECU?
- serious camber issues with 17's on a coupe
- 93 Del Sol headlights
- Civic eg ek innformation needed
- 99 DX rear disc conversion
- Overheated 92 civic, now it want start?
- Noobie With a quick question about, engine lagging?
- trans/axle grinding noise
- 97 dx with GSR problems. not mounting right
- swapping engine legally
- loud ping
- ls-vtec or gsr
- B16 Gasket kit question
- Problem: Low RPM/Honda Civic D14A3
- injectors
- Is there anyway to find out if a motor is stolen from the numbers under the b18C letters ingraved in
- Saving up for a big upgrade?
- HELP WITH D16A NOT ADVANCING
- Seat Options in my EG
- Help, Headlight install
- Gas Gauge: cluster problem
- mfactory swaybar kit, how to install.
- Making a Integra GSR gauge cluster fit a 1992 Honda Civic?
- Running 5 wire o2 on z6 p28
- type R pistons in a b16 block.
- Turbo D16y8 vs LS Swap
- NEED HELP PLEASE...
- Idle Problems
- A little story... gotta do some head work
- maybe dont clean your iacv
- Problem w/ sohc vtec?
- PICS!!!!!OF MY P.O.S
- Help! Honda Civic EG seadn 1992 engine swap B16A2
- Question about Transmission serials...
- looking for a link to service manual
- code 14 help how do i fix i t
- Transmission issue
- O2 extension
- problem with vtec
- horn problems???
- Which ECU to use for b16a2 swap in 96 hx?
- Lets play: "ID this Camshaft"
- Torque spec for a z6 eagle rods w/ arp bolts
- AC condenser
- EK sideskirts??
- Too much Oil No VTEC???
- datalogging p28
- attn anyone with a b18c in a 6th gen civic...
- spring problem!!!
- H22a Problem HELP!!!!!
- door window motor 98lx 4dr civic same as 95 civic 2dr
- exterior help
- Bad Main Relay?
- Help with swap please!
- Do a 96 type-r acura suspension fit on a 96 ek hatch
- changing a tired
- How to test an EGR valve?
- headlight help
- Grinding noise
- Distributor Help
- CEL Blinking while driving now my car sounds like a SUBARU?
- AIR CONDITION CAUSING PROBLEMS!!
- MY CAR WAS STOLEN NO!!!!! ANOTHER EM1 BITES THE DUST
- Axle popping out of tranny
- fuel pump
- Odd Cooling (radiator) problem ..
- mount ?
- Oxygen sensor connector location
- Getting A title?!?! I hate the DMV
- After done swap from D to b16a
- WTB honda cat converter
- Skunk 2 Intake Manifold???
- Motor help!
- Brake problems: deciphering between sitcking caliper pin or piston, or brake lines
- b16 tranny
- Help! I cant get out of park!
- Anyone Seen This Overheating Problem Before?
- Help Plz! Mainshaft Bearing Came Apart!
- Radiator Hoses?
- S.Techs pics/info
- clutch problem, new tranny.
- Failed Smog - high NOx
- white wire on MSD Digital SCI+
- Next Upgrade Question
- who has a helms for a 95 gsr
- 98 Integra REAR seats into a 96 Civic coupe...
- DIY : WINDOW TRACK PROBLEM
- High Engine temp @ red lights
- power expectation from mugen exhaust and mugen header
- Civic will not accelerate while running A/C
- Car died at a traffic stop..Help!!
- NEED HELP
- Cat back muffler between eg hatch and sedan or coupe??
- Engine mount question for all swap gurus
- Help VSS
- Intake Manifold Problems....Help
- KYB GR2's wont fir 93 eg??
- gm 3 bar map sensor
- z6 swap?
- another mpg question
- 96 Civic Window Regulator - Price?
- 96 ex grill dimensions...
- wiring spal fan ?
- installing radio in 92-95 civic
- Screwy Window
- are honda/acura rear sway bar end links created equal?
- Flasher Relay?
- high idle problems with my sohc engine.
- help diagnose shimmy when braking
- CELs all over the place
- Questions inregards to the components of an srs system..
- Detecting Fuel Additives...
- is it possible to install an a/c system into my cx?
- brian crower cams
- Code 41
- When driving over 60 mph, the car starts to shake ONLY after a slight bank or bump in road
- Need help on EK Coupe( turns over but won't start)!!
- B-series reverse is synchronized!
- es tuning exhaust
- Oil Pan Gasket
- c&r radiator drain plug problem, please help ?
- need part number!
- You can buy yahoo Japan by oneself.
- obd2 wire-tec
- For those who have a ek hatch + type r/CTR rear sway bar
