View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Pic request
- Swap Question ODB2 to ODB1
- wireing question
- putting rsx seats in a eg hatch: need help ASAP
- CEL Code #1 on EG B16A WTF..........?
- somg failure. need advice...
- short shifter issuses
- engine lagging...
- JDM Headlight do it yourself link
- can i datalog from this ecu?
- poll - yellow bulbs or hyper whites
- ek hatch weight
- ITR LCA
- Help.. Car Started.. and now it doesnt... ECU problem maybe?? HELP..
- DIY catch can writeup... less that 20 bucks!
- Having trouble with coilover installation
- CEL 41...need opinions
- Eg front on Del sol
- VTEC problems
- Does torque matter? im a noob...
- Electircal Problems....HELP!
- What is causing my fluctuating idle/surging idle? *Searched*
- should i go obd 1
- Need fuse diagram underdash for 96dx hatchback.
- h4, h4-2 hid harness
- 99-00 Fog light diameter?
- dc control arms on ek
- Painting EK Side Skirts
- pr4 same as p75 (searched)******
- d series tranny question
- cooling line heat wrap
- What ECU to use for a b20z2 into a 99 ex?
- foglight bulbs
- to OR nOT tO
- What OEM rims will fit on my 2000 ex?
- Are these stock Si seats?
- what turber is good for a d16z6
- rs*r gt2 onto a 99 civic dx hb with a swap, what size test pipe did you use?
- bearing clearance question...too tight?
- del sol si
- Weird problem when braking
- Car wont start
- 92 civic ECU upgrade
- HKS Hi-Power
- Bad relay?
- Installing Civic Type R lip on EM1.
- Quick flashing signal
- another newb q
- SI climate control, will it fit??
- F22B1 swap
- Answer my question correctly for money!
- NEED ADVICE? B18A1 into 92 eg?
- DIY tach installation
- just blew my b16
- anyone recommend brighter headlight bulbs? need input
- 2000 si tranny grinding
- D15b8 93' Cx Vavle Lash
- Looking for advice on EJ1 repair - Flood Damage
- what do you guys use to lube rubber bushings and to keep rubber boots from deteriorating
- wow i found a bad @ss website
- Oxygen Sensor / Heatshield
- Civic HB Exhaust Question
- which A/C compressor do I need?
- Wire Harness Help (B18C1 in 92 Dx Bubble)
- throtle body question
- shiftlinkage problem!!!
- Quick title ?
- B16A Tune Up ( Help )
- quick Si question
- which motor has more potential, d15b or d16z6 ?
- Dose the GSR fule pump fit a 92 civic?
- THrow Out Bearing Noise
- H22 AXELS
- Where's this oil coming from? Around driverside headlight.
- Tire Pressure
- can this be fixed
- HOLY F'IN MOTOR MOUNTS.
- b20 turbo
- 2000 Civic Si HELP!!
- motor bogging and fuel cutoff
- lug stud / nut combination
- smog check needed click here
- eg si/sir lip on ek
- obd1 code reader
- how to block off PCV hole on valve cover
- 99 si and 00 si?
- d-series with lsd
- emissions question for cali residents and other states with smog
- just got a 1995 civic ex coupe.. any suggestions?
- is the 94 del sol rear bumper different than the 97 del sol rear bumper?
- 1992 honda civic hatchback vx
- Smog Test Question: High HC, Barely passed pretest.. Smog Test Only Center awaiting
- Remember: Long magnetic drain plug = OIL, Short magnetic drain plug = TRANSMISSION
- Civic Si codes....?
- I am a complete retard but I want to learn
- tein hood dampers for 96-00 civic
- guys i need ure help only u guys can help!
- aftermarket power door lock making grinding noise
- Civic Relays?
- What are some good tires i can get for VX wheels?
- swaping a b16 in an eg
- Del Sol AC into EG
- How do u install a universal FUEL PRESSURE REGULATOR???
- cam caps wont come off
- Overheating Problems
- B16 Turbo vs. B18C with boltons
- rpm needle help
- help!! take off visors from my ek hatch??
- installing power steering
- wire diagram request for 00 SI hazard light
- broken spark plug seal?
- y8 head onto z6 block questions
- clutch pedal feels soft
- will a 30x6x3 fit my 95 civic bumper?
- twin loop exhaust anyone got clips?
- AC Autotechnic race manifold What are ya thoughts on this IM??
- Del Sol Seats in an Eg
- p08 chipping question??
- Tranny Crunching
- MY B16 SWAP ON MY EK..SHAKES MY WHEELS..NOT AXELS...WHAT COULD IT BE.?.HELP
- A Choice of CHampions :-D :-D
- Deciding on Exhaust System! Need advice...
- i need all input on tokico hp's (aka blues)
- EG Sidemarkers Installation Diagram?
- 02 sensor replaced
- MODS CHECK IN PLEASE.
- Exhaust scrapes ground! (searched)
- what to get...00 civic si
- Will this CTR steering wheel fit on a Eg
- creak in rear
- What would happen if I unplugged the o2 sensor?
- 2 resonators bad?
- cat converter question
- Header for Civic
- P28 chip question??
- SAFC2 help please??
- 93 civic ex sunroof question
- Identifying an ECU without lable?
- Seats?
- Air Conditioning Pressure Switch
- spec 6 puck
- HELP! Does anyone have a chilton's guide for a '93 Del Sol Si?
- $1500 left....what to buy?
- exhaust rattle
- odometer swap into new cluster
- about to paint my car
- Please help me.. Sunlight (Sunshine Yellow)
- TCMotorsports?
- quick qestions about top speed and a race
- where can i find images of Ek hatchback pictures?
- thats the difference between a 96-98ek and 99-00ek?
- turbo?
- Any FAQ's on Wire Tucking? with updated pics.
- How long will it last?
- I Need a Bloody F'n Motor!!!!!!!!!!!!!!!! I have $$$$$ on hand!!!!!!!!!!!! NW INDIANA
- What belt for CTR N1 pulley???
- Exedy Stg 2 Clutch Slipping!!!!
- Motor Choice for 94' del Sol! Help me decide!
- o2 sensor/ other problems.
- Best place to get a...
- Civic hatchback Model Differences
- What Honda comes with a D16Z6
- Offset and custom fender work-- I want to run a wheel with a stupid low offset
- taking off crank pulley bolt
- Power Window install to battery??
- Loud Air Coming From Engine Bay
- Magnaflow slip on cat?
- LS idle issues
- Carbon in Fuel Lines
- Engine Harness Conversion Problems. OPEN IMMIDIATELY
- obd0 to obd1
- B18C1 GTI INSTALL NEONE????
- help with codes!
- synthetic oil
- broken motor mount, energy suspension bushings?
- Drop in gas milage
- need input. pro-kit + ____?
- vx header 02 sensor
- 95 civic 4door brakes
- eg-6 for sale
- Whats going on everyone? Well I just got back into my 2nd Sol and I want to do this one right. I had
- Does a 2.5'' exhaust bolt up to stock cat.
- eibach pro-kit
- Lowering a 98 Dx
- having bad vibration when braking.. ideas??
- 96-2000 cat passing smog in 92-95 civic
- car idling problem need some help!
- drag coefficiency for civic 96-99 ??
- EK Tar Removal
- Obd2 to OBd1 in 99 ek hatch
- difference between usdm b20 and jdm
- SRS light, power inturruptions 98 Ex
- k series crank sensor
- do i need to convert my harness??
- B20 knocking when cold
- mid-pipe fitment
- fuel filter questions
- Wipers keep on running!!!
- funny noise from my exhaust does anyone know?
- fuse panel
- s2000 wheel in a delsol
- b17 eg hatch coverted to cable.. questions.
- instrument cluster problems
- b16a bolt torque?
- horn wiring
- Clutch Doesn't Feel The Same.........(replaced c/m/c)
- Differences between USDM & CDM for a 93 Si
- oil lines ran for y7/y8 mini me?
- My damn blower sure has been noisy lately....
- question about injectors
- B16A in to civic hb
- D16Z6 vs. D16Y8
- Doing Auto to Manual Swap this weekend, any Advice i need?
- Where's the cheapest place for a Megan Exhaust?
- stock rsx type s axleback on ek?
- Resurrection of the D16Y8
- What's wrong with my new thermostat?
- k series into eg 92 bubble
- paint my CF Duckbill??
- ls/vtec check engine light at the end of 3rd gear
- i know you hondata guys can answer this....
- will LS throttle body fit on d16z6 manifold
- 92-95 civic dx master cyliner upgrade?????
- 92 EX ABS code question...stumped here
- How much horsepower is needed in 1995 EX coupe to make high 13's?
- stock strut tower bar
- does a d16z6 trans use same axles as d16y8??
- Should i get this for my car?
- I need a Silicone nipple or pipe hole cover , dont know whats its called.
- P28's?
- Well I Seafoamed today...
- bypass valve or not
- how to bleed jacks
- Loose inside mirror 98 Civic
- Torque Specs On Head
- vtec for d16y7?
- Main Relay
- pro-kit + tokico hp? need input
- abs question
- B16 with B18 crank
- gsr sway bar in EG, now my muffler dont fit
- with all the theft going on
- installing euro rear fog
- 95 Coupe ex shell for sale. or wiling to part out
- question on wiring up JDM headlights?
- thread question
- need help my car idel
- how do i clean my stainless steal header?
- 2001-2006 civic oxygen sensor compatibility
