View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Installing camshaft
- wtf size are the nuts on arp head bolts help asap!
- b16a into a civic?
- Can u use a D-series O2 in a B?
- brand new 6 puck sliping? help please?
- help!!! need to know what site is the best when it comes to buying a complete swap
- Short ram or cold air?
- Can i use Any VSS(Vehicle Speed Sensor)?
- ECU CHipping p28
- How do u fix ecu code 41? Primary oxygen sensor heater
- 91 4 door ex master cylinder into eg.... question??
- 92-95 civic hoods the same?
- IAB question
- ppl with APEX N1.. would u reccomend it..
- doing 5 lug in a different way (question)
- My Car Won't Move! Help Please!
- I just got a new tranny lsd.
- buddy club spec 2
- Distributor causing power loss?
- VIN # on SOHC Motor?
- Question about State Ref in CA...
- tranny question..
- Best place to buy just the clutch disc anyone know where
- JDM center console?
- strange rattle
- reverse gear squeals
- clutch gone wrong
- B20B question???
- I know I know another idle problem but come on, this is tough!!!!!
- switch p75 ecu for a p28 so my gsr can hit vtec. After pluging the p28 in the check engine light tu
- exhoust is touching back bumper
- Review My wiring Please
- some questions after b18c swap.
- tell me if this sounds like the truth
- 4 door civic or crx
- plannin to paint me rear ctr lip
- windsheild interchange
- how to identify honda wiring harnesses
- civic or crx
- parts i can reuse?
- i need to replace the rear hub but should i get a teg or civic hub?
- d16 clutch
- difference b/t d16z6 and d16y8 fuel rails?
- son of a...
- Where do you buy engine components and question about main bearings
- I got hit (technical appearance!)
- HOw the hell?!?!?! Please help A.S.A.P
- targa top for del sol
- del sol auto to a manual swap help?
- Blinkers not working.
- Pic Request: 99-00 Si Cluster w/ CTR Carbon Trim Bezel
- exhaust w/ muffled sound
- VSS problem Need help!
- problem starting car
- what can i do to my civic gx 4door?
- CV boot
- modding questions
- A/c problem, where are the a/c gurus?
- Tein S Tech vs. Neuspeed Lowering Springs
- Will a six puck hold 350whp?
- LX oil pan fit EX?
- what you know about hondata?
- EM1 With P28 Chipped ECU + JDM B18C ... Code 22, Help !!!
- Sluggish D16y8
- WINDOW TIPS AND TRICKS
- B20 block on B16A2 motor?
- Another car wont start!
- Part # for primary o2 sensor
- Pics of Flat Black ES Oval 2.25 and 2.5 of 92-95 Hatch??Anyone??
- d series shit
- Swapping a b16 into a Civic h/b 93
- **Mini-me swap questions**
- KNOCK SENSOR I NEED SOME IDEAS
- phearable ecu
- Anyone with a 1 gen SiR motor have any problems with it so far?
- AC light
- 92-95 si tranny rebuild
- question on throttle body.
- B16a Swap tranny questions
- Check engine light came on =(
- Throttle pulley Differences???
- How much is this civic worth
- Swap Mount Issues
- Sunroof problems
- only happens when it rains
- SRR
- broken tabs on si lip
- turbo information
- CEL Code #9 94 Civic EX
- where should i start
- bulging on the floor of my car
- Help D16z6 motor on 95 civic eg coupe Help
- Trying to understand the VAFC a little better.......
- electrical problem!!! Blinker and speedo
- b18b VS b20
- anyone know doors?
- car idles around 100-200rpm
- can someone tell me more about this cylinder head???
- brake discs (rotors) for a 94 civic del sol
- Clutch wet with oil? help
- Noise coming out from the shifter
- Trying to get CEL code, and ABS light flashes??
- supension help
- catback for 00 si
- sleeper exhaust/muffler
- Bleeding Brakes
- Need New Air Vents
- civic coupe seats fit in a sedan??
- Carpet Interior color for 92 Civic HB VX?
- cleaning air intake filter
- wacky speedometer
- c-pillar bar the same for coupes and hatchback?
- obd question
- 2001 civic front fascia for sale
- Replacing outside trim...
- quick eg swap question
- Which Brake Pads??
- hose down engine and everywhere under the hood
- Need Advice on a 95 eg coupe
- quick help asap!?!?!?!?!
- orthia??
- A/C issue
- b16b
- swapping dashes
- d16's....the z6 vs. the a6.
- 99-00 Single Din Radio Blockoff Plate
- '94 Civic Ex transmission problems.....help
- how to convert obd's
- oil leaking!!!
- take off an oil filter
- filters.... for the fuel system
- Floor harness question - power windows, mirrors and locks!
- power steering and A/C
- Work in Progress... Retro fitting Bi Xenons into stock eg housing
- quick tire size help
- 99SI vs 94SI (EX w/B16)
- How much should i be paying?
- NEED HELP WITH INSPECTION IN JERSEY
- MAP Sensor PLEAS HELP!!
- NEED HELP PLEASE!
- p28 and y7
- Installing lowering springs on 00 Civic
- best thing to do w/ hole in intake and hole in motor head?
- 96-98 vs 99-00 civic
- Tranny makes noise...
- f20b into ek?
- Bomex mirrors and window visors
- Need help, Replace clutch . .. .
- another clutch problem tech needed
- Identifying engine serial number
- 92-95 Interiors? what fits?
- transmission fluid
- please helppp
- Injector replacement
- ebrake button issue
- keys lost
- Cylinder Update (with pics)
- Help?? Car without MAP sensor Runs??
- IAB question
- 96-98 front end on 99-00 civic...
- New to the world of honda
- 1999 civic si valve lash
- 91 prelude si seats in eg?
- intake manifold questions
- ek exhaust on an eg
- wiring problems
- ENDYN Breather Kit Issues!! Help
- NJ, DE, or surrounding area....help me do my valve lash
- K swap essentials
- How to drive with LSD?
- Master Cylinder?....
- what is a good starter engine for my 98 civic hatch that is easy to install??? thx everybody.
- Help! What motor, trans. mounts do I need to put a b16...
- really need help...alternator question
- Vafc instructions
- still bogging
- Looking for an eg6
- NEW TO HONDA-TECH.COM
- What timing belt to use for a jdm d15b non vtec?
- Help with ek9
- STOLEN: Red 92 civic hatch !!!!!!! PA !!!!!!!!
- changing shaft seal on tranny and saw this s#it, is suppose to be there
- Speed limiter
- B18C VTEC Question
- I have some questions about adjusting AEM cam gear on d16z6!
- Any answers to hard to start when cold problems?
- low idle problem
- Spoon exhaust
- Looking to sell my 00 si.
- Looking for a Valve Spring Compressor
- Adding Power Locks? Difficult?
- need help
- Car doesn't want to start.
- 2000 Civic SI Intermittent Cruise Control
- Just out driving and car started missing bad & CEL blinking
- 93 civic seat brackets onto integra seats 94???? help please...
- AUTO TO MANUAL SWAP HELP PLEASE
- Will a hatch axleback exhaust bolt on to a Del Sol?
- 94 z6 into a 00 civic EX?
- Is the S4C tranny really a B16B(CTR) tranny?
- Need a suggestion
- Help... car won't start!
- someone good with photoshop????
- couple general questions about motor swap on 89 crx
- Power windows for EK.
- Running Rich
- B18B1 Swap Into 99 dx hatch
- How much is my car worth????
- So how do I go about this.......
- ex header on d16y7..
- very QUICK/SIMPLE questing about ebrake!
- very frustrated! no brake no reverse lights!
- Idiling and Temperature Problem.. help
- EFI engine tuning: how do i calibrate the engine to fill in all parts of the fuel table??
- quick swap questions?
- What color does the EK's oem cd player light up?
- Help me order the right size CAT PLEASE
- carbon fiber parts
- motor oil
- is this correct?
- collector size question, JDM B16
- 00 SI throttle body search!!!!!
- B16A reliable?
- skunk2 strut bar
- Tranny LOCK UP on a D15 anyone know whats up?
- h22 eg hatch vtec has a mind of its own
- gas Problems with my 92 cx b16 hatch
- items needed for manual to power steering conversion?
- High flo cat for my 00 si?
- 1/4 mile expectations?
- weird problem and wont start
- exhaust leak
- question bout MC/BB setup on my ITR SUSPENSION
- Wire VTEC CAR WONT START NOW............. KNOCK CENSOR???? HELP ASAP PLEASE
- injectors for D16y8
- Vtec solenoid question
- Did swap-Have Problems
- Cable trans to a hydro trans
- LS Vtec
- super charger
- JDM center/audio console and armrest
- FLUIDYNE RADIATOR problem
- d16z6 into 98 hb non-vtec
- window visor installation?
- wtb: usdm del sol b16 gauge cluster
- stock p28 on b16
- Engine Block questions...
- FOR SALE!! 1.5 VTEC 95 del sol
- '92 Civic SIR-II motor in my '99 EK hatch motor mount questions...
- need help finding door panels
