View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Rear discs on a del sol
- Koni Yellows or Tokico Illuminas? Cant Decide!!
- ebay ctr replica grill
- '95 Honda Civic EX - Where is the water coming from?
- civic capet
- car dies when a/c is turned on.
- torque specs for d16a6 eagle rods p.n. 5394
- 2000 Civic LX Short Ram Air Intake Question
- Third gear "jumping" out , S80 gear in 98 hatc
- My hatch build, single cam slam, body and motor! (56k be warned)
- What tap size for b18b1 crank flywheel side?
- buzzing coming from fusebox car not starting.
- side moldings on 99 ek hatch...
- more [freak]ing problems: car wont start
- ecu hunt
- The K20 Type s, and the work along with it
- bleed a brake master cylinder by the caliper?
- my civic sounds like a truck?
- jdm k20 on EK!!!!!!!!!
- 99-00 EK: Cant get the dang door harness disconnected!!!!
- idle problem,.....continued.
- this is urgent. seriously
- Motor swap
- BOGG-A-PALOOZA on a b18c1
- Fuel pump wont stop!!
- del Sol EG2 wheelbase question.
- 93 Honda Civic dx air conditioner help
- VAFC-2 wiring. HELP!
- motor swap info
- Performance Headers
- k20a3 swap
- 92 cx
- P0420 Catalyst System Efficiency Below Threshold
- Rims? Interior mods?
- Favorite Bookmarks
- skunk 2 stage 2 cams
- help with body kits
- I need a mechanic ASAP to do a water pump on a d16y7
- Nightmare 00 Si - Wired from hell
- getting the door open?
- CEL 22 VTEC pressure valve
- car wont start!!!! searched and im at a loss!
- Engine harness
- Where can I get used Honda parts online?
- Si 2000 strut fork and lca into 98 hatch
- LSD trans prob
- just somethng i was thinking
- greddy emanage on a b16
- dizzy ?
- ek sideskirts on eg.
- need clean pic of 6th gen
- Help Windows Want Roll Up
- Coilovers: Skunk2 or Ground Control
- help with greddy
- 97 Civic DX O2 Sensor, HELP!
- What's the most painless SOHC swap for a 1994 Civic Del Sol > 6 of VIN inside
- Main relay - No fuel
- where can i get a 1997 del sol front bumper?
- Suspension/ Handling Mods for 92 civic EX sedan
- Exhaust Piping
- cable or hydrolic??
- Del Sol EFI
- car wont start, just a steady crank... main relay?
- Gsr Turbo kit
- Need Help : EG Front Upper Arms
- gutting out a 92 4door civic
- Going to Paint my Engine Bay Questions??
- Auto box oil level..
- ENGINE MILAEGE????
- Del Sol Exhaust
- B18b or B20 turbo?
- ? about my Eg's adjustable suspension
- Missing Plugs? LS Swap...
- climate control light
- difference between d16z6 IACV and d1678 IACV
- Hubcaps not staying fastened
- d16z6 with boost questions......
- Omni power 4 bar map sensor problems.
- How to hidden Honda harness?
- B16b internals??
- NEED HELP WITH MY TRANNY SWAP! D Series TRANNY! PLZ HT MEMBERS!!!!
- Lowering 98 EX coupe help
- b16 rod bolt
- Will a CAI for a 98 fit a 94?
- which lower control arms would u buy?
- 95 civic dx front end damage
- boosted trouble ?????????????
- Clutch Fork
- LS/Vtec Vacuum Hose Diagram? Too much Pressure in Crankcase?
- window regulator
- will integra window regulators work in an ek civic?
- BUMper FENder question
- question!!!!
- my car shakes!
- Alternator Sensor Fuse #15 keeps Blowing On Civic 2000.
- can someone please tell me where these go?
- 92-95 si sunroof
- Timing Belt / Water Pump Change. Now very Noisy..
- lsvtec with no vtec....help!!
- Del Sol window replacement
- fule pump/windows/clock/not coming on alsobrake light wolnt go off
- Bushings question.
- Front End Popping
- side marker install
- my car is slow, stock hp?
- JDM eg6 cluster.
- delslow gaymatic to manual tranny
- does anyone know
- Stock Camber for a 2000 Honda Civic Si (EM1)
- Idle adjustment screw
- 92 hatch speedomiter
- New to honda
- Anyone ever swap manual regulators and cranks into a power window set up???
- d15b block d16y8 head mini-me into odb2 d16y8 civic
- Coupe VS Hatch door
- 94 civic bad thermostat?
- clutch lock.
- screwed up my a/c
- JDM CTR EK Front and Rear Lip
- bump stops (yes, searched)
- VIS CF hood question - did they screw up?
- burn out my gauges
- whats a decent im for ls
- Need help!! How to change your break on a 94 civic Ex
- dizzy wont fit!!!, searched need help asap
- 99 civic miss at idle
- Torque drivetrain loss
- Wheel Offsets for 15X6 steel wheels 01 civic
- Does the memoryfab intake work with the stock front strut bar(EM1 Si)?
- 93 civic ac line high side were can i buy?
- 94 delsol blows ac fan fuse after ac gets cold
- 94 Civic sputtering problem...
- oil pan question
- ECU question
- H2b EG with A/C? Possible?
- FAQ I'd like to add to. Valve Stem seals and springs while head is on car. Cure for JDM oil burners.
- What happened to my MPG??
- Engine like on O2 sensor(bank1)
- Is this worth it 00 SI??
- mugen or tanabe
- Swapping from H22 back to Stock
- how do u know if ur clutch or tranny is out?
- PLS GIVE ME ADVICE !!!!!!!!!!!!!!!!!!!!! HELPPPPP
- AC stall my engine/makes loud noise when turn on.
- Ek Axleback Question Coupe/Hatch??
- boosting a z6
- Weird over-heating issue!
- single cam internals
- Air Conditioning Help!
- clutch problem.. need help!!! won't go in gear...
- Upper and lower radiotar hose very hot and swollen. Help..
- ecu code problem
- OK SIZE WHEELS AND TIRES COMBO???
- Front brakes - replaced and clicking?
- 2000 civic with obd1 convo, wuts with the extra wire on the distributor (rpm signal)
- Project Del Sol 40mpg
- Need advice on lowering my del sol!
- knock sensor size
- NO POWER!!!
- Finding former owner of vehicle
- RHD questions!!! HELP!!
- ek9 b16a swap advice
- B series wiring
- How to remove fuel filter
- Theft... And what they do
- black stuff from exhaust not burnig oil???
- complete AC
- gauge cluster...
- Help with error codes on engine swap please...
- itr cams and ecu
- brands for calipers
- Basic turbo sohc
- Question about d16z6 motors
- 99-00 Civic Si Spoiler on 99 Civic EX 2Door
- wilwood proportioning valve in civic EG ?
- B16 crank HELP!!!!!!!
- wut plug wires go where on the distrubtor
- Seat/Bracket/Rails
- replacing oem wing with ctr wing
- b18 crooked?
- Air Conditioning Removal
- o2 problem. Help b16a
- eg8 vs eg9 doors
- Tail Lights, Instrument Panel, & License plate lights Not functioning. Please assist!!!!
- Dropzone coilovers
- Will the intake fit?
- car bogging, and has a hard time starting up
- single cam 2 step
- where to get primer?
- Axle question?
- NEED HELP QUICK!!!!!!
- How can you tell a P28 and a P06 ecu Internally from each other ?
- idle problems...
- I NEED HELP!!!!REALLY BAD ON THIS CONVERSION PLEASE HELP
- A/c Clog
- modified exhaust ticket. help!
- Headgasket Question
- CEL 67 Catalytic converter
- need help with brakes
- Stock Mounts??
- Help thottle body b16a2
- 1994 Cx Hatch with 96 ITR Ecu Question
- Cold idle bounce, stalls sometimes on deceleration. Bad IACV?
- Quick Question Regarding Spare Tire Cover 96-00 Coupe/Sedan
- My soon to come (hatch)
- installing sleek mirrors
- weird whistling noise.
- Is it possible to make a hatch handle good?
- CTR vtec cross over?
- need to replace mom's engine...looking for direction
- cx hatch engine problem
- gas milage
- brake line
- DIY Roll Cage EJ1
- HELP, MY EX TACH isn't working!!
- smaller displacement + turbo swap = economy?
- Clutch Problems
- Upper radiator hose SWOLLEN! Please help..
- what do you guys think?
- Carbon Fiber
- my 97 civic...misses sometiems
- over heating question?
- CAN I WIRE apexi avc-r avcr electric boost controller TO MY SI??
- ek d16 into eg
- 98 Civic Timing Belt/Water Pump Question. (Searched already)
- eg obd1 swap with obd2 b18c1
- manual conversion problem
- dizzy conversion harness?
- Battery or alternator
- IACV plug questions with pics
- replaced headgasket and timing belt now car wont start..*SEARCHED*
- b20z cams in a b18b?
- no power to my distributor
- WILL A D16Z6 ENGINE HARNESS FIT A B16 ENGINE SWAP????
- ??? Need Help Identifying OEM Parts For Your 92-00 CIVIC/DEL SOL (USDM)???
- Lazy Oxygen Sensor
- b16 wiring in ek question..
- repeated rear main seal failure
- Thieves tried to steal my EG.
- eg starting issue? video to help
- Aftermarket horn in an eg
- NEED HELP WITH MY EK ASAP!
- k20a3 ?
- Will LOW gearbox oil, cause HARD shifting
- I need someones carb legal intake for EK! Give ya 40$ and a BLUNT!
- 2000 civic ex---b16 question
- will 99-00 dash directly replace a 96-98 dash??
- leaking oil from spark plug cover bolts is it possible or do I have another problem??
- best place to buy a new axle?
