- Fuel filter
- HELP!!! Car die after valve lash adjusment
- Need a trim piece 96 coupe
- Dim Brake Light on Dash
- 93 Del sol - Interior parts -
- help
- trial....???
- Inspection..am i getting screwed?
- working on car right now please help?? code P1337 after h22 swap?
- transmission
- jdm climate control??
- HHO on D16?
- need help choosing ECU P30 or ITR
- head stud question
- Wire harness question
- VTi cluster in MPH?
- power steering delete trick????
- 93 civic w/ gsr adding a/c
- Fuel Return Rubber Hose Section
- 8 valve 2 16 valve d15
- 00 Civic, Sitting for a year
- RPM Gauge Jumps at 3.5K
- 2000 civic 4dr dx?? d15b7??
- Are all these ECUs vtec?
- Check Engine Light B16a2
- Need Intructions on how to remvoe wheel studs?
- keyless entry on my ek
- alternator wire burned
- well im pretty sure my valves are bad or piston rings?
- I should know this one too! Bswap throttle cable
- abs light is on??
- air/fuel question??
- Where to buy valve stems?
- Should I replace my proportioning valve?
- can u put a vtech head on a b18a1 motor???
- S2000 cluster/carbon fiber
- Piston Pin Installation & Removal Help - JINOTIQ...
- alarms
- rhd da9
- Resonator Pipe
- no power to fuse box!
- eg6 interior pieces
- spark plugs
- Gsr in EG
- power window & power locks
- Weird problem please help
- How to clean the throttle body? Does dirty throttle valve casue loss of power?
- brake problem
- mugen or SiR?????
- Watts? Factory speakers..
- Motor swap exhaust question
- Replacing battery.. is OEM good or should i go with something else
- Engine code. v halp
- motor question
- Rough idle and 7 check engine codes - I could use some help
- Chassi codes i think?
- 98 Civic : H3 Xenon Headlight Install. Need Help!
- Supercharger for LS motor
- starter replacement
- quick question about FLYWHEEL :)
- Another question I can't believe i don't know!
- Engin swap for my SOHC LX 98'
- i need help on
- z6 oil pan onto a y8
- brake problems
- CEL 11? Help
- These F#%king Muffler Bolts!!!
- ecu fuse
- Rare Rims
- need help choosing ecu
- O2sensor question about header install
- SI cluster MPH messed up
- best tranny for my d16y8?
- twin loop :)
- will this work?
- swapping a 95gsr into a 97 civic hatchback
- need to replace mom's engine...looking for direction
- re:b18c5 bad dyno result
- 94 ex exhaust
- 93 del sol si wont start tried everything!!
- HELP, CAR WONT START
- Greddy EVO 2 Exhaust? Headers?
- HELP!!! HAVING MAJOR PROBLEMS W/ FRONT CAMBER KIT ON MY EM1
- exhaust piping
- cigarette lighter
- how much should this be worth?
- Does D15B7 head work on D15B8?
- How do you take off your steering wheel?
- Manifold Catalytic converter options
- Fog Light Bulb
- 92-95 ac into a 96-00
- car not starting (searched)
- civic
- 1993 honda VX idle problems
- help with my first car purchase
- EG clock in EK
- ls/vtec swap
- any diy for obd2a-obd1 ecu plug conversion?
- Swaps on LI NY?
- Stock 92 CX wont start? 5$ paypal if you figured it out!
- 98 civic ex for 93 del sol w/ ls swap
- Civic 98 ex...Help
- automatic gsr swap
- removal of back interior panels in ej2?
- Brakes?
- b16
- BAR cost
- How hard is it to make EG RHD?????????????
- Supercharger!
- 99-00 SI intake into EX
- GREDDY EXHUAST QUESTION...
- Help finding parts...
- Headgasket Questions
- Clutch problems
- What exhaust should I get?
- Mai New Car! [with cel's]
- hydrogen assist
- How can I get water out of my tail light?
- front suspension clunk....
- Ideal Naturally Aspirated A:F ratio for a B18B1
- Honda Civic CX engine swap
- a/c issues...
- anyone know how to reset the ECU?
- IAT sensor problem.
- Cable to Hydro Tranny
- prop valve question
- jdm eg6 red carpet
- raspy sound after installing testpipe
- EK mid pipe on EJ1?
- pioneer problem in 95 coupe
- Ebay clutch kits
- Does anyone know if the 99' Civic 1.6 estate's came with a leather interior?
- B-series TB on D-Series Intake Manifold
- Any good ramps to drive car onto?
- help need it eg conversion to power windows
- low-fuel warning light not litting up?
- camber kit
- looking for coilovers for a 94 civic si hatch
- Function and form Type 1 coilovers
- eg6's
- Side Markers
- need pics.
- 10SEC
- need help!
- EG headlights
- Differences in OE R12 & R134 a/c systems?
- Do all Spoon Style Duckbills have fitment issues?
- Erratic bouncing tach needle
- B-C pillar Bar?
- crazy idle after boosti ng
- is this even possible?
- EJ1 build!!
- 96 civic dx auto to manual conversion
- car runs like crap when i first start it
- Looking for a intake manifold
- HELP-- locked only key in trunk of del sol!
- Wheel studs, spacers, Lugnut?
- how much vacuum on a stock gsr
- wire harness setup for honda del sol(need instructions or help)
- iNEED A HELP i WANNA DO LS SWAP TO MY DEL SOL 93si
- Turbo?
- stock speaker size
- Question about B18c axel and hub problem?
- Replacing stock Del Sol seat belts?
- Throttle Sticking- After acceleration
- 97 DX refuses to start *SOUND CLIP INCLUDED*
- Need a little help please. Possible distributor failure.
- 92-95 A/C parts fit 96-98?
- Looking for EG dash/cluster wiring diagram, maybe some help.
- starting k24a2 swap...need advise on max power
- 98 EX Cracked Header
- b18c valve spring tool
- Stock Z6 CR ?
- Looking for visuals differances between gsr and b16 cams.
- Question about going from 5spd. to Automatic. Yes Stick to Automatic.
- Help me pls...
- Tein Superstreet opinions and questions
- b16 question..
- Civic/Domani Aerocatch Install
- I can't believe I'm asking this...
- removal of steering wheel question?98 hatch- all bolts removed but will not come out????
- need help adjusting stiffness in my clutch
- 2001 gsr b18c1
- b18c5 delsol dyno. not what was expected
- How do I know its a starter problem?!...Barely Cranks.. Help
- classic clutch *press and squeak*
- 94 del sol head unit install question
- oil pan question
- Motor Mount Bolt Just Spins
- jdm dc2 headlights on usdm eg6?
- which starter do i need
- Gas Gauge Problem
- JDM ITR Brake Booster/MC Question...
- Dizzy ID number Help
- Cusco 6 point cage into EG hatch with sunroof ?
- NEED HELP REMOVING FENDER!?!?!?
- Header question??
- help! b16a swap
- adjusting clutch
- speedmeter
- problems with brake lights on a 95 Civic VX
- thinking of getting 14" Mugen CF48
- engine mount swap question
- knocking out a cat
- Error code P0118
- lca bolt snap HELP!!!!! QUICK RESPONSE PLEASE
- Broken Wheel Stud
- Gauge cluster question
- Rear Main Seal
- 1992 civic CX hatchback: Jumps and jerks to the RIGHT BAD!
- Friend's 99' Civic Si was stolen
- GSR Brake Swap... how do i know which pads to get?
- Coolant Temperature Sensor problem
- Spring rates?
- Clock for 1999 civic
- Oil light on after z6 swap into a 97 civic
- VSS issue
- Anyone ever swap EK cupholders into an EG?
- swap question eg d15
- 95 honda civic ex
- golden eagle eletric water pump convertion???
- 5 speed 97 civic
- d16z6 problem..
- 92 cx hatch with ls swap exhaust question?
- 92-95 civic radiator?
- I want a 3 stage vtec
- Weight Dist. Problem? Spring Problem? Tire Pressure? Help!
- Cost of LS/VTEC in 1997 civic EX
- eg with A/C or with out A/C
- tranny question
- Wheel lock stuck!
- manual to electric window conversion
- Windshield
- Why am I leaning out???
- NGK blue spark plug wires
- d16z6 with hunting idle issues.
- Clutch Slave Cylinder?
- Electricle problem.
- A/C in a 2000 civic? which ac mount do i need?
- EG Hatch exhaust on an EK Hatch?
- cable to hydro conversion.....
- 98 civic vtec
- 96-00 ek auto door conversion
- cat
- DOES ANYONE HAVE A SMOG CHECK GUY?????
- B20 vs y8 turbo
- hub lock
- Ideas for EG CTR?? What would it look like if they made one?
- D16Y8 trouble
- fault code #10 IAT SENSOR
