- EG Center Console Question.
- help 98 civic ex wiper issue
- Remove passenger side airbag...
- Help if you can!!!! 92-95 civic
- stock intake
- d16Y8 supertech titainiam valve springs and retainers..QuestioN..
- 00 civic si wont start!!! NO POWER
- Oil leak!!! HELP!!!!
- Power steering question
- EG6 Radio help( 94 civic dx)pics
- 1999 Honda Civic Sir, Brake line repair
- need help with ls swap
- Best b16 mod for $1500?
- how much would you pay for this 2000 civic ex?
- Proper Radiator Hoses for a 95 DX/ Type R Swap?
- CEL Issue
- Need help. Relocated battery.
- Will It Work
- general rim question
- reliable place to get smoked amber corner lights?
- help - gauge cluster, clock and turn signals quit working *92 civic hatch*
- How does the IACV work? B16A
- I need some Help on 94 civic t bracket issues
- OBD1 B18c - 96 Civic swap question
- No power when i turn the key???
- Del Sol Guru's.. New Owner with some questions!!
- One last step left - wheel studs
- Stripped head studs (block)
- Hard to start when the fuel is low.
- code p0141
- Over Heating Problem...Please look
- squeeky camber kit?
- stock p28 limiters?
- Radio-need help
- not an si?
- ummm ctr cam question!
- Gas saving
- Replacement Carpet? Best quality/fitment?
- b18c1 easy swap?
- Timing Belt Broke
- fuel economy of 92 civic
- VC sealing
- turbo oil feed line
- Possibly worth it?
- type r cons..
- gas problem?
- need help my car doesnt go into gear right
- Vtec-e OBD1
- my eg ferio 125k build kinda need some help though
- Password JDM reliable swap?
- CEL when its cold, not when its 45ish +
- shaking from 45+only while braking
- 99-00 front end conversion
- B16 Help/Advice
- need a little help with 96-98 civic cluster
- Idleing at 2k HELP!!!!!!
- do they make non carbon bys eg lip?
- When to upgrade fuel pump????
- eh3Si z6
- I cant find side skirts
- rear bleeder bolts completely siezed... what do i do
- rear camber arm stripped
- Oil Pan Gasket with Silicone??
- Found a 1993 Del Sol for sale
- intermittant start-up.. sometimes yes, sometimes no!???
- b18a1 swap in 96 hatch help
- SiR2 Doesn't start...distributor or something else?...
- eg suspension help please...
- Replaced timing belt- now having issues!
- shifter is very sloppy!
- Flushing out brake fluid! help!
- Fuel Pressure question???
- compression test results
- Brakes keep going out???
- Vtec Help...
- brakes
- Need help deciding
- boost controller problem!!!!
- Car is overheating please help!!!!
- 92 Civic Si won't start
- stock eg wont start
- Compression test numbers for d-series?
- super loud creaking noise
- back pressure
- will 4 door teg gsr stock cat back fit 4 door 3g
- Can you fix a distributor?
- intake cam on exhaust side??
- HELP, can there b HIGH PREASURE in system RADIATOR CAP ???
- Code P1298 - 97 DX - ELD
- haveing problem with my clutch
- HELP Koni yellow ground control?
- CE light and v-tec?
- VTEC Soleniod to Block Torque Spec.?
- Driving a EJ9
- Identify this JDM EG Civic Ferio interior - AWD RTX or RTSi?
- Vtec problem??
- check this out!!
- O2 Sensor question
- HELP!!! please
- Stock Intake Or Aftermarket?
- header and exhaust question
- Anyone have a BuddyClub Spec 3 Exhaust?
- Axle play on my EK
- universal flanges
- . b16 in 98 ex, cel and weird issue.....
- Bennen tie bar and lower control arms
- 94 Honda Civic Ex Coupe
- Del Sol e-brake cables same as Civic sedan??(pictures)
- Seafoam?
- Question: 97 civic driving problems
- GSR injectors?
- help with getting key made?
- water pump help!!
- Apexi WS question
- HASPORT a/c bracket question
- 96 EK Coupe DX with a dead speedo.
- alignment problem??
- help!!!
- Need help with 00 conversion in ek hatch.
- eg hatch Question?
- Del Sol or CRX
- Creaky noise at the front end.
- What were the OEM wheels on an EG6?
- automatic to manual JDM ECU conversion question.
- need help locating O2 sensor wiring.
- Check engine codes 5,and 14
- Need help putting SI rears into hatchback??
- GSR Cam shaft
- Del Sol Rearview Removal?
- torque sequence for d16y7
- 130k miles what to do!!! Please Help
- 96 Civic sedan front windshield fit 00 civic coupe
- for OEM exhaust
- new tires and brakes
- Idle Problem with p28 ecu!
- Help!! Driverside torque Mount problem
- i have a question for vtec lovers...
- B series Engine Stand
- cel no code?
- idle problem....rpm jumps when engage on clutch
- sunroof doesnt work
- idle problem b16a
- 8 pound of boost on a stock single v..?
- speedometer problems
- b20b?
- Another del sol owner!!!!!!!!!!!!
- CEL 8 along with dying car
- Heavy duty coil springs
- 96-00 HB tailights intergangable?
- we have a problem... Need help with bump steer
- Just curious if I got a good deal
- Fog Light Plug Favor
- Gsr Smokes in vtec!!!
- 96 Civic Idle Problem!
- Still Overheating.
- 2000 civic horn question
- Ek hatch ZC help vtec
- Wire tuck write up?
- Over heating problem eg civic t4 turbo top mount
- how much is it worth??
- msd mounting locations
- D series in ek hatch
- wiring problems. please help
- Alright i have a question about the 99 civic si
- temp gauge problem need help::
- 99si tranny
- Who knows?
- B16a2 swap in eg part list
- Timing
- is stock 99-00 si grill the same as ctr grill...
- 93 Civic no spark/no fuel??
- Is it bad that i have nightmares about people trying to steal my honda
- help plz. mini-me help needed
- foglight not working!
- Jdm itr header and cat converter
- D16 vtec injectors in GSR motor help???
- Quick question concerning swap of head on obd1/obd2 1.5 sohc motor.
- Question on Valve Springs!<please Help>
- comptech ice-box intake?
- B.a.r. ???
- rear disc brake question
- does your car do this ? RPM Jump?!
- Gsr cluster
- hytech header with mugen catback
- Dual Valve Springs Question
- use rear sway bar with springs??
- Compatible Starters? (JDM D15B vtec)
- Weird??'s-Mini me ECU going back to original one
- Gauge cluster and climate control wont light?!
- Side skirt question
- Damn em1...o2 sensor help
- eg front end conversions
- CV joint going out?
- 96 civic wont start after swap, help please
- more thoughts
- Looking to pick up some sway and shifter bushings :)
- will i or can i pass smog and/or get it bar'd?
- Password jdm Hood Dampers
- window issue
- Random things that i dont know if i should take off
- Is there a website or posting for oem parts w/part numbers?
- ITR pistons in b16
- How much is my car worth??
- just wondering
- In need of tires for a decent price.
- will this hood fit on my EM1?
- to the 92-95 civic thread
- b20 vtec where dus vtec suppost to kick in?
- Im noob =]
- Indicators keep blowing fuse.I can only turn left!!?
- Hypothetical:NSX engine swap?is it possible?
- Steering Wheel ?
- apexi n1 exhaust
- Eibach Pro System Plus. Anyone using it?
- help? fitment
- d15b7 for b16
- FMU on a N/A b16a?
- idleing problem.. RPM stays UP when stopped 00 si
- Back 2 Basics, B16 breathing...
- 00 Civic HB auto tranny problem.
- My New Project
- Thermo
- knocking sound when in idle
- Fusebox question
- will this fit a USDM 92 Dx?
- integra away bar
- Water4Gas (HHO) Hydrogen Injection -- Product Test
- EK raybrig fog light install - HELP!
- Cruise control
- ek front end conversion
- Safc Wiring diagram & Sensor type question problem ???
- iac valve
- Differences Between Stock EG Ex and Sir Lips
- engine having trouble running . need help
- 95 Honda Civic CV Joints.
- Gsr cluster in EG
- question about taking car to which body shop?
- LS VTEC help please!!!
- need help type r header fitment
- ls vtec :(
- Coilovers.........
- switching to stock headlights
- p72 ecu with a b20?
- How to clean Headers of a B'' series Motor
- question about engine noise (i tried searching)
- What is causing this white goo???
- SRS problem
- p28 a52 and p28 a51
- Airbag question
- Need help with p28 ECU!!
