View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Where did you put your gauges?
- HELP PLEASE !!! civic question
- where to get aftermarked tranny synchros
- rear trailing arms for sale
- Who made the oem 96-00 d series clutches?
- PLEASE HELP! problems with z6 intake manifold and b18 TB swap on auto d16y7
- Flywheel problem ?
- fog light help
- EG6 vs EG9 - Handling wise
- fill me in on this civic!!
- Idle too low..?
- which is better?
- PUTTING AN EX INTAKE MANIFOLD ON A DX
- how do you port heads?
- rear disc swap into a 94 coupe need help on what i need
- city light bulbs
- Is my oil pump going out
- Integra GSR knuckle same as 94 Civic Knuckle? Brake swap
- Want to upgrade suspension parts...
- vouch for Charles B. anyone?
- EG mirror question
- B16aII swap = can't start!!!
- Sohc Turbo Charge...Need some pointers
- Shifter stuck
- VTEC Valve Cover on a Y7
- JDM Motor/harness
- EX coupe power windows/locks into Si hatchback
- Air/Fuel Ratio gauges work on b16's ????
- Still doesn't fit
- The head on my LS Vtec!
- jdm fuel rail...
- Newbie: EG4 brake improvements
- vtec wiring HELP
- will d16y8 spark plugs fit into b18c1?
- can i use a soch starter on a b-series motor?are the timing covers both top and bottom the same for
- Wiring question?
- Del Sol turbo project!!!!!
- if i ever needed Honda-Tech's help, i need it now the most, i need a step by step tranny swap guide
- SOCH AEM TRU-TIME CAM GEAR
- Typical Price Range for OEM Integra GS-R Suspension Components
- Trouble Starting at times
- 10 second Del Sol
- Automatic transmission from ZC in 94 del sol how to convert speedo?
- hks hi-power sound clip 99/00 si?
- Need a GOOD transmission shop in Queens, NY
- Um.. changed my pads and everything is acting up?
- Best Underbody, Under hood, body, rust protection
- Will exhaust bolt up? B16a into ek hatch
- Anyone have any experience with Tanabe Suspension in a 92-95 civic hatch?
- ok what should i do with the "new" tranny? should i pay for install? or DIY
- Have installed a drag turbo kit on a DX 2000 Civic..... showing rich condition p0172...
- How can you tell the difference, in appearance, on a motor with....
- Help on 99-00 frnt end conversion
- Fluid resevior
- too lean
- washed my engine and oh no help!!
- IAC Question, please help
- Somebody tell EBP-SI(member)
- ITR/CTR lift and duration diffs
- does anyone have a fuse diagram?
- Identifying a Zex D-Series VTEC Cam?
- Hawaii guys
- sunroof
- part on motor
- Troubles with putting an automatic ECU in a manual car?
- catalytic converters
- clutch problem... HELP
- HB Rear Quarter Panels
- EG sedan front end.
- 2.5 mandrel bent pipe w/ Es Oval VS Apexi 60mm WS2
- itr camshafts or ctr camshafts!!! which is better
- Doing a h23-vtec swap in a EG.
- Stock idler arm slipped
- Tranny Price Question
- Carbon hood weight differences
- help!!!! something wrong
- brake light?...
- height difference ex/si
- Down pipes
- HEad work to a LS
- Flare wrench for brake lines...
- tightening alternator belt
- 95 GS-R Motor in 92 DX Civic, I'm ready to burn the little basturd!!!!!!!
- LS tranny or GSR tranny??????
- jdm b16a swap
- is a dohc zc a direct swap into an eg?
- C/F Hoods???
- Help?? Tuner Lugs
- burnt rubber?
- Emissions in Colorado
- AEM Big Brake kit??
- integra front sway bar
- jdm climate control install on 96 hatch
- [FAQ] Post your fuel consumption, What's your hondas MPG?
- hatchback question
- want to boost my ek
- 93 dx coupe, possible to shave 300 practically?
- b18a1 in to eg hatch questions??? SEARCHED
- 2 Problems here: And yes I have searched.......
- 92 VX bogging issues looking for some ideas
- tranny problems....D series, i need to have answers ASAP
- Question in H22 EK hatch, CEL related, P28 ECU
- smog legal
- good resources on tuning honda vehicles
- ok what was the freaking problem
- Cleaning the inside/ outside of your engine
- Two Questions: (Clutch and Exhaust)
- hiccup type problem.
- honda parts
- does anyone have unlimited carfax reports?
- my car is F'ed up.... help!
- 00 si fog lights on 96-98 bumper
- Help getting SRS cable reel/tape disconnect on EJ1.
- Body Mods what works?
- ic pipes?
- Cruse control removal???
- Can i use the outer taillight from a coupe on my hatch?
- Is it true you can install any B series header on any other B series?
- EG6-drifter?!?!
- CEL Code 41
- what are these wires for?
- ek civic lude helms
- [question] Acceleration Noise???
- Removing A/C
- Could I have been scammed... again?
- Maintenance light on but no check engine light????
- 4 wire o2 sensor for swap b18c1 on a 94 cx hatchback
- what motor mounts is recommended
- Thanks for your help Honda-Tech, Just finished my Tune-up!
- POwer steering removal problem!
- HELP - Rusted Bolts and Dirty A$$ Bay
- wiring plx300 wideband to ecu
- Need advice on tranny problem
- b16 clutch
- where would i find this part?
- throttle body compatiblity with aebs manifold
- question about wiring oem 99-00 fogs
- EG....EK, Major Differences?
- CTR Engine prob
- Del sol steering rack into hatch
- 92-95 Red and Clear tail light
- Clutch Issue once again. Help !
- k series swap into delsol HELP
- car feels like its bogging at 5k rpms
- break lights out
- Anyone in Detroit
- FS: Fuel problem
- Engine cutting off and now is misfiring
- ek front end on eg?
- code 10 ? please help
- Need a machine shop in NJ (southern NJ neer philly)
- fuel pump for ls/vtec
- rhd eg9 front clip work on the 92 eg hatch?
- I am now a proud member of the Jap club... !
- GSR AC compressor on a civic
- d16 into ej1...do i need a BAR sticker?
- ek fog lights
- Need help in Engine swap..
- TPS and Map sensor switched?
- whats a good site for front lips, rear lips, and spoilers?
- best compression ratio for d16
- shifting with out clutch????
- Integra rear disc swap Q(concerns wheel)
- d15b... Any sensors different from VX other than o2?
- How heave is sound deadening?
- CHANGING A GAUGE CLUSTER
- FUCKING TRANNY!!!!!
- cowl induction intake system on 99 sniper kit
- Slowly going back to stock...ignition next?
- Another B.A.R question... Searched w/o Answer
- Already ran a search, idle goes crazy at every stoplight
- 96 Civic Fuel Filter Change Details
- will my drive axels and motor mounts still work with this swap
- z6 trans onto a zc
- ??? [B]SS fuel line[/B] question ???
- exhaust manifolds and collectors why are y8's different?
- Bseries into civc... what shift linkage???
- need helpful info on swap
- Yokohama AVID TRZ?
- strut bolt help
- 4-1 Or 4-2-1
- 98 civic ex Codes P1298, P035, P0141 please help ???
- brake problems
- New 93 Si dash...airbag out...horn doesn't work
- OBD2 immobiliser
- Need VTEC oil tap location diagram.
- seatbelt help, seat swap!
- B18 swap upper passenger side mount (RHD)
- Cam timing for Z6?
- weird noise coming from D15b2
- Hatch VS Coupe LBS, other than optional equipment, where does the weight come from?
- Easy question...
- Clutch Problem.. **HELP**
- p28
- my swap...does not fire up. HELP
- anyone with a 1.3/1.1 drop on a 96-98 civic??
- Just installed my new Lightweight Odessey Battery.... whats next ?
- AC in GSR civic
- need to get something straightened out
- obd1 tps same as obd0
- What year P2P ECU is this, and is it for a 5spd?
- where does map sensor vacuum line go to 99 civic si?
- need help hooking up VAFC
- EK headliner question: Random I know, but just wondering....
- Omni power Bouncin my car around
- Can anyone confirm the prop valve ratios for the various brake setups
- need help with my hasports :(
- 99-00 Civic Si/compatible: Removing the rear caliper mounting plate
- Newly Registered, what do I new to do to get more access????????
- rear defrost cables
- Steering wheel shakes at low speeds 00 civic
- Clean Vx or si?
- Dying Interior Black 96-00 Civic
- rhd sir del sol
- New to Honda Tech & Car Mods
- defi gauges
- D15 Distributor help
- Cams and our cam shafts for SOHC
- Quiet Mufflers??
- quick question....what does the 94 civic dx hatch model weigh in at?
- SAFC problem
- b16 throttle body
- civic owners parting out integra in integra forum
- Question about header fitment?
- civic swap shifter question!!!!help please!!!!
- Huge problem, will paypal $20 to person with the solution, Car not starting, not battery not main re
- What would you pay for my car? 2000 white ek hatch turbo
- Possible that ECU can have pin problem with VSS wire?
- 94 5spd dx - random squealing?
- Help H22A BUILD - UP?
- What will i do??
- got cheap good seats, but stained bad, need help cleaning
- best hp gain exhaust but quiet......best one?
- No fuel no spark
- sknunk 2 single or double bent shift kit
- '97 DX Manual Tranny Noise
- can i do d15y7 mini me?
- b16 rear motor mount
- Turbo'd LS. Y1 tranny yea or nea?
- Del sol conversion to ek 99-00 civic front.. NEED HELP
- rear sway bar position
- CEL HELP code 43 and code 41 out of nowhere.. HELP!!!
- ????can anyone help???? need detailed instructions on installing clutch
- Teg stuff in an EK? im new to civics
- Stupid Question...
- exhaust leak ???
- gsr cluster into ek [probs]
- Mobil Clean 5000, anyone using it?
