View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Torquing damper-fork-to-lower-control-arm bolt on 92 Civic LX
- 1999 Honda Civic DX Maintenance help
- Civic 94 EG B20B CODE 41
- 94Civic EG B20B Intermittant gear selection problem
- disappearing coolant??????
- '93 Engine runs, oil/batt lights remain after turning off and removing key
- Possible ignition issue?
- could wheel alignment have dammaged the slip ring gyro connector part in the stearing
- EG Shift Boot/Shift Knob ID/Query
- check engine light is on yay
- 95 civic - How do I set the mechanical timing?
- Rebuilding a B16 Throttle body?!?!!
- B18C EJ8 bad tps wiring or ignition maintenance? PICS!
- b16b compressor
- Interior Specifics
- D15Z6 upgrade?!? I want loud and fast :DD
- 97 civic lx auto cruise control vacuum nipple location.
- Transmission mount weld?
- 95 eg hatch ebrake sensor wire
- 96 honda civic distributor issue?
- b16 idle problem
- 94 honda civic reverse problems
- car doesn't always start
- Rebuilding Block and i see micro cracks need help v. PICS
- 92 Civic hatchback Seat Mount on chassis?
- Tachometer Gauge Wire Confusion
- 94 Del Sol 2 dead cylinders.. Advice?
- OBD 2 Location (civic 98)
- 00 Civic died and won't start
- Radiator Fan not turning on
- need help..cylinder head plug and camseal
- Need Help 98 ex is driving my hair line back
- 93 del sol brakes
- RPM Gauge dropped to 0 while driving and now won't start
- 93 Civic/GSR swap - Motor Mount Questions
- 98 Civic- Possible broken keyway- can't get crank pulley out
- Hope for my Headlight?
- Can I use Fuel Grade Sealant to plug hole drilled in EVAP system shut valve?
- 96 civic sedan front lower contorl arm bolt???
- ~~D16Z6 vtec not working~~
- Car starts fine, when warm it stalls... Help Please
- 94 Civic VX mis at 2k RPM
- NEED HELP 94 EG GSR SWAP
- 98 civic ex - can't get to run
- Identifying b16a3 internals
- need thoughts,input,ideas
- 1999 Civic - Speedometer works, odometer doesn't
- 3 point brace
- Another electrical problem... twice this week had to get a jump start
- Random, won't start after driving fine..?
- timing a 98 civic ex ?!
- obd1 to obd2 on an eg?
- damaged b16 head
- '93 Hatch Rear Defrost Ground Wire location?
- Headliner Question 00 Civic EX
- EG horn fix
- Cheap Mod to produce sound of an open element intake
- EG6 Cluster into '92 CX Hatch
- 95 4-door civic engine swap (Thailand)
- D15Z1 swap into 90 CRX
- Possible to remove engine block only? D16Y7
- 94 Civic - left blinker also makes the 3rd and right brake lights flash
- 92 Civic - Sudden Bad Fuel Economy
- 96 Civic LX overheated, loud pop sound
- Help with b16a2 swap
- 93 Civic DX - Engine Build Thread
- 95 Civic EX A/T starting issues. Please help
- 95 civic ex - Overheating
- Timing belt need help!
- 99 Civic - Need help putting timing belt!
- 93 civic , engine wont turn over in cold?
- The "Where To Buy a Honda/Acura Engine" Thread
- Does anybody know where i can buy a reliable honda/acura engine?
- civic 98 Thermostat - part number?
- D16Y7 CEL?
- Civic hatch quarter panel damage - fix or start over!?
- please help eg8 turbo - what transmission oil?
- Hatchback muffler
- Misfiring 99 civic ex
- b18a1 swap into 97 civic
- 99 Civic/B18C1 swap/S80 tranny - Overheating because of damaged tranny?
- 2000 Civic LX - Possible Blown Head Gasket
- obd0 to obd2 swap
- d15b engine swap
- Exhausts for 93 del sol
- Hard to shift gears
- 93 Del sol SI Fan not turning on
- 92 Civic gauge cluster Tach swap problem
- B20 swap in ek, throttle cable question??
- 97 Civic has idle and starting problems
- D16Y7 '00 - White smoke, water in oil. Cracked head?
- Ek hatch idle problems
- 97 civic rear bumper bar help ?
- Only respond if you have successfully swapped y8 internals into a y5 head
- 97 EK GSR SWAP clutch problems
- 92 Civic Brake Problem
- Can this B16 be repaired or should I buy a replacement?
- 98 civic obd2 to obd1 conversion
- 00' Civic EX, Cooling Issues
- 95 civic sedan - alarm, rear seat, and horn questions
- Door lock and ignition swap over. Questions.
- 95 honda civic AC problem
- DIY eg civic d15 timing belt
- EG/GSR swap - CEL codes 1, 21, and 43 and running poorly
- 95 civic ex sedan - Power locks not working
- mounts for a B series in a Del Sol
- 00 civic hx - tie rod ends and bellows ?
- 97 Civic DX Keeps Turning Off, Rough Gear Shifting, Rubber Burning Smell?
- 98 Civic - Power locks, dome/map lights, and plate light not functioning
- eg8 B20B vtec [RHD] building
- 93 Civic ignition lock issue
- JDM D15B VTEC - Where buy YCP 75MM (or 75.5) Vitara Pistons?
- EJ8 B20B/LS tranny - want a good amount of horses!
- 97 Del Sol B16A2 - CEL at Redline "Not Shift Light"
- Civic Si spoiler without a brake light
- can you tell me if my recaro seats r real or fake?
- 99 civic hatchback - Powerstop Drilled/Slotted Rotors don't fit?
- 98 Civic EX - Jerkiness at low RPMs.
- 1998 Civic EX Sedan - Only Driver's Side Unlocks
- d15b2 in a 1994.. motor mount question
- 95 Civic with ls/vtec and GSR tranny - starter won't crank
- 96 Civic - What is this smoke under the hood?
- 98 Civic DX - Horrible door wiring & blinker idle
- 98 civic ex - Help me with tachometer
- Throttle Body fitment and general question
- 96 Civic Exhaust Hanging Extra Low
- Help with front lip!!
- immobilizer problem EK4 - can't get car to start
- 1996 civic dash lights
- need swap advice 98 hatchback
- SOHC ZC Vtec in 92 CX Burning Oil
- 2000 civic si rough start codes 6,7&10.
- 97 civic dx coupe 5 speed - Little more power? Maybe?
- coolant bleed valve on 98 civic DX?
- Bought a "built" d series 00 civic - Anyway to verify?
- Question about Keyless System Parts
- Use stock 02 sensor on aftermarket header?
- Quick ek firewall line question
- 96 Civic transmission swap
- DIY Crankshaft Pulley Bolt Tool (D15B7)
- new to this please help!
- B16A startup problem turns over but wont start?
- VTEC pressure switch
- 99 Civic LX Power Steering Delete
- 00 EM1/B20 swap - Low idle problem
- D16Y8 dead cylinder
- b16 with auto tranny in 92-95 civic
- 97 civic type r flaps fit or custom work?
- Mystery EG Civic Cluster: 9200RPM redline, 240km/h, black face
- Integra-Civic swap questions
- anyone with tranny experience?
- long term Build direction?
- Front lower ball joint boot circlip part? Diagram included
- Intake gasket problem with y8
- REPLACE A/C COMPRESSOR. HELP!
- 94 civic vx idle 500?
- 97 civic temp gauge reading low? Need some advice
- cold lower radiator hose?
- Steering Rack/Tie Rod
- DA seats in in ej7
- 93 del Sol/swapped b16a2 - High RPM in 4th and 5th gear
- Clutch sound.
- bad idle after cleaning tb
- EK3,EK4,EK9 RHD Floor Mats
- Obd2 to obd1 conversion
- shift linkage for B series swap into 94 Del Sol
- 3 stage jdm D15B head upgrades
- Clutch slave cylinder should I replace?
- 37820-p75-a54 ecu convert to manual help!!
- B16B swap axel question
- crappy idle issue b7/z6 mini me
- 97 del sol driver side wheel
- noob d15b question?
- Strange Noise When Cruising
- window regulator help
- 94 civic heat gauge problem
- Is engine timing off? 98 Civic EX
- What is the best engine mounts for a 98 civic ex
- Whats the cheapest way to get Keyless entry?
- Help: Civic VX a/c compressor won't come on
- 89 IAC and crazy idle
- cleaned IAC valve, now have CEL P0505
- 00 Civic Ex Random Misfire - Need some input.
- OEM Shoe Horn Scraping Noise
- 1996 civic ex crank no start?
- 92 civic hatch d15b/z6 - 15A ECU fuse keeps blowing!! pics in thread!!!!
- Honda snap ring tool to replace the lower ball joint boot
- What is this broken part?
- 95 del sol - carpet and other questions
- 1997 Honda Civic EX Start Problem
- accord ws1 on eg?
- 99 D15B twin VTEC solenoid - oil leak problem
- 95 civic ex rear disc brakes in my 97 dx?
- AT to MT mount
- 93 Civic dx won't start intermittently - already replaced main relay and fuel pump
- Questions about Jdm D15B swap into 96 EK Sedan
- starting issues 93 civic - no click from main relay
- Advice on rerouting hood latch cable. ek
- Better Motor Mounts
- Cruise control removal help.
- bad head gasket D15B
- 93 Civic si d16z6 start issue
- 98 honda civic hatchback will turn over but not start
- Radiator
- Which oil pan gasket can I use?
- Rear strut lower mount bolt / bushing issues
- Cooling Fan Issue
- 93 civic del sol wheel hub
- So i have an oil leak, O ring? distributor? Vtec solenoid?
- 98 Civic lx, Started and died as soon as I put it in drive and now won't start
- Full suspension upgrade 99 civic
- 94 Civic - Cluster gauges don't work
- My 95 Civic (d16y3 block/PM3-4 head/P06 ECU) only goes 85 mph
- Can you install a toddler seat on ej6?
- 97 civic EX - Do I have Keyless entry?
- 1999 civic map sensor issue. Please respond
- Auto to manual clutch problem
- Issues With Short RAM Intake
- D16Y8 head with supertech or stock valves?
- DIY Request for removing 92-95 dash
- 98 civic SI - Random Misfire issue, where to start?
- mini me swap problem - won't start and plug 4 shattered
- OBD2B to OBD2A Civic
- Where locate replacement Honda parts?
- Help returning '93 Del Sol to stock suspension
- 97 civic coupe - Rear Camber adjustment
- Bad shake on take off
- Transmission Flush vs Drain and Fill- EJ1
- OBDIIb engine into OBD1 car help
- Civic d16 head question
- i need help finding out where to order parts from
- Mini-Me Wire Harness Q?
- 97 civic coupe veering off to the right
- Auto to manual swap
- 97 Civic Ex - pulsing lights, not typical fuse 15
- My build thread
- trying to find the part number for the civic sedan window seals.
- getting ready to swap... Ecu question
- [FAQ] DIY How-to: Replace Civic 92-95 climate control bulbs BUTTONS'
- Real Fuel Tank Size on a 1998 Civic EX?
- Cat-back question
- New catback
- WHAT ARE SOME SITES THAT I CAN BUY PARTS CHEAP FOR EK HATCH
- 93 Civic DX mod ideas?
- 1992 EG Hatch B16A Build Thread
- 96 Civic Alarm connections
- 00 Civic, 5SPD/D16y8 - Head gasket is blown and need advice
- Need help on 99 civic ex motor swap
- EJ8 with Y8 swapping to a B18C1 questions
- Hood Release Cable Clips
