View Full Version : Honda Civic / Del Sol (1992 - 2000)
- jdm cluster install
- D16A6 Build Questions
- how do i hook up the evap purge control solenoind in my 93 civic with b16sirII?
- type-r valvesprings vs stock b16a valvesprings
- My sportlines, one side higher than another : (
- what size should i get my piping??
- ac fan on ek
- Will a 96 Civic hood fit a 94 Civic hood?
- B16A SIR II in 95 DX coupe won't start...Help
- Brake problem
- Help me out, need to choose a racin seat for a REALLY BIG GUY...
- a6 pistons into a y7/y8 mini-me
- Good scrapyard in NYC area? need B20
- What other throttle bodies fit on my 95 Civic 1.6L Vtec D seires?
- Electric guages, how to?
- Roll Bar / Roll Cage
- The Lightest EK/Coupe
- front lower control arms
- What axels and engine do I have in my civic???
- Quaife QR steering rack parts are in!!!
- Salvage Title Question
- Are all d15 valve cover the same?
- 92 Hybrid HB stolen in South/Central PA
- timing dilema on my d15/d16 mini-me
- Problems...
- D-series shifter fork interchangable questions... Help quick
- Guage Cluster HELP!!!!!
- Wierd revving sound coming out of my 00 SiR
- Will 91 Prelude wheels fit on my Civic?
- non powersteering question
- Is This JDM
- B20 bore for stoker kit
- 92 civic h/b a/c ?
- 95 civc stock engine swap up/down idling problems
- Exhaust And NOS Questions. ^_^
- Y8 header/downpipe of b7?
- What kind of Harness do i need guys need help!
- b16a2 into del sol? what needs to be done as far as wiring goes
- Any chips for a Honda Civic Hybrid for increased gas mileage?
- Exhaust question!
- D16a6 with y8 headgasket
- its posible 2 timing diferent whit 2 diferent ecu?
- How do I get power steering into a 93 CX Hatchy?
- ej red tail light
- Who makes an alternator only pulley kit for b series motors?
- ***Lets name some free ways to free up horsepower for some of the noobs on here.***
- drop zone shock/springs
- WTK: would 96' integra gauge cluster fit in eg hatch
- Axle question
- Universal breathers for the valve cover?
- help w/ my friends car "automatic prob's"
- Grinding noise when I stop.
- is there a o2 plug in my catcovt? about to get a test pipe what yall think??
- VERY VERY INTERESTING NEWS!
- Problem with wiring
- ECU/IAB/HIBRID/ Problem
- EH on Eibach Springs, Need Help Identifying Which Ones
- Low Oil + VAFC = VTEC Work?
- d16z6 Intake Manifold
- 96 EK hatch, with 00 B16
- WILL INTEGRA 4 DR EXHAUST FIT CIVIC 4 DR(SEARCHED)
- windshield washer nozzles help
- odyssey came in for an oil change and left with a new motor -- -- ouch
- 99-00 OEM fog light wires
- did any 01 civics come with rear disk?
- Del Sol intake into 88 hatch
- Does the greddy kit come with the e manage program?
- Tein S Springs in ek
- S2000 Ballast, Install .. How??
- Give me a hand on my GSR/EG (secondary butterflys)
- ABS Standard?
- jdm d15 vtec question
- fuel pump with zex
- 91 Honda Civic
- B16 sitting on engine stand what should I attend to?
- AHHHH! Can't get into D4!!!... Car Starts though in Park only! I can't reverse!
- Bought a B16 need new hoses
- Another integra dash swap question
- Power pulleys for 95 civic ?
- Best Place to buy CTR 5-lug
- Electrical problem on sol
- ??? about my front axels on my 97 civic ex
- just got Monroe Sensa-Trac (need help)
- B18C1 engine trouble. Please HELP!
- car will not move: something is wrong with the clutch
- Depo foglight instructions....?
- Upgrading fuel sytem for 95 civic question
- New Engine for my Del Sol
- 99 Hatchback w/ No Tach
- Neuspeeds sit high in the rear anyone?
- 18 inch rims on a honda civic,but what kind of lowering springs???
- Cusco strut bars
- seats in a civic coupe
- help w/ abbv
- 90 civic starting problems
- What is up with Total JDM/Total-boost??? I still have no motor for '98 civic!!!!
- Apexi S-Vafc meaning of Narr o Wide
- Resetting TDC
- my engine is gone....
- High idle after start up
- just got a strut bar
- no voltage to injector clips
- S-VAFC question.....
- aem v2 vs the regular aem cold air intake
- Midori hatch w/ slipstreams anyone have pics?
- 1997 HX???
- how much gas does heat/ac take up
- Possible Starter Problem
- code 43/3/8/22
- English OK Greetings from Costa Rica
- defrost/cruise switch removal?
- Un saludo desde Costa Rica.............
- Holy locked posts Batman!
- need a name for a car club......
- Looking for the "FULL" swap..B16B/B16A
- header question
- Disc Brake Conversion
- somthing went pop
- My eg has no heat when i turn the heat on only blows cold air(heater core gone bad???
- Check Engine Light
- What the hell controls the air flow to the vents ?! Please answer!
- Anything Wrong with 2.25 piping to 2.5 muffler? SOUND??
- Hondata or VAFC (for sohc vtec) and (dohc non vtec)
- best suspension setup
- Will 94-01 Integra Steering wheels fit 96-00 civics?
- Anyone know how to read this?I finaaly found a lip i like for my foedoe
- VAFC Question!
- HOW DO I WIRE UP THE CITY LIGHT??? for an ek
- B18C1 in 97 Civic Hatch
- mini me.......no spark???????
- Del Sol Manual Transmission
- 96 Civic looking for a swap, i need info
- larger rierview mirror, like broadway.
- Carfax please?
- Hondata vs. safc
- Carbon Fiber hoods
- wiring of dual point to multipoint harness... HELP
- best "knock-off" spoon side mirrors....
- Loud Pop sound while shifting gears?
- on the way.
- Help! Speedo went bezerk and then guages turned off while driving down highway!
- which integra seats fit in 4door 92-95 civic?
- EG does a disappearing act.
- head gasket price
- Scammed on Ebay
- Question on B21 Prelude engine???
- Canyon Trails in San Diego...
- For those of you with foglights
- 1992 Civic SI Motor
- OEM gsr spoiler fit a del sol?
- Boring played-out question
- JDM ITR 5 lug wants small spline...
- auto-manual, is speedo interchangable???
- mushy brake pedal :(
- problems with boosted del sol
- A/C components????
- TYPE R IAC Valve
- Comptech Icebox install
- header problem
- I finally tried sea foam
- DC 4-1 header too short,pushes against oil pan. Wrong one?
- I have a question
- Silver Engine Dampner
- 5th gen Civic eng is seized.
- Which Strut?
- Wire question
- Deciding between EG or EK
- GSR swap question
- What exhaust will work on my 94 VX with b16 swap
- a ridiculous question but i need help
- Recaro or Bride seats in Del Sol... Anyone.
- weird weird problem... need help
- New to Honda world...
- integra dash conversion: what parts are needed
- Civic HX primary o2 sensor
- How often I need to do alignment in my car
- rhd conversion
- D16y8 compression test done. #'s too high?
- type r muffler on ek hatch????
- will this really help my honda?
- Mini-Me swap
- One headlight shining brighter than the other
- Checking TDC
- San Diego Area Hatchback STOLEN!!!!!!!!!!!
- hasport mount for sale
- where to find info of CIVIC hatches..
- would you rather buy white eg or custom color eg w/ white engine bay
- Exhaust Problem (Fitment)
- ignition fuse blown , AC/Radio/headlights wont work!! Helpp!
- hi all i'm from thailand,have my engine show u!!
- stock ej8 intake fogger
- B18b into an EM1
- 1. 75 OR 2.5 DROP ON AN EK COUPE SITTING ON 205/60/14??
- Are b16a2 and b16c camshafts interchangeable?
- Radiator fitment question
- Need Someone to Install My 99-00 OEM CivicFog lights
- ne one in the washington area?
- Going to knock off some weight this weekend on my 95 DELSOL. ANY IDEAS?
- where would i get flanges/gaskets/02 bungs?
- i have a civic 01 and a turbo from an eclipse 1990 & supra 1988 help!!!
- Fuel rail replacement
- damn!!! upper bolt hole on tranny cracked? how bad is this?
- where do i get a 92-95 civic blitz bumper for cheap?
- Damn!!!! my timing belt snapped
- brake problem, help it's a emergency
- SAFC-2 For Sale
- [FAQ] The Official DOHC-Powered Civic 1/8 Mile Thread
- Do you think this is worth 6K? PIC
- GSR radiator in a ek coupe
- quick question about code 14 iacv
- how much to chip a jdm p30 for a jdm b16a in a 95 delsol?
- How Do i fix a cel code 5 Map sensor????? and i think i have 2 map sensor HELP!
- Skunk 2 Intake Manifold. 99 Civic Si help...pls
- HELP!!!! 92 d15b7 about to put SOHC VTEC head on...QUESTION
- Ran into a little problem installing my ITR Sway and Beaks Kit
- Errr...another dumb question....
- atuo tranny VTEC Final drive & non-vtec Final Drive...r they the same?
- questions abotu the sohc motor
- head swap question
- Changing clutches...
- Mounting a VAFC in EG
- ebay fenders or Honda fenders
- Upgrading to an ex or dx cluster in an EG...
- Supercharger vs. Turbocharger on B16A2 in a 99 Civic?!
- Sway bars
- NEED HELP ASAP! PLEASE HELP ELECTIRCAL
- prevent corner lights from leaking?
- Question... Noob question maybe i duno...
- f/s 95 civic ex gsr swap for sales clean!!!
- crv a/c bracket question
- can u put a b16 or type r intake manifold on a LS head
- CIVIC engine question
- HELP!! car starts put dies after 10 minutes
- i feel completly dumb
- New brakes... squeeking after 2 weeks.
- H&R sport springs Differences between 96-00 and 92-95
- quick pricing questions on 94 cx
- any hks hi-power exaust for sale
- del sol swap question
- H22 or B16?
- FOR SALE!!! FULLY BUILT B16 Block!!!! MAKE OFFER
- Why JDM
- CLUTCH PEDAL STICKING!!!
- d16z6 flywheel torque specs(searched)
- HEY IM SELLING MY CAR!
- oem foglights on a 94 coupe
- Carbon lip possibilities?
- HELP! problem with lower ball joint and nut
- Strange humming from Air Intake Area
- Good deal on Ground Controls?
