View Full Version : Honda Civic / Del Sol (1992 - 2000)
- brake proportioner valve leaking help!
- 99 civic EATING OIL - Oil almost gone after driving 300 miles
- NUMBER 19 FUSE KEEPS BLOWING -- PARK LIGHTS WONT STAY ON
- 95 civic hatch cx - how install rear sway bar?
- What oil are you using? B16
- Looking to get a Civic, wondering what the differences are between the years
- EG or EK rear shock measurement request
- 92 Hatchback - loud popping exhaust, bad cat, and black soot on rear bumper
- HELP: EG seat belt light won't come on.
- 92 civic automatic transmission - Can't get into gear after started
- 96 Civic/97 GSR motor swap - bogging and power problems
- Gsr dizzy cap leaking oil
- True jdm type r cluster from ek9 swapped into 97 civic hatch - Plug & Play?
- 94 civic/Y8 mini me - VTEC not working and only 6500 RPM rev lmit
- transmission leak! Motor was sitting a uneven and passenger post mount snapped off
- 1995 civic coupe with b18b1 extra coolant hose
- Extra nipple on water pipe.
- integra brake conversion on ek
- Going with F20b into my Del Sol Si
- 94 Honda Civic Ex bogging
- 99 civic cracked manifold/converter. what to buy? help!
- EG/EK AC compressor fitment EF Hasport AC Bracket
- LS b18B Compression test results after adjusting valves
- b16a w/ s2 manifold,ctr cam, tri y.. what size piping 2.25" or 2.5"??
- OBD1 to OBD2 questions for h22a civic si?
- 97ek hatch w/zc swap won't pass smog in CA: WHY?
- will 13" steelies fit on my EM1??
- Vtec keep cuttin in and out.
- Ecu's keep buring up in the same spot..
- Crank, wont start
- How do you calibrate your tach...the right way?
- Anyone with a Inner Tie rod DIYon the EG? Please post NEED YOUR HELP!
- Tow Bar!?!?
- steering squeaky
- 98 Civic DX won't start - no spark
- Eg with H22 !! enlighten me
- Valve cover bolts
- Weird starting problem after battery/ECU disconnect. Relay click once.
- monroe sensa-trac shocks mated with ground controls
- 97 Civic/h22a4 swap --> HELP!!!! WON'T START!!!
- 97 Civic with h22a4 HELP!!!!
- Honda part numbers for EVAP Bypass Solenoid Valve - need assistance from experts
- k20 swap
- Problem HELP please,,1 of my cylinders is not firing
- Proper throttle body cable tension -93 honda civic VX
- 93 Civic Hatch With GSR swap Bogging problems
- Good temperature sensor?
- EG hatch/B20B4 - What's the best vtec head and ecu for this set up?
- sway bar question on 95 dx coupe
- Failed smog @ 15mph passed 25mph Solutions needed! ( please help )
- What would happen if the axle nut came off while driving?
- Upgrading "The big 3" and wondering how much amp the stock alternator would push?
- Cyprus Ek3 jdm D16 soch vtec TURBO PROJECT
- Acceleration Issue around 3k RPM's?
- 95 Civic EX - Help me decide between basic tein coils and NRG sleeves
- What clutch best for my 94 Del Sol VTEC B16A3 (with plans to boost)?
- How do Si dashboard swap in my 96 dx? And how do I fix the speedo?
- B Series Loom, 5 Of the same Plugs What go where? [PICS]
- 96-98 frnt end conv. 99-00 a gap on the hood
- 99 civic gsr swap (runs rough) need help
- 99 mini me leaking oil like CRAZY!! HELP PLEASE
- B16A2 Cylinder Head Gasket Kit OEM# 06110-P2T-030
- 94 hatch with a b18b - What trannys options are compatible?
- 94 Civic DX hatch - low idle and cylinder 1 misfire
- Help me build a super economic Honda
- WATER IN 00 EK TRUNK
- What internals should I do.
- b16b high flow cat question
- Dimmer switch problem on EM1
- Replaced timing belt: dead
- question about shift linkage for 92 hatch cx
- Reverse lights? Electrical input appreciated
- BUG GUARD? NEED HELP!
- Sir Conversion
- help: ICM / Igniter Questions and problems
- lambda sensor trouble
- b18 swap in eg: Stock header won't fit
- 2000 Civic EX 4dr - best exhaust?
- 94 Civic rear brake lines - What is the tube size?
- Grinding sound when turning left in my h22a swapped civic si
- D16Z6 Low Rev Limit and No VTEC Kicking
- Opinions on obx lsd - I've heard they have problems
- 95 Civic EX - Fuses for cluster lights and gauges keep blowing!
- Are Energy Suspension tie rod boots and ball joint boots any good?
- d16y8 to d16z6 - no knock sensor, help please
- Its been a While, need opinions on a decision...
- Building 95 dx/H22a swap for road racing - What's the best tranny for this set up?
- Installing AC in 99 CX HATCH - Need complete parts list and price range
- Fan switch problem again!
- 97 Civic/jdm b18c - Will 98+ jdm itr header bolt right up?
- Stock 00 civic ex with blown D16y8 - Will D16y5 run with the EX ECU, harness, and IM?
- 93 civic - fuel injectors #2 and #3 won't pulse
- high mileage d15b7 tips to keep running strong
- b18c1 s80 tranny- am i getting ripped off? this seems like a great deal?
- Question I have never been asked, until today....
- 99-00 front end conversion help
- 98 Civic DX/00 EX Mini Me Project - What's needed besides Y8 head and gasket?
- mirrors for a 2000 civic 4dr
- OEM EG Foglight + PasswordJDM Harness
- My good experience with a headlight cleaner product
- how do i tell the difference from real jdm CTR headlights from the knockoff?
- Radiator fan won't run after radiator and thermostat replacement
- 97 Ek with B16 swap - Engine does this rev thing at low rpm
- del sol clutch/trans problem. help
- 05 Civic Si seats into 97 Civic coupe?
- 1994 Honda Civic VX timing HELP!!
- Tsudo SP2 exhuast.. has anyone tried it?
- 92 civic si (manual) - radiator fan does not work
- Oem foglight switch with eBay fogs.
- Del Sol after 20 min of driving turns off, main relay already replaced
- Cooling Issue on boosted b16
- 94 non-VTEC SOHC into 99 dx: Is my parts list for this swap complete?
- Massive spark jumped from coil with distributor cap off -- What did it blow?
- NEW Fuel pump buzzing noise inside the car?
- Replaced dash - Where do I get replacement vin# for new dash?
- 93 civic dx/b16 head/b18c block/stock p72 ECU -- hitting rev limiter at 6k
- 95 EX coupe/00 b18b - It revs up and down when cold
- wondering if eg cat back fits on a delsol
- REMOVAL OF ECU QUESTION
- d16y8 0bd2a harness for swapped 96 dx - How ensure that $100 harness is correct?
- 93 DX Hatchback Lights dim/Power loss
- Another b16 Idle Thread. (I've searched..)
- My EK4 B16A2 gets beat by EG6 on track -- Why?
- Factory CD Player will not play 700MB/80MIN burned discs? Solutions?
- EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
- What gas to use for b16A2
- 92 civic- spark plugs wont fire, need help
- 97 civic dx coupe with GSR gauge cluster - tachometer doesn't work
- My 95 civic lx 4dr is overheating - disappearing coolant
- Blower motor doesn't run
- b swap with d series auto transmission?
- 97 civic DX Sedan - both of my back doors won't open
- What is this connector for on top of the transmission?
- Camshaft measurements and descriptions - what to use with what
- B16B: DYNO TESTS SHOWING POWER GAINS FROM PERFORMANCE HEADER OVER STOCK
- 94 civic ej2 coupe/99 b16a swap - Want trade opinions & help with problems from swap
- My 95 Civic CX hatch build
- Having an issue with the steering after installing camber kits and coilovers.
- iac valve question
- gauges work only when revving
- Bought 94 Civic EX - New member looking for ideas
- 2000 EX, GSR Swapped, Car Bogging/Speedo Spazzing
- what kinda glue should i use for my hatchback roof brace ?
- 00 Ex Coupe, car is idling very low after warmed up. ~200rpm
- 95 coupe z6 overheating issues. Need help fast
- I need to know what brand B16 header this is...
- d series hatch auto manual swap mounts ?
- Just bought an 00 Civic EX with 146K miles: What special maintenance is required?
- Finally done with the shop *JJSPEC*
- 94 Civic DX/D16Z6 swap -- No fire after tune-up!
- Engine rebuild: What do you guys know of Laskeyracing???
- 98 ej8/ls swap: What should be my average gas mileage?
- 97 Civic EX Sedan - Planning for custom headliner. How much fabric is needed?
- Machine shop in 949
- 97 hatch/K20A2 swap - fuel pump won't prime but has good power and ground
- 97 Ek Weird No Start
- Questions about B18C Type-R JDM swap into 98 civic ex - please help
- Looking for eg8 silhouette outline
- STD Stage 4 w 8lbs FW Good for Del Sol D16Z6 JRSC?
- 94 Civic/ls swap/5 speed/stock P75 obd1 ecu - Why would it throw code 12?
- Is my head gasket bad? Are they hard to replace?
- EK B swap neccesities/ parts list/ modification.
- 1999 civic si * Turbo OR Swap??
- Can't switch off running lights and low beams don't work
- EM1 - black shit all on my rear bumper
- VTEC head conversion
- 95 Civic hatch - Front brakes locked on - car stops without pressing brake pedal
- CIVIC SI with knock sensor code 23
- B16A2 SWAP IN 98 DX - speedometer, tachometer, and distributor problems
- Idle jumps to 2500 rpms after start up
- Car will not start after shut off without a jump start - new battery and alternator
- 95 dx hatch itr swap ecu
- Best upgrades for my civic si
- D15b2 main bearing selection
- EJ1 Horn and Cruise Control Problem from my steering wheel
- AC/Heat blower motor
- dx fog and lip installation
- 00 Civic Si 212k miles Pics of my Exhaust Valves..WTF
- what sensors do i need for a eg9??
- Found 99 civic hx ej7... is it worth it?
- Pass HID kicks off after 2 min.
- D15Z1: A project for the unemployed + pics
- [FAQ] Ultimate Swap Quick Ref. for EG/EK
- 96 civic dx - spark but no fuel
- Car bogs and looses power when it rains
- Z6 Intake Manifold auto/manual different?
- DIY 96-00 rear brake converion
- 93 civic- starter not working
- What parts do i need for a B16A turbo build, and what can i keep ..
- Any How-To threads on replacing a starter?
- Handbrake light blinks on when cornering hard ??
- wanna gain power
- 99 hatch/gsr swap - Won't Crank!
- ABS Removal?
- eg civic si no pressure in radiator lines help!
- OBD2 to OBD1 auto need options
- 98 hx planning b18b1 swap - Will my hx harness work?
- D-engine to B-transmission
- IACV CEL code on Y8 auto
- help please
- 2000 Civic ex takes longer to start
- Mini Me swap questions?
- 93 del sol/D16Y7: Any suggested dizzy mods?
- 97 civic engin swap
- Strobe Light's for civics
- 3rd Gear Grinds at High RPM on Z6 Tranny
- Does anybody know about this site www.jdmenginedepot.com
- Rear main seal: Do I use hondabond or none
- eg - Is the gsr disc brake conversion easy?
- hid ?
- Does a p28 throw a code for evap can delete?
- Did this really destroy my V-Tec
- B16A wont stay running
- Rusty brown water in my radiator & overflow ?
- DIY: 96-00 Civic Manual to Power steering
- Car Not Starting! 40A hood fuse for ignition switch keeps blowing
- Need new block for d16y8: What blocks are compatible?
- Bad head gasket - WHAT TOOLS DO I NEED TO BUY ?!
- 99 dx with body kit - What year and model is the body kit?
- Need help with swapping a b15 with b16 speedometer!
- how do you tighten the belt going from alternator to crank?
- HOW does the vtec oil pressure switch bypass work?
- How to remove old paint from rims
- 99 dx - D16 to b18 swap - Will the DX exhaust fit?
- 92 Si hatch with SRS - Will 94 hatch glove box fit?
- Which dupli color paint for Ctr headlights?
- Will an igniter unit from other Hondas work in my obd1 gsr?
- How do you remove/disable a JDM p30 knock board?
- Stolen from Pasadena City College - black 99 hatch with Si's and tinted windows
- 1997 Honda Civic DX Sedan - Why does it have a sunroof?
- 97 civic coupe speaker sizes?
- dist never points at number 1, WHY?
- Semi built b16a2 smells of gasoline under the hood
- D16 drain plug - What is pitch and size?
- 93 Del Sol/D16Y7 swap/MT - Motor mounts don't line up
- Ignition timing was off and now mechanical timing is also off
- 1993 Del Sol grinding noise and severe vibration in front end
- stock gsr aftermarket intake manifold and tb worth it?
- Stubborn axles! Won't go in!
- Help: EG sir headlight install
- gsr eg not turning on (electrical problem)
- D15b7 rods...
- Inline Four Electric PS?EK Kswap Aftermarket AC Lines?
- OEM Integra Exhaust bolt right up to 93 sedan?
- auto ecu to manual ecu, solder as jumper for rp18
- Low readings for compression test
- cant get my car to idle normal...or consistant
- Cruise Control Not Working- 98 Civic EX
- Not enough power to go on hill
- throttle problem
