View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Quick question help me out
- clutch problem
- radiator fan nut fell off
- alignment issues
- beaks bar and sway bar do not fit help
- 93 civic b16 wont start. Fuel Pump, Fuel Pump Relay.
- anyone know how to align a sunroof??
- Best motor for 94 Del Sol: d15b2, d16z6, or d16y7?
- Clock spring nightmare
- B18c1 in a 97 hatch how do I get ac?
- B20 swap Q's
- Timing belt help
- Clean Throttle Body, Mess Up Idle
- Rear camber kit for 96 del sol
- 1993 Honda Civic EX 1.5 L, electrical /fuel pump issue
- Squeaking from the front end
- GSR seats in EG Hatch?!
- Radiator Support 93 del sol
- Momo horn connection
- AC isn't recharging
- D16z6 Fast Idle
- JDM D15b parts query
- Anyone have some thoughts on jumping rpm gauge?
- DSM black top injectors
- 2001 cluster into a 92 dx sedan
- A/C- instant frion loss.
- EM1 back seat question
- Spark plugwire and distributor??
- 1995 honda del Sol S with a d15b7 questions...
- Fuel?
- Whats The Fastest Way to see if im getting fuel
- What Do Yall Recommend I throw in my EK Hatch?? B16, GSR, LS Vtec. Ect
- o2 sensor
- E30 basketweaves honda center caps
- D16Y8 VTEC failure/shuddering idle
- Fitv wont stop sucking air.= [
- H23 in a 94 civic?
- Fuse 15 keeps blowing
- booster delete with wilwood master cylinder
- MFPi Problems, idling at 4500rpm
- charcoal canister
- e-85
- 92 Civic, d15-b7, shaking/low idle/coolant smell
- Tail lights and corners won't turn on. Help needed.
- please help fuel or eletric problem?
- knock sensor obd-2
- Starting Issues '93 Civic DX
- Putting a motor in without an engine hoist
- D16Z6 Cranks, Won't Start unless I pump gas pedal..??
- Fair price for a 95 steering column?
- old wrench
- Why does my 93 civic dx studder sometimes
- h23 vs b18
- Two diff del Sol tire sizes??
- Hot Potato with a D16Y8..HOW HARD TO LIFT?
- Bad bogging?
- SMOG ticket
- just swapd a 94 ls into my 93 dx ej1 now white smelly smoke
- Anybody like rota gt3 or drag dr-16??
- Turbo price?
- Vtec SI Engine Swap
- ae86 fender flairs on a eg hatch
- b series parts
- for those who have asked about my setup
- flywheel help!
- MIS *FIRE* KING
- 93 si with obd1 LS no power...suggestions?
- Lighting/Radio/ Electric Problems Helps!
- Squeeking noise coming from front, help ?
- EG spoon style mirros on DC4.
- lowering springs.
- 2000 EK Hatch...Thoughts?
- Hitting the Rev Limiter?
- car wont go into gear when it on or off
- 98 civic vss wiring problem?
- B series Blox camgear question
- LS-Turboner's civic coupe build thread
- bracket for jdm eg armrest
- custom wire harness
- manuel window regulator install
- D series bolts fit b series?
- 96 civic window issue
- car wont start - turbo d16
- eg window wont roll up. broken window arms?
- Need help...Valve Clearance --?
- need help! b20vtec turbo build what valves?
- Clutch Masters Stage 2 FX200 or Unorthodox Street Sport Sprung Full Face
- Transmission help.
- whats all the parts i need to convert to power window on my 97ek hatch
- how much bank did u get 4 your booSted civic
- Whining sound on high rev speeds
- Mugen CTR Airbox Install - do you know where does this part goes? (pics included)
- Swapping a 96 GSR motor into a 95 Civic Si, What wiring do I need?
- 97 hatch b20 swap problems
- CTR LCS's.....
- D16y5
- 1995 Honda Civic DX 1.5 Manual Transmission STARTING PROBLEM [NoFUEL/NoSPARK]
- Problem with my 99-00 DEPO Fogs
- question about ignition switch
- the new guy
- 95 DX ignition switch - Does auto/manual matter?
- What are these seats??
- Mini-Me: Timing Questions
- Look what I just found on ebay...(del sol owners beware!) Ha!
- Connecting your Knock sensor and IAB
- b16A3 vtec cuts in and out
- Hood Question
- Problem with a 1994 Honda Civic LX
- 1992 civic vx hatch A/c PROBLEM!! NEED HELP!
- OBD1 GSR into OBD2b civic HX (99 EK)
- FUNTION7 OR SKUNK,ASR,BEAKS (LCA'S)???
- how hot of a spark plug is safe for b16a stock
- Need help removing engine harness on a 95 Civic
- 1994 Honda Civic DX Automatic Transmission COOLING PROBLEM??? HELP NEEDED!
- Setting price on my em1
- looking to LEAN out my motor a tad :omg:
- stance questions
- quick question?
- is there a long o2 sensor for headers?
- Oil in spark plug hole
- omgshawn's daily driver 'build' - EG hatch
- Motor Swap, 1993 Civic Hatch
- what seats will fit in my 95 dx eg coupe?
- 95 civic dx heater and ac lights not working???
- handcommand ecus?
- ARP head studs, bolts and washers
- 93 si project
- Need opinions on goin vtec or nitrous
- d15z1 crank same as d16z6 ??
- help with small mods i can add to my 95 del sol S
- 205/60/15????
- Another d16z6 idle issue!! *Mel Gibson roar*
- 1992 DX Hatch and 1990 CRX HF
- No fuel or relay kicking on?
- OEM wheel screw?
- 98 civic a/c throws (tcc) torque converter circuit control CEL
- car wont past 3500rpm ckp code
- 1994 Honda del sol idle and shifting problem
- 00 civic bogging
- civic 95 /integra dash
- GSR rear disc brake swap help...
- d16 y7 non vtec
- b18b1 swap questions
- A/C Is warm when its warm out
- OBD2a differences between harness's
- is it the tps or iac.... any inputs?
- Fuse FI E/M Keeps blowing on my Ek hatch.. Help!
- flywheel help
- car does NOT start
- 92 civic cx b20 swap problem
- Ignition Problem
- ek with gsr swap, stuttering around 2-3k rpm when driving
- 1995 civic random engine shut off
- crank, no start. h22 eg.
- help with overheating issue
- Turn signals stopped working...
- how much HP can a cable trans hold?
- Greddy Fest2, Open House Enthusiast Car Meet Roll Call!
- 92 civic 1.6 erratic idle issues with AC!!!!!!!!!
- fuel pump
- obd1 dizzy plug converted to obd2 CEL- car shuts off.
- skunk2 muffler??
- Help with suspension 95 civic
- *List all possible reasons for no spark b16a2*
- What is the compression numbers for the Jdm b20b?
- eg d16z6 tranny question
- check engine light (jumpin temp needle )
- 1995 LX sudden no start condition
- need suggestions on turbo build
- B16 Nightmare problems, tried everything!
- engine help
- iat wiring diagram
- headlight plug?
- ECU fuse blows when I let out the clutch
- what kind of pistons do i need for my b18?
- angled muffler pics
- Cel light
- alexander and the no good horrible day
- b18b motor a good idea?
- Dealership wants $998 for E-brake fix...
- Auto 94 DX Hatch Problems. Need Help
- Fuel Pump Problem..
- how long will gc/stock suspension last?
- My Free EG Hatch
- My car is STILL overheating... any ideas?
- car startup noise squeals and go away
- CEL 23 KS HELP!!!!
- EG9 Seats
- what did i short out.
- Where do I locate the valve for ac recharge
- Headlight low beam issues
- NO acceleration in EG hatch!!!! Timing?? IDK??
- Ac filter drier
- z6 to y8 head swap questions. 95 civic ex
- AC line tuck help
- F'en HARBOR FREIGHT TOOL
- ls swap question
- help me figure out which iacv i need.
- 95 Civic ignition switch or lock cylinder?
- bleeding brakes for1996 civic
- what is wrong with my shift linkage?
- Best aftermarket crank pulley?
- D15Z1 Overhaul Question
- A/C Replacement Help
- Will this 1.7L 03 motor fit in my 95 DelSol SI?
- del sol gsr iacv problem
- Throttle Body bad?
- 1993 DX Cruise Control?
- question for the d-series guru's
- buying a Civic DX help me choose
- Anyone know the name of this......?
- What's wrong with this?
- need help whats goes here on b16a2
- gsr harrness speed sensor issue
- eacv problems maybe?
- Noise when turning car help.
- starter help
- build a b series or build my d series motor ?
- Fuel pump not working
- Turbo d16 help
- Gas Gauge problems.
- Transmission shift points and what controls it?
- ticking noise from D16Y8, help!
- Just replaced drive belts. Now it squeals at start up only....
- z6 not starting
- Fog light question?
- Misfire/Popping at WOT?
- Car wont crank
- Mini-Me power estimate
- Car is hard to put in gear, and will move when clutch is engaged.. HELP
- Young kid asking n00b questions
- ZOMG, Gutted Air Box or not!?!?!
- how can i tell if my b16a2 came out of A 2000 si
- Which OBD2 ALT would fit an OBD1 JDM B18C?
- new swap, auto tranny takes to long to shift
- accelerating problem 96' civic lx 1.6 auto
- Civic Cluster Lighting!!!!
- Shifting problem while in gear
- will a s2k steering wheel fit on my 99 SI
- Would a deadener bother you?
- 92 civic DX won't start? help?
- 95 del sol swap question
- d16a6 head on d15b2 block
- I GOT A HOLD OF SOME JASMINE HEADERS WHAT ARE THEY
- best way to clean pistons?
- H22a in 92 eg missing, cant find out why
- RusTy Hunk oF cRap 94 PROJECT
- mainshaft will not spin
- 95 honda civic has no spark
- Want to know whats the best oil pump for d16z6? PLEASE NEED ADVICE!
