View Full Version : Honda Civic / Del Sol (1992 - 2000)
- removing crankpully bolt with engine out of car?
- buying b18b, with 99 Cx harness...info needed quick...
- headers
- changing brakes WTF POS is stuck
- My Car screams/squeals and vibrates when the A/C is on
- B16, D16?????
- B16 A + ITR box
- D15B2 QUESTION????
- I need a picture of a STOCK EX engine bay.
- bolt for rear upper control arm
- PCV on a '99 EX sedan, 49 state emissions???
- Weird Clicking Noise Only When Braking Softly!! Not Bad Axle So Dunno...
- Open Exhaust?
- Cruise control stopped working.
- EJ8 owners.....
- Installing Cruise Control on CX???
- need help... ecu diagram initials
- 02 sensor problem
- B18B boosting 30
- 99-00 si wheel locks
- WHich camber kit For 99 SI
- 96-00 Civic rear swaybar question....
- What does "Knock Sensor" DO???
- Knock sensor wiring
- B16 SOHC Tranny
- need help finding fastners for civic...
- how many clips holding side molding??
- Want to Use my Tien Coilovers on My EG...what options do I have?
- Failed Smog check at State REF.. PLEASE HELP!!
- how to take off firewall?
- How does my head look? part 2
- depo fog lights
- gsr dash swap q's
- paint?
- Oil filers
- ok dumb question but hydro to cable?possible?
- b20b head
- rebuilding gsr shortblock
- 92-00 radio harness the same?
- Code 45...
- Civic to b18 auto
- Honda Vin Numbers EXPLAINED!
- Please Help Code 67 and 90
- WHAT HAPPENED! Hit a nasty bump and now look at this pic of my poor shock. :(
- reliability Mini-me setup
- ball joint/camber kit?
- whistling noise, 2.5 and up
- clutch/tranny noises?
- y8 intake manifold
- Master cylinder/Brake booster need help
- zc motor?
- metal on metal contact?
- Good Deal?
- Moisture in Headlights
- rpm points for vtec-e.
- how to tell vtec?
- driver side door won't open HELP!
- biggest T-bo for stock y8 to
- D series shift linkage problem? Help.
- stripped threads for valve cover bolts
- Questions about VIS Hoods....
- civic exhaust on del sol???????????
- Somethings not right here.....
- B20Z and B18B1 injectors compatible?
- Battery is dying and I get a BIG shock when i get out of the car.
- 99 Civic hood Roma Red up for trade
- one man brake bleeder kits
- HELP - clutch sounds like squeaky shopping cart wheel.
- any 96-00 civic owners using Full Length Koyo Radiator?
- keyless entry with removing lower radio/97 EX
- CRASHED my car today :(
- Need help with 93 dx hatch!!(searched already...no flames please)
- anybody here drive a del sol S?
- p28 Ecu problems please help
- Any problems with VAFCII?
- gsr tranny to buy used one or have it rebuilt?
- Brake job, am I paying too much?
- clutches
- D series transmission gear ratio
- Del Sol gaps in the body joints
- im goin to be boosted in 2 weeks
- Transmission Whine/Grind Need Help.
- 99-00 si front conversion vs 98
- alternator problem
- INSTALLING TRACTION BARS!! HELP!!
- d15b8 Vs d15b7
- Black Box
- Civic SI cat specs plz
- Building a gas mileage monster...
- Good place to buy OEM stuff?
- Driving with no gauges?
- B18B Swapone explain
- Individual throttle body manifolds for D series?
- Removing 93 civic seats
- Changing Alternator in 1998 CIVIC EX
- B-Series vtec solenoids
- Wont Stay Started. Whats Going On?
- help b18 swap
- Del Sol Guys -- Little help/insight here.
- strange noise when turning left any ideas?
- JDM D15B and USDM D15B2.. Help Please!!!!
- JUST for Fun mess with my ek
- Got some weird ass problems here
- B&G Full Coilovers???
- Camper/Caster plates
- high rpm shut off
- overheating on hills.... blown head gasket? help needed!
- Question about mini me swap
- alignment/steering issues.
- Price to get tranny fixed?
- LS into a Ek hatch????
- Biggest Brakes Under 15" in Your EG?
- I just called American Honda about 96-97 CIVIC RECALLS(You get free TuneUp)
- New exedy clutch kit installed...grinding still?
- HELP!! Omnipower ADJ. Lower Collar doesn't fit!!!
- Trailer hitch question: Differences in rear frame/bumper area between 3dr and 2/4dr?
- Starter Crank Noise...
- OBDII pinout question?
- I have a problem; need advice
- turbo in civic hatch ESI?
- Looking For Diagram of 2001 Honda Civic Firewall Grommit and Wiring
- motor mount question
- Y8 Fuel pressure. Help!
- I need a good PDR in florida or toronto...
- Question: What would cause coolant leak from this spot? (PIC inside)
- 99-00 specific fiberglass hood?
- Swaping a Straight B20 nonvtec (Turbo) into a 2000 civic si
- vtec pressure switch Q"
- engine not firing on all cylinders, changed plugs/wires now it wont start at all wtf???
- speedo problem
- Question for the guys who bought led cluster lights from SUPERBRIGHTLEDS.COM
- Cellphone to open your door
- Frame pull.... experts!! How bad do you think this is?
- switching o2 sensors
- h22 swap ?s
- What Do You Guys Use To Get Out Paint Dings
- HEATER ???
- engine break in? floor it?
- ?? Quaife Quick-Ratio Rack & Pinion Kits??
- 93 vx swap question
- misfire all cyclinders
- Brake pad for street/track Del Sol VTEC
- posting for a buddy, AEM BIG BRAKE KIT HELP
- Anyone Run An Apexi WS2 With A Turbo Setup?
- idel problems....vtec dosnt work either
- problems with vtec
- dizzy caps and rotors - please respond
- Engine Swap Help. Quick question
- I Need Your Help
- WTF Surging Idle
- wtb: vtec ecu
- Clear radiator hoses?
- Weld nut on LCA...replacement?
- Removed factory CD player, what to do with space??
- Ebrake problem...
- swoosh gauges
- Apexi Gaskets
- COMPRESSION QUESTIONS
- tweeter question
- y5 boost or swap f23?
- need help with tps did a search already
- anyone in moscow Id or Pullman WA area please help!!!!!
- K.. did a swap.. now i'm confused.
- a quick turbo poll...
- TACH QUESTION (Dimmer/Light Control)
- car wont rev when given gass....
- Wiper Control Question Please Help!!
- Cleaning out engine cylinders
- omg im scared... what is wrong with this plz?
- D16z6 using 98 GSR tb
- spc problem
- Need Advice Or Opinions For B16 EG6
- Jdm Optional Console part numbers?
- 10w30 full synthetic
- Wheel hop = this....
- Hop Up Racing.COM???? Anyone hear dof them? For an Apexi Exhaust system?????
- Swapped in a P28, than problems started...
- Running too rich???
- DIY Red/Amber lighting in your 96-98 stock radio!
- EG hatch mandrel bends: What degrees of tubing required?
- HELP with D16y7
- Does changing you altenator require you to remove or mess up timing or timing belt?
- Need Your Opinion
- What kind of LSD is this????
- stolen civic in utah
- shift linkage
- totaled pistons? please help!
- FAQ: Integra Dash Into EG
- Tranny for b16a2
- door lock problem?
- Remote entry
- what mounts do i use and what one can i leave b18c1 into ek ******
- 99-00 fog light wiring?
- Quick & Easy question
- CARCHIP monitors performance?
- ATTENTION ALL VENOM VCN-1000 USERS!!
- Part number for DOHC del sol or 99-00 Si air conditionn - A/C bracket?
- Where's BlueIntegraBoy's Thread on Wiring the Integra Cluster Into EG/EK
- Help me reach my goal
- ::::::need help with d15 idle prob:::::
- HATCHBACK PROBLEMS!!HELP!!
- I need some info..
- which diff? tranny is coming out because CM stage 4 wont hold.
- help finding....
- Best, Quiet exhaust out there?
- Big risk trip?
- which would be easier, faster, less expensive?
- SOHC ZC block stamp
- need help caliper question?????????
- help! my windows wont work. NOT fuse.
- rear sways
- snapped bolts on the water pump. HELP!!!!
- Need some help with identifying tranny
- EG Conversion on 93 del sol...
- Climate Control Specs and Differences- HELP!!!!
- Crank Fluctuation Sensor??? Will it rob hp?
- buying old dx, motor,
- ARP HEADSTUDS TORQUE QUESTION
- P28 vs P06
- ecu chip?
- Good source for Konig wheels?
- What size resister can i use to fake the O2 heater?
- Which Motor Does These ARP Head Studs Fit? PICS!!
- D16Z6...Fuel filter torque?
- what should I do!!!!!!!!!!!!!!1
- fuse panel diagram???
- codes for a 89 si hatch
- Tire RPMs
- 93 VX hessitating and stalling?
- fuel pump rating
- idle problem (sirII b16a in a 92 cx)..throws code, but no code found
- OBD2 Engine Harness on OBD1 Car With OBD1 Components - HELP PLEASE!
- will a 95 rs mc bolt right into a 95 civic ex bb?
- engine throwsCode 45....reset ecu....good for a week....throws code 45 again....repeat
- need help wiuth distributor
- civic 4dr???
- Car wont start, possibly valves...help me out
- Ignition key starter
- Serious Wiring Problems.
- how much for paint?
- ANTI-freeze leak
- Will a 92-95 Civic Ex turbo kit work with a 99 Ex?
- HELP NEED TO FIX .25 panel
- PS removing help ??
- AM i over doing it??
- Endyne Catch Can...
- Progress
- What head gasket does the JDM D15b vtec use?
- Anyone running stock springs on aftermarket shocks ?
- '96-'00 Honda Civic EX - D16Y8 Timing Belt Change Interval?
