View Full Version : Honda Civic / Del Sol (1992 - 2000)
- I'd like to install cruise in my 97 CX
- creaking noise from brakes when slowing down
- Lug size for _____?
- need help on obd1 to obd0 dizzy
- got oil on the timing belt
- auto to five spd conversion
- Sensor Q
- P08 Question...chipped or not?
- engine swap 97 civic
- ls vtech vs poor mans type r?
- 97 civic lx from the grave
- how to
- p72 ecu??
- b16 crank pulley on b18c1 engine, what alternator belt?
- Which exhaust??
- What does this do?!
- which one is the throwout bearing?
- compression test
- Bad alignment on EK, any help?
- Getting a hid kit soon but want projector headlights for a eg? where can I find some and what are th
- made some strur braces for my car.
- Anyone have any experiances with Camp1320.com H4H HIDs?
- EX/Si Front Sway Bar Hollow?
- EG OEM fogs, with precision 750 intercooler... got a question
- Need a new exhaust!!!
- ITR front sway bar on my 96 DX
- Question about Small chips in Pistons PICS HELP
- car revvs up to 6k then redlines down ahhhh!!!!help me and my 2000 si!!!!!
- backyard special
- Front Swaybar for Car w/o Stock Bar
- Cheap Front camber kits.
- What distributor for 95 EG w/ a 96 GSR swap????
- car won't idel right afta a b18b swap
- What parts do I need for a auto to manual tranny change.
- NOT ANOTHER ELECTRICAL PROBLEM
- Hey guys,Need help With knowing avablibe swap for blown 95 celica...thanks
- Mugen twin loop on ej8
- anyone selling parts for a Del Sol 93'
- wtb hatchy shell eg or ek
- q about b&m short shfter (bend and stright langth)
- Code 6 for obd2 to obd1 conversion
- hey guys need help with d15b7 with z6 head in ek
- How much is my 1992 EG worth?
- Using 98 ex plugs in 99 hx. Harmful?
- Spoon Gauge Cluster
- how to open a trunk to a '93 del sol
- BRAKE light
- Bogging problem 99 civic si everyone's stumped
- need help wiring an OBD1 dizzy to a OBD2 harness
- smog question?
- Alternator question
- POST YOUR FAVE 4-DOOR EG'S!!
- socal stolen eg help!
- PLEASE FIND! STOLEN BLUE EG GSR TURBO
- how do i wire up a secondary o2 sensor?
- focuz exhaust
- 13.0 c/r dd!!
- Anyone know how to change gauge faces??
- Why does the 1999 civic si burn more gas then a 1996 acura gs-r??
- knocking noise
- is this worth 1200
- First Instinct: Headgasket. Now??? [searched]
- Hawk hps vs. axxis ultimate brake pads
- spring question
- NEED HELP wit b20 swap
- Will bumper reinforcements for "coupe or sedan" fit HB?
- glove box question
- has anybody ever fit a civic door inside their civic?
- Which axles
- Radiator fan not working.
- what to do? concerning coilover suspension
- 96 civic sedan 00 trunk?
- d15b6 block + d16z6 head + y8 .025 headgasket =10.55 cr ratio mini me...
- oxygen sensor readings
- indentifying a z6 transmission
- p05 ecu??
- 75mph + steel plate on road = metal on metal squeek sound
- new to this
- Clutch question
- Removing e-brake cables from handle..
- Engine Swap recommendations
- Distibutor for 93 civic
- Extreme Vibration inside car and engine
- will 91 DA rear disc brake fix a 92 civic hb
- Help, when I exit the freewayand brake, I get a pull?
- steering wheel vibrates stopped
- Valve Adjustments
- Mini Me
- NON VTEC ECU?
- Need help. Car intermittantly is jerking only on acceleration???
- Performance Control Module
- Changing the original speaker system in a Honda Cr-x del sol ?
- where to buy shift linkage for a delsol??
- 2000 civic EX Clutch grabbing at top pedal mean clutch is going???
- ITR Header Bracket
- 92 civic keeps dying
- Rev Limiter.
- converting 5wire to 4wire oxygen SENSOR
- dizzyz
- swapping hoods
- idling problem
- Knock sensor
- post up 92 hatches with 2000 front end
- del sols targa top
- d16Z6 questions
- guage cluster w/ tach
- swapping brakes
- WTF? RUnning on 3 cylinders, super rich, help!
- EJ?
- Buying back my 'totaled' hatch. Is a salvage title issued?
- ----------> ENGINE SWAP HELP QUESTIONS <----------
- rear GSR leather seat gap
- Help Me Out. this is annoying
- CEL wouldnt go off
- '92 Civic Si. ABS or not?
- *UPDATE*--on my ecu i decided imma try on my own...
- speedo..overload?
- body kit
- Stock Civic Piping Size??
- Tranny problem fixed... But now this?
- bummper probelms
- Some misc 92 Hatch questions.
- vtec
- What above the Hazard Button in EG Cluster Bezel?
- NEED HELP: my stock 95 civic wont start when hot
- Head Swap and Ecu
- Basic help with 7 Civic SOHC
- Wiring complications
- Brembo big brake kit
- b16 dyno!!
- Y20 tranny... what's it off of?
- b20 wont rev past 2500
- need help with fuses
- Rotor and pads suggestions plz...
- d15b7 to d15b8 map sensor what do i do????????????HELP?????????
- si vs. ctr grill
- Need help A.S.A.P with motor
- impatient noob
- Rough idle then steady idle then dies when throttle is givin
- Different size in steelies anything DIFFErent with them
- type-r ecu in my 2000 si any gains?
- timing is off hel me!!!!!!!!!!!!!!!!!!
- cable tranny
- missing part on eg civic
- ported b16 in. manifold or aftermarket??????
- aftermarket steering wheel, removing airbag wires???
- soooo need your opinionnnn
- Side view mirrors?
- need new engine?
- EG Axleback exhaust on EK Hatch?
- 92-95 b16 swap
- B16A swap from a civic into a del sol. Should swap right over right?
- Sway Bay Question for 92 Civic
- Integra Brake Knuckle
- mount????
- h22a swap
- someone please HELP ME H22 SWAP!!!
- D16Z6 idle problem
- Cat compatibility question.
- 99 civic Power window trouble
- Civic EG Sedan Questions frm a Noob
- quick answer needed, problem with exhaust.
- engine swap
- EK b16 swap shake
- Jasma? Anyone with knowledge, please enlighten me...:)
- distributor problems
- Recommendations on a turbo kit for a 97 civic...
- 00 Civic Head Light Bulb - HELP?
- are b16a2(pr3) rings the same as b16a sir-II rings(p30)
- Steering Wheel Vibrating Like Crazy...
- Coilovers
- what else would you suggest for my lsvtec
- Sohc Civic Turbo help
- B16B Ecu on a GSR Motor ?
- Head Gasket Problem on EG's??? Is this common?
- www.hondapartsunlimited.com/
- Anybody running power steering in a B swapped EG?
- 93 Hatch- interested in teg front end coversion
- waster leaking in on passenger side WTF?
- Steering wheel swap
- code 22.....vtec pressure switch. need some help please
- Water in Trunk/Boot
- is there any good k20 swap guides online
- Want to buy or trade.
- detonation new b18 swap
- Del Sol fuel pump replacement help
- Need Some Help
- Trial Member????
- Sup everyone? New to site and new to Honda
- 2000 Civic Dying
- Metal scraping sound in wheel
- Engine won't crank
- timing on a mini me swap 92 civic d16z6 head d15b7 block? somebody help
- stage 3 engine rebulid problem
- ECU PROBLEM (5 speed conversion)
- will a cat back for a eg hatch work for a ek hatch?
- JDM B18C wiring problem
- Shifter into em1
- Jumpy accelerate after cold start
- Short Shifter in 00 EK
- Deer Vs Honda... not good..
- WHAT ECU DO I NEED FOR MY 92 CIVIC WITH A SOHC NON V TEC ZC SWAP
- Ewwwww....dirt in brake fluid..HOW
- ebay sohc header gasket
- Think I spun another rod bearing, i got some questions.
- JDM gauge cluster eg6
- Distributor HELP
- REAR CENTER BRACE?
- vis carbon fiber hood
- A whole trimester in Auto...what to do to my stock 96 EX?
- Swapping a non-pwr steering rack into my 92 Si?
- Driveshaft shop question?
- ek swap problem need help
- Will this headgasket kit work with d16z6?
- 95 EG2 gauge cluster wire harness
- LS AC mount the same as GSR?
- Red fluid under carpet??
- lug pattern ???
- crx rear LCAs on eg
- B20B motor swap into a 93 civic need help!!! car wong go into gears
- boosting a d16y7
- HELP! ENGINE SWAP WONT FIRE! cant figure it out! gettin spark n fuel?!
- Can I JB-WELD my tranny?
- ebay headlight + OEM headlight....work??
- honda civc ex
- What causes b16 to run super rich at idle? High HC reading
- Anyone want to see a broken rota!
- Engine Won't Turn Over, leaving me stranded!!
- hey quick rotor question
- JDM Ek vent coin pocket
- D15B cold start issues
- help!
- Spindle nut question
- Dash/Corner/Tail/License plate lights don't work and the fuse is fine - Please Help!
- Wiper Motors shot?
- I need a transmission.
- Is there a difference between a SI lip and CTR ?
- Throwing code--- what is it???
- BLITZ WHEELS TYPE 01 3PCS
- Vtec wiring help needed for 94 cx hatch
- question about head and block
- Help!!!!! can't find any front lip that fits my 2000 coupe!!!
- newbie ? about windshield
- Installing AC in non-AC car?
- right hand drive
- EG front forks
- OEM Instrument Cluster
- need exhaust help with new swap. info please
- earl's bulkhead fittings from the stock fuel filter to a aem fuel rail. WHICH ONES?
- Idling issues
