View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Question about Flow of a Test Pipe
- Cat Question
- OT ?: you want a 99-00 si bar without spending $$$ give me some inputs.
- intake question
- ** need help with this one folks **
- where to get cf lip?
- picture of my hatche
- 94 eh2 cluster ?
- finally got rims like what I wanted...what do you think??
- D16y7 and d16z6 head compression ??
- carsound cat....
- stock shifters
- Anybody who has a done an EG tranny swap from the DX to the EX?
- del Sol wing, Keep it or not?
- Psudeo type R 5lug...?
- heater core question
- Auto Tranny remove & replace, any suprises?
- Prelude Seats in a Civic
- one piece fiberglass front end
- Baro Sensor?
- someone help me out with gross vehical weight
- tranny slips out of 5th gear
- Engine Buying
- help: Suspension knocking noise
- 92-95 Hatchback Shell
- Need Help Please...
- A1 muffler - (Socal)
- Cable type hood locks on Civics
- quick question about 92-95 civic throttle body
- Anybody ever used N1-Spec.com for parts...
- Are all single-cam d-series headers interchangeable? Sorry no time to srch.
- Vortech Question
- The magnaflow 2dr/4dr exhaust comes with a test pipe!?
- oem si lip bolts and clips.. where to get?
- Custom Exhaust - Cali Style !!!
- Anyone ever try super mesh rims on an EK/EM1 ??
- doin rear disc swap, using del sol prop valve
- Will a exhaust off a EG fit a EK
- place racing crossmember vs. z10
- s21 or y 21?
- Gotta get something straight...
- 1/4 mile :( itr si
- B18B and Turbo Kit Install ----> Portland, OR
- Master Cylinder???
- EG Tachometer - Possible Problem.
- D16y8 Oil Pan the same as D16y7?
- obd 1 distributors?
- Recommend me a header for my 99EX D16Y8
- vtec problems
- ctr lsd in a b16a tranny
- How to clean under the fender?
- SEMA 2003 pics
- exhaust the quietest
- Squeeky belts
- last pic post for me for at least 3 months
- What does it take to be a normal user?
- Whats the difference between 96-98 CTR and SIR headlights?
- k20 engine mounts?
- ls swapin, ??? question
- sir2 door panels / gathers cd player
- Lugnuts for Bogarts?
- NEED HELP with this alternator plug, and knock sensor
- Back to 5 bolt, think this is a good deal?
- Whats a good setup for an auto EK sedan?
- Fresh GSR swap couple problems.
- GTP/Importfan.com Look at this.. EG bumper
- FS: Brand new greddy (gsr's) and drag turbo kits (can get other kits for civics) (cheap)
- Autometer Water temp sensor...melted?
- colder plugs for sohc turbo
- Cap and Rotor question.!!!!! Will this work..
- if i installed type r valve springs, cams, rods, and cam gears, would that cancel my turbo out?
- what OEM honda/acura strut bar for EK
- how to install timing belt cover?
- how to check wires/resistance on my IACV sensor??
- boxAnyone need skunk 2 cams?
- FUNNY!!! Ebay auction! hahahaha
- d16 head
- Tranny
- Can i add vtec to my car?
- Can someone please answer my fuel pump question
- ???? "Mini Me Swap"
- Who sells an a/c evaporator?
- tein HR's???
- Suggestions for D16y8 with Skunk2 IM?
- NYC Eg owners please....
- Question about a Spoon Spoiler
- ATTN: Civic owners with the Suspension Techniques Anti-Roll Bar
- 92-95 Civic si tranny vs 92-95 civic cx,dx,vx tranny is it all the same?
- do i have the del sol updated seals?
- Rev limiter on a 96 EX?
- In the SEARCH feature, is it possible to search for 2 letter phrases???
- SirII Brake Pads, Same as Del Sol Vtec???
- Sound like a good trade???
- b20 questions & pics of the del Sol
- d15 spark plugs and spark plug wires the same as 99 gsr?
- High flow cat question???????
- b series question
- USed spoon cams, how do i tell if there real??
- 96-98 Type R Lip
- Engine Swap question??????????????????????
- B-series swap into an eg. question about mounts.
- help with bracket, just did swap
- Are there different Starters for D-series?
- Time Serts
- I need sideskirts!!!
- Can this fit?
- tires for 16inch 2000 Civic SI
- Some Comptech Suspension Questions (did search)
- Will a 98 CTR Ecu work in a 2000 civic si?
- OT: just got a question on this wheel being sold at Exospeed.com
- Question for ARC box owners
- Blower Motor
- Can anyone find help me find ITR Front & Rear Sway bar???
- coolant leak under my feet?
- Gti Recaros in my 93 ex?
- found out who made my lip
- K&N filter?
- I got lucky today!
- Spoon N1 or Type one axle back?
- Will DC2 sway bar fit on my 99 coupe?
- Yoko AVS ES100 vs. Toyo T1S
- d16a6 in my cx times
- 5th gen ant. block off plate
- Which chip is best? jun/spoon/skunk 2/mugen?
- How To Swap in ITR longblock to take out Ls longblock????
- air fuel gauge install help plz!
- Well I am PISSED
- Osaka Motors...
- JDM sucks
- Swap question obd1 to obd 2
- Is it possible to switch the front end of an eg hatch or coupe with that of a Del Sol??
- Ok...wheelmax.com has anyone dealt with them....I read the searches!
- What to do with 3k?
- stripped brake line nut.. help
- Time to hear opinions
- 92 SI no start problem...
- Any Tampa Bay Boyz?
- need help car is making a wierd popping noise
- comptech icebox question......
- I need a side skirt for a 98 hatch
- Custom Spring Rate on GroundControls
- ABS PLASTIC
- skunk2 vs, ground control!!!!
- what's best engine
- first post...my car!
- 17x7.5 on a Delsol?
- side molding question
- Alittle OT but relavant for stolen cars owners (MD/DC/VA)
- I won da prize...
- all motor build questions
- what ecu came on 96-97 del sol vtecs?
- dc2 recaro in my 98 ek civic install how to help
- Anyone have first hand experience with the 96-00 civic Zex cam?
- Best Exhaust
- Cruise Control - Not an option
- A new phase in life. (no 56K)
- what are your setups on your LS swapped hatches?
- Stripped wheel stud.
- Prop valve where to get one???
- Exhaust
- San Diego tranny shops
- Changing oil question
- rust sucks
- Turbo kit review
- two catalytic converters
- any one from upstate NY
- F.S / Parting out a 1993 Honda civic Coupe.
- 94+ Dash swap out on a 94 EG Hb.
- Exhaust Question
- skunk 2 break in?
- EK with Panasports
- Prop Valve for the Brakes. What is the Truth?
- window rail...
- How do I become a non-trial user?
- i have a problem..please help
- Some quick help...With Spoon N1
- side marker lights?
- Hi! I new to H-T and i have a question...
- How much could i get
- good deal 2500 complete b18c5
- stock z6 throttle body size???
- wtb: civic parts!
- 92-95 jdm foglights?
- Installing a tach.
- Is it just me....
- Is the 98 EK rear bumper the same as a 99?
- How do I clean the EGR ports on a 92 vx hatch?
- DynoMax Cat-Back
- 1990-1991 acura intergra rs/ls skunk2 intake manifold into b16a2??????
- Auto ecu vs Manual ecu
- whos a jdm freak?
- will an itr cluster fit in my 98 civic???
- EX and DX automatic transmissions: interchangeable in EKs?
- CD Player fitment?
- 15's and wilwood kit or 16's and big brake kit?
- B18A T-BODY did search
- a few pics of my Civic
- idle
- aftermarket timing belt?
- New Member Here!
- Total-Boost.com?
- Teg dash in an EK?
- Crank Pulley: ONE quick question
- Suspension repair and cost...
- Question about JDM door panels, already did a search...
- Who is from Toronto?
- how do i run a block to make sure its legit?
- turbo project almost done, just need injectors resistor box
- Rear Tranny Mount went crack....
- del sol exhaust?
- OEM FPR same specs for B & D series engines?
- on the road again
- How much is too much CF?
- Can you advance 2 degrees timing on a stock motor?
- WHAT IS THIS!! on the EG radiator?? need to know in about 20 min!!
- CARB CLEANER IN IM = BAD
- d series pistion? compression to octane usage question?
- Si doors in a 96 dx hatch ?
- Motor Acting up HELP!!
- Neuspeed spings(makingNoise)
- 2.5" drop: too much for stock shocks?
- need tips on swaping 98 jdm type R into 94 cx
- LOOKING FOR EK PARTS!!! HELP!!!
- Problem After Gutting Cat
- fuel pressure
- Ignition advance DESPERATE please!
- Southern NJ Meet!!
- Identifying year of b16 heads?
- CEL . . . maybe good for running a turbo . . .
- B16sters ,What vtec x-over are you using?
- O2 Sensor wont budge!
- i need help please
- Will a 00'Si harness work....
- 6x9's in EG HB, Yes I did search
- Possible to run B16A short block+GSR head?
- Need 2 know: Power window conversion...97 DX
- ls set ups.
- rear disc brakes?
- 4 door JDM Civic parts?
- GS-R brake swap links
- O2 sensor, IAC codes from P30. Speedo quit too. HELP
- 99 civic front end conv.
- how much for my ride?
- Mini-Me Woes...
- bolts for eg seats
- civic type r or JDM fenders
- another problem came up when swapping an engine, need help
- What would you do? (EM1 or EH3)
- Good base to mess with
- EG sedan interior question
