View Full Version : Honda Civic / Del Sol (1992 - 2000)
- B18 idle issue
- Dash & tail lights shut off with headlights turned on
- Flat, carbon door panels.
- civic eg8 mini me mods. where to start?
- 92 Civic/b18b swap - no spark problem
- Civic EK - Climate Control repair
- Best route for moonroof replacement!
- Bogging issues...
- 98 Civic Track Car, Need help, Longish post.
- 94 del sol si - sticky/notchy throttle and auto trans shifting issues
- Red Lining at 5600 RPM problem
- 97 acura el rear running lights
- Swapping JDM B18C into 96 Civic Hatch - D to B Hasport Mounts question
- honda civic 98 ex with idle, stall, and stumble problems
- Need help identifying motor
- Save an EG: the making of a daily driver
- Need help from Texans
- Broken Coolant Temp Sensor
- fuel and spark but won't start..
- 96 hatch/b20b swap/chipped P06 ECU - low idle speed, misfire, no code
- broking window
- Civic 96 Dx B20 swap P28 Cel code 15
- 92-95 civic quick release fit a 2000 civic?
- 1996 Civic AC compressor doesn't turn on
- HELPPP!!!! D15b7 eg hatch blowin white smoke
- 99 ex b16a3 dyno
- 97 Civic turns over but won't start - No power to 2 injectors
- ek4 /ej9 ABS retrofit into 1993 Civic
- Clutch pedal
- 98 civic ex coupe wiper motor bad?
- 99 Civic EX-AC Fuse 56 keeps blowing
- 1998 Honda Civic dx EJ7
- Hello with stripped valve cover stud b16a2
- VERY strange overheating 97 ex
- obd2 B18B tb into D16z6
- Is this deck hosed?
- Civic Eg with b16a2: Hard starting, rough Idle, 3k rev limit. Videos inside
- Which Size Thread Should I Use?
- eg - climate control buttons light up without key in but blower doesn't work
- 96 CX b16a swap no fuel pump prime
- civic 97 ex/LS VTEC Turbo/obd1 p28 - sometimes injector 3 stops working
- '94 Hatch, Delay in fuel pump prime, bad ECU
- 98 Civic - Fuse 56 blowing
- D15b7 sits at 3000 rpms when I start it up
- My 94 eg Turbo H22 build.
- 95 Civic/turbocharged D16z6 - no start after replacing the distributor
- 98 Civic LX - Is this JDM engine a compatible swap?
- D16Y8 mild setup suggestions
- 93 Honda Civic EX Auto Tranny Issues
- 93 eg dx civic mini me swap problems need some help
- Strange bogging/hesitation issue- 95 Civic
- Best engine to swap into my 1993 Eg6 Hatchback
- 00 civic ex - idle surges from 1000 to 2000 rpms when warmed up
- Gsr Swap
- Rough & Low Idle?
- Stumped - 93 eg no check engine light ever??
- 99 civic lx - blown A/C compressor
- 00 Civic si - car wont start as fast when low on fuel
- Koyo R1952 radiator fitment issues
- Ek LS swap
- 93 Civic EX *STOCK* driver side headlight wiring up in smoke!
- im back
- Eg Auto to Manual conversion question?..
- b16a2 rev limiter problem
- 92-92 vx vtec-e
- Eg hatch HID/headlight problem
- door pillar molding
- 1997 honda civic key fob problem
- 97 Civic shut off randomly while driving
- 94 Del Sol - srs module (solved)
- d16z6 block with d15b7 head? Can this work?
- 98 civic dx hatchback/B16a swap/5-speed - swap parts opinions
- Engine/clutch rattle
- 97 civic cx with y8 swap and auto to manual conversion - Idle problem
- Radiator fan switch
- Please help me find this image on the parts category
- Turn signal fuse blowing
- 16" rims for 2000 civic si
- i guess new build thread
- 2000 Si.. cold air intake...
- good Reliable sites to order parts to rebuild B16a3 engine
- Sorry but... Exhaust questions. {PIC}
- Question about the model of my Fathers rear interior.
- 99 Civic --NO power to radio after removing battery cable
- Gsr eg hatch vtec not working and fuel issues
- b16 ek final step wiring
- 2000 Si.. buying parts...
- Need help diagnosing engine seizure
- custom vtech controler
- EK hatch stock exhaust system
- Will an intake manifold on a d15b7 fit on a d16y7?
- 99 Honda civic hatchback rear disc brake conversion
- 99 civic ex - code P1456
- Ef steering wheel on an eg?
- Manual transmission coming out of gear?
- Acura EL bulb size?
- Clutch Issues? - LONG Post and Very Specific, Odd Problem
- What brand for OEM Flywheel replacement? (EM1 b16a2)
- 97 Civic HX - overheating
- cx, vx, dx, ex stickers
- Never had a chance to ask...Are 92 Civic frame rails replaceable?
- 93 civic hatch fuel problem or maybe spark? help
- springs on stock struts
- Hose clamps on rad hoses
- 2000 Civic Si shell project
- 1994 Honda Civic W/b18b1 Clutch Master Cylinder Complications
- AC not blowing cold....fuhhhh!! =(
- Spoon replica mirrors
- b18b swap in a 2000 civic
- 96 civic - losing coolant & overheating
- 98 honda civic wiper motor failure
- 99 Civic - Clutch interlock switch -- How to access
- 98 honda civic lx - auto transmission problems
- Performance springs with least lowering..
- Tein Basic Rust
- 95 Civic Ex - clutch pedal does not spring back up
- 95 Civic EH2 D15B7 - its issues and challenges.
- 00 Civic EX - Misfire, Stumble, low idle: WARM START ONLY!?!?
- is the d15b (dual stage vtec) obd2 (96-00) the awesome best d series engine?
- clicking noise on accel and decel
- 2000 ex swap auto to manuall
- 97 Civic - Surging idle
- wiring issues jdm b18c
- Aluminum spoiler with stock mounting locations?
- Need to buy parts but unsure for which car or engine
- Are B16a2 piston rings compatible with a B16a engine?
- 95 ex - Choosing Coilovers
- Need Info/Advice on a '95 Del Sol engine
- 00 civic dx hatch power locks questions
- Cheap things to do to a D series.
- 2000 Civic Dx LS/VTEC help.
- incorrect gear ratio
- gsr swapped ek axle issue
- Project F'd up EKHB
- 97 Civic Idle Hunting
- 99 honda b16a2 vtec civic si distributor help needed
- Engine coolant issus civic 1998
- 00 em1 starting problems, starter is good.
- 1997 Civic LX stock performance??
- new 97 civic owner - stock exhaust system?
- $1000 1993 Del Sol S -Now $2000 Del Sol!!?grr
- Would this bother you - door lock installation and tow damage
- suspension/shock struts
- AC On = High Pitched Squeal
- d16z6 smoking after rebuild
- 1996 honda civic rear windshield wiper
- 1993 Del Sol - Passenger side lock mechanism is broken
- Engine code #7 TPS
- 96 Civic EX Starting Problem
- 96 civic si - bumper conversion shortcut?
- Compatible distributor for 99-00 Civic Si?
- Foglights not working
- Civic clanking noise
- Coolant flush question
- 92 eg hatch/D16Y7 mini-me swap - old time member new car!
- 98 civic ex leaking coolant
- Got a 99 civic si (Canadian) - what I should do?
- tail light (auxiliary lights?) problems
- $500 d16y7 upgrades.
- 00 civic ex/B18c r spec swap/p73 ecu - vtec and bogging problem
- Please post head codes from your Honda engines here
- Do i have an air bag?
- Upper control arms put in on wrong sides?
- "P2J-5 01" head code - 99 civic Ex ?!?
- Rear roof rail
- 99 Civic LX sputters (misfires) at low RPM's when warm.
- SRS light won't reset
- 1998 honda civic Ex. fuel injector pulse issue.
- Please Help if you can.
- Speedo is way off
- D16Y7 - auto transmission won't shift from P to D after "cool" start
- spark plug tube seal
- Issue with dropping revs on a '93 Civic (automatic transmission)
- timing 180 degrees off?
- Dc2 twin loop muffler on eg hatch,cut and reweld?
- Vapor lock? 94 Civic EX
- Should I change Manual Trans Fluid?
- HELP ASAP!! B16b 1993 del so, axle question
- Tilton pedal box
- d15z1 in del sol "issue"
- 99 civic si lip
- at what point does the rear sway rip out subframe
- 93 Civic EX 1.6L 5Spd Not Cranking
- D16a6 Si trans on a Y7 block?
- Replaced ECT but still get check engine light
- '94 Civic Hatch A/C Compressor No Voltage
- need rim help
- 96 EK hatch - muffler / lip kit questions
- my build thread
- Gauge issue
- 94 Del Sol random CEL codes
- 1993 Civic EX blower motor
- Testing the Ignition system on a Honda civic accord Odyssey and CRV
- so frustrated with rebuild
- 1998 Honda Civic LX Overheating
- damn horn
- Looking to upgrade alternator... advice?
- Thinking About Building A Street Car
- headlights jacked up
- someone help! car wont start
- 99-00 Civic si cluster tach repair?
- 97-01 prelude seats in ek who has done it
- D15b7 overheating.
- NEED HELP WITH FUEL LINE!
- 1998 Honda Civic LX A/C Compressor Always On
- Si & EX transmission Question
- 98 Civic DX - idle problem and code P1399
- 98 civic ex dying at idle :/
- 96 Civic EX Misfire when warm.
- 1999 Civic EX - Noise and CEL codes
- Anyone try these new calipers yet? (Wilwood 4 piston)
- D15b block D16z6 head?
- 95 EX sedan rear brake hardware
- A/C blower assembly removal..headlight harness tuck
- Non vtec d15b help .. Smoke
- clicking/rattling in engine bay D16Y8 VTEC BOOSTED
- Hello Everyone! I have a 95 Civic Ex D16z6 and need some advice, this is my situation
- Help! Oil Drain Problems!
- 2000 civic d16y4 timing belt teeth
- Weird idle issue
- D16Z6 block with Y7 head
- Squeaky stops on my eg
- Coolant leaking 98 Honda Civic
- Break Light Not Working on my 94 Civic Hatchback
- TD42 Distributor rotor removal
- Can a z6 distributor for b7 head?
- Service repair manuals
- 92 civic Tach/sputtering problems
- 1994 Honda Civic EX overheat - whining sound from RH of engine under plastic cover
- 98 Acura EL - C552 door plug pinout
- Engine vibration at idle on rebuilt d16y8
- 97 Civic EX - i have no clue where this sensor goes
- D16Z6 engine re-assembly questions
- 95 Civic LX Sedan Rotational Noise
- Vacuum Gauge Illumination Wiring?
- 1997 Del Sol - speedometer/odometer problems
- help oil capacity
- A/C button light won't illuminate and compressor won't turn
- Coolant hose leaking - 97 hatchback
- 98 civic lx/B16a swap - bouncing idle
- 1993 EX sedan, replaced soft lines, pedal still feels like ****
- 98 civic dx misfires when warm
- Weird oil drain plug broke inside the oil pan... please help!
- 97 hatch with B16 starts and dies
- Non-vtec D15B engine replacement for 99 Civic Dx Coupe
- Help with Engine Codes
- Overheating issue. Please help! thanks :)
- need some help
- Eg catalytic converter on ek
- CRANKS but WON'T START: please help
