View Full Version : Honda Civic / Del Sol (1992 - 2000)
- PLEASE Help.......Sohc Turbo Coupe
- wiper switch problem...
- oil light, stuttering,b20vtec!!?? help please
- water in fuel, or fuel pump going?
- !!!PIC REQUEST!!! Maroon EG Ferio(s).
- Clutch "slips" from 3k-4k?
- Does this sound reasonable??
- what throttle cable and bracket?
- worth it for an ek9
- b series lsd
- Old Gas Or Old clutch causing bogg?
- question about an S80- transmission.
- GSR Brake Conversion?? on EG...one easy question
- b16 calipers and disc on d15 knuckle - pics
- Official GTFO mod on EG 4dr
- sohc dyno correct
- injector inquiry
- d16z6 tranny swap?
- Obd0 motor into EG sedan, what do I need?
- gsr turbo question
- Notable differences between 96-98 & 99-00 Civics?
- IACV
- Short Circuit?
- tiered of coilovers
- eg6 brakes
- 97 ek hatch with 93 si motor help
- Wire colors
- clutch help!!!!!!!!!!!!!!!
- how much do these go for?
- So i switched my girlfriends car to E85
- B16a Questions
- 95 gsr into 93 civic si hatch. ahhhhhh
- LS into 94 hatch wiring help
- Weird intermittent "poping" sound
- 92-95 civic LCA?
- My tranny mount is shot
- skunk 2 racing chip
- im doing a motor swap and i need help
- headgasket change
- top speed questions.... and an h2b v k20 question
- wat kind of gauge clusters can i put in my civic lx
- EK cluster tacho RPM not working
- A weird engine problem?????????
- WHY DOES MY ALL STOCK D16Y7 DO THIS< NON_VTEC AND REDLINING AT 7,500RPM(VIDEO)
- sohc vtec question
- Help on CTR Center Caps
- Q-??? 95 SEDAN BUMPER WITH A 96-98 SIR LIP(will IT WORK)???
- d15b5 engine code what car is it out of?
- axel question
- scared to boost?!??!
- GAS?!
- Engine Help!
- 92 civic, no fire!!! and have checked all i can think of
- wife kicked fuse panel in her 98 civic now 3 codes. p0500 p0135 p0141
- maybe someone will get a laugh outta this
- Best hup caps?
- my coupe is restored!
- dont know where this tube goes
- 96-00 2 DR window switch work in 93 Civic?
- b20b throttlebody
- lighter flywheel
- Car shakes 00 si
- o2 question!! help
- EG CX Hatch vs. EK CX Hatch ?
- installing axleback help
- would front brakes on 95 dx fit the back drum.
- torque damper
- d series vss?
- bad alternator or battery
- Horrible gas mileage, high idle after intake mani swap
- what else could it be?
- EG civic power steering pressure hose interchange, any others models work?
- Honda Lx tranny on Ex engine?
- cam gear for d15b7 block and z6 head??
- quick question?
- power window relay number#?
- My h22 Civic Hatch
- Is this a good set up?
- Automotive, Mechanic Shop - I'm from Lynchburg, VA
- 2 Head gasket quick tip questions, PLEASE HELP
- EG question
- which short shifter is better?
- windows are slow goin up and down.
- Quick alternator question
- DIY B16 Clutch???
- exhausts in the 2.5"-3" range? finding most name brand ones to be smaller.
- vacuum diagram
- RED 96 EK HATCH STOLEN IN NOVA THURSDAY DECEMBER 20
- Need a good/cheap/easy to install remote start for civic... suggestions?
- IMPACT- BC canada anti-theft program
- D15 sohc non vtec
- NA b20 vtec
- honda tops the list...again
- Advice on B20b4 SLeeve!!!!! ANd modsss
- type-r cams in civic
- VTC and TDC were is it on a OBD1 ECU
- AC PARTS
- RPM signal on OBD1?
- 98 honda civic engine swap?? need some advice
- New clutch ,new master cylinder, engauges right off the floor
- tubonator?????
- I am having some awful luck!
- I want to grab some fogs..... ebay the way to go?
- What is the Intake Air Temperature (IAT) sensor for?
- oxygen sensor problem. any ideas?
- What difference will a new head gasket make?
- What does Si stand for?
- suspension
- need help .... bad wheel viberations
- Need Help! Question about swaps for 96-98
- Clutch lines and Radiator
- NEED HELP!!!...Car doesnt go into gear...
- quick question
- exhaust CAT vs. turbo.
- car wont start after a rainy day
- Car accellerates very slowly help!
- Ground Control Top Hats
- resistor box install? s
- WHATS WRONG WITH MY CAR?!?!?!?!
- Hey look I'm a NOOB!
- D-series build
- ecu question.
- Wiring walk-through? My car is b0rked
- my rims
- what will my del sol will run
- Shaking
- next mod?
- Identify this column
- idle prob
- Very high heat (Climate control)
- Opinions on NGK Iridiums vs. NGK V/G-powers
- hood latch won't work????????
- 99 OEM Si lip????
- What steering wheel is this?
- 92 civic 215k...
- GSR throttle body on AEBS intake.. janky throttle cable??
- How to align headlights
- Del Sol
- tire alignment??????
- car not starting just clicking.....
- b20/b16
- 99-00 double din conversion.
- lookin for a lip for my boys 4 door
- oem itr clutch and flywheel
- Wiper arms
- please help me with a 91 civic
- H2B Question!?!
- Shaved side mirrors? do they make a molding for that? fiberglass/plastic
- Where's this hose go??? *PIC*
- fuel pump help!!!
- Hand Brake Cable Question
- what tha hell is a civic cx???
- Click on me!!!
- What's my car worth?
- ex front lip
- Weird Noise
- HKS hi power question
- Engine harness identification
- Wiring Question.
- Automatic transmission (loose solenoid maybe?)
- hate rainy weathers...
- HEADERS AND INTAKE MANIFOLD QUESTION
- jdm climate control problem....HELP
- *****Car keeps dying**** 98 Civic 4dr with Gsr swap
- 99 civic ex
- I know you get it all the time B16 or B18 but I have a scenario
- change headers or not?
- P08 ECU question.
- Stolen civic
- h22 build
- Which one are they?
- 92 civic HB B18 Transmission problems
- Harness Help
- Newbies car from UK
- ecu p04 p06
- 00 engine noise
- How to tell when you need a valve adjustment
- !!!!!WINDOW WIPERS!!!!!
- 5spd P28 but throwing Code 19(automatic)
- need help
- abs question
- Hollowing a DX EK cat, can it be done on the car?
- Wat Lowering Springs Do You Recomend ??
- b16a2 head on b18c5 block
- D16z6 Water pump and spark plug interchangeable?
- Timing Belt TDC question
- EG w/ 5 LUG?
- Which light weight Flywheel is good for 99 Civic
- 2000 b16
- Thinking about 450f/400-350R on GC/konis
- Double checking on spoiler compatibility ('96-'98 on an EM1)
- a civic fell into my lap
- d15b swap into a 00 EJ8 acting wierd... need help
- EG jdm gauge cluster part number
- EG SI/CX steering questions.......
- d15 camshaft
- Purchased my first Honda! Need some advice.
- oem throttle body and skunk 2 intake manifold
- car wont move
- oil light?? I'm Retarded!
- buddy club vtec controller w/a pr3
- injectors
- when installing extended wheel studs
- Supercharge a B18c5-R?
- where u guys get your lightweight windows at?
- Power Door Conversion Quesion
- D16Z6 engine block and parts with D16Y8 parts
- What Civics or Integras have the B16A3 Engine?
- Wet Cold Air Intake.
- Selling price on d16?
- exhaust problem
- E-85
- Koni=rear shocks discontinued for 96-00 civic????????
- gauge cluster bulbs
- need help fast average price for wrecked 99 si
- still trying to fix idle problem!
- what ecu???
- Automatic transmission help - stuttering second gear
- ek sir clock.
- gunmetal EG stolen. I HATE THEIVES!!!!!!!!!!!!!!!!!!!!!!!!!!
- 1994 oem JDM EG Coupe/Hatchback Catalog O:
- 96 honda civic --just finish replacing axles
- color of guage cluster
- axle replacement 96 honda civic
- si em1 front lip
- 00 SI, Need suggestions on spring rates!!
- Battery Running Out
- 1995 Del Sol VTECH DOHC Coolant Problems. Please Help!
- Radiator Nightmare!!
- Help: Camshaft holder question?
- cosmetic upgrades...
- stock springs front or rear
- Window wiper problem
- how do i take out my gueage cluster
- whats next?
- d16 tranny question....
- jdmcarboy EK4 bumper's
- ej1 rear disc conversation from ukspec eg5
- just oredered my asr sway bar.....have a few questions
- how do you take out eg hatch door panels
- d16z6 minor build
- B20 automatic swap.....into DC question about switching throttle bodies....
- every bump i hit my hatch raddles. is it loose? how do i tighten things up?
- Where can I buy this part, window tab?
- CTR CF cluster Surround?...not the meter trim
- Parts List? (K24/K20 swap)
- need help removing 3M sticky crap on interior trim
- Column keyhole light
- h22 ek wont start
- Whill 92-96 Mounts fit 96-00 Civics
