- b18a/b18b swap into a 96-00 civic. what axles?
- Wheel bearing question
- Theives attempted to steal my car on thanksgiving and my car pwned them
- How to Disconnect hood?! (make a secret switch)
- What Loom?
- D15..D16
- Can anyone post a pic of their 99-00 Si AEM intake CARB sticker?
- Tunerzimage
- is this a good turbo setup for b16
- sk2 vs. gc
- rims and tires question
- vtech
- DC integra exhaust on a del sol.....
- My Car is down again
- diference between d15b3 and a d15b7
- EK fogs into an EG
- Got weird engine problem
- SOHC Turbo Build.. UNDER CONSTRUCTION
- alternator ?
- 97 Honda Civic noise
- I HAVE A PROBLEM AFTER DOING A H22 SWAP INTO MY EK HATCH
- ebay steering wheels?
- help urgent!
- manifold question
- What do you guys think of my brake setup? (OE stuff)
- swap or not (lsv)
- auto to manual finished mounts do not fit need help..
- 96-98 Fogs
- I have a 92 phantom grey hatch.....What color should I paint it......
- question regarding weight reduction.
- s2k cluster
- Does PROJECT MU make front/rear brake rotors for 99-00 SI????
- my door is vibrating and i think its my lock
- Manifold
- Injector Question
- killswitch
- b18c1 vs. b18c5 (boost vs. all-motor) for a '94 bubble
- H22 swap problems in EG!!!
- HELP!! B18B1 OBD1 SWAP in a OBD2 97 EK CIVIC HELP!!!
- Confuse by spare tire !? .....
- VTEC HELP!
- Help on question about rsx muffler stamp????
- help code 6 and vtec not poppin!!!!
- New LED turn signals in the rear, how to fix fast blinkers?
- Need Axels But not sure wich one to go.
- what does one do??? car title ???s
- Will D16Y8 Alternator fir 92-95 civic ? D15Z1
- wiring for itr swap in 96 civic dx hatch
- EG Optional Audio Console in TAN!?
- how to change wheel studs
- Light blue smoke
- New member saying hi!
- Wiring 02 Sensor question
- skunk 2 mani question.....
- check engine light
- need help with p24 ecu pins
- will 13" rims fit a 2000 civic DX coupe??
- those with momo hub on ek please help
- Cluster Bulbs OUT!!!! HELP
- Odd idle problem
- Happy thanksgiving!
- center console
- stick with d16y7 or swap ?!
- what did i do? used brake clean on valves now smoking!!! HELP
- Wierd starter Problem.
- need help//bad
- throwout bearing.
- Spider/tripod position on driveshaft?
- Another Nooby...with questions
- Introducing my '95 Del Sol
- Shady theives and hes on honda tech
- front ends screwy
- please help
- swaping rails and brackets
- Need a little Wing/spoilers help, nothing big
- pistons and rods for b20
- half shaft wont come out!!! HELP!!!
- CRX!
- 92-95 civic 3dr. si front and rear seats
- Problem with my brake sticking, ebrake doesn't fully release
- dirty injectors
- del sol front end conversions!!!
- intake
- help with fuse box
- Lower Control Arms
- Alignment problem? HELP! URGENT (PICS)
- em1 wiring harness
- not sure.????please help
- stock intake questions
- 2 trannys for 50$?
- Removing del sol front bumper
- MS. Clutch Relay?
- my Eg Si
- tie bar brace install
- eibach anti roll kit
- gunk comeing out of muffle need help
- Test Pipe fit? LS fit a CX?
- Looking for that Braided looking ground wire
- 92 honda civic eg hatch Si
- wtb fenders
- fog lights
- civic 96-98 coupe ej8 RADIO LIGHTS
- gsr carpet in ek hatch????
- car is smoking like crazy, help
- Flywheel Identification needed...HELP!!! =o]
- starting issues
- Camshafts and head parts
- EK3 OBD2/DLC connector location?
- 99 civic problems
- Any one been to the BAR at Huntington Beach?
- where can i buy cheap sir bumpers?
- Symptoms of bad 02 Sensor?
- GSR 93 hatch rod bearings OUT
- B18b swap in ek Idle problems
- weird electrical problem... car won't start
- Koni Yellow Shocks adj. spring perch quesiton
- Injectors
- need help with: putting a ITR cluster in a 92-95 EG6
- Hey need vtec help
- Whick shock are best?
- momo bracket and sliders .. help??
- hey has anyone put a s2000 brake booster?
- HELP! b20 delsol has issues with idle and gas!
- are my injector clips on the right order?
- cleaning valve train while head is still attached???
- Is it bad to mix brake pads (F/R)?
- k20
- stole foglight.. again!!!!
- Trans Problem...
- abs light is on can anyone help diagnose?
- honda civic
- I need some injector help for my B18C (what size)
- Bad gas mileage on my 98 ex
- WTB: Honda Civic VX Tailgate
- BOOST
- car problem
- b16a swap
- Idle problem when cold
- ECU Swap problems in a 98 civic HX
- fight with dad
- Steelies
- will i max out my stock 240cc injectors? ls/vtec setup?
- b16a
- tire pressure?
- ca broke down today!!!!!
- To Sell or Not?
- Drivers side window
- My Car Got Messed up
- camber kit for rear on ek hb
- Integra/civic integra suspension question
- My Car Wont Start
- hard brake lines
- Honda Civic HalfShaft replacement - Help required
- 92-95 rack n pinion
- 92-95 coupe/hatch front bumper?
- does a 2001 celica seats fit a 96 honda civic seat rails..
- mild head build on 18c1 or K20???
- MY MOTOR SINGLE CAM VTEC TURNS OFF AFTER A MIN OR 2... HELP!!!
- A little help please.
- suspension
- Do I Need To Change My Distributor???
- Code 54 - CKF - Crank fluctuation Sensor
- sidemarker question
- copy of 92-95 2door coupe EX illustrated index of door from helms or haynes
- power and manual window interchangeable?
- random click start no start
- why does my car smell like gas?
- 1997 Civic LX Dy16Y7 Vacuum diagram?
- Do you think its good or not
- LSD Question???
- Stage ___ clutch
- need help with dash 92-95 si
- No Spark!!! I've searched the entire site and tried everything I can think of, HELP!!!
- ys1 and usdm s1 cable tranny casings interchangable?
- Leaks - With Pics!
- Is my clutch to much?
- suspension
- quick question
- h22 transmission question?
- alternator belt flipping
- Fender Liner
- changing mileage 5k limit insurance
- B16A2 swap into a 95 civic CX w/ D15B7 non-vtec
- broken shifter
- What to do?
- fender and hood
- d16y8-b18a1
- Where Do I Get D Series Axles
- 94 style integra carpet in 5th gen hatch?
- Quick Q B16A1
- 99' EM1, is this factory or collision repair?
- whats the difference between the b18a1/b18b1
- Any aid in my suspension selection?
- ANY IMPORT WEBSITES IN MOBILE AL?
- exhaust question, please read!! need opinions on aftermarket exhaust.
- Snapped the head off my LCA bolt. Now what?
- Some Black Friday Deals for Cars I found
- Need help with exhaust.....
- sensor question?
- another fog light question
- Hondata help please
- 92VX can i use the engine harness for a Bmotor
- 95 ej8 cambers.
- twingling a D16
- d16y7 Injectors being 190cc throws code?
- Weird redline CX d15b8 VID inside
- d16/d17a1
- b18b (ls) swap 93 civic
- WANTED in socal 619 EG miracle X bar or 4 point bar to make replicas from..
- Problem when installing coilovers
- Swapping b18c5 into 99 civic coupe
- How do you swap an OBD2(civic si) into an OBD1(1992 hatch)? Do I need to convert od change anything?
- crazy high idle after cleaning throttle body...HELP
- throttle body spacers
- I need a set of acl race bearing
- Can i use OBD2a Injectors with a P28?
- what head is the p72-2 head off of???
- i need a diagram or something for my exhaust -1995 civic 2dr
- Greetings from Germany
- Is there any local honda forums?? i live in washington
- Intermediate Shaft
- Axel . . . .
- How do i tell what ecu my car is running?
- Alternator Question
- 97 dx tranny breaking? Checker at fault?
- swap
- Pulling EG dash alot of time ?
- FUEL CONCERN
- Horrible Gas mileage D SERIES!
- HELP with turbo and wastegate on jdm b16a
- Windshield install anyone sugest some tips?
- gsr swapped civic wont start??
- swap a b16 or rebuild d16
- B18a1 Combo Swap TUNE UP QUESTIONS?
- removing rear-view mirrors civic 98 hatch
- 93 civic not turning over
- carbon fiber hood
- ecu pins
- Is my headgasket gone again?
- 92-95/96-00
- Best place to buy ECU?
- Depinning OBD2a ECU plugs?
- Is a d16z6 Crankshaft pulley reverse threaded?
- new intake weird sound
- I'm changing head gaskets, should I get a Y8 Head? Cost? Other Parts?
- Beater Material? Opinions PLEASE.
- Help with cigar smoke/odor in car
- ? With E-Brake on 4 Wheel Disc Brakes
- difference in 2dr or 4dr hood
- prob with my windows
