View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Question
- Cam Shafts in Coupe????
- Civic wont start, injectors not getting power.
- GSR Leather in a coupe??????
- Rear Disc Brake Swap... HELP!!
- worn/torn front lca bushings?
- Colorado Connection??
- What intake for jdm B18C gsr swap in a 99 dx coupe?
- 96+ civic front sway bar difference
- My 92 Hatch has Died !
- broke down
- Motors running really lean... new cam = bigger injecters?
- coolant lines on back of z6 block??? where to?
- Probly a Stupid Question but need a answer:)
- 3" exhaust on EG
- HELLA HORN INSTALLATION ON 92-95 CIVIC EG H/B...
- i cant find a turbo cam for my z6
- D15b or b7?
- -- Clicking from ECU??
- Help with car in safe mode
- Need some help with a weird noise.
- Instrument Cluster Lights Out
- WTB 99-00 si fog lights
- odometer forward with vss signal?
- New HONDA Ignition Distributor. Ignition Module, Ignition Coil - From Taiwan No.1 maker
- unused car not running great
- Will a D-series AEM V2 fit a B16 EG?
- best brake set up for EK
- Check Engine Light!!! P0505
- weird clutch..... sometimes
- WTB: 92-95 Civic hatchback Mudflaps
- problem with parking brakes
- Leak in Passenger-side footwell: Any suggestions?
- Starting Help
- GSR Rear sway on ek
- New Paint, How Long To Wait?
- check engine shift light...
- having trouble wiring up my raybrig fogs in my ek
- are blox mufflers any good?
- any1 know of any good eg pic threads?
- 8k rpm on sohc
- SPEEDOMETER!
- Oil Pressure Light....
- when i bang gears my car jolts back and forth????
- hmm will it mess anything up?
- jdm seats?
- tb stop vtec?
- obd0 to obd1?
- bypass the srs light with after market steering wheels..
- del sol shift linkage question (URGENT)
- oil treatment?
- ooooook
- 96 ek with gsr swap
- jersey shop
- civic clogged fuel lines
- Took it it out on the road
- need help with swap B20 VTEC
- Rear Defroster doesn't work :(
- What is this?
- 98 civic ex swap HELP
- HELP!!! Car won't go into gear while its on
- WANT TO BUY: Integra GSR Sunflower Rims, Special Edition
- CEL 41
- Would It Be Good To Swap A H22 In A 98 EK?
- Which shifter bushings for B-Swap in Eg hatch?
- Metal shavings on transmission plug (searched)
- d16z6 with a d15b7 tranny....
- Rattle from drive side rear after disc break swap. 92 EG.
- friends em1 got hit and run. estimate cost on repair? broken axle.
- power steering.....?
- valve cover studs.........please help
- Nice, my check engine light is constantly flashing counted to 100 and gave up
- any egs for sale in southern cali
- need some help
- Fasn comes on and wont turn off
- Embarassing clutch release fork question
- exhaust ticket
- STOLEN: 1997 civic from shafter, ca
- obd-1 plug wiring diagram
- How to install rear fog light on EG6 SiR?
- help
- cleaning red sparco cloth
- Car stuck in first...
- P0450?
- wiring up v-tec....
- Looking to buy a 92-95 EX or SI anyone want to sell? (northern California)
- want an eg
- EJ1 swap exhaust question
- Enough is enough....need some help with my exhaust, stat!
- 15 x 7.5 38mm offset
- *Stolen* 1998 VSM Civic North NJ
- Help! Rear brakes dragging after shoe change! :(
- rear seats out in coupe... front higher??
- plate relocator? good or badd?
- 92-00 Flywheels the same??
- OBDI vs. OBDIIa, Do they used different ECU wires????
- will any engine harness work? 95 civic
- obx cam?
- Help changing color on stock 96 civic headunit?
- Burning Oil
- Power steering shuddering. (not a n00b)
- Interior removal EK H/B?
- for anyone looking for jdm parts
- where are drain bolts located on block of b16??
- NEED PISTON HELP!!!!!!
- need to know when motor is at TDC
- 98 Civic to 99 conversion
- Oil Change...
- no fuel and no spark
- Edelbrock Throttle Body Idle Problem
- HOW CAN I SUBSCRIBE TO THE FORMS
- clutch
- paint code.
- 93 civic, 95 black dash swap
- valve cover spark plug seals
- 92-95 Civic Auto To Manual Swap Question Not The Usual Questions Help Me Please
- JDMSHIT Spoon Copy Off Muffler
- Coolant Pressure, Cold Start
- Do ek hatch side scurts fit on 92-95 hatch?
- idle / battery voltage drain
- I belive master clutch cylinder failed. Or could I have blowen the clutch out?
- gsr muffler on 2000 civic si
- Trany problems
- civic not starting help!!!
- A/T to M/T Tranny Mount Problems
- what Front sway bar to use
- 92 Civic LX IDLE ISSUE
- 95 civic hb exhaust system fit the 95 coupe?
- quick header question- b16 vs GSR header into a EG hatch?
- will this fit?
- strange sounds whilst driving in rainy wheather
- -00will this work
- quick question
- 2000 Si Seats Into EG?
- Mirrors?
- Best K24?
- EG Hatch window rattle..
- Will B16 ARP Headstuds Fit on a B18 Block?
- any D-series oil pan on a 00 hx?
- new EK project...
- replaced front rotors+pads, noise from rear drums!?
- headlights turn signal bulb?
- apexi WS 2 or Megan Drft spec??
- Ticka Noise
- GSR brakes in 95 eg BAD VIBRATIONS when freeway braking
- oil spill
- Car Popping Out of Second Gear
- Any modifications needed to run 215/45/16 on ek hatch?
- Needing a chipped PR3 ECU for a JDM B16A
- Transmission Help Needed!
- what intake for gsr motor in 00 si?
- Trying to install ITR 22mm Rear Sway
- head for b20
- Civic dispute...
- password jdm headlight bulbs?
- Missing Splash Shield '97 Civic
- Rear Brake Conversion for a 97 HB..
- obd2 -1 wiring help PLEASE!!!!
- duckbill wing
- ls vtec question
- EK center consold in EG pics anyone?
- Help Me Decide Which Way To Go.
- del sol seats on a eg hatchback....
- bypass valve?
- Idle surges with clutch pushed in?
- OEM bushing removal without right sized punches...
- how to take out 6x9? civic coupe
- IM pressure question
- New Here B16 Question
- JET Performance Chips???
- obd II car throwing codes
- 96-98 fog lights fit in a 99-00 bumper?
- PLEASE HELP VERY SERIOUS INPUT NEEDED!!!!
- need help installing eg sidemarkers!!
- cant find a diy for installing a y8 IM. searched and searched
- reverse tail light wiring
- EG Rear Sway Bar?
- door locks?
- Tranny Conversion, idle problems
- hey guys i have a question
- Cam for d15b
- Leaky axle seals
- Need help as far as info on my D16Z6. Easy question...
- 00 SI ebrake cables on eg hatch?????
- maybe you know
- New Hatchback Shirt
- which cams to add to all motor type r motor?
- Weird Rattling NOise (EG hatch)
- secondary o2 plug
- Check engine light . B16. ek
- registration
- Copies of Name brand bins, jun, mugen, skunk, etc.
- 1993 Civic tire size?
- d16y8 ARP Torque specs
- D16z6 swap.....
- Code 20 and 36?
- Ebay headers - my personal experience
- k20 in to my 93 hatch
- Rear Power Window Drama...Help!!!
- exhaust question, help
- code 0111... anyone ever get this one?
- stock civic hatch cx 92-95 ecu??
- Adjusting my pfr...problem...?
- WTT.
- new 02 sensors still check engine ?
- 98 Civic EX Coupe Fuel Gauge Problem
- installing gauges???
- Need help
- EK Civic Headlight Problem...
- has anybody ever tried this manifold
- type r rear sway bar fitment help!
- would.....
- shift light help
- '96 temperature guage and fan not working
- My Windows wont move?!?!
- Quick Q...disconnect battery to reset radio code???
- k20 in 96 ex
- testing waters...D16Y8 for sale
- obd2 to obd1 problems
- rear trailing arm GURUs needed....please help my woes
- Exhaust Quesion!!
- K20A INTO EG6 - WHAT NEEDS TO BE DONE?
- Clutch question.
- car bogs a cold start
- H22A w/ ARC Box? 92-95 Civic Hatch/Coupe/Sedan
- Thought I'd share this
- EP3 rear seats in EK
- few questions - just bought a '94 eg hatch
- del sol engine mount question
- need help with gauge cluster
- really quick question
- C-West K Style Hoods Old School Stuff
- anyone got pics of 16" gt3 rotas (red) on a civic?
- quick D series question
- What is stage 1 and what is stage 2 and so on?
- my cluster fuse keeps going out...help
- 92 Civic Cam Gear Broke off while driving ?
- CEL: code 14, NEED HELP!
- Install a Vtec Controller
- how to remove paint on the interior
- There was a big article on race/aftermarket seat comparisons..
- towing?
- Please help a newbie find TDC alignment notch on D16Z1
- amperage limit fuel pump efficiency?
- Muffler
- my car idles funny only sometimes
- Who around NC can do a swap on my 93 civic coupe?
- b16a2 gerarbox in d16z6
- tick sound
- car is smoking do to high fuel pres what can i do to get it to stop?
