View Full Version : Honda Civic / Del Sol (1992 - 2000)
- nrg engine damper install (help) pic included 92-95 civic
- dx to ex...
- 92 civic ECU problems
- some general tech information upon brakes...
- might buy engine stand: how much does a b16a2 weigh?
- Dash Problems
- How To Remove Rear Windshield Wipers
- whats the difference between....
- transmission bolts stripped
- POST PICS OF OLIVE COLOR EG HATCHBACK
- Best Sites to buy a Steering Wheel?
- 92 hatch.. suspension options..
- :really lame question but is this beneficial??:
- can i change my obd2 to a obd1 with no problems.
- swapped eg question
- Are ITR driveshafts compatible with Si???
- ek fogs on eg,, seen it?
- Is an auto half-shaft same as a manual one?
- 92 hatch w/ b18b. I've got questions
- gsr cluster into ek, tach probs
- motor swap... need help
- skunk2 short shifter help
- 98 civic parking brake lights on
- Skunk 2 Intake Manifold (Y7)
- what exhaust do i put on?
- AEM short ram intake, good or bad?
- Shifting problems
- if turbo is added, which will i get more for my money, an h22 or a b18?
- CEL P0131?
- major dizzy problem
- obd2 b18c1 in obd1 eg?
- i need the 96+ comparison for all kinds of parts that are interchangable!! searched couldnt find it!
- Lost A Constant 12 Volt ?? Someone PLEASE HELP With Wiring
- help!: Clutch sticks at high rpm
- inside tailight eg hatch bulb number
- del sol headlights?
- Sensor Question
- Please point me in the right direction
- integra radiator in civic
- Throttle Body (Price ?)
- Omni Master cylinder Install ?'s
- RS*R exhaust for Turbo?
- Egine Bogging
- B20 MOUNT ISSUE FOR "EG"...NEED HELP
- How to identify an OBD1 Vtec Dizzy
- Brake Problem on EG
- pic of the master cylider
- Very impressed with exhaust wrap!!!
- auto ek hatch
- Code 20 and battery light
- jackson racing part help
- How much would you charge?
- B18C5 Integra Type-R Motor
- Axxis Ultimates, or should I stick w/OEM pads?
- !HELP! No cel,Spark,Fuel !HELP!
- 1998 Civic EX coupe question
- injector or spark ?
- Problem getting into gear?
- I need help with a part # for a relay
- ek coupe with b18b1.... how to make faster?
- ek cluster in eg?
- anybody every heard of this brand?
- HOW TO QUESTION
- OBD1 B18A from 1992 Integra into a EG hatch. Can i use DA mounts and axles??
- CIVIC EX POWER WINDOW DOORS INTO A EG? HOW DO YOU DO IT?
- Question about Dizzy and OBD-I conversion?
- engine shop in Orange County
- Will an 89 fuel pump work in a 93 car? are they the same respond quick please
- my new hatchback
- D16Y8 Redline
- left turn signal blinking really fast, but both work
- Turbo b16 bogging - please help!
- cluster not working?
- prepping car for paint
- Question about OBD2b ecu's
- problems at 4900-5300 rpm
- 96 Civic bogs down during acceleration with 1st and 2nd gear
- Question about tranny oil change
- help, i need some idea.
- weird CEL situation
- i'm retarded...
- 2000 Si suspension vs Type R
- CEL at High RPMs, then goes away after recycle the ignition
- ECU question trying to hook up V-AFC II
- stupid question...
- Who's got the best price on VIS carbon hoods shipped? to ny
- harder brake pedal feel
- Need help with spoon lower-tie installation
- B20b/z with B16a2 auto transmission?
- potential of EG
- under dash neon install (HELP)
- fuel rails / regulators
- Tranny Suggestion
- Greddy Turbo Kit on Del Sol
- what are the best cams for a b16a1
- Broke 1 piston, do I HAVE to replace all 4?
- AEBS-intake mani?
- Question about similarities and if not exactly same engine ??
- Del sol auto to manual question
- lbs/hp for 11sec track car???
- Loose Rear View Mirror!
- '95 Honda Del Sol
- New Engine
- ZC VS D16Z6 ! !
- engine warming problem !!!
- from a D16 to B18
- Y7/Y8 minime into a 97 EX
- eg trailing arm bushing help..
- 93 LX Problem
- flywheel
- 97 ex. Speedomoter jumps?
- safc question on a eg
- which turbo is good for the D series?
- Swapped H22A in EK hatch!?....
- Ignition fuse
- idle looping
- TDC code 8 after mini-me, I think everything was tried.
- pictures of your eg and ek
- why do my ac compressor make noise?
- Will eg coupe exhaust fit on a del sol?
- What just happened? I've been banned
- how hard is it to take out a eg dash?
- 2000 dx ac turns on automaticly?
- brake problem...............
- Why is my steering wheel still shimmying
- which sway bars?
- 93 hatch speaker setup
- harness question
- Will ls brakes fit my ek?
- stay with single cam or get an LS swap?
- d16z6 dizzy will it fit into a d16y8
- B18B a direct drop into an EG? (confused)
- d15b7 problem
- VTi motor in 92 DX hatch from factory, possible?
- wires and spark plug? diy tune up?
- headlight switch?
- anyone grind third??
- Honda makes their motors a year before the car is released, right?
- Throwing Code 19 and idling funny: Searched 10pages
- How to fit a d16a6(89Si) trans on a 94 auto?
- will a integra 94 gsr fuel tank fit an eg5 hatch?
- anti lock brakes on a 95 si?
- installing ls carnk to gsr block question?help.
- brakes went out, then suddenly worked
- codes 10,23,41 but still have vtec help?
- trouble shifting from park
- Passenger Side Lightning Issues
- bad idle, cel, HELP
- power steering n ecu help???
- flywheels which is better?
- window replacement
- help engine light ..
- What Proportioning Valve is this?? (pic inside)
- syncromesh question.
- trans assimbly NEED HELP QUICK
- anyone know how to take eg w/airbag dash board out of a car??
- H22 VS. GSR
- lookin at these 16''volks
- CV KEEPS COMMING OUT!!!!!!.....HELP!
- I need help for all the EK experts
- k20a3 in 97 EK good move?
- How much would you sell it for
- Ok, I am officially tired of this- nostart 93 civic d15
- d-series performance
- S4C Transmission Help
- Help me with my D15B
- rota slip opinion
- tried self diagnostic CEL did not flash but my SRS light flased this info 11 and 51
- anyone know what wire on an obd2b ecu is for the air fuel? theres no d14 and i tried a23 already
- better cooling fans
- The colyers. Family of car thieves in salem/keizer, OR
- changing brake pads
- So I have a 2000 Si in the driveway, should I buy it?
- Is there any way to tell between a B and D series tranny?
- .:: Save the SOHC? ::.
- help on installing pod gauges
- ctr pistons on gsr motor
- b-series to d-series??
- 250 HP Del Sol
- Air/Fuel and Oil Pressure gauges help
- 04 civic clutch
- Neuspeed Short Throw Shifter Install questions
- hood for an ek?
- wheel spacers who has them and what are thay good for?
- jdm gsr into 00 civic ex
- Winter beater Opinion
- Help: should I change distributor for no-spark problem?
- vtec problem
- coolant temp sensor
- humm... what does the brown plug behind the control console do?
- WTF? I need help with vtec solenoid
- 1995 Civic EX color door trim?
- 5 lug whats the point?
- Which Clutch to use on a B16 SiRI with Hydraulic Tranny?
- Civic Swap
- Rear Disc Brakes on 4-door Help!
- A/C Compressor Cluth problem
- FAIR MARKET VALUE OF MY 2000 CIVIC SI?
- Stolen Civic!!!!
- engine check light for O2 sensor
- i have an 2000 si with greddy turbo need help!!!! urgent !!!
- ls/vtec or b20/vtec ???
- yellow light bulbs
- CONVERTING TO AUTO TO MANUAL 90 (EF)
- 99 civic si valve adjustment help!
- Your Thoughts on Clutch/Motor Break In AT THE SAME TIME!
- Shift Lock..is there a purpose or need?
- Will 95 civic Test pipe/cat fit on a 98 Integra RS?
- how to change drum brakes?
- good light bulbs for EG?
- Idle or timing problem ,need help???
- white face gauges
- sqeeky clutch
- 95 coupe
- ignition problems...
- 92-95 Körbach Performance Frame Locks Installed
- Broken Torque Mount, bolts won't come out?
- anyone know the exact torque specs for the headstuds on a y7/y8 mini me?
- d16 rad
- low compression
- 5 lug conversion
- Looking for a good, quiet exhaust for 92 Civic hatch
- Tell me wut u think so far of my project...
- Please help me identify this bolt/screw.
- need help wiring ob1
- 96 dx hatch w/ b18b1 and gsr tranny
- white smoke from oil filter area. just installed oil filter relocation kit
- b16b engine swap..(diy)
- STOLEN EK in Los Angeles w/ rare rims!! 7/26/05
- Problem installing Tenzo R 17 rims on 2000 Si
- a poor civic hatch owner needing advice
- VTEC
- Quick help please...
- intake question for 6th gen civic with b18c
- Si/Ex Lip
- yellow head lights.... illegal?
- Lower tie bar
- help with autometer tach
- HEY EVERYBODY VOTE PLEASE ALMOST WINNING *15mins!!*
- High idle when clutch is depressed and car rolling?
- Eg for sale.
- ECU ?
- 99-00 civic si cd player, will it fit my eg with no mods? need help asap
- TRANNY PROBLEM!
- whats the difference between a SiR and a SiR-II
- Removing the Orange from tail lights
- Swapped in new Steering Column, Key won't turn
- Need Help Car Wont Start
- 11mpg stock d16z6 - help
- damn hood cant open!!!
