View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Problems with c/c disc common?
- Car only starts sometimes, and starts rough.
- DYI: In Dept 6th Gen Tachometer Installation Tutorial
- Rough Start/ Low Idle (Warm Start)
- Need some guidance selling Thermal R&D Exhaust
- Inline fuel pump help!
- Crispy Spark Plugs, why?
- 1993 Del Sol- No Windows work
- Yet another Fuel Pump issue
- Are These Teeth Messed Up? (CV Axle Gear)
- Car overheating,help please!
- Help me!! Rack and pinion down. All the way down lol
- Mini-me no power after cam gear f'ed
- d16y8 obd connector/ socket
- Valve Stem Seals
- mini me water pump?
- 99 ex coupe B16B swap!!
- 93 Del sol si smoke issue
- Clutch Fluid Line
- OBD1 in OBD2B Civic Distributor/CEL/Won't Crank
- Coolant Leak
- EM1 Exhaust Leak P0133
- 99 Civic EX Idle Problems
- How to tell if my 98 Civic has a Tec or Hitachi ignition system?
- 93 Del Sol SI Rear Caliper Removal
- Engine problems maybe?
- 1998 Civic LX code: 1362
- How Many Dowel Pins?
- honda civic ex 1999 Shuts off driving
- Anybody ever used Brake_Overstock (EBAY)?
- Crank issues!! Please help!
- Just took my civic to get smogged
- Oval single, or dual muffler on civic?
- Fast and Dirty Intake Manifold Removal
- B series shift linkage
- Another no fuel pump prime question
- ECT Sensor Removal
- B16 ALL MOTOR BUILD ... NEED ASSISTANCE
- how to check PCV is working
- 15x8 Offset question
- 95 civic LX 5sp 3000-4000rpm studder
- 94 si, intermittent stuttering around 1000-2000rpm (solved)
- left rear fender rubbing tire
- smoking after wet compression
- Welding Exhaust Manifold
- A/C HELP NEEDED!! Will R12 compressor from a 92 GSR work in an 00 Civic Si?
- Removing upper timing cover
- Vtec help
- When to replace lower ball joints....99 dx
- '99 Civic EX starting/power problem
- Voltmeter Wiring "experienced members only"
- Knock on the driver side in the Engine Bay area.
- 93 del sol si. Codes 3, 6, 7, 14, and 41
- d16z6 build. y8 head?
- '95 Civic DX AC Issue--DESPERATE FOR HELP!!!
- Intermittent power loss
- 95 ej1 electrical issue.
- 94 EX Warm Dies and No Restart
- Remove Oil pan w/o dropping exhaust?
- 00 em1 cranks but no start like if the compression went out over night
- B16A2 coolant connections
- p28 limp mode no cel
- Help Read Bad Spark Plug! (With Pictures)
- PS issue after B16 swap in my EK
- Civic HX (D16Y5) injectors in EX (D16Y8)?!
- 1999 Civic SI Parking Brake Issue
- Timing Issue on D15BY8
- Icu making clicking noise
- turn on problem
- 93 CX Hatch. Clicking noise, left A/C vent.
- Only firing on cylinder 4
- b20 ek
- oil pan gasket...can it be reused.
- vibration after front end work
- Radiator question
- D15B7 block, PM3-7 head. Which dizzy?
- D16Y8 manual, starter problem. Won't start sometimes. Hot-wire tested ok.
- stock Ls/vtec
- Pretty much at my wits with this fuel pressure
- A/C, low side EXTREMELY high! (98 Civic DX)
- B16a in a 97 EX, looking for some pointers
- Idle issues on a 97 civic lx
- 1996 Honda Civic DX Timing Off
- New user from Argentina, needin' some help
- 96 Civic Throttle issues
- 92 Civic brake dragging/front end shake
- Just bought civic, now I have questions about the drivetrain and others
- air/fuel mixture problems.
- Spark Plug Help! Porciline Turning brown/ missfire
- Going to build a turbo SOHC, d16z6 vs F23a1
- neptune rtp/ demon combo
- VTEC wiring/ecu
- crank sensor on a 1996 civic
- Ecu problems
- Need help after T belt
- 95 ex clock spring?
- Cluster swap prob
- obd0-obd1 problems/no spark/fuel/nothing!
- HELP!!!! SMOKING LIKE CRAZY!
- front headlight wiring harness question
- speedometer not working
- Battery not charging on 92 civic after second alternator! What could it be?
- Emergency brake
- sorry i sound like a noob but does anyone know how to install jdm emblem on a 6gen?
- Need help ASAP> no power to starter
- 92 Civic electrical issues
- What Should I Know about my Engine d16y8 Head with a d15b block?
- ek hatch brake pedal is siff but no prssure on brake lines !
- A/C Climate Control Cable Location.
- Another power window trouble question....
- Auto Trans Flush or Drain?
- Build Planners Block????
- Driver side axle for a B16
- 96 Civic CX Dome Lights - LED conversion
- 97 Civic with surging idle problem
- hood question!
- Symptoms of bad thermostat (open when cold)
- 95 Sol Swap/Build
- Trunk Gap and Leak
- clicking or clunking in brakes
- d16y7 compression numbers. after 357,xxx KM's
- Problem, Need some help "Fuel pressure"
- first time honda 96 civic ex p1336 code
- help with rpm problem
- is this a oem b16 head gasket?
- Intermittent Squeal
- Brake lights dont work!
- 97 civic with oil leak - which torque specs to tighten the head? 1.5? or 1.6?
- y7 surges when driving
- Overheating while idling?
- Y8 head mini swap
- Catalytic Converter
- shifting hard / rpm stuck at 3k / rattling noise
- '00 B16B Misfires.
- What distributors are compatibile with a 2000 civic ex?
- Can somebody tell me what this is???
- 92 hatchback re-wire everything??
- 96 Civic - slow cranking
- 95 del sol si idle issue
- b16b intakes....?
- 98 Civic EX b16b idling problem
- EG gas tank question
- Help with exhaust manifold
- CLUTCH JOB
- EK Fuse #44 Shorting Problem
- S20 tranny spec questions..
- '97 Civic - Speaker Wiring Diagram
- Question about Seats
- 1996 Honda civic engine wire harness unknown connectors
- Does my canadian 99 civic si engine have VTEC?
- Clutch problems, not engaging when cold.
- ac question need some real answers
- 1996 Civic DX running issue HELP
- oil leak drivers side?
- EG ebay resonator testpipe to straight test pipe????
- PCV Valve Broke.
- p1336 code on a 96 ex
- 97 Civic HX - running pig rich
- ECM confusion
- HELP!!! System Failure 1998 civic hatchback
- Racing Seats
- P0505 on 98 EJ8
- Best ways to tweak HP gains out of a 93 DelSol?
- Another Windshield Wiper Question
- Apparent Head Gasket Leak
- Mannybus Del Sol Build
- 3 wire idle air control to 2 wire? Without swapping intake manifold.
- 00 civic lx automatic with CEL code
- New honda owner.
- No tail lights, running lights, dash lights, etc...
- OBD2B B16A2 into 92 VX swap questions
- multiple codes help
- 2000 Dx sedan auto trans replacment HELP
- Car jerks at about 1500 rpm all gears
- car has power but will not crank
- 99 obd1 built civic randomly just shuts off. then wont start for many minutes later
- '98 Civic Sedan Trailer Hitch?
- Silly question about top passenger mount
- 99 Civic Fuel Pump fuse keep blowing 15amp under hood
- Lip+grill help
- HORRIBLE GAS MILEAGE!! HELP!!
- Clutch Squeak Please Help!
- overheating help
- EG Air Mix Cable? HELP PLEASE
- 93 Del Sol - Need help installing an aftermarket keyless locking system
- '94 Civic DX Brake problems
- looking for nice catback system on stock honda help!
- Replacing A/C thermostat without removing evaporator
- 1998 Civic EX 4Dr Auto ABS 51 Trouble Code Problem! Help!
- D16Y7 Engine Noise (Help)
- Rebuilding CV half shaft
- 2000 Civic Si with older cluster
- how does KYB GR2 ride quality compare to OEM/Tokico Blue shocks?
- Door locks on Civic not working sometimes
- Symptoms of a clogging cat on a civic?
- No low end!!! Knock sensor
- 92 civic cx hatch help ! (wont crank!)
- idle / ac problem... brand new iac
- 92 civic D15B7 Dies when stoping hard
- 92 Civic DX AC Question
- Eg Civic, 4x108 Wheel boring?
- blown strut mount?
- European 99 Civic - Back Up fuse questions
- how do I pull the top half of the timing cover without pulling the valve cover?
- 97 civic won't start
- never ending sedan build...need help!
- BOLT SNAPPED WHILE REMOVING LCA! NEED HELP!
- question about keys.
- seeker wing for ek
- 1993 Honda Civic EX Exhaust Manifold Gasket
- 94 honda civic will a zc motor pass
- DIY EG/EJ floor mat eye loop stay
- Need information on compression ratios
- OEM vs Ebay style fog lights
- Gear ratios?
- oil light on my Eg
- Mileage help :)
- Thermostat housing ground wires
- 1992-1995 Civic hatchback rear speaker
- Headliner foam backed fabric replacement
- Check engine light when thermostat inserted
- 93 Civic EX with charging issues
- can I use a p30 ecu on my 1990 b16a?
- Does the dashboard harness from a 97 del sol auto fit a manual?
- New exhaust civic dx
- 96 Honda Civic Hatchback CX Headlights
- 94 Civic CX starting issues
- Throttle cable/gas pedal bracket help
- Who wants to help me fix these CELs (B16a2 in 94 civic)
- overflow MYSTERY
- Connector release puzzle
- Starter issues
- 97 LX Cel 0/solid & no spark
- Can a 2.5" collector be mated to a 2.25" test pipe?
- s20/s40 frankenstein?
- Anyone DIY an Automatic Transmission
- oil leak from head gasket?
- Gas mileage?? 1998 civic hatchback HELP!!!
- horn not working?
- Will a 2000 civic automatic transmission fit a 2002 civic?
- my del sol hesitates and stalls
- 99 civic/lsv swap - hunting idle after head gasket job
- 93 CX Hatch/swapped Z6 -- Slipping BRAND NEW CLUTCH AGAIN.
- Automatic trans preventative maintenance
- Vibration when AC is on
- installing Si one piece stamped LCA front lower arm on a DX?
- OMG Squealing Sound
- what is si rear brake conversion worth?
- 97 Civic won't start
- Could it be my CV Axles?
