View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Gasket sealant
- Help this guy out
- Tranny question?
- post your VSM EK's!!!
- HELP!!! INSTALLING A D15Z1 OBD1 ENGINE INTO AN EK CIVIC DX OBD2 SHELL !!!
- whapiping should i use on an axle back exhaust.
- Suggestions For A B16a2 Swap
- 99-00 climate control swap into a 97 EK
- GSR OIL PAN ON B18A1 BOTTOM END... HELP
- About my post.
- mini swap
- My car feels like it has no power!!!!!!!!!!!!!?????????
- got a ticket today...Cal ref station help
- 98 ciic shaking steering wheel
- Anyone in the area?
- overheating problem 92 cx
- Some pictures of my EG.
- gauge cluster swap
- SRS Module Reset 96 Civic
- today was such a good for me
- h22a1 swap
- car running real rough under 3k rpm...
- will a prelude vtec fit in a civic hatch 1992-2000
- eg sedan front end on eg coupe
- idle messed up (up n down) only in park and neutral - 96 Civic
- 00 civic hb power steering removal
- h22 ek
- 1995 Civic DX hatch m/t speedo doesn't work
- New NightHawks not to impressive
- amazing stunt!! civic driver survives after volcano drop in hawaii!!!
- 94 ls block alternator bracket ??? need help
- what o2 is closest to #1 on b16a?
- Im a new owner of a 92 civic cx hatch back
- Code 3 on '92 B18C1 hatch
- **PIC Bearing worn funny?
- Not too sure what this is..
- need help in tn/ nashville area
- MAP sensor and VTEC.
- why isnt the FAQ pictures workin
- Wire problem with rear taillight
- ej1 electrical problems gahhh
- injectors
- what is the Spark Plug Wires order on the dizzy for a d16
- Rear Lower Control Arm Mount Replacement
- 95 civic w gsr swap having trouble with main relay
- 96-00 mini me
- 95 del sol died while I was driving it. Distributor rotor not spinning what do I replase?
- Stainless Steel Brake Lines
- Civic EX ecu in Civic HX Will it work?
- WILL THIS FIT ON A DEL SOL
- 1992 Civic
- How to tell if tranny is good or bad
- Does anyone have a 3rd brake light for a wings west CTR wing?
- DC header, what cats will fit?
- EG Motor Swap Tool List???
- GSR Inake manifold questions
- Need some help figuring out what this tranny is from...
- Kteller magnaflow muffler???
- more re: CE 14, IAC Valve, and where is my post?
- IGNITION SWITCH? CAN I USE A AUTO ON A MANUAL? OR A MANUAL ON A AUTO?
- Complete motors?
- help engines codes
- Lowering spring=New shocks??
- replacing a door
- Integra Cluster In An EG??
- Quick question, replacing radiator
- Serious Steering alignment issues.. Expert opinion required
- How do I get to post in the classifieds?
- Switching from Si to Hatch
- ebay Turbo
- For Sale
- Relays
- 2000 Honda Civic won't start.
- CAR BOGS, please help!!!
- 99-00 Climate Control into '96 Coupe?
- Replacing Thermostat. . . Drain Radiator Fluid? . . . Or leave it in?
- from power steering to manuel steering
- Guys, uhh.
- Energy suspension- polyurethane shifter bushings are they ever black in color
- Which header to use on the swap....
- CEL code 20 and code 23 after build..
- Air Bags Deployed, now what?
- What to do with a 93 Dol Sol D15B7?
- B16a bogging!! Need help!
- D15B turbo
- Ecu to use
- D15b ecu?????
- Civic Vx or Cx? Better for Ls/vtec swap?
- eg civic
- Gas Strut Supports For '98 Civic Trunk
- tranny d16z6 questoin
- LS Integra wiring harness HELP!!!
- wrong size rear lower tie bar?
- Around Lemoore
- Transmission Noise! Not gear grind!
- boosted b20/ls vtec awd or h22 boosted
- Loud noise passenger side???
- how much to replace clutch hardlines
- speedo prob.
- 94 Civic dx question
- jdm fanatics!! is there any difference..
- is this solder still good???
- Need help
- idle problem
- What seat do you like better, DC2 JDM recaro, or DC5 JDM recaro
- sup guy just wondering
- civic swap gsr problem????? HELP!!!!
- need info on civic swaps
- Best way to modify delsol shift linkage to work with swap?
- 91 integra XSi????????
- Rear Disc Brakes
- pic?????
- d series rad hoses thickness = b series rad hoses thickness?
- Please Vote
- b18 swap using d16 ac compressor??
- Just installed rear speakers...
- aftermarket radiator.. hose issues..
- putting on header..d-series step/check
- D-16y8 help...
- wheres the extra weight at on a si?
- 95 Del Sol Si o2 senser Question
- What it is Exedy OM or Stage 1?
- 00 ek lower rear control arm bushing part number, help please (pictures inside)
- Install power steering on a 1997 Civic CX 3 door
- si cluster swap
- lsvtech
- Climate Control Removal 95 Del Sol
- puddle of water in passenger foot areaa ?????
- Inatke manifold Help!!
- check out this cool auction
- Dex cool accident
- 2 Canister Exhaust,But who will win?
- 99 civic dx hatch wont start!!!
- Can a d16 exhaust mainfold fit on a d15???
- Question
- Increase throttle response on EM1
- all motor d16z6!!! IS IT WORTH IT
- will these bulbs fit?
- 99 EX Trunk Light Problem
- Cluster question (again)
- rebuilding engine for turbo
- anyone ever seen these honda access corner protectors????
- IACV....but want to confirm
- A quick D-Series Swap w/ pics
- Clutch pedal squeaking...
- vtec head
- what gasket to use or is this possible? lmk
- piston question
- ABS front brakes v.s non abs
- Short shifter help
- Dist. Timing and Phearable.net Ecu
- Speedometer/Odometer not working right...gas mileage dropped too????
- Chad Costello, i need to contact you!
- ECU Gods I Need your help!!
- engine vibration, new shock mounts and ride height
- In need of a switched source for HID's in 95 civic
- Another write up on auto conversion/b-series swap parts info
- Will an EK coupe side skirt fit the hatch?
- Suspension Query
- Is this a stock DC one?
- Leak in the car on the carpet...
- Few Questions After a D15B Swap
- wtf
- z6 swap help please
- b18c5 spark plug wires on a d15b7?
- Brakes quick question
- 93 civic h22a just swapped....need good motor mounts...guys??? good price?
- need help with the key tumbler
- Lil update. And a thought to ponder about your honda.
- VTEC solenoid gasket for B18C1
- Hard to get into 1st when cold
- spoon style mirrors have a question on them
- foglight switch
- eg6 jdm headlights
- BRAKES WENT OUT
- Pic Request: Hayame exhaust installed on any 92-00 Civic coupe!
- EK cluster convertion problem.
- NEWB HERE!!
- sound deadening Q's- Searched
- ek window visors
- complete h22 swap!
- 2000 civic getting horrible gas mileage
- Header
- will a b18b hydro tranny bolt up to a obd0 b18a
- blinkers dont work?
- b18c1swap in eg. Does it have to be custom exhaust?
- Leak in 96-00 Hatch
- coin pocket ???
- GSR cams on My B16A Head/Motor!
- Turboing a Sohc d16y8
- Help! Alternator Problems with my Ej1 with a d16y7..... *Searched*
- vafc diagram
- Boom
- Abbreviations
- Shifter wobbly... help? why?
- what is this ek shell worth? honest answers please!
- will 90-93 teg spindles fit on a EG?
- wont go into gear
- Accelerator kill?
- How can u tell the difference Between the GSR Cams and B16?
- has anybdy heard of using 5 lug prelude suspension and retrofitting it to a eg?
- brake swap
- Question about CTR Pistons in a B16
- just wont start
- doing a motor swap and i need help
- VTEC doesn't kick in until 6200rpm?
- Where to buy brand new Steelies??
- What is the easiest way to change your water pump and have ac in your car to? SOHC motor.
- HELP NEED TO KNOW????
- sir killing gas
- What do you think the ride height is?
- Rear eg hatch speaker wire location with pics
- weird code on chipped p28
- my car is throwing a code 12
- how do i fix code 21?
- 99-00 OEM Fog Light Wiring Question (searched)
- header question
- Need Help Quick.... Spark Plug Cover Bolt Broke... Car Driveable?
- does a d16a6 clutch/pressure plate/flywheel setup work for d16z6?
- Blown Head Gasket??
- fixable?
- EF Exhaust on an EG?
- suspension for start?
- chipped ecu questions
- B16a OBD1 into 99' Civic swap with some "hiccups"
- intake manifold swap on 98 dx with 1.6L
- Coolant temperature sensor died?
- GSR leather seats in a DEL SOL?
- b18c axsles
- help ebay CAI
- Injector Clip Voltage
- Trans swap time
- OBDII B16 firing order.
- question about part swap
- EG civic ex rear ABS disk swap into EG civic dx non-abs
- vis or seibon? civic92 hood cf?!!!
- intercooler questions
- Apex N1 Suspension?
- help wanted
- California people!!!
- dry ice, how much?
- Brake Rotors
- My under dash wiring is a complete mess, please help?
- cheap ebay headlights question. thanks for looking.
- 95 ej1 over heating
- tachometer
- hid or fog lights installation guide?
- Smoke Everywhere
- help with rhd door panels
