View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 12V Power Source Wire???? COLOR???? WERE ARE THEY?
- my 00 si turn signal/hazard lights dont work fuse looks good? what can be worng?
- inner trunk carpet/kick panels out of a 98 4 door, will fit in my 00 si?
- Suspension question
- Mugen Temp
- how to measure master cylinder?? (MC upgrade Q)
- gauge cluster problem.
- need help ! should i doitmyself
- need door inserts
- Lightweight battery Q/comparison
- honda guru's please help
- 1/4th Mile comparison of EG Hatch and EK Coupe
- Thudding sound near clutch pedal after my swap...
- Gsr endlinks on Ex LCA w/Si front swaybar
- The amazing exploding del sol!
- Does a jdm EG6 gauge cluster just plug right in with no rewiring?
- Best place to find a headliner for a 92-95 civic SI hatch???
- Valve Springs in 2nd Gen JDM B16a
- HI having problems after Swap
- b16 swap question (technical)
- How do you modify an 93 si shift linkage to make it fit to any B-series swap...
- ignition wire..
- question on installing caspers shields
- d16y8 intake mani on a y5
- new body style civic si whp/ability from a roll
- 92-95 Civics in Jap land.... were there airbags?
- NEED HELP factory fog light?
- D16Y8 JRSC question
- EK SIR front lip = EG
- Omni Rear Shim Kit
- Subframe damage???????
- fuse box help
- a/c bracket pieces
- 2K Civic EX Max Mileage
- crazy idea, accord motor in 91 dx crx
- CLIMATE CONTROL QUESTION
- Lighting in Gauge cluster.....
- not sure what this is can someone help me out
- Car Cover
- PLS run this civic VIN at carfax or somewhere...
- mini me HELP!!
- question about hinged strut bars
- Greddy Timing Belt
- coolant overflowing...
- Couple questions - New 92 & JDM D15B?
- new part number
- car feels like its struggling
- B-series direct bolt in to the EK body?
- o2 sensor question...
- 99-00 si front brake conversion on dx
- c pillar bar work?
- 95 Civic HELPPP!!
- Engine Swap Progress Pics (56K, Grab a Snickers)
- 02 problems
- Cluster shift light
- can you use any lexus HID lights on civics 02 and up ?
- Dash Screw Info Needed! EG
- Squeal at high RPM's (searched)
- Momo hub 4 sale
- EG Optional Audio Console
- B16a Sir II Swap into a 93 VX
- having problems with cable shift linkage in hydro car
- CEL comes on after few minutes of driving
- Are these too stiff? Zeal coiover.
- Anyone have opinions on Cusco LSD?
- interchangability of b-series pts
- after changing brake pads
- Give a noob a little help
- *CAI* this a good deal?
- rear main seal replacement and clutch
- Brakes dont work HELP! ! !
- Will an apexi n1 silencer fit in a greddy evo muffler?
- magnaflow oval what size to get?
- Civic noob needs Weber help 4 d15/40DCOE
- Koni Yellows
- Chasis code...
- help a newbie build a single cam..
- Conversion Harness Supplies
- Problem with OMNI Power Camber Kit
- Yet Another Awesome Exhaust Question
- Help on fitment!! With my EK..
- I WANT SOME HEADERS! ...
- b16 or b20
- Clicking noises...
- Best junkyards in San Diego?
- Swap - Advice / Referals on where to get a good swap
- Body Panel Separation
- selling my del sol si with b18c1
- B18C5 vs B18CR
- Help getting a air bag code
- Ordering a bunch of brake parts. Best place for one stop shopping?
- has anyone dealt with wheeloptions before?
- no vtec engagement, no cel's.
- Best 1/4 mile track
- 99 Civic question
- block guards? do they work?
- EG suspension setup advise
- itr 5 lug to a 99 civic ex
- just installed the jdm sir gage cluster..
- 97 civic ex - Lock Actuator replacement front passenger side
- ECU PINOUT (96 honda civic ex 1.6 sohc vtec (obd2a) to b18c1 1.8 dohc vtec (obd1).)
- How to check PMs?
- TD 84 Distributor for B16a SirII in OBD2 Car
- CEL 14 IACV, Im kinda lost
- Concerning Wiper Fluid Dispensers
- Relocating Map Sensor
- Ok planning a Mini-me swap
- 1995 civic ex vtec injectors please help
- Axle problem help??
- bilstein HD shocks...already searched..need more opinions!
- HIDs on halogen lamps
- A lil help finding a part PLZ...
- I got a ? about exhuast
- replacing underhood fuse/relay box
- cat burned out again
- GSR Front Swaybar on an EK hatch
- Rear tie bar?
- I'm really skeptical about this, what are your thoughts?
- jdm b16 axle wont fit...
- Key Inserted, Door Alarm
- Check engine light?
- Del Sol Pistons Question
- MSD ignition
- Replacing Door Hinge
- 97 civic axel replacement
- PHASENINE.COM
- Interchangeable? Hood and fenders
- stock cpmpression ls vtec?
- Where to Buy Complete D16z6???
- Soshin USA
- Serious Question: CX motor into DX coupe....
- Car Problems
- factory instruction on adding A/C
- 98 EX/99 Si swap problems
- OEM EG Strut tower bar how too
- whats a good upgraded cam for d15b vtec
- B18C EG Swap (Wrong Mounts?)
- Civic EX and CX arm...
- WIDEST spacer i can use with arp Extended studs???????????????
- new gal wants to know about her car...
- lips for 96-98 ek's?
- I need opinions on this hatchback
- How come i cant slam my Hatchback?
- Increasing the compression on the d15b? Would it be worth it?
- B16A2, SKUNK2 STAGE 2 CAMS
- What OEM Honda wheel is this?
- quick question
- anyone open up their Denji's???????
- b18c1 swap into 93 si hatch
- ignition problems...really need some help
- speakers
- race on the 110 freeway, south pas area against silver ek
- bad starter
- Air Conditioning for civic cx
- Painting Dash
- Transmissions are swapped! Just one small problem
- 94 civic engine head swap question
- Ok really bored today and did a burn out
- Clutch is shuddering
- are these headlights brighter than OEM? for 96-98 EK
- GSR Swap Done!!! Throwing Check Engine Light....
- is my radiator working or not?
- d16z6 tranny on d16y8 motor, which starter do i use?
- My short shifter is getting really hot??
- anyone ever call CHP about vin numbers????
- When I Apply Vac to Booster, Wheels freeze
- How much paint needed to cover?
- Lock Problems.
- Civic Vx injectors the same cc's as b series
- How to take gas out of your cylinders.
- is there a supercharger for 96 civic LS
- Q\ Are the cam gears the same for a sohc si and cx
- Guys please help.....this is really pissing me off!
- BUMP STOP question!!! on ur suspension
- what car do d16y8's come in?
- Energy Suspension Hyper-Flex kit
- back deck
- HELP I NEED ENDYN BREATHER KIT INSTRUCTION. i LOST MINE
- vtec not coming on when it should.....
- gsr swap what should vtec be set at?
- Y7 to Y8 tranny upgrade????
- Name this mount!!
- Need suggestions for camber kit
- remeber the 4g63 hatch, now its for sale...
- 98 Civic EX Tranny Problem - Got engine codes - please help
- Props to Poison!
- Drop Forks and drop lca's?
- Where on earth does this strut come from???
- QUESTION? ABOUT,dual bent short throw
- how many lbs do front stock disc brakes weigh? *92-95 civic si cdn version*
- Amber lights in cluster...
- D-series motor swap. Online or Bay Area
- New Distibutor Problem
- FUEL PUMP
- Looking for DIY How-To 96-00 hatchback water leak fix
- I Need Help: JDM Type R 5 Lug Conversion!!!!!!!!!
- best rim and tire size.
- Stock B16a2 Si whp? (already searched)
- How would I go about fixing this hole?
- *** Help installing OMNI COILOVERS!
- ITR sway bar
- I'm going to be getting an EK soon, can you give me some info...
- mitsubishi turbo to d16y8
- point of aftermarket lca
- Motor MOunt PLEASE HELP!!
- I need help!!!!
- 94 LS into a 00 SI
- Clutch Replacement, pilot bearing also?
- jdm vs usdm distributor?
- Sprint Hart Dunlop Cp-r's 15x7.5 on an EK: Widest tire possible?
- insulation/muffler question????...PLEASE!
- can the d series handle it?
- 5 lugs disk brake conversion which axles to use?
- Is this product any good?
- Does anyone make a front lip for del Sol's?
- Where to get engine code reader????
- Hasport Hydro to cable tranny conversion...
- BROKE SUNROOF HELP
- CX motor cranks, but wont start need help
- obd2 b16 engine question??
- *urgent*
- Check engine light and tranny
- hp and whp ls vetc
- p08 auto to manual conversion help!
- HELP! eg-gsr dying at every stop =(
- d16 vtec
- Cluster Needles Dont Work.....
- honda civic hatchback.. H22 turbo or Gsr turbo??..
- Carbon Fiber Hood ....help Needed
- Window Rodery ?? Need one 99 honda civic dx
- HOw do I modify an automatic p30 ecu to manual p30 setting?
- EG Hatch with this set up?
- Can Someone Please run car fax for me?
- Power steering removal - The right way?
- Low idle..Searched. Please help.
- GC Coilovers and KYB AGX Problem
- Understeer/oversteer problem with h22 in eg
- Hood Latch + hood cable *urgent*
- final drive swap ?
- 98 civic - help!
- Throwing CEL CODE 54. How do I fix it.?
- can I use D16Z6 sparkplugs and wires on a B16??
- Specs on Civic 4-door
- Alternator Replacement....How hard is it????
- cel flashing when i check it, doesnt stop, constantly on HELP
- D14 motor with y8 intake manifold - which cold air intake?
- carbon fiber hood fading how to restore????
- Common oil leaks on 95 Civic?
- any good powdercoat shops in SOCAL???
- i need help???
