View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 95 Civic sedan front end questions
- 2000 b16b...OBD IIa OBD IIb
- EG6 SIR-S rear interior conversion ??????s
- installin clutch difficulty?
- Transmission question . .
- Non abs conversion
- problem with radio
- transmission trouble
- b20 turbo
- How to put metal rod back into trailing arm bushing?
- MFactory Sway bar install problem
- Brake Pad Orientation ?
- uuuh oh
- Ex headliner in Eg Si????
- Having problem with white smoking coming from the exhaust.
- What Paperwork Needed when Buying a Motor?
- coupe light on hatch?
- How do I smog my car?!
- DIY install Coilover 00 CIVIC ex
- where do these wires go??
- Modified exhaust is illegal?
- Exhaust Bolt Stuck, what is PB doesnt work?
- Please Help Me
- can some one tell me where i can find ppl on here selling motors
- omni valves VS. OE valves ?
- 97 CIVIC WITH 99 SI B16A2 SWITCHING TO JDM GSR OBD2
- One more Problem.....
- A/C repair
- reset abs light on a del sol 1994
- H&R springs for EK
- Need help with 96 civic
- how much should i expect to pay for rod/main bearings labor?
- Head Gasket Kit
- rebuilding b18, what torque is main bolts?
- y8 head internals in a z6 head?
- OK need help on cel
- Will an EG axleback muffler fit on a 99-00 Civic Si?
- Suspension Questions
- EK motor question
- any1 tried putting 99 si tail lights in a del sol?
- B18 and tranny into 99 DX sedan
- Wiring IAT directly to ECU?
- Did Honda sell the civic Type-R in the USA or just Japan?
- injectors
- should i buy this high mileage civic?
- CEL situation
- 97 civic auto to 5spd wont start with 5spd ECU
- Running two fans on one pin??
- valve question
- b-series ac bracket question
- my koni yellows
- Paint Code
- rear brake caliper bolts
- Forged Internals
- mugen parts
- Fuel Pump
- 5th gear help
- 98 b18b swap in 97 ek, High Idle
- timing belt cover for d16z6 head and d15b7 block?
- electrical problem with a/c, mirrors.
- anybody know where i can run engine serial numbers?
- B18c5 or b18c1??
- VX or CX
- MONSTER MOTORSPORTS WINSTON-SALEM NC
- SK TUNING (BURLINGTONG NC)
- Clips Help???
- stock p30 fuel on p28 ecu..
- Getting rid of stock intake nonsense
- NEED HELP?????
- B20Z Starter questions... Help!
- anyway to get engine codes without light??
- 96 Civic EX D16Y8 FITV Plug problem
- Thermo Causing Heat?
- Type R swap Problem (need help ASAP)
- which motor mount insert?
- How to Remove my 98 sedan chrome window trim. HELP ASAP!
- b20 in EK hatch
- PCV/black breather box question
- EG6 Civic 92-95 rear brake question?
- Car Problem
- Orlando, Windermere, Ocoee... Whats the scene like...
- starting problem
- h brace
- why axles break easier on the street than the strip??
- what Taillights fit?
- car dies after warmed up, no cel on
- b16a2 without 02 sensor = bad ?
- converting obd2 ecu from auto to manual
- Need help with Blox intake install on GSR
- DAAAAA QUICK Q ek b series axles
- Pulling a trailer?
- Headlights
- 300 bux to spend
- tranny
- What Trannys will work with my hx b16(2000 si) swap
- d16y8 into 1995 civic
- B16 Cable Trans. VSS Wont Come Out. Where To Fill With Oil?
- b20 swap got some Q's
- Misfire
- Want a loud muffler for cheap, whats a good brand?
- Quick headlight bulb question
- Dipstick help :)
- removing cruise control
- Need Wiring Diagram for Ek9 Power Folding mirrors
- valve head n knocking noise...
- integra exhaust on a del sol
- 94 coupe speakers
- O2 Sensor on D15b and D16z6...help me out
- hids?
- i need help with my eg. can get no interior lights to work
- Power lock Does not work
- IM TRYING TO GO ALL MOTOR
- HELP! WHICH SENSOR IS THIS???
- D15B????
- power steering leak help please
- Do window visors help with wind noise?
- charcoal canister.... wtf does that do???
- relay switch or something else?
- EX door panels into DX....
- Major problems after b18b motor swap.
- turbo flange's which will work
- PS problem with b18b swap-Need Help ASAP!!
- 4-2-1 headers looking!!!
- B16 Tranny Problems
- Quick question about my Head + Cams
- Cost of 99-00 front setup on older civics... 96-98?
- Some progressive help please? lol..
- Rear shoes replaced - now rear wheels will not spin freely.... why?
- B16A2 with high compression + nitrous?
- quick response/better ratio steering rack for EG?
- b16 radiator
- D-Series Transmission not catching 3rd Gear AFTER A 4th GEAR RUN!
- b16 turbo question???
- help, nothing in the interior works
- integra lower ball joint same civic lower ball joint?
- bronze valve guides
- im a newb with some questions..
- tires
- Help!!! Can't get started after tune-up was performed? Weird
- Delsol understeer
- CEL Code 54
- del sol front end on an eg hatch?
- 94 cx with d16a1. have some questions
- car just dies
- JDM lovers can you help me with a price quote?
- Does ITR Axleback fit ek hatch?
- Drive By Of My Sol With No Muffler
- My B18B Motor / B16A Tranny Q&A Thread
- shifter problems
- My First Car I need advice
- New head bolts are necessary at rebuild !?
- Del Sol Roof?
- changing to obd1 ecu
- 94' Civic DX Hatch Mods
- Correlation between AC and air/fuel mixture - anyone else notice this?
- si wing brakelight wiring harness?
- Need Help Changing Piston rings
- Headlights Burning Out In EG
- Sour smell from exhaust?
- Front Lower Control Arm Bushing needs to be replaced, polyurethane bushings?
- Carbon Fiber body panel?
- Good replacement for OEM Alternator 98 ex
- Final Drive of 99-00 civic misconception
- I WAS TOLD THAT REAR RADIUS ARM RUBBER BUSHER ARE GONE, WHERE TO BUY AND CAN I CHANGE THEM BY MYSELF
- problem with water leak when turn the A/C on
- obx lsd problem
- can bad water pump cause therostat not to open
- Q: can i put Integra coil assy. to '93 D16Z6?
- What Tranny Parts Am I missing??
- engine swap question
- Stock alarm?
- OVERHEATING!WTF!?!?!?
- question! 96+ civic dx hatch w/si floor harness for power window conversion
- EK stock axel back same on coupe ex and hb cx/dx?
- 96+ Civic cup holder
- Spoon Replica Exhaust
- b18c swap help dont run right PLEASE HELP
- Turbo D16Y8 OPEN PCV Box OK or NO?
- Si guage cluster in DX hatch
- ek fog lights on eg
- check engine
- What are the names of these car parts, and what are their worth (PICTURES INSIDE)
- DC Sports Headers AT or MT
- how to set ignition timing on an OBD2 b16b? HELP QUICK PLEASE.
- THROTTLE CABLE
- Smog Time! Two check engine lights!
- WTF D15B Overheating
- Headlights...
- will 92-95 civic coupe cat back fit.
- HELP!!! my rpms on my cluster are slow from 3-5 they act weird until vtec!...
- oil leak in spark plug well #1 , what are consequences?
- what engine comes in the 95 dx
- HIDS Only Work When High Beams are On??
- DISTRIBUTOR o ring
- lagging problem
- civic type r gauge cluster install.
- obd2 dizzy help
- WEIRD SH*T! help!!
- driver side oil leak, seal or oil pan gasket? (alot of oil)
- Camber/Caster Alignment
- best headlights for a 97
- ? about motor and tranny mounts.
- p28 with b16?
- how to wire in primary o2 sensor
- whats this Reflashing ???
- o2 sensor question
- Speedo Cluster Amber Bulbs
- 99 ek
- Distributor Seal/O-ring
- d16-t vs B16
- sparkplug/wires
- S2K guage cluster
- are all 92-00 sohc civic water pump inlet pipe the same?
- My Passenger Side Window not working
- Running rich, poor gas mileage
- ticking noise when i turn my car off
- Car & Engine Harness for sale for a del sol????
- Ignition help
- make 95 dx motor as fas as possible
- how do you get the plastic door protectors off
- Module
- need help locating speed sensor
- stock injectors big enough
- y8 cam with z6 gear.....
- IAB wiring question, ek swap, not a how to
- B18C or H22A1
- What distributors will fit my d15b8? Mine isn't getting spark. Need one ASAP.
- dohc v-tec cam question
- Stalled car today and now it wont even crank...
- ek interior specs
- question about b20 vtec
- Why wont my header fit? wrong one?
- Auto To Manual Tranmission
- del sol front end change over!
- new headers and my car sounds like crap
- To those with 4x114.3 suspension, what pads rotors to replace with?
- Frustrating forum problem!
- power steering leak help! *pics*
- Another wack car stalled and wont start topic!!
- B16 question about removing A/C?
- Front end shaking when coasting, whats up?
- replaced tb/wp/tensioner, now rattle coming from that side?
- Which engines can fit into a Canadian built 1997 Civic Si without modifing Wiring harness and Engine
- Car won't start...wtf?
- what DIZZY will work for the jdm d15b vtec motor?
- intake problem *squeaks
- Skunk-2 camshafts (d16)
- No start on the sohc y7!! HELP ME
- 99 civic auto door lock, sun roof, dome light all not working after doing tranny work. help please.
- For those running stock mufflers on their hatches
