View Full Version : Honda Civic / Del Sol (1992 - 2000)
- ziptech o2sim evolution 2
- I have a hatchback with a b18 what should i launch it at
- tires
- del sol lips
- PLEASE HELP~~!!~~
- 2000 Honda Civic Clear Corners
- JDM Body Parts
- would prelude seats fit into a del sol?
- motor mount question
- Distributor Problems
- Civic Type R
- coilover problem ?
- B20 VTEC Track Car
- Pistons in B18B
- how do you tell the difference between 92-95 civic trans and 96-00 civic sohc trans?
- In need of Speaker Wiring Harness for 1997 Civic EX
- I need a tranny for b18a1!!!
- www.kwcengine.com ?!?!?!?!??!?!?!
- 95 Teg RS seats in EK
- exhaust leak or bad timing?
- Searched for over 2 hrs now "Please Help !!!"
- Electrical Load Detector circuit, COde 20, wtf is it
- Del Sol kick pannels
- PRoblem with ObD2 IN MY EG p28
- [q+a] spark plug replacement
- SAFC sits at -760mmhg and doesnt move...AT ALL
- What fuel pressure should I be at? B16...
- Honda Del Sol, what to look for when buying?
- Sway Bar install problems?!?!?
- How hard is it to maintain a BMW 325i ?
- i think my both my rear shocks...
- clutch/ pressure plate question
- Tein S-tech Springs
- 93 civic door panel remove
- radiator question
- AC Compressor for 97 del sol
- Lightweight underdrivepully w/lightweight flywheel, problems?
- Skunk2 notchiness?
- 92-95 civic sedan/coupe/hatch hoods
- 2004 civic wheels
- pic request: EG coupe on 205/45/16
- clutch weirdness...please help
- eg fenders
- Axles problems!
- code 70
- Carbon Fiber?
- engine swap help?
- Integra shox in crx?
- aluminum radiator problem
- H22 or B18C ITR
- low compression in one cyl...what does that mean?
- What can I get for this?
- hx tranny and ex tranny
- any difference in LMA?
- z6 in coupe or hatch?
- Boost on my Civic
- ITR LCA's into 92+ JDM EG ?
- After Market Steering wheel...HELP!
- Hey WTF*** Ahhh my cars motor mount bracket just moved about two inches!!!!
- Front Brake Conversion for 93 CX. What all do I need???
- dpfi to mpfi EUROPEAN HELP HELP
- i need help were are the tech's
- daily driver manual swap suggestions
- building my block what bearings do I use?? please look!
- The D16Z6 swap into LSI D15B2
- 89 Civic Hatchback Si rear speakers help
- 96-00 civic swaybar question...
- Civic OEM Foglights, Fuse burns out everytime i turn on foglights.
- blinker works but parking light doesnt help!!
- light buzzer
- Need help ASAP!
- 95 DX suspension question
- Are integra fuel pumps bigger then civics? Do they interchange?
- Finally!
- CEL: Code 3 (MAP sensor) 97 dx
- rear disk conversion questions
- spare cover in trunk....
- 00 Hatch weight... any guesses??
- bad tranny, which 1 will fit???
- coilover install questions
- will a chipped p28 auto work the same as a chipped p28 manual?
- Where is the speed sensor?!?!?
- 95 civic Air Conditioning issue
- *need help ASAP- LCA bolt wont come off*
- (Help!)...Feels like fuel cut....but could it be timing.?
- WHAT OTHER BRAND BRACKETS CAN I USE WITH A CORBEAU SEAT?!?!?!?
- Spark Plug Wire order HELP!!!!!
- d15b rev problem
- Need some help Ek with ls swap
- a-spec-racing.com
- S/V-AFC NOOB QUESTION
- alittle rain wont hurt my car?..
- AEM Pulley- Piece of S*&^!
- ALIGNMENT ISSUES
- jumper ecu harness - where can i buy and how much
- 94 ex brakes onto 94 dx will they work the same
- buddy club spec II exhaust
- !! MY TIRES ARE RUBBING ON MY WHEELWELLS !!
- d16z6 head upgrade adds 50 hp to the wheels????
- 99-01 Civic Sedan Manual?
- Lets Play....Name That Sound....93 Civic HB Come on downnnn....
- Anyone have experience with Megan Racing Guages?
- need help itr brake booster and master cylinder or gsr?
- Lowering a LSi Coupe
- Exhaust Manifold
- PLEASE HELP - Modifications without Fuel injection
- JDM Electronic Parts Catalog - Anyone Got It ? Know Where I Can Get A Copy ?
- shaved key hole question
- V-tec for sale
- Question about manual transmission???
- Who has used Metalcast by Duplicolor??
- Slicks....
- my h22 del sol is not sparking!?!?!
- Engine Oil
- seeking advice on buying a 1997 civic DX
- How do i shorten b18c1 tranny to fit ek hb?
- How much are SHOCK SENSORS worth?
- Radiator Hoses?
- 02 Sensor Problem...
- b16a obd0 into EG
- state ref
- I need a rear disc conversion on my 96 ek hb....suggestions?
- rear coilovers are popping
- D16y8 head swap??
- what rear sways will bolt to factory lca's?
- 1/4 mile times? Whats your prediction?
- engine code for 92 civic si
- What years were B20B's made?
- How high does a B16 gauge cluster read in RPM's?
- Need some help from the techies
- air conditioning problem
- A'pexi compatible with Del Sol?
- How Much can i get?
- starting problems
- ****CAR WONT IDLE!!! HELP me OUT!!****
- Greddy Evo Exhaust on my del Sol (Video Clip)
- Need a B series tranny...where to find?
- EK 96 CIVIC HB
- Update: My EG Hatch project
- brake squeeks with new pads... ?
- Difference between 90-03 teg shifter vs 94+
- simple question i need help with...
- Check engine light, doesn't light up when checking code. WHY!!
- GSR brake conversion onto hatch CX few quick questions
- ek sideskirts onto a eg
- Removing Aux Lights
- need help here with a lip to fit my car
- Squeeking/Rattling
- JDM fog light switch?
- Have a good b18 with a junk block.. want to move up to a b20.. what will swap
- type r lsd in a b16 tranny
- Would my 93 ex coupe beat a focus zx3 hatch? Anybody ever run one?
- whats an s4 tranny from?
- starter problems
- d16 head on an ls block howso? willso? help please
- dash not fully lit?
- Car Revs.. Car Won't Go
- FS: brand new Tokico Illuminas 92-00 civic, teg
- oil sending unit.92-95 same as 96-00?
- p28 or gsr
- brake issues, pictures
- 96 civic oil pan d16y7 leaks...HELP!
- integra exhaust on my civic??
- Loud Clunk when stopping
- sparg plug info?
- Weird noise when I turn
- Fuel Pump not turning on
- idleing low
- Hey guys plz read
- What hood is this?
- EAGLE RODS WONT FIT...NEED HELP!!!!!
- catback from ebay...
- might be a dumb ? but pleas help thanks
- how to break in?
- Stuck in a bind
- Squeaking noise. Please help me pinpoint the noise.
- homemade or kit
- Seafoam And Turbo
- retrofit into oem housing???
- Possible to bolt a bigger compressor/A/C condensor? A/C gurus needed...
- where can i get extended intake manifold studs?
- JDM SOHC VTEC ZC motor 1.5 or 1.6?
- Bosch platinum +4 plugs....
- b16 throttle body swap into d16y8????
- where does the fresh air come from?
- honda tech i need help
- b16a1 intake gaskets
- 99 civic SI hood same as 99 Ex hood??? please help real quick
- In what application would you use this.......
- ok the motor is in
- F22 write up?
- Should I buy? 4G Civic Hatchie ...
- Which D series tranny has the best gearing?
- What ECU do I need?
- need help plz!!!!!
- Got SOme upgrades, how many ponies you think?
- Anyone every thrown a code 54? Crankshaft fluctuation?
- Converting AUTO to MANUAL?
- i just need to confirm a few things on an obd2 to obd1 conversion
- will the autometer oil pressure sensor fit the greddy sandwitch plate?
- WTB: SLicks and wheels
- b16a swap help
- wheel fell off while driving!!
- The New Guy....
- b16 turbo keeps on overheating
- apexi N1 muffler on a tanabe catback
- Finally my H22 turbo dyno in my 93 civic 4dr!!!!!!!!
- removing bumper-- where is the fender screw??
- rattle noise under hood?
- Whining noise
- Rear disks from a 95 coupe w/abs...
- H22 transmission mounting issues. Please help!
- anyones main relay go out this summer? how much for eg
- rim problem...
- rsx seats in a 92 hatch
- Why the GReddy SP sucks...
- 00 LS swap in 97 EX gone wrong...HELP!!!
- Head Swap help!!!!!!
- TRANNY COOLER
- my civic is being weird... newbie... HELP PLEASE!!!
- Wheres the cheapest place to buy factory motor mounts???
- what bolts for jdmsh!t spoon style mirrors?
- Civic EX AND HX transmission question..
- Clutch Pedal Adjustment (Searched just need help)
- Red light on steering column
- Another quick question
- what is the difference between nitrous oxide and nos?
- ------- Cleaning oxygen sensor ?????? ----------
- What do you think of this intake setup?
- question about cd player wiring
- ABS Lip and B18 swap
- year stamped on my motor wrong???
- Error code for Too Lean
- Ambering EG2 gauges
- motor upgrade
- knock sensor
- Reading ignition timing degrees
- Speaker size, Deck seeking and installation
- kenji chipped ecu and timing question
- Shift Boot Question
- Another hatch almost lost...
- sway bar/control arm question
- 99-00 Si B-pipe size
- I want to make sure I installed this right...
- b16sir2 swap problems
- Kseries Swap Need A plug!!
- del sol shifter in eg
- What is the finish on an OEM honda body part?
- shaving door handles?
- Where can I find pin location or pinouts for Alt-C pin in OBD2 ecu?
