View Full Version : Honda Civic / Del Sol (1992 - 2000)
- air condition for 1996 with hatchback
- D16Y8 Mini-Me swap, CEL and Idle Surge
- Axle Nuts
- 92 civic LX no spark!!!
- Some Help on my Tow Hook
- EJ1 rear disc conversion, now shitty braking
- EK dies after running for about 8min..then wont start
- proportional valve leaking brake fluid.
- Front caliper rebuild kit
- auto to manny swap problem
- opinions on pistons and valve train lsv set up
- EK Ecu plug harness VTEC wiring help
- 98 DX Auto with EX auto Gauge cluster?
- knock sensor??
- very slow d16y8, why? need help
- Help finding a helmet in IL
- motor mount question
- Help Clutch issue 96 civic hatch
- interior electrical and starting problem..
- Iacv
- couple questions
- Found Underneath My DASH PIC/DIAGRAM!
- cheap/small d16z6 project
- Ebay type R floor mats. I only found old threads in search.
- what all do i need to finish my B16 swap?
- 96 civic loud knock coming from left side of engine
- clutch bleeding???
- Harness Q?
- OBD0 b16 swap
- fuel questions need some help ???
- cam trouble?
- 96 civic ex... think it head gasket....
- help for cluster lighting issue
- Driveable rim?
- Need help on rim size & offset!
- vibration, crank, crank pulley, flywheel, idk...
- Where to start / What to do.
- Who makes 99-00 si rims
- sleeping ls/v HELP!!!!!
- Wiring Question: 96 cx
- spring and strut install cost
- Please help 2000 si air/fuel
- D16Y8 throttle swap
- eg ac parts in a b16 ek hatch
- Clutch pedal hit the floor!!!!!
- Head gasket replacement cost?
- what to do first
- Del Sol Problem
- Help: OBD1 Z6 overheating
- o2 sensor, code 1
- Any difference between EM1 Shift Knob and Prelude Knob
- ITR and CTR valve springs
- skunk2 manifold Q's
- injector questions??? ITR And Si has the same injector sizes?
- ek shocks
- Pacesetter header...anyone have one?
- A few problems with my 92 4 door civic w/ d16y8
- ? about v-tec and speed odometer
- Alternator not working?
- stem seals in the sump!!!
- NRG Torque Damper (D16Y8) Install help?
- 550 injector question
- will this tripod strut bar fit to this EK 1.4 (warning europe civic LOL)
- ++ Ask about rear Lower control arm bar ++
- Passenger floor water leak ONLY when driving in the rain
- CEL on Knock Sensor Help!
- better trans...?
- d16a1 clutch into 95dx HELP
- Where do I find the ignition wire?
- 1994 Civic Hatchback: Cracked Windshield...
- RIP my dear JDM B18C Type-R. What next...
- Removing center caps - Si wheels - HELP PLZ
- 96-00 suspension on to 94 del sol?
- integra control arms
- EH6(del sol) Seat tech ?(already searched)
- It's alive!!
- Old Sol new life
- Exhaust/Test Pipe/Cat >?
- EM1 99 SI loss of power?
- No cruise control or horn?
- Fuel issue/running rich
- Door vs F150: How bad is it?
- Rain water in my trunk
- air conditioning help!!
- Wierd Noise
- Del Sol Transtop Metal Gears
- 98 HB Cx exterior door handle removal, tamper proof??
- shock rod bolt stuck on my wife's 97 civic
- Random starts, and loud click.
- H22 f22 cables?
- Cooling Fan not turning on properly
- It's time for the 2nd annual, NAME THAT LEAK GAME Our 1st contestant is a 94 coupe...
- Decide on which offset for my EG hatch.
- boosted b16a3 questions
- solenoid leak
- ek driverside mounts keeps breaking.
- D16z6 Engine not running.
- HELP:: Possibilities why car wont Start???
- Anyone swapped collar on JDM boot to take factory knob, EM1?
- Fan Switch Amperage??
- EM1 Civic SI Short Antenna?
- Are blox and skunk2 upper control arms exactly the same?
- ECU Problem? - P28 is only one that works?
- 2007 Civic Si Rear Seats Installed into EM1...
- AC/Radiator Fan Issues
- Legality of swapping motors ..
- Rear Disc Conversion... Done.
- fuel pump switch/wire
- Need help!!!!!!
- EM1 (99-00)si coilovers for sale(SKUNK 2)
- suspension help?
- Rear main seal d15b?
- 99-00 civic EX gauge cluster in 99 CX Hatch?
- Where have you purchased direct fit Catalytic Converter?
- Trouble removing tie rod ends
- Newbie...
- Aftermarket vs stock flywheel...drivability...
- B18c1 will not go past 4,000 rpms
- transmission fluid
- rough start and black smoke!
- B16 oil leak need HELP
- Gauge Cluster Problem
- Emissions bypass
- Just wanted to say thanks to the forum
- Shift Linkage which will work?
- what size swaybars are yall running
- ???LS Slave Cylinder On B16 Trans???
- ac question
- Engine Swap Problems
- Passenger side axle leaking.
- Plug & Play harnesses for city lights on JDM EK lights
- suspension question
- how to install side ambers on 00 civic coupe.
- timing
- Lightweight glass for an EG
- Did i get a deal?!
- Door panel arm rest brittle, EK
- ek suspension to eg6
- vin number location
- confused on obd2 - 1
- change y8 to b16
- blowing fuse.
- eg steering wheel, what size??
- h22 in eg vss help
- k20 in ek help
- sound of detonation
- 93 hatch help
- CEL # 45??? where to go from here?
- oil drain plug is leaking....
- Special Polymer IM Gaskets
- Low Temp Fan Switch. Good or Bad?
- Hot Problem of the day....
- EG center audio console question
- need help
- crv a/c bracket into ek with b18b
- Crv obd2b harness into 99si
- deep Sound coming from intake tube/throttle body
- *Urgent* 99 civic sputtering, check engine light flashing!
- Exterior opinion
- y8 head swap help needed
- car not moving after start !! HELP!
- 93 Sol b18C swap
- mini-me in ej...which motor mount???
- going to be buying a turbo, but need a little help deciding.
- sloppy gsr shifter in civic
- Plugs fuel soaked, tested & firing?
- Shift linkage b series
- Replacing Catalytic Converter - Any surprises?
- weird tapping noise
- just bought a ctr steering wheel for 99 hatch
- cluster swap trouble
- SI suspension
- Need help finding a part.
- Ecu???
- what is this wire/plug? (picture)
- ej1 motor swap and build
- Do JDM EG fogs work with USDM hatch, wiring?
- ls loosing compression
- Adjustable cat-side flange on a header?
- sun visors instruction
- thrust washers n the damn oil pan
- snotty textured oil
- h22a starting problems?
- 95 Civic EX - No CELs; massive hesitation at low RPMs
- Do you need all engine mounts
- Snapped the head off an LCA bolt.....
- Cluster Trouble!
- car problem
- Radio Code `99 Civic
- oil catch can
- Boost or swap?
- need help idling funny
- 95 DELSOL CRANK BUT NO START? Ignition//fuel??
- srp pistons in jdm ek9 1999 type r b16b motor
- how to identify good fogs
- my car leans to one side
- what 92-95 headlights/corners do i got?
- Rubbing tires in the Rear , New Suspension
- Bogging problem after minime setup
- car wont shift please help
- Starter signal Fuse pops?
- whats the best way to cap off coolant line
- 93 Del Sol S b18a1 w/Cable trans swap?
- b16a swap vtec engagement trouble
- intake question
- Slow Building My EG Update Daily!
- ek engine bay tuck
- B18C1 or B16A cylinder head?
- Piping or Full Exhaust for PERFORMANCE??
- Si rims for EJ8
- 97 Civic HX General Questions
- Help - Auto to Manuel conversion information inregards to wiring!
- D16Y7 Fuel Injector Question
- Idle Issues, Need help
- Time for a new engine swap *pics*
- civic ej8 (sir style with ctr lip)
- will itr lma's work in a 1990 b16a head help asap
- Aftermarket fuel rail pulsation damper
- 1,000,000th cel 14 iacv thread
- Skunk2 Intake Manifold
- Speedo malfunction
- tockico shocks
- brakes 240mm? or 262mm?
- Hondata S200
- ls vtec trouble plz help
- I/H/E...1k..help deciding and imput
- d16y8- Low rpm's when driving
- What brake Lines for Rear Disc Swap????
- Rim photoshop request
- replace master cylinder on eg now left disks brakes more
- question for my automatic 97 civc ex?
- Constant Metal scraping when rolling.
- Help - Auto to manual conversion
- need help no rear running lights
- Best looking oem Honda/Acura 4 lug rims?
- D16Z6 on a 98 Civic Hatch as stock engine, true or not?
- New to HT, what to do?...
- questions
- burning oil
- Really need help. wierd story. H22a
- Really weird clutch problems. Please help!
- Cable to hydro conversion?? pics anyone?
- no power to gauges, car wont start, what fuse is it?
- Ep3 seats on eg coupe...
- euro r manifold h22
- 96-00 sunfoor on 92-95 civic
- "mini me" for a first build? any suggestion?
- plug?
- How to test fuel pressure
- 88-91 and 92-95 struts
