View Full Version : Honda Civic / Del Sol (1992 - 2000)
- toda cams vs jun 3
- Key cylinder swap - Ignition and Doors - ef to eg
- Upper/Lower Ball Joint PLZZ HELP
- 93 civic oil light keeps comming on why? help plz?!
- cold air intake
- cam problem need help
- What is the small hose that comes from the power steering boot?
- ... MPH Needle was bouncing but decided to Stopped Working! HELP :(
- My CTR engine # doesn't match the Frame... Why is that?
- Good place to get aftermarket parts
- remote trunk release and low fuel light installation questions.
- Del Sol Wheel Size
- Problems with power locks after alarm install
- Having Trouble with gauge Indicators
- wheel hubs
- replica 99-00 si lip???
- Shift fork setting pin different??
- What type of engine do i have?
- Thump or Pop in new installed axle 95 civic
- Compatibility issues between JDM and original engine?
- Hesitation on acceleration, rpm slugs and catches up..
- EJ civic with b18c swap V-TEC not working, help!
- Please Help With Intermittent Buzz
- ?¿?¿ Don't know name n need help ?¿?¿
- b16 throwing codes please help
- cel code 17 wont go away!
- Head gaskets and head bolts
- What struts to get?
- 95 ex having shifting promblems
- PLEASE HELP SAVE MY NOSE
- B20b series into ek(d16y7) wiring Problem please help
- I need some ideas for my d16z6 rebuild or not?
- Help with B-Series Build
- B20 rev limit
- pleae help my eg6
- EG / DC Front Subframe into EK
- d16z6 isnt getting spark
- EG B18B1 swap Q's
- ITR Strut bar VS. Strut bar that bolts to shock studs?
- obd1 non vtec dizzy on vtec head..help please
- first honda
- tire fitment?
- Easy to reinstall OEM shift knob?
- k20 or b16 turbo???
- 95 SI hatch long term project!
- d16 intake manifold swap
- How often do you service the oil pump?
- a lil extra mileage for the money
- eg hatch exhaust on eg sedan...
- 88' civic flywheel on 95 civic
- 1992 EG civic idle question?
- Civic VX foaming coolant and idle surge
- TYC projectors on Civic EG sedan
- ls in eg hatch reff question
- What parts are these???
- Steering wheel WAY off
- black smoke????
- what size double din would fit?
- D16y8 tranny noise
- Unsure what upgrades to make for 00si
- EG window Conversion QUESTIONs -
- 92-95 Civic Cabin Noise and Solutions
- Quoted to have new cat installed for $1000 from shop, true? (California/ EK COUPE)
- How to identify a d16a6 crank?
- idle surge!!!!
- Catalytic Converter 98 civic lx
- air filter swap
- 1995 Civic EX Sedan HP Options?
- blippy throttle?
- WHATS wrong?? overheat
- Trouble with h22 swap
- D15b7 On a d16z6
- Front clip question
- B16a in to a 97 civic dx
- D16y8 head with d16y5 bottom runs great when cold but bogs like hell when warm!!!
- Front camber kit
- I'm looking for ebp stock front bumper and rightside front fender
- Trans Or Linkage Issues???!!!
- Civic Armrest Foglight switch
- PLZ NEED HELP: Map Sensor malfunction
- EK COUPE Exhaust Piping Question
- Valve tapping sound from head after Mini-me Swap
- Headers
- Del sol aux lights
- Inner fender help
- Strokin d series
- power steering leak from rack end seals, where is recirc kit?
- TURBO QUESTION!
- 98 civic TCU/ECU question
- swapping blown d15b7 w/d15z1
- b16a2, ECU, And Five speed tranny into a 94 Del sol?
- b18c civic
- Z6 Y7 Mini me timing problems. NO START
- b16 to b20b block
- Help! The famous 12mmx1.00 brake fitting
- Wheel advice for EG Civic
- '99 Civic Si- Tein Coilover Died, Suggestions on New Setup
- Upper control arm problems
- Worth it? Eibach Sportline Springs
- just sprung an idea..automatic rad into oil cooler??
- f22 swap into Ej/Eg wiring question
- Aftermarket Steering Rack or rebuild kit?
- Power Steering help
- 95 EX CLUTCH PROBLEM I THINK PLZ HELP!!
- My new (to me) 97 four door LX.
- Tranny for 98 civic hx Please Help
- GSR Swapped EK Intake/Sensor?
- 92-95 Civic Lowering Spring Help
- New to HT
- Del Sol F20B swap?
- HELP! 2gen jdm b16a in 92 SI 3dr {VSS}
- ek parts?
- IACV valve 2 pin change and pins on computer change HELPPPPPPP PLZZZZZ..
- 96-00 civic motor mounts...looking for performance mounts
- New window regulator wont go up??
- what size tire
- Car died while driving
- code 15, should I go OEM or after market?
- Online Honda Parts Database
- illuminated hazard switch for eg's?
- how to roll back or forward odometer (for use when swaping gauges only)
- Ignition fuse keeps blowing! please help.
- d16z6 motor swap
- Shopping for used A/C compressor need advice
- d15b8 to JDM d15b. helps?
- reving problem
- quick rear lca question
- del sol ciggy and radio fuse...
- Turbo EK wont pass smog
- 00 Civic rust question.
- 2000 civic ex manual trans fluid capacity?
- My first Honda (beater) '94 Civic
- which ecu on jdmb16
- Difference in GSR and SI wiring harness in EK coupe
- ac compressor between ef and eg ?
- QUICK QUESTION
- how to tell if you have a SOHC or DOHC?
- how do you change the back wiper on a 93 hatch
- help me!!!!
- will ek SI parts fit on my eg hatch?
- Lambo Door Kit
- Integra seats in hatch?
- 1993 honda civic code 6 ? help???
- Need help! Few questions about my swap into an 2000 civic coupe
- Need Advice... Piston ring leakage
- CEL Dilemma - Need your Expert Advice!
- high idle and jumping rpm help!!!
- '93 CivicEX - Major CEL Dilemma - Please help
- Wil These Work On A Civic??
- Need some help on gettin a wiring schematic!!!!
- 97 ex dome light help
- b20b idle problem when warmed up no check engine lights
- Problem shifting in a 94 Del Sol
- 95 si Civic hatch wont start
- Best Speakers for 92-95 civc
- need some help on lost wires in engine bay
- EK blower/evap in EG?
- GSR swap red lining at 4k rpm!! NO CEL- V.-Im stumped!
- b16 valve cover bolt snapped off
- need some help with ideas for upgrades for 99 si coupe..
- wiper lever
- oil leak from filter
- Adjusting door in/out? Help please
- B18C into EK need opinions
- NO start after cap, rotor and plug wires
- RSX seats in 97 del sol.
- is it normal for my shifting stick to move when i accelerate and let go of the gas?
- TDC crank off 97
- tranny issues
- 94 Civic EX windshield wiper problem
- HELP!! ....93 eg2..D16z6
- anyone know the thread size??
- d16z6 ECU questions
- GSR seats in EG are too high..
- NEED HELP with wheel fitment
- Del Sol Map Light And Power Door Lock Rod Help
- eg cluster help!!!!!!! plzzzzz
- crash
- em1 rhd convervision
- Question about the CKF connector on a EX civic
- coilover sleeves
- HELP NEEDED with 98 ek sedan rear end conversion to 99-00 wiring
- 97 Civic - wouldn't lock manually or with power lock and then broke arm off actuator
- electrical problem help!
- 94' Honda Civic
- skunk2 ef suspension on del sol help!
- how to remove rear interior paneling in del sol
- Tips for properly storing engine?
- 95 civic stock headlights slow to come on
- Aftermarket Headlight Problem
- Del Sol D16Z6 Intake Air Temp Sensor Code 10
- '94 civic bouncing/jumping in 1st and second
- stolen 97 Civic in socal (Wilmington)
- Help piecing together missing a/c components
- 1998 civic ex floor wire harness
- What torque mounts are compatible for a EK with d16y8?
- Ek getting a interior makeover. Help!
- if anyone has a carfax left over or free for a eg si.
- !!!stolen 1994 civic ex 2door teal green!!! Temecula CA
- Adjusting Headlights
- 94 Integra uprights and control arms on a 97 DX
- bogging out when trying to accelerate
- Hytech header on b18c question.
- HELP PLZ!
- Stolen computer, need a replacement!
- Car wont turn off?!
- 97 civic output shaft leak
- Da lowering spring's on Eg civic?
- car run WITHOUT vtec oil pressure sensor?
- oil squirting out vtec solenoid HELP!?
- Any of you guys running straight pipes...
- 00 Civic EX, auto transmission - TPS troubleshooting
- I BROKE a UNKNOWN sensor... help plz
- Summer A/C Guide, How it Works, When it Doesn't: Redirect
- 00 hx surges from 2000 rpm to around 3200 rpm
- what liter engine do i have?
- A/C and Heater Issues...please help
- my dx power conersion
- Ebay exhaust system
- do 06-09 si front & rear seats fit on an em1?
- D16 Idle problems
- ecu
- Interior clips?
- **D15B8 IDLE PROBLEMS**
- TACH QUESTION 96-99 EK HB **OPEN**
- Best degree of advancement for low-mid range power
- Difficult shifting??
- 95 Civic Hatch Rear Suspension Alignment
- Educate us all on Civic Hatchbacks What types are out there and are best?
- New windshield
- Where can i find this bug deflector?
- 2000 ex
- rpm feed wire to ecu (need a wiring guru)
- Can you use 00 EX MC for rear disc without problems?
- very raspy exhaust b18b1
- em1 tranny problem
- What steering wheels fit?
- swapping intake manifold
- Front Left Turn Signal Doesn't work..?
- EK rear suspension bolts, all siezed.. foooock me.
- injectors wont work
- Tie Rod question 96-99 ek HB..**IMPORTANT, OPEN**
- 99-00 si seats
- Eg power window conversion need help
- 00 civic ex coupe trunk carpet specs?
- B18c Swap Help With Alternator Plug
- Losing coolant but no leaks
- Hytech Replica or DC Sport Header on b18c5 del sol
