View Full Version : Honda Civic / Del Sol (1992 - 2000)
- D16Y8 cam seal ?
- Grippy tires
- Cylinder 2 Misfire out of F'in no where? How?
- does anyone here put synthetic oil in there stock civic engines?
- Vss problem
- D16y8 into an HX
- autozone fried my ecu
- Strength of Oil Pan
- WANTED - 92-95 Civic Hatch
- Timing belt sloppy on exhaust side?
- [FAQ] How-To: Removal and Installation of a Distributor O-Ring.
- center console help!
- surging
- sway bar question
- What's better for RODS!
- radiator support question
- Need help on choosing a cat-back exhaust, tires, and headers =)
- White EG Hatch in anaheim/orange socal???
- Pricing
- B18b or sohc vtec
- tranny?
- 94-01 Teg armrest/console. Yes, I searched....
- ek bakes same as intergra brakes
- center console?
- how long will these tires last?
- 04 cluster in 00
- '94 Civic VX WTB & Questions
- Newbie, question about 96-00 auto tranny
- 92 cx hatch motors 70hp stock do you think this is smart
- will bigger rims make my car look higher or lower?
- high flow cats
- What clutch?
- Removal of distributor.
- Will a d16y7 fit in a 93 civic dx 4dr?
- D15 timing covers to set timing?
- OEM Honda Del Sol Window Stamps (Do they say Honda?)
- [FAQ] Power Windows, locks, Mirrors into EG Civic
- civic gx internals in d16z6
- moderator help me
- taking out automatic shift indicators from auto cluster
- 68mm holly throttle body wtt
- What's it worth?
- need to confirm, mugen strut bar installation (front)
- San Diego <<<{{STOLEN}}>>> 96 Civic Coupe SILVER
- Skunk2 strut bar ?'s
- rebuilding quesiton
- 00 Civic Lighting
- Where can i find the Ignition Fuse?
- CARBON FIBER HOODS 2 DOOR 4 DOOR OR HATCH
- need under dash fuse diagram for a 00 civic
- does a gsr center console fit in a ek?
- Best future mods hp wise for my turbo hatch? Please post up ideas!
- NEED HELP WITH MY 93 SOL Si
- How hard is it to this list by myself?
- Does not having o2 sensors wired up effect performance
- anyone else paranoid?
- Is this air compressor good enough?
- Will a Greddy Evo cat back off a 99Si coupe fit a (1998 HAtchback civic)??help
- d16z6 onto a 00 ek?
- 96 hatch ctr si conversion b16a2 FOR SALE
- Lowering?
- OBD1 Conversion Paranoia
- Snowboard Rack for an EG Hatch?
- code 43?
- knocking sound
- eg hatch eating up oil like its water *HELP*
- Help...... My car just died from out of nowhere
- Omni Power Coilovers vs. K Sport Coilovers
- anyone need a 89 honda civic parts car?
- doing a y8 tranny swap have some questions?
- Wipers won't shut off...
- trans noise...
- EK rear lower control arm specs
- mini me Swap Starters Questions
- a/c pump question
- will ITR 5lug setup bolt directly to 4dr civics?
- z6 trannies (SI and EX)
- Good deal? Need answers quick
- 1996 Honda Civic CEL problem
- Very slow oil leak - dripping at bottom of timing belt cover ?
- 00 civic si, Horrible high pitch howl coming from pass side engine bay.
- humming from left rear tire???
- Tach / RPM gauge is not reading correctly
- Knocking noise, then the car dies after a week, not quite sure........
- 7th gen. 02 LX tire
- Timing BElt cover
- question about b18b swap in eg
- b16a
- 1993 Si starts, then immediately stops.
- new (to me) civic and question about "low mileage japan engines" found in CA
- ITR lower control arms
- s2000 civic hatch
- swap help
- auto tranny troubles
- is this a common problem?( lowering springs related )
- eg time slips
- i don't understand it why does it misfire??
- OEM OFFSET??? On 92-95 cx hatchback
- Compatible Shocks
- anyone ever done business with.....
- how to tighten throttle cable on b16a2
- Carfax for 1$
- Wiring in A MAP sensor.
- CAI and check engine light?
- need civic type r doorpanels
- car starts only sometimes
- any one in texas with a lift?
- 99-00 Si bumper on a 96-98EX
- torn axle boot
- Aftermarket REPLICA body kit all kind of imports
- Skunk2 coil-over/strut combo?
- Front clip ?
- Has anyone put 97+ Lude seats in their EK?!?!
- honda wont start
- turbo question
- Issues with Starter; D16Y8
- b16 or d16
- C&R Drag Full Size Radiator into an EK
- Trunk full 'o' water!!!!
- please look at your 2 gray, 1 green harness that go into fuse block
- b18b harness axles ecu tranny motor
- 92 civic hatch and coupe/sedan front fenders interchangeable?
- Muteki lug nuts?
- will this fit?
- Can't seem to find any street legal headers for my civic
- Help: 40/40 Prop Valve Install onto EG/EJ
- any Jdm eg9 / Ferio 92-95 pix?
- o2 sensor
- i need help with my 97 honda civic ex
- good used part places?
- Injector Question
- 96-00 Y8 Throttle Cable on a 99-00 B16A2?
- radiator help
- Anyone looking for a 1996-1998 Civic Service Manual?
- HELP: Blowing imobilizer fuse
- Hid 's in jdm eg headlights
- that clicking noise is driving me crazy...!
- HELP
- anyone selling
- D16z6 cat options for emissions - which one?
- non civic mirrors for a 92-95 hatch?
- need help, need a vin for insurance quote
- d16y7 Cable Tranny HELP ASAP!!
- .:HID QUESTION FOR 96-00 OWNERS:.
- Integra seats in a 97 Civic
- 92-93 or 94-95 civic a/c lines??
- Need quick help
- Hx wheels/tires....
- Air Conditioning into H22 EG
- store review
- Megan rear Lower Control Arms
- need help with 98 civic lx ecu prob
- ferio
- 1998 CIVIC HATCH FOR SALE, GOOD CONDITION!
- b20 swap
- b series throttle body
- Question about OBD-2 Diagnostic 16-pin plug???
- Is this a good deal/reliable car? Gimme your opinions
- 1.8ls info
- b20 sleeves cracked?
- SoCal: Need Help w/Install Clutch/Flywheel
- SI and ZC hybrid Tranny / Transmission questions
- Timing belt quick way?
- HOW--power steering conv
- What hatch stuff fits on 2dr coupe?
- zero lift
- B18c coolant system, and idle problem?
- Question about the DX models...
- Upgrading from CX brakes to EX brakes...
- headlight bulb number?
- Engine bay cleaning, what to tape off?
- throttle body techs
- car wont start help
- Does anyone rub with 205/50/16 on an EM1?
- Quick question about radiator swao (ek to eg)?
- stock intake hoses
- how bad is it...
- Advantages the EG has over the EF
- 93 teg question about a swap
- Help: REF and BAR problem on 97 EK
- CX Rev Limiter and Redline....? Help please
- Scammer Threads
- Frame Help.
- City lights on EBAY! NO DRILLING!
- Small leak on transmission, need help.
- Passenger side window problem
- alarm question
- evo8 recaros in a 5g hatch?
- 93 Hatch Leaking Water Into Driver's Side Carpet / Foot Area HELP!!!!
- Better Cam For Street B16 EG
- air ride sugestions?
- fastest 1/4 mile time in a dx coupe with stock dx motor
- i am looking for some airbag suspension for my civic
- o2 sensor trouble with motor swap.
- CRASHED!!!!!! the EG, need help.. want to see if car is worth keeping or not....FRAMe???
- MTF
- i need help with EK hatch exhaust.
- which struts to get for the EJ1
- New JDM B16A2 swap. Have questions.
- DOES a del sol S model have a front sway bar?
- LS engine
- would eg skunk 2 camber fit on 92 integra?
- Swapping from a D16Z6, to a D16A (Jspec) I need to know the differences.. Help!!!
- 1998 honda civic 02 sensor question
- who should pay for my car
- JDM sidemarkers?
- Hardcore BLASTING
- Swapped my blown y7 for another y7 now surging?
- logout
- Penzoil Synchromesh
- Neon boys engine is going to BLOW because it has aids and cancer
- What intake manifold is this? d16y8? Also IACV question about this IM
- REDLINE ON 92-95 CIVIC DX?
- looking to buy cheap exhaust system
- Which spark plug wires?
- Rear Sway bar for A EG2
- Emission
- code 67
- VTEC Controller in 04 Civic
- LS motor cam skipped timing problem.
- cx pistons
- heat shields
- Anyone know much about Natami products?
- door handle swap
- Guage Cluster Swap
- Lambo doors... Moderators are slow? Hello... Can't even post to my own topic?
- service light vs check engine light?
- 2 door eg front end on a 4 door
- stupid ?
- Is there anyway to do away with your map sensor?
- integra linkages in a eg
- Which throttle cable?
- Shocks and springs?
- skunk2 cat back for crx and civic 88-91 fit EK??
- Just picked up a 95 Coupe...
- help me identify this plug from the gsr harness???
- Head swap or whole engine swap?
- Momo hub compatibility?
- eg interior door handle lock problem
- Brake conversion
- K20 motor for my '02ex
- carfaxes while they last.
- Happy B-Day to me... I need a carfax done.
- JDM b16, which IAT do i need?
- Help! Timing belt install issues. Patience wearing thin...
- 97 honda civic - check engine light on
- Information on 96-00 Honda Civic Type R (EK 9)
- Did a search and nothing is helping....Header gasket
- Will HX WHEELS clear 92-95 SI Brakes?
- Don't be mad, but another IACV Post
