View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Code 65, Sec O2 sensor.
- Is a Civic SI (B16) & Integra LS (B18) oil pan the same thing?
- JDM ITR header and high flow cat
- which sensor it this? (PGM-FI IM) picture inside.
- 92 Integra Set Into 95 Hatch EG???
- I need help on installing my engine mount inserts.
- 95 RED COUPE FOR SALE (swap & tuned)
- wtb. legit b series block ma/ct/nh/vt
- knocking noise in my trans.
- ANYONE HAVE EXTENDED WHEEL STUDS? WHAT KIND OF LUGS TO USE???
- advance auto rebuilt axel
- please buy my 2000 civic si man im broke
- Fuel pressure gauge
- Looking For Typr R pictures for my design
- ca. state ref ticket ?
- 95 Hatch+ITR+Greedy Exhaust=Not fitting
- LSD transmission
- Q: MUGEN TWIN LOOP & ITR LCA+ ITR SWAY BAR on EG?????
- Carfax please?
- D16Y8 into DX Civic
- 13 inch steelies on dx hatch not working.
- 98 Civic Electrical Problems
- Busted 99 Ignition after theft attempt, hard to replace?
- wtb legit b18b or b20 block in ma or ct
- Lower portion scrape guard for ITR header?
- 99 ex coupe rotors on a 92 si hb. will they fit?
- b16a2 smoking problem.
- 2.5" piping on a 00 Civic coupe w/ jdm b18c??
- VTEC w/ HIGH milage
- What went wrong? Axle or Brakes?
- D16y7 Knock Sensor
- B-series and D-series intake boxes interchangeable?
- THis Turbo Setup worth it?
- Las Vegas Speed Shops? Southern Cali Speed Shops?
- Gutted+Turbo+Omni+Ohio Winter=?
- HOW TO: build cheap HID Ballast
- ls/vtec question
- what mpg are you getting?
- axle back muffler/exhaust?
- ** Weird Problem ** My beater's cluster is acting up, need help
- cheap header?
- Valve Cover
- Wiring color codes for side mirrors
- d-series swap???
- Need a new intake
- help help help
- Taking out my motor....
- wiring diagram for fuel pump for a 2000 civic ex
- ls/b20 cams
- LSD for GSR in civic
- where do you guys get your amber corner lens?(yes I've searched)
- Need help, I wanna paint my valve cover...
- egr on log sytle intak mani?
- factory ground clearance...
- 94 Civic Driveaxle help...
- SOHC and DOHC same??
- question about a Catalytic converter......
- not getting fuel
- Need torque specs for cam holders on B16A
- what wires on VSS for a b16 swapped eg????
- FS: 92 Civic SI Midwest
- which upper arms are better??
- reverse light plugs
- naw
- Open header
- Will 00' ex Rotors Fit A 92 si hatch?
- I need help on my suspension upgrades please!!!
- Code 43 Help
- civic shaking when stopped
- Question about CTR E-Brake Console cover?
- SI owners: How do i change my clutch fluid?
- low pitch grinding noise
- 6th Gen rear conversion on 5th Gen civic??
- AT won't go into gear after swap
- question: fitment....
- forged internals
- Crank pulley bolt..........
- Help with ZEX DRY KIT install on d16z6...about vacuum lines
- horn
- whats mods to make to b16 to make it run more efficient?
- has anybody got twb itb's in your eg?
- HELP NEEDED FROM ANYONE WHO KNOWS FUSES AND RELAYS ON MY EK
- Shiftlinkage
- EG Exhaust
- LCA's
- Getting ready to retrofit HID's into CTR headlamps.
- Just replaced my blown speakers, still a bit of rattle?
- Getting ready for heart transplant!! plz help!
- greddy turbo kit experiencec on a d16z6?- searched
- sorry guys veig question
- EKCTRwallpaper
- b18 ls Civic
- intermediate pipe for 94 civic coupe
- I searched already.....ITR trunk bar on EG hatch!!?
- hey i need HELP ASAP!!!!
- autometer air fuel gauge install help
- 96 in 92
- best whp for b16a2
- Is it possible to change the KMH in my JDM Cluster to MPH?
- electrical problem
- brakes
- 1994 civic ex rear disc swap
- B16 clutch and flywheel
- Looking for a good sounding exhaust - 1995 Civic / B16A Engine
- EG civic gauges went out
- **Stupid theives Broke my Hood cable**
- Car wont start, nothing works like battery is dead but really isnt. (Weird) Read on..
- Ek or Crx
- fuel problem?
- rear bracket question
- Quiet muffler
- Ignition Problems
- b16 turbo
- overheating
- HELP....how to change mile back to zero on a cluster??????
- checking for leaks in TB
- Info on Head Conversion
- Hood latch relocation.
- EG rear wheel bearings
- Question about tiresize.
- Greddy or Edlebrock kit for d-series, need for slim fan?
- what yall using to repair bumper-bolt holes?
- greddy turbo question
- why are there 2 map sensor codes 3 and 5??
- adjustable coilovers
- Climate Controls still work when key is out
- Simple Question about piston rings
- b16a2 throttle body question
- who did i talk to about a custom carbon fiber lip?
- car smoke at idle....
- Shift light
- Clutch pedal sound like a door knob
- 93 DX MAP sensor wiring help (nightmare)
- Fuel injector tapping really loud..... is it going bad ????
- rear disk help...
- shells?
- ls/vtec
- b16 swap
- DIY angel eyes?
- Del Sol Swap Question
- car revs by itself!! help
- oil separator box cracked. help!
- Dents in CF Hood
- brake fluid Q,... how much is needed?
- 99' civic si Vafc-2 question.. VTM adn TDC
- I'm a cheap Bastard that needs help
- 99' civic si Vafc-2 question.. VTM adn TDC?
- blower
- Steering wheel vibration and wobbling!!?!?!?
- Has anyone swapped a K20 into an eg or ek?
- jdm itr wheel... quick release hub??
- K Series Swap into a 00 coupe
- OMG I BLEW UP MY DEL SOL!
- intake
- (searched) help with adjusting SiR headlights (EK)
- (SEARCHED) Can someone tell me which H22 Header this is?
- d15b vtec water pump and timing belt
- B20b/z question, I've searched to no avail...
- ecu question
- acl housing d16y7
- ex/si tranny???
- aem 99-00 si v2 fit 94 se teggy??
- Code 42 help
- TP error need help!
- serious problem...
- Is it hard to..........
- differant bumpers for 96-98 civics???
- Detachable steering wheels.
- were can i find jdm side marker templates?
- Girfriends Coupe, My DA, preview before The Turbo project.
- my swap.
- Swap shop
- 98 civic window TRACKING help
- Can I safetly run a Mugen 26mm Rear Sway with ASR Brace on an EH2?
- PROBLEM WITH MY 93 CIVIC VX!!!!
- How do you tell the difference between real and fake SPARCO'S?????
- how to check if dimmer switch is bad?
- 94 del sol
- del sol horsepower
- Special tools needed to properly bleed brakes that are ABS equipped?
- Intake Manifolds... Yes or No?
- HELP!! how to remove the window crank?
- Need help in choosing coilovers
- Need help with Swap...
- Hybrid A/C in to Civic....
- Buying Salvage title car...?
- which is which?
- How to Adjust Valve in civic 2000 EX stock motor? Did the search and found for DOHC
- Did it fuck up?
- anyone know what color ek fog lights are?
- 93 prelude
- can i use regular motor oil tranny fluid??
- What is this called (air assist silenoid)?
- a/f guage signal wire help
- Is THere a SIR spoiler for a EK! not mid wing
- front sway bracket cracked..
- timing problem. now set to tdc and wont crank. please help
- how to get error codes obd1
- Miss shift, now Burning oil at high rpms?
- engines direct bolt on fit?
- search is not workin just looking for a answer real fast
- modified exhaust ticket..
- Shift Points For My Tranny
- GSR head??
- Alternator Fuse Keeps Blowing
- Built B18C5 in 99 hatch with stock Exhaust
- 200K miles and 200+ psi compression test? d16z6
- Ticking noise around 3K RPM????HELP HELP
- 02 EX CIVIC CLUSTER NO SIDE AIRBAGS AUTO
- Which engine for my EG6?
- sidemarkers
- Unpluging my o2 sensor makes my car idle smoother....huh?
- changing door handles.
- A/C ON MY 96 HONDA EK CX ???
- How to make a custom intake
- Please Help.. 99 Civic Dark Gray Dash into 97 Tan civic 4dr ??????
- AEM V2
- P28 vtec wiring yes i searched but cant come to a conclusion help me out please
- How to install a clutch on my 95 Civic 1.5L SOHC
- whistling sound at 4500 and up
- Del Sol Door Problem
- Difference between DX and CX hatchback?
- CAR SPUTTERS...HELP!
- JDM Guage Cluster Conversion
- Can someone help me with some part # and confirmation
- trial?
- VAFC with FMU??
- STOPPING!
- urgent: Cluster light problem.
- The ITR forum is for ** ITR ** owners
- Setting Pgnition advance
- Short Blocks: D16a6 VS D16y8! Which to use for Turbo build.
- Need some help: Just did a trannyclutch change
- d16 help
- Intake Manifold Question
- advice
- HELP ME..PLEASE
- How come my AC is not cold when the weather is real hot?
- idle problem (i searched)!!
- how much does a 1997 honda civic ex weigh???
- Auto to Manual Conversion ONE quick question about axles
- mini me swap
- WTB: Jdm EG center console, and bumpers for trade
- s2000 Sidemarkers in 96-00 Civics
- which belt is which>?
- Help!! center piece muffler broke in half........
- anyone bought a Bodykits NW CF Hatch???
- LS Swap questions for 92-95 civic hb
- putting an integra front on a 93 hatch
- Header benefits on a d16y8??
