View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Over heating with antifreeze?!
- MAJOR oil leak, not rear main...what is it?
- Pizza Delivery and MPG
- Heater core hoses?
- Center Exhaust possible?
- obd1 B16 swap/97 coupe alternator problem
- Front End Rebuild
- Dohc and Sohc throttle cable?
- Help on 05 Gauge Convert To Honda Civic Ek
- EG Headrest Pillar Clip / Removal
- 2000 Si clutch issue.
- 97 Civic Coupe Door Lock issues
- 98 Hatch Project
- 00 honda civic - Idle problem after engine swap
- rear trailing arm bushings
- 1996 Ek Hatch Problems
- Car stalls in reverse or drive
- Rear drum and rotor, wheel bearing are they same?
- B series headers help
- my ej8 project
- How to make my EK weighless????
- 94 civic ex coupe coolant question!
- Why does gas pump stop even when the tanks not full?!
- My 93 eg hb si build!
- ek sedan foglights?
- 96 civic swap into 2000 wont start. diff ecu?
- d16 non-vtec
- d15b8 n/a build help!!!!
- identify these plugs please :)
- possible to swap d15b 3stage vtec into civic vx
- stalling and hard start when warm.
- Rough Idle Issue
- How do i identify a 99 si harness
- front sway bar on ek hatch
- Clutch fluid leaking down pedal?
- Sunroof and rust?
- Info Vtec Selenoid Upper Gasket
- Car staring trobles in the moring!
- Clutch Recommendation
- The Layout For My Car
- 99 Civic EX auto - Suggestions for improvement?
- Quieting Exhaust
- LS integra air box fitment in EG hatch?
- will da9 integra suspension ride better than eg?
- oil drain plug replacement
- AEM COIL PACK/ HONDATA V2
- '97 Civic LX Sedan issues, which issues would you fix to get a better price?
- What width wheels can I use on a Del Sol?
- do you guys use lube on your o-rings (IACV,etc) such as DC-111 paste?
- 94 civic 1.5 L DX - intermittent fuel flow problem
- how much oil is required for a 1996 honda civic DX 4dr
- battery dies when it rains or snows
- 98 Civic hatch - obd2 to obd1 conversion for p06 ecu
- Universale apexi ws2 question----->
- 00 civic - rain water leak front passenger floorboard
- EG hatch fail smog miserably
- JDM B16 engine minimum wiring req. to run
- Battery relocation issue
- '98 Dx Intsrument lights not working???
- Weird Noise.
- z6 keeps throwing o2 sensor code. PLEASE HELP
- EK, no horn, partial SRS harness
- s2000 calipers on ek civic?
- tachometer issues
- The right oil for B16A with 70-76k miles?
- how do you remove all the air vents under the dash?
- damaged ignition lock cylinder
- 96-98 Front end on a 99-00
- 99 Civic Ex Radiator Fan Not Starting
- RPM meter is not working
- 15x8 +12 - what kind of spacers needed to fit them on EG hatch?
- 94 civic alternator interchangeable year list
- signal blinkers and emergency blinkers dont work!!
- my 97 ek build...
- 93 del sol s weight reduction
- b16a idling problem (itr tb)
- Problems with front wheels...see pic
- 99 Civic EX - constant battery draw problem
- 97 Civic - stone dead, no lights work but starts with jumper cables
- B-series swap into 96 Del Sol Si -- need help tying loose ends
- 95 civic EX/B-series swap - Will a stock 92-95 transmission work?
- Test for high compression pistions?
- 97 Civic HX - P2P ECU not completely plug and play
- Heater works for 10 mins then blows cold
- 92 civic cx - suspension problem after cutting 2 inches from springs
- 94 Eg8 having problems
- fuel and oil temp gauge issue
- auto to manual Question
- 97 Civic coupe??
- 92-95 civic knuckle/spindle assembly interchangeable?
- 96 ek hatch rack n pinion
- 92 civic d15 engine harness diagram
- Opinions on B16a3 manifold trade??
- 96 Civic DX difficult to start after replacing head gasket - please help!
- Will a 92-95 dash harness work on a 93 del sol?
- 93 del sol si coolant leaking, overheating
- obd0 b16a into obd2 99 em1
- D15B7 engine clicking
- B16a starts then dies, re start its fine
- Catback fitting on my 97 ex.
- Oil light Issue
- 98 ek wire tuck....i need help!!
- Del sol build help
- EG8 starts but stalls if accelerator pressed, then refuses to start until next day
- 98 GSR Dash in a 95 Civic CX?
- how do i convert my chipped manual p28 ecu to auto?
- 15s or 16" rims for ek coupe?
- EK wont start, HELP!!
- my first EJ build
- Motor Mount Madness
- Spring measurements
- Help broken window regulator
- Ultra Slow EG9 Build
- 93 Del Sol Si Mystery Motor
- 1998 civic belt change
- New Hobby
- Looking for information on hatchbacks, aftermarket brand parts, and lowering
- EG vx d15z1 redlines at 5,500 rpm???? wtf???
- I broke the combination switches in my 99 V Reg Civic (U.K.)
- vtec gasket leak
- help with del sol seats in ek.
- '99 Civic OBD2B W/ 97 Del Sol B16a2 OBD2A Swap CEL?
- Where is the IACV on my 96 Civic DX?
- Winter project ideas for 98 Civic?
- Is my alternator going bad?
- shaving the bay need some input
- civic dx motor build on a budget need help
- ball-park how long to bleed clutch (there's no air, just freshening fluid)
- Throttle problem b16
- 01-03 CL seats in EJ6/8
- LSVTEC CEL CODE10!
- What do you think about the invader style carbon hood on a hatch?
- show me your short/throw shifter
- Head Gasket blew again after 20K miles
- 93 DX Coupe w/ 15b7 turns over will not fire up
- Front Suspension
- civic 95 ex fills up with 3 gallons, HELP!
- which spark plugs to get?
- Hazard light Not working
- p2e 5 wire to 4 wire help p0135
- Mini-me Help?
- '92 hatchback - broke college student build/repair thread
- b16 rebuild questions
- DC Sport Header Installation
- what size axle for 5lug?
- After which dissassemblies is a front end alignment required?
- What Could be Wrong?
- The "unnamed Project" 1993 Civic Si Hatchback
- Squeaking when I turn please help
- civic 1.8 s9b lsd into an eg6 sir b16??
- engine decision help
- 97 civic ex exhaust mani same as jdm d15b
- what cars have the same radiator core support as a 1995 honda civic del sol
- Dashboard layout?
- Front/rear brake conversion
- Code p1655 SEA,SEFA,TMA,TMB. Signal Line Failure
- Help w/ b16 parts
- 2000 DX rack - Replaced the rack and the right side clamp rattles
- Need a manual tranny for D16y7
- Vin check??
- Del sol AC fan vs Radiator fan
- Is my clutch slipping?
- D16Y7/D16Z6 Mini-Me headbolts
- 95 Honda del sol D15b7 setting no.1 piston to TDC
- Could clamping history be the reason for painting wheels? [pic]
- 1999 Honda Civic EX - How many oxygen sensors does the car have?
- 97 lx civic - What engine swap?
- 98 civic - speedometer stopped working
- Replacing Head Gasket - what else should I replace?
- Loud Blower Motor
- Tire rubbing-like and squeaking noises coming from my car :(
- Wheel/tires from 95 Civic compatible with 00 Civic?
- 1996 Civic - high and hunting idle after changing head gasket
- d16Z6 Vtec pressure switch on a d16Y8 head?
- 99 civic manual swap
- 94 Civic EX - Only starts if ECU is unmounted and unplugged
- best body kit if any for my 93 ex coupe?
- del sol AUX lights, not FOG
- 319Caby's 1996 Hatchback Build
- ex coupe 93 civic
- OVERHEATING PROBLEM HELP PLEASE !!!!! :(
- 98 civic dx hatch just lost acceleration while driving! help plz
- 97 Civic transmission mount - Need size of three bolts
- 1995 Civic Coupe Rear Disk Swap.
- B16A2 bad oil leaking (intake)
- '97 EX - Code 22, Idles shity, stalls, runs fine over ~1200 rpm. VTEC stuck on?
- ****98 Civic Coupe (JDM B18C Boosted Sputtering / Idle Issues Help!*****
- 95 civic LED cluster help??
- help plz. ek hatch front end shakes.
- possible spring unbalance - 93 Del Sol
- filling tranny, small bb flowed out at the end, after tranny job
- Eg coupe bogging
- 93' Del Sol - seems to want to stall
- 98 Civic HX - rear defroster dont work
- interior light wont turn on with doors open
- inconsistant power issue
- 97 Civic HX - What Engine do I swap...GSR B18C, B16a or what?
- Fuel pump lags to prime.
- Theft prevention
- Too much oil
- Frozen clutch
- 00' civic sir - exhaust question
- Eg hatchback si vs Eg coupe Ex
- 98 civic with multiple codes please help!!!
- Really bad oil leak
- P1768 code
- 96 civic stock catback exhaust broke in half
- 93 CIVIC HATCH d16z6 problem
- 92-95 civic front end help
- Too much oil!
- 00' civic sir (canadian) - Exhaust install question
- $2000 to spend basically stock 96 ek coupe .What do I buy 1st?
- Idle problems 2000 Ej8
- eg hatch under construction...
- Just purchased my first Honda the other day...
- 98 ex: lost control on ice & hit curb. bad wheel bearing?
- 93 Civic/D16Y7 swap - Engine sputtering again + Other problems
- Best route for 250-300 hp on a civic or del sol?
- Hesitation and bucking issue
- 99 Civic will not start - HELP!!
- Wanted to get flywheel recommendations based on other people's experience
- ek with b series starter question
- OEM door actuators fit in manual lock (92 vx)
- JDM ZC swap into EG - Will d16z6 motor mounts work?
- 92 Civic core support.
- 98 civic SRS light
- Anti-theft hardware suggestions? (bolts/Screws)
- 92 EG CEL problem
- 95 civic sunroof issue
- 95 Civic Dx Automatic 1.5L Intermitent start
- CEL 8 On / Off Fixed And Still Showing
- seats acura/honda slide forward
- Best place to buy CTR headlights
- 97 LX Door problem
- Oil in Radiator Overflow Cup, 99 Civic EX
- my 92 hatch on its way to greatness..
- 93 Civic EX auto - what can I do for cheap to make it quick?
- manual TO auto conversion
- BogosEG8 TURBO BUILD
- B16a2 swap into stock EK civic with D-series - How deal with h, ac, ps?
- 94 civic no crank no start
- Picked up another toy, this time for the wife. Turbo H22 EG Coupe inside ;)
- Transmission problems after D16 swap
- 1999 Civic heater blows cold air.
- Any info on power window motor bolts?
- Del sol keeps loosing power
- Del Sol b16 Tranny vs 99-00 SI b16 tranny
- Different approach. Difference in o2 sensors and what Ecu is should I be running???
- 95 Del sol: Squeaking sound every time I accelerate.
- 95 civic wiring and sensor issues
