View Full Version : Honda Civic / Del Sol (1992 - 2000)
- clutch or tranny problem? car is hard to get into gear also poor MPG
- Eg with a carb legal k motor
- About The Exedy Clutch
- Cylinder Head Porting
- exhaust piping
- 96 Civic Sedan Towing question....
- exhaust bushings
- Wat Rad In My H22 Eg
- 94 civic fuse box
- integra steering coumn into ek
- Is it true that if you don't use it, you lose it?
- Code 22, Help please?
- Lower rear control arms and sway bar questions...
- Ek navi question
- What is a VX Engine and 5 Spd Worth
- What city light bulb / bulbs for these sockets?
- black housing on EG
- posi or not?
- which power steering bracket is the rite fit.....help please
- 92 to 95 Honda civic two door front end (wtb) in MIlwaukee, Wisconsin
- b2o build
- 99-00 Fog Lights....NEED HELP!
- I need your help???
- well a 96-99 civic coupe exhaust fit on a 92-95 EG civic ??? please help
- i am an impatient noob...
- h22 swap into 93 dx i need parts list
- 93 D15B7 Auto Tranny Cable
- Radiator Fan and A/C
- car leaking water...any ideas?
- 97 b18b swap into ek
- 99-00 Civic FOGLIGHT HARNESS!!!
- b series timing cover question...
- codes 71-74 random misfire in a b18 civic ek
- What seperates EG6's from other EG-EH model names...
- in the market for a new cat back exhaust
- turbo in the exhaust?????
- how rare? 95 civic ex coupe black leather/pleather interior
- steering wheel question
- I'm having serious wiring issues, and now my windows wont roll down...ITS HOT!!!
- srs and fuses!!
- DX to VX Wiring harness
- b16a distributor? Need help
- Good JDM Website?
- integra dash in a eg civic
- I heard a B16 or LS automatic bracket would fit??
- Anyone know where to get.....
- help me pick a bucket seat
- ecu question
- Help bleeding the clutch, to the floor
- advantage and disadvantage of a lighter flywheel
- What did i get myself into?
- how hard is it to change head gasket on D16Y8?
- 93 Civic Ex 4dr k20a swap
- It looks funny but it works!
- b16 timing belt cover top outer
- Accord motor in civic?
- vibration please look!
- what would a 93 coupe run on the quarter mile
- LCA's
- FOR 92-95 Honda Civic
- Nothing in the car works, won't start
- Tech Help needed Here
- NEED HELP PLEASE!
- new toys for my EM1
- probable b18b issues
- problems troubleshooting!!!!!! help
- where to buy clamp for intake
- Flushing Power Steering Fluid??
- FAIL!!!!!!!! State Ref. Test PLEASE HELP FIX PROBLEM. Test resluts pictured in posting!!!!!! bump f
- Best of the Best 2....
- H22 EG DRIVE SHAFT PROBLEMS... what aftermarket choices do I have??
- Best of the Best....
- Can 00 GSR CAT directly replace 97 EX CAT?
- Windshield Question
- Missed a shift..
- qwestion about hondata ecu....
- Keyless Remote programming
- iacv pinouts
- help car wont start and vtec controller dont work
- bad axle?
- On and Off Vibration
- really bad idle.. ! help
- Racing Pulley question/opinion
- How would I go around cleaning my spare tire area in my eg hatch back?
- need help with my car
- new brakes queston
- quick tranny question
- H-T HELP!. battery fuse keeps blowing
- good camshaft????
- OBD2 to OBD1
- So someone decided to steal my car
- b16a2 10k miles engine burning oil???
- Megan Racing headers
- EX/HX 02 Sensors
- Need Advice : Should I build my D15b7 engine up?
- i need i deas!!
- disecting y8 ecu
- Motor Cooling Problems
- 92-95 VS 96-00 Civics.
- Dizzy problem
- which harness to buy? want to run ctr ecu on obd1 car.
- mini me question
- no fuel, no spark, no start!!
- Question about my 98 civic lx...about the brakes and the suspension
- stock haedlights 96 hatch
- Dizzy????
- 96 hatch A/C fuse keeps blowing need help
- car makes no power under load.................help?????
- Overheating.... Damn...
- dizzy price at majestic honda??????
- eg with k20
- climate control in glove box
- how do i foun out wat chip i am running
- Break light comes on while driving?
- *** EG's PERFECT EXHAUST???
- power steering bracket
- Which ecu?
- Need help on my sohc vtec swap into a 99' EK civic hb.....
- which one is the best....
- Old gas=Rough Idle...NO CELS
- HOW ABOUT SOME AIRBAGS????
- 98 EX doors on 00 EX Coupe. Locks not working & blowing fuse ... help!
- password fog lights for ek HELP!!!!
- GAUGE BULB PROBLEM!!!http://www.autolumination.com/!!!!
- simple ecu question
- ground wires
- clutch question
- low idle(barely runs) giving it cause causes the engine to die
- mini me v-tech help
- b16a3 ecu code
- gold gt3 on red si?
- PO133 bank 1( slow response)
- need to do complete exhaust from motor back what should i use
- the process of lowering your car
- d16 overbore?
- Opinions on good investments for your ride
- Irratic idling problem, not the typical one
- Mud flaps question..
- 94 Honda Civic b16 swap problems? Questions. NEED help/advice
- eg brake lights out
- Which CAI?
- Advice/Comments on a '00 Civic SI
- need help!!!
- wtf is this noise????
- does anyone know..will the 96-99 civic coupe greddy exhaust will fit on a 92-95 CIVIC eg6 HATCH?
- codes??? 93 del sol with obd-1 jdm d15b
- check engine light is long on and off and keeps going
- Rear Drum Knocking While Slightly braking
- I want to add a/c +power steering to del sol
- I want to add A/C + Power steering to 93 del sol
- state ref question???
- Aircon radiator
- Anyone ever add an A/C to there del sol
- Anybody have an opinion about the turbonator?
- Brake bleeding?
- TURBO OIL FEED LINE - from the top or bottom?
- DTC question for em1
- srs help
- Idling Problem, Rough idling Keeps Bouncing up and down..Help Please
- good or bad idea
- Major engine problem!
- check engine light?
- Throwing Code 21 - VTEC spool solenoid valve - how to test?
- Trouble replacing H4H bulbs
- For some reason vtech aint doing its job
- high mile chassis?
- Help with control arm bushing
- 97 civic jdm b18c with major problems need help
- radiator core support replacement help
- ZENN?
- 5 Lug from an EK9
- AEM Adjustable Cam Gear
- Car starting problems.
- Heater doesn't work well
- Which is the best...
- eg civic bumper quick release
- looking for lost picture
- 1 wire o2 to 4 wire o2
- pilot bearing
- 92-95 civic guys
- HELP!!
- Help with finding a frontbumper to EK4
- Problem
- to keep or not to keep
- car overheating. temp drops when heat is on.
- please help with my d16z6 swap in my 97 hatch
- OMFG Leak!
- what is this part of the window called? (regulator..gear..etc.)
- Civic Suspension
- OIL PUMP QUESTION B18C1 and B16A
- DIY: How not to get your car stolen / Security measures
- what torque for flywheel bolts
- are there any A/C guru's out there?
- Do I need to replace the tensior when replacing my timing belt?
- Paint Question??
- Factory struts interchangable though the years?
- Ek weight crisis! which engine for autocross?
- Cooling fan doesn't spin. Help.
- any easy way to adjust your idle speed?
- nedd swap help
- 92 Hatch for sale
- Password JDM license plate relocators
- eibach sway bars..anygood?
- Left brake (tail) light does not light up
- problems with my hatch
- Aftermarket shock mounts?
- bad sputter when the car idles for a min.
- hey
- iacv ecu Pin?
- axle back exhaust
- Will this fit my car? 92 Honda civic Hatch
- O2 sensor keeps going bad
- 99 civic si Injectors
- 1,2,3 probLems: brakes, carbon fiber repair, running lights
- help... do i really need this fuse box to run my car....
- exhaust system
- ls swap options
- Paint code.. URGENT!!!!
- spark plugs
- New mounts but motor still shakes????!?!?!
- stock B16 whit a cat back non cat
- Oil pan stud, comming from the block, stripped out - B18C
- B16a3 header
- Del Sol overheating..
- Belt Tightening question
- supercharging b16??
- ball joint
- Question about CRX SI Seats in 94 Civic EG hatch....
- y7/y8 mini!?!?!?!? WHAT
- JDM->USDM chassis codes/names confusion again!
- some one help please!!!
- ODO Rollback to 000000?
- MOMO steering wheel - help me fix my horn!
- help me (EK Hatch)
- ZC Swap Leftovers
- turbo d, vs stock b18c1
- ECU/CELcode problem
- opinions on itr bar and beaks kit for EK chassis
- civic rear hub work with integra spindles?
- Rear fog.
- oil preasure gauge
- paint ?
- horn doesn't work
- 92-95 JDM EG6 gauge cluster lighting problems... wiring? What. Help me out.
- Not a main relay, what else could it be?
- So now my gauge cluster doesnt work, help por favor
- 99/00 ek conversion
- How to clean my rims????
- oil on spark plugs
- ls swap into an ek
