View Full Version : Honda Civic / Del Sol (1992 - 2000)
- 17" rims on coupe
- building up d series than boosting...
- Timing Belt moving side to side on cam gear
- Civic 96-98 cassette player wiring?
- what is needed to do a 2000 civic conversion???
- hmm maybe off topic
- distributor help
- some questions
- D16a9 head gasket? will it fit a D16z6 engine?
- question on 99/00 Si
- what parts do i need for a b16a swap?
- Is this a knockoff?
- K20 vs b18 type R or b16 type r civic?
- Civic Type R pulley, what belt do i use with it?
- Having huge issues after swap was done.. wiring guru help appreciated.. 98 ek hb..
- broken temp gauge
- 3rd gear 95 mph
- D16 tranny swap info. What works
- looking for that exhaust!!
- Adjustable shocks and CTR strut bar
- where to post build threads?
- skunk2 cams q's
- Bogging Q Help please.
- single cam turbo or motor?
- Timing Belt Tensioner Question: Need a DIY or Instructions.
- rattle under dash in my ek.
- manual boost controller install
- new to HT...just wanted to say whats up and post the rides up. (ton of pics)
- leaky clutch master cylinder
- Has this happen to Anyone on H-T.com before Window came off track and not to sure how to fix it??
- different clutch suggestions?
- automatic to manual
- 2000 civic build up
- cluster not lighting up 98 hx
- Oil Change..
- help cluster not lighting uo or climate control..
- Anybody install a Sparco EVO L?
- Grinding noise?
- p06 ecu to vtec question
- Where can I order some real authentic JDm parts
- wire tuck
- 98 EX Auto, GOT FUEL, GOT POWER, no starting is driving me nuts
- Broken part - need help to ID
- MIRRORS???
- ecu ???????????????????
- identify rare om ek lip?
- Clutch & Brake pedal bushings
- car wont start
- brake light switch problem
- Car shuts off
- 92-95 hatch w/newer obd2 motors in california..
- Del Sol Exhaust?
- never ending overheating problem......
- identify this unit??
- which trans is better since i have the y8?
- rolling my fenders help
- b20 ls scam?
- Please help me to identify this part.
- trani knocking!
- How much for a JDM Type R??? (b18c)
- rebuild a b18c5 for a del sol
- more hp out of d16y8?
- GSR swap idle problem
- what to swap in???
- 96 civic dx running lean and burning oil, please help
- 95 eg camber
- new kidd on the block !
- how do i read any codes if i cant find the plue to put the clip into
- Should i sell this?
- 1991 honda hatch front end????
- what plug is this on ls block?
- plug question?
- wiring my vtec to p72 ecu
- Trans or clutch??
- stolen ej8 escondido recovered pics
- A/C Problem
- Spark plugs for high compression y8?
- question about jdm fog lights for a 99-00
- 2000 si engine problem.
- 99-00 civic SI CD player
- Interior Kit for 1993?
- Question about suspension?
- TURBO KIT
- Which Computer to keep Virgin P28 or Virgin P72 for a GSR motor
- baro/atmospheric pressure sensor
- Car Stolen. 97 Civic Hatch Roma Red
- Finished 92 LX JDM D15B Swap...Pics 56K BEWARE
- need diaphram with wire color description and what plug goes where?
- Planning stages - turboing D16z - Parts list (so far)
- problem with swaping b18c1 to eg hatch
- checking cel for 96 hatch
- I am in need of SERIOUS help.....
- p06 chip
- Baffle for magnaflow
- Stolen civic NYC
- NEW TO THIS SITE
- fan
- is there any where I can purchase painted ctr grille?
- powered non CF spoon side mirrors
- Engine Confusion
- Intake
- Request: Part Number
- !!!HELP!!!
- headlights question
- Sound from clutch (not a squeak)
- Fitting twin-loop on a 92-95 Hatch
- Full SS System for my EK4
- door hinge civic 92
- oil pan two low
- please help, sqweeeeky rattling sound from engine bay :( tried to fix,
- weird engine noises
- V-tec difference in b16 and b18
- Welding hangers on muffler
- new swap, running a little hot. help needed
- Blown Motor! :(
- Input shaft bearing?
- Do EDM and JDM B series blocks have VINs
- quick question about LS swap into civic
- Basemap question
- MiniMe Swap D16Y8 head D15B8 Block how to???
- jdm EG6 SiR-II requires what type of Pads?
- will b series clutch and flywheel bolts work for a d series?
- will 13s fit on a 92 civic si?
- How to put a gsr gauge cluster on my 95 ex????
- 96-98 & 99-00 digital climate control query
- foglight installation
- GSR hatch header/test pipe question. **Pix inside**
- Noise when i let go of the clutch
- Whats the diffrence between a D16Z6 head, and a d16Y8 Head?
- 1990 Civic wont start (has fuel, fire, and i just check the timing belt) PLEASE HELP!
- Exhaust rattle/Disk brake noise
- problem with my gsr on my 99 civic
- resurfacing
- Interieur EK to EG
- anyone know where i can get a type R head for a reasonable price here in socal ?
- hey guys
- Mini me swap, running rich, rough idle, oil coming out of exhaust
- VAFC Question
- I HAVE A QUESTION ABOUT DENJI HEAD LIGHTS ?
- bored b18?
- horn problem for 99 civic
- New Clutch ???
- Gauges on your Ek?
- E-Brake cable confusion
- bent valvue/ skipped tooth question,
- 1994 civic vx with gsr brake swap.
- what is a good brand carbon fiber hood that wont fade easily??
- WTF D16A??
- Newb to D series motors
- New Here!
- Wiring diagram???
- d16 single cam motor and trans,100k miles
- ek sideskirts???
- QUICK QUESTION
- b18c
- ex trans on y7 block
- B Series del sol swap
- c-west body kit or 99-00 front end conversion
- Few problems help?
- who hates oxygen sensors as much as me?
- My build: H2b into 2000 Ek
- Vtec Solinoid questions, D16Z6
- I Need Help and Info on an Engine Swap...
- fan??
- will this work?
- Need some opinions on my new DOHC ZC
- Differnence in between em1 and ej8 exhaust?
- new pistons question..answer fast pl0x
- Civic Inner Tie Rod = Integra Inner Tie Rod (Searched)
- how do instal my buddy club v-tec controller
- water temp sensor question
- trade b20 da for a hatch or coupe
- 1995 d15b7 wire harness how to....
- Help w/D16y8 Timing Belt, Marks are off, tried everything!
- Frequest Stalling/bad idle/rough idle, cyl #1 to blame?
- SOHC TURBO ISSUE....
- TRAILING ARM
- NEED HELP!! i have a JDM b16 valve colver but my motor is b16a2.
- NEED HELP!!! New fuel pump but no fire!! won't start!!!!
- advise please - Replacing timing belt and cam tensioner?
- muffler ?
- does anyone have a shopkey log in?
- vac leak help! asap!!!
- delsol jdm cluster
- Fuel Line?
- need help!!
- 92-95 SIRII rear disk on 94 ej1 coupe ABS?
- MOMO HuB wont come off
- 98 civic oil pan torque
- del sol power steering problem!
- Does This Seem Normal?
- Brake Light/Horn FUSE Problem
- Del Sol dual core radiator for D-series?
- tranny question
- ek with obd1 swap
- home depot set
- Rev limiter
- Replacing Wire Harness
- Water pump pulley came off...
- OBD2B car with OBD2A wires?
- Couple of questions about my new Civic.
- New 94 eg hatch teal. take a look! any ideas? first things to do? exterior? engine?
- b16a into vx, won't start
- Who know what these connectors are????????
- interior hatch paneling removal
- carbonfiber roofskin
- a/c
- 99 em1 body work. Please help!!!
- super fkin noob question
- help! left signal not working after installing ek9 foglights
- HIDs for JDM EG Headlights
- Wheel bearings?
- Intro for an old skooler
- Role cage
- 96-00 civic ex cluster.... What is the green plug?
- del sol trouble
- b16a swap will not rev past 3200rpm help
- swap question
- Auto to Manual Swap Using Cable Style Tranny question
- Nippon rims? anyone
- Mini me D16z6 head with D15b8block VS D15b
- what swap should i go with?
- will ek center consol fit in eg?
- OEM Plastic gas tanks??
- Springs or Coilover
- o2 sensor
- Alternator belt will not tighten at all.
- >>>>>>>>>>>>>PLEASE Help Me!!!<<<<<<<<
- B17 IN A 94 CIVIC COUPE?
- Rebuilding b16 transmission
- Engine shakes too much
- POWER LOCKS AND WINDOW PROBLEM!!!!
- code 71, 72, 73, 74
- I think my Del Sol has finally Died
- messed up cvt tranny
- d16 problem
- broken spark plug
- Mirror question
- where to get a exhaust manifold gasket for a 4-2-1 2pc header ??
- Ricer..heh yea it looks like it..shifting problem
- Noob question
- 0
- newer tires at the back or at the front??
- b16a OBD0 swap into 93 del sol
- wheel stud replacement question
- engine over heats while revving around 4k-8k
- replaced heater hose now i over heat
- location of main relay?. 98 hb..
- ef dual poing. swap to fuel injection motor. what do i need to know and buy.
