Best ecu for a b20b swap?
I know this questions been asked a thousand times already, but anywayssssssss
it's a 2000 jdm b20b swaped into a 95 dx hatchback, current ecu PR4, I'm planning on going vtec in the wintertime, so I'd like to be able to chip it for that, I'm thinking p72, but I wanted a second opinion from you guys.
O.G. triple O.G.
Re: Best ecu for a b20b swap?
Don't use the P72 unless you are running a Gsr head. The cheapest way to run Lsv setup is p28 chipped ecu. However, if you won't have that setup until a later time, run a P75 LS ecu.
Use a chipped P28 with a b20b map in it. This will get you by until the winter. When you install the VTEC head, have either your local tuner reprogram the chip with B20-vtec maps, or order one online from a reputable vendor.
I'm a baller on a budget right now, so I'm probably not gonna get anything chipped until I go b20-v. I'll probably pick up a p75 then, anyone got one they're tryna get rid of =D
JDMhoe1992
12-23-2011 05:22 PM
Jdm_Ego
12
09-27-2010 03:42 AM
MontanaSFS
05-18-2008 09:50 PM
