View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EBAY Exhaust systems!!
- 95 civic d15b7 gasket replacement
- EG8 Trans & Engine Swap Help!
- My mini-me build
- Size of the speakers for a 92' Civic Si Hatchback?
- Cruise Control Kill switch!?
- engine redlines at 6K?
- EF suspension on EG, disadvantage?
- Sealed Sunroof?
- Help eg civic si swap problems
- do ek hasport mounts fit an eg
- Head bolts into d15b7 block.. Possible to use longer ones
- D16Y7 help, strange rattling when accelerating.
- 2000 b16a2 oil leak
- climate control problems - 1 and 2 settings not blowing air
- Selecting the right piston size?
- Coolant Temp Sensor
- Groove on crank from rear main seal
- NEED HELP WITH MY 92 HATCH/b18 b1 block - What ECU?
- 1992 Civic LX Little or NO Heat
- p0450 evap system
- 97' Del Sol S
- moisture inside my 98 ek sedan, loud blower motor, same issue?
- Civic has a hard time starting?
- Need to Hide the Radio car Hole?
- Rebuilding B16a2 head...anything missing?
- 1994 Honda Del Sol Troubleshooting
- Suggestions for lower seating position
- Lca question 93 del sol
- EG parking brake light always on???
- Flywheel resurfaced?
- Have some foglight system questiuons
- 99 Civic HX auto has hesitation problem
- 97 ek4 -- Driver Door Open switch
- 2 silver sticks sticking out on sides of mudguards...what is that?
- HELP!!!!! With JDM D15b!!!! PLEASE!!!!
- Replaced Lower Rad Hose Clamp getting lots of bubbles after 30 mins of bleeding D16Y7
- Anyone tried these headlights or site?
- 95 Civic hatch - H out B in
- '96 Civic Slave CD Player Problems (P/N: 08A06-181-210)
- Blown Headgasket?
- EG with quick release - now want to go back to stock
- ecu questions
- Tenzo-r Racing seats parts ?
- Can I get OEM Honda emblems from dealer?
- Rear Disc Brakes Question
- Speedometer randomly stops working
- a blue plug?
- Front suspension HELP!!!!
- Weird startup questions
- 300hp. Am I getting a good deal?
- Smoking from the head
- Del sol - couple questions before ordering from ebay...
- 98 civic lx/mini-me/auto transmission- what Ecu should i get?
- Mini Me Swap Compression Question
- 1998 civic ex- no heat!!
- what connector do i need to short the service connector?
- Need assistance selecting seat rails
- Need opinion
- My 1993 Civic didn't pass inspection. Nox reading.
- Vtec Solenoid Question
- Blown Motor 94 DX d15b7 to d15b JDM
- Integra Immobilizer into 00 Civic Si/00 B18C5 Swap?
- b16a2 fuel rail on JDM b1c-r
- Anyone know where I can get some new lugs for my EM1 wheels?
- Delsol LEAKING ROOF fix for cheap. PICS
- 97 Civic..Swaped b18b1 turbo...TPS Issue or sumthin eles?
- no start 92 civic 1.5l (detailed)
- k20 swap plz help lol
- Wire Question (93 Del Sol)
- Help swapping 98 D16Y8 into 98 hatch D16Y7! :p
- H22 swap fuel line question?
- My car was stolen this morning - How to keep it from happening again?
- 95 Civic - new engine needed - looking for online sites
- is this hose mandatory?
- Car Overheats after replacing thermostat
- eg worth fixing??? help!!
- MAP sensor test, 1998 Civic, done correctly?
- Used transmission inspection
- 99 Civic si EM1 Dyno pull
- 98 civic hub spline count
- 96 Civic clutch/gear engagement problems
- Question: KW suspension varient 1 opinions on Ej1?
- Which coilovers would be good for my 00 Civic SiR (B16A2)?
- Cracked exhaust manifold
- 95 civic, nothing lights up, cranks very little
- h2b-what do you recommend
- obd0 and obd1 1 wire 02 sensor same?
- Sick 00 Civic/D16Y7 - No Power, Bad Gas Smell, weird idle
- Si Gauge Cluster reading 20 mph and 2500 rpm while sitting at idle
- 92 civic ls - codes 21 and 23
- 97 civic w/ b18b1 swap wire harness question
- 92' Civic Si Hatchback - DASHLIGHT PROBLEM!
- Help with climate control?
- 97 Civic EX coupe - Shock tower harness & connectors (driver side)
- 98 LX header fitment issue
- Main relay not unsoldered, but still bad..??
- 92 civic crazy idling problem
- car won't move in any gear, clutch doesn't even grab
- Full d16z6 swap with ecu..now gets 15mpg and diving idle in neutral?!
- Need help quickly - Lower Control Arm Bushing (inner) on 2000 Civic EX
- I Keep Getting CEL P0171 (lean) On My EM1
- 0bd1 wireharness needed 92-95 civic manual
- Intermittent Speedo
- what year is my engine??
- Raising Compression!!
- IAT code remains after connector swap
- Whatcrank pullies willworkon D16Y8
- 96 civic cat URGENT HELP
- D16Z6 swap having trouble starting/staying on.
- 95 hatch with D16A6 seems to run cool
- How to do a compression test when motor is not in car?
- new distributor,rotor, ECU etc & still won't start
- JDM b16a lsd problem?
- 2000 civic si rear camber question
- Slight Knocking sound, not constant/ all the time
- Watch out for thieves in Plano, Tx area
- Civic 93 will not start. Cranks up, but will not start? No spark
- Transmission ground strap mount?
- Anyone know what are thease side skirts??
- First swap. 96 LS into EK hatch. help
- IAC Valve
- Desperate! 00 civic misfire, p0141
- front sway bar experts
- Ac rattle?
- vtec working?
- bleeding brakes when change (1) single line
- 95 CX USDM hatch - Is blue interior rare?
- Heat stopped working (97 lx)
- B16B distributor
- my tdc.. ( pic )
- How difficult to put a 98 ex vtec engine into a 98 Civic lx?
- -97 Civic EX - Odd grinding/metal/squealing noise in front
- 98 Civic hatch/99 B16a2 swap/P2T obd2b ECU - won't start
- honda civic 94 EH9 seat belt and head light chime problem
- DIY FG seats into a EG
- 99 civic si wont start.
- 2000 civic si misfire problem
- Need help doing a 06 si seats swap in a eg
- D16Z6 Engine Mount Bracket Bolts
- Hondabond 4 on rear main seal housing
- Is there such thing as a quiet 3" exhaust?? TURBO SETUP??
- woo
- 98 Civic EX - Why is it bad to flush your manual transmission?
- Advice on I/H/E, cams, valves for stock D16Z6?
- Air Intake Replace Question
- Bench bleeding clutch master cylinder
- EJ6 and EJ8 Automatic transmissions?
- Injector questions.
- Whistling/whining/almost a supercharger noise at various RPM
- New Honda owner with a couple of questions
- Half throttle going up hill = open loop?
- 96 hatch/B20 swap -- ITB's & Computer questions
- 99 em1 with b18c
- p28 injector driver question
- Engine swap, pull trans or not.........
- Civic Ex Swap with a B18B1 - What year Acura does this engine come from?
- Del sol - headunit cuts off then turns right back on and headlights dim
- 96 civic cx died and won't start - Codes P1300, P0303, P0304
- 92 Civic/94 ls swap - what bracket for power steering pump?
- 93 Civic DX - Brake Pedal Engages Low
- catalytic converter problem on a ek hatch w/ gsr swap!
- Will rotors from a 2002 mr2 spyder fit in my 97 Civic?
- Intake manifold - What is this broken piece (pic)?
- Quick Question
- B16 Pistons
- B20 bad rear motor mount??? Question
- 98 ex won't start, exhausted the obvious things
- what engine will fit my 98 civic ex?
- Honda Civic Automatic Tranny questions
- d series exhaust manifold
- 99 Civic DX/JDM b18C swap - cruise control, main cap, and wire harness questions
- 2000 Si B16a cranks but won't start Please Help!!
- HELP Del sol fast jumping idle@1500-2000rpm and bogging at 2200rpm
- Brakepad shims?
- 96 Civic weird random problems
- 1997 civic si catalytic converter
- oem front bumper
- bit of bad luck today and in need of a part??
- 97 civic hatch compression problems
- Mechanic said that dark oil is one sign of bad rings. Is this true?
- EG -- questions about windshield trim, roof molding, and door seal removal
- VTEC Solenoid Issue (Base Gasket?)
- wheel bearing issues
- Photo or how to I.D the gsr third gear
- how to convert to ABS?
- 90 hatch with d16z6 and lots of questions
- at what rpm @ 70mph ex or dx tranny?
- Hardrace bushing kit 99 EK, where to get em ?
- d16z6 motor with cable trans?
- Replacing ONLY Crank Seal on 99 D16Y7
- b20b Del Sol exhaust question.
- Lower Hose - Cold? Direction of Flow?
- small bubble coming from radiator with the cap off
- My ek hatch build
- 93 Civic EX Bad MPG & other problems
- knocking sound whats the problem?!!
- Help!! I need Advice on buying a civic!
- Stock fuel pressure for b16?
- NRG damper review for those interested
- Need Parts/Advice for my new Del Sol! Help!
- Exhaust interchangability with swapped vehicles?
- Shifter boot replacement - 98 w/ 5 sp
- Where buy steering wheel and quick release hub?
- Noob w. 92 hatch axle problem need some help
- identify this transmission please..
- How do I wire an A/F ratio gauge?
- Gauge Cluster
- D16y8-Whats The Best Intake Manifold Gasket For Performer X?
- Help with d16y7-d16y8!!
- Transmission oil leak.
- D16y7 intermittent misfire
- Bypass CEL PO325?? Question??
- Throwing TDC sensor CEL
- Coolant dripping from exhaust, car eating coolant 97 civic lx
- 99 civic ex with gsr swap won't rev pass 3000
- B18c Head Noise 95 Coupe
- TDC sensor P1361, P1362 Help please!
- 97 LX still won't start after alt install
- 97 Civic Dx Driveability problems
- Its been a while.. .D16y8/d15b2 questions.
- Misfires and no compression. HELP!
- B/D Series shift linkages
- 94 Civic hatch/96 GSR swap - CEL codes 10 and 21 - Please HELP
- Engine Selection Help
- Swap harnes help..
- car is sputtering when i accelerate
- Vacuum tubes
- how do you rollback mileage?
- 2000 ej8 transmission problem!!
- coilover help
- What is that? civic ex
- help on d16y7 - idle problem, iacv and ELD codes, and speedo doesn't work
- d16y8 misfires please help
- D15B fuel injection question
- 99 si with b16a cel code problems.
- gsr wont redline to 8200. HELP!!!!!
- Hiccuping b16a?
- exhaust popping
- 92 EG Radio OEM Radio Swap Issues
- srs codes pulled up
- found this on my magnetic oil drain plug
- 1996 Civic LX - Can't decide what route (motor) to go with?
- 1996 Civic EX passenger lock not working
- Questions after an accident - Airbag related.
- obd2 help
- 94 eji civic amber corner light problem.
- just replaced fuel filter and pump in my 95 del sol - code 43
- Massive problems- 94 civic dx zc motor.
