View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Clutch
- I did not know this, but...
- Help please...about posting topics
- Anyone with carfax for free...
- lug nuts or rear tie bar?
- jdmshit engines?
- smoke frm engine??
- 99Si clutch pedal assembly in a 98lx
- B18b swap
- Hello. Help again :)
- tuning my cam gear
- Help me label this pic please.
- JDM SIR spoiler for EG
- steering knuckle question
- just did an oil change and #$%^&*&
- Free Carfax
- EG taillight removal
- HP and 1/4 mile guesses
- Which cat to use
- anyone know if they are the same cat
- Please I need a Free car fax!!!
- stuttering!! please help!
- b16 del sol 1/4 mile times
- is this worth 300
- Problem Starting Car, Need it for new delivery job so help ASAP please!!
- sensor on the catalytic converter
- T-Bone car accidents
- Good info on wheel weights..
- 93 Virgin Hatch Meets Mr JDM
- JDM rear glass on a 92 Hatch
- 92-95 Civic Ex/Si rear motor mount
- Need help patching/fixing my CF lip
- My car wont go into gear and Ive tried about everything...Need car for work ASAP, please help....
- SRR sway combo vs Comptech sway combo
- HELP......96 Honda Civic
- Update to the EK just thought I'd share some photos (56k ?????doubt it)
- about rsx-s seats in a civic using stock eg seat pans?!??!!
- Heater stays on when car is turned off. Can anyone help me?
- my e cutout :) pics
- Read this and tell me what i should do!
- Help!!!!!Tranny or LSD problems
- D17 tach wire?
- Toggle buttons bulbs?
- Finally, Greddy! SOHC VTEC Turbo Kit is Cali legal.
- RHD anyone?
- how much are 15" black w/polished lip mugen MF5's worth?
- Which one is a better setup for a EK hatch as far as sway bar goes?
- B-series Transmission stripped mainshaft
- eg4door + c1 + OEM cat & exhaust....=which OEM header? ls,gsr,itr?
- trunk light in EG hatch?
- i want this
- posting?
- Autometer VAC install
- tire question for si's
- Can you help to stop EK EG EF EM thefts!!!!!!!!
- Idle Problem
- G Tech Pro Manual
- Subframe Reinforcement Methods???
- Will Skunk2 coilovers & KYB shocks from 95 Integra GSR fit a 97 Civic HB?
- Del Sol Exhaust questions...
- Oem front light install? help
- Majestic Turbo Vs. Force Performance
- Help my car stoped working.
- Someone Trade my Ek for your EG.........
- b18a1 in my ej6
- CYP sensor...pinouts needed....some fricking help.....
- i might buy new suspension is this good combo?
- JDM bulb trick
- speaker sizes in EKs
- check out the interior
- You think it wont happen to you.... then it does.
- Another Eg hatch
- 195/50/15 nitt 450's? Few questions.
- How do I get the Door latch out?
- Clutch question for my D16z6, help me out.
- B16a3
- can anyone run a carfax for me??
- One last tire question......
- how much is your car worth?
- Looking for engine harness
- 5th Gear RPM on 99+ b16a trans
- Test Pipe Question
- climate control????
- Small Vids of the Sol
- Mounting rear sway on VX question
- Eibach sway bars for civic si
- Planning to do 00 h22 in eg.
- my crazy idea, think it'll work??
- painting lips
- Help Plz, 98 EX civic
- CEL Code 21 (VTEC Spool Valve) quick question REWARD INSIDE
- is these oil fiter real honda stuff?
- Look what i traded my hatch for!!!
- front camber? rear camber?
- DIY tricks?
- Dash Swap
- which car weighs more?!?!
- just put another in the hatch
- DC cam gear error (pic)
- will the itr shift boot fit normally in a stock eg?
- H&R Coilover Spring Rate?
- what would be a good plan for me?
- Car makes a lot of noise
- 02-03 Civic SI seats in an eg
- civicsitek block
- D series...ARP head stud washers?????
- cx w/ Y8 manifold?
- Piston Slap
- headlights diff for 5th GEN civic coupe and sedan?
- Painting my eg flat black...questions
- eg corner lights?
- A quick guestion3
- throttle body/fuel injector cleaner
- Need a quick Answer: Will a hood fit in my hatch?
- engine idle unstable
- S2000 seats in eg.............
- PIX of...... EK FOUR
- Switching hondata between different ecus?
- Hella Bi-xenon ECE projectors on my 99 Si coupe(56k HELL NO)
- Was offered a CRV block and head...should I take it?
- looking for a good write up on swapping to 5sp
- sick front and rear lip kits for 96-98 civ's...
- power steering removal
- Substitute for Rota Center Caps
- need help/question : jdm cluster.
- 5 lug question
- anybody here running strut extenders?
- suggestions on suspension setup for 5th gen civic?
- VX/HX Center Cap / opening Size?
- ***stolen eg***
- where do the lines on the z6 intake mani go??
- Argggggggg IM PISSED!!!!!!
- tps
- exhaust
- Fuel pump will not kick on?
- my transmission is making wierd noises
- Video of my hatch on 10psi
- Skunk2 Camber kits Yay or Nay?
- Is this a good idea?....
- Help with Mini-Me...car came with swap, but it's screwed up...
- switching oil, what ya think
- Finally got a pic of my Si
- Helms manuals asking for password?! Please help.
- Where can i find K20 mount kit for 99-00Si?
- Smog problems 95Civic DX
- how do i fix this???
- has anyone used the APC licence plate L.E.D. screws as city lights?
- {convert EG-coupe front into}(99)-(00)EK front what needed to complete
- Rear disc conversion on a EM civic (2001+)
- auto cluster in 5 speed?
- how long do you stay a new user???
- anybody have pics of an itr intake on a 97 civic?
- rear discs w/o new trailing arms?
- Skunk2 Mega-power Exhaust bolt and gasket sizes?
- Master Cylinder of an EG SI w/ ABS to a DX w/o ABS????
- anyone know where i can get a stock obd 2 ecu cheap
- transmission problem (automatic)
- wheel studs????????
- suspension noise from a '97 civic ex
- Totaled
- Del Sol D series question
- El Dials
- 92-95 civic coupe/del sol brakes
- How do you guys remove the plastic rivets behind the door panel??..please help..
- H23A1 For Sale... Parted out...
- Stage1 Conversions???
- new meet in ca
- Hondata
- WTB 3 inch thermal exhaust
- My sols first and last appearence
- building my z6, here is my ideas
- vtech
- rear seats ep3 into 96 ek??
- Baked headlights or real "jdm" (96-00)civic
- ek skirts on a delsol
- I NEED HELP!!! lol
- are 96-00 civic tie rods same as 94-01 integra?
- HONDA OPTIONAL AUDIO CONSOLE
- OK, what sohc tranny for a turbo...
- pics of hatchs,repn big front mounts!!!!!!!!!!
- EF front sway bar?
- where is the ultimate skunk2 manifold thread at?
- NEED HELP: 99 civic wont start...
- Arrgh!! keyway/ dist. slot diffs. between y8 and z6 cam
- vafc or no vafc with hondata?
- Lug Nuts Torque????
- chipping the P72 JDM ECU
- painting valve cover
- 93 CX Hatch to save or not.................
- Stock exhaust question
- how do you bleed brakes????
- dB on the n1?
- F/S: 92 white eg!!!
- sick of drivin 89 ford f150 extended cab
- Need info
- SRR
- How do you tell the year of your motor?
- would you buy something that you "might" use just because it's cheap?
- EK9 CTR
- should i put a ls fuel pump in?
- B-L-O-W-N HEAD GASKET
- b16a2 head onto b18b1 block
- do Honda sells 92-95 coupe in Japan ?
- h22 swap in eg?
- Individual Tein parts?
- squeaky iac valve
- b16 swap problems
- tighten your throttle cable!! makes a big difference
- comments needed
- Quick question about my socket p28 ecu
- 96 Hatch
- engine question again
- sohc vtec???
- EK COOLING SYSTEM?
- cruise control hook up
- Help with subs in civic..... problem with the box? pic in thread
- electrical question
- engine question
- Using DOHC Axles & Halfshaft with a SOHC Engine?
- 99-00 civic coupe nova area stolen
- What Rear Lca's with factory sway bar mount points?
- People with broken cable or hydro trannies....
- Do not buy from Granada_sun....Frank Miller Jr
- Tranny fluid (When to change)
- HAPPY CHINESE NEW YEAR!!!!
- Where can I find ECU error codes connector on Civic 94?
- wats up with the short shifters?
- ITR b pipe Fitment into a 95 civic coupe... and couple ?'s
- New to the forum, just sayin Hi
- best suspenion?!?!?!?
- Where to buy RED tail light spray
- Whats a good front sway for a ek hatch
- need answers with fuel related question
- I know this has been covered a number of times but what the hell......
- ? about ctr's
- Swaps...
- everyone, how much does your B18/B16 civic weighs in?
- is my clutch shot?
- Need help with 99-00 OEM fogs
- adjusting my headlights (please help)
- seat belt tensioner
- 2000 Honda Civic Si - HELP
- rattling at low idle
- 99-00 civic si shift knob???
- gm syncromesh
- sc4 transmission question
- 96-00 civic coupe owners. with comptec sway bar and tie bar combo. what exhaust?
- WHAT iS THE DiFFERENCE BETWEEN CX,DX, AND VX
- c/r for y5
- Tach problem idels at 100 rpm or 0 rpm
