View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Mounts?
- Spindle question :?
- 98 civic wont start
- Wiring battery straight to head unit.
- Do they make rear brakes?
- upgrade brake booster & MC for wilwood brake?
- A'pexi 3" World Sport II Universal Muffler fitment on 96-00 Hatch
- 100k miles what to do?
- wiring help please.
- tranny question
- HELP tranny problem in first gear. tranny skips
- suspension techniques sway bar...
- does any one know
- lowering springs...
- civic problems
- oil in boost gauge line
- JDM D16Z6 or D15B in del sol
- obd0 block with obd1 head
- My exhaust is too short!! HELP!
- Should I let this Slide or NOT
- wtf timing belt wont go on
- Burning oil??
- What are symptoms of a failing Clutch master cylinder?
- should i go ls turbo or lsvtec
- Gas mileage
- password jdm side marker question
- hi flow cat and gas mileage
- need opinions on my car
- Which Intake Makes Vtec Loud On A 99Si?
- HELP HELP !!!!!!!!!! 96 civic defroster HELP HELP
- EG and EK Radiator Same?
- adjust the free length on new clutch?
- Ek B series shift linkage to EG?
- Intake????
- Insurance
- Ecu?
- Cigarete lighter help
- Tiger Japanese
- 96-98 Civic Coupe Rear Window Visor
- How can i fix this
- ugh.. PO filled mounts with window weld, which mounts do I need? (PIC**)
- obd2 harness
- Does anyone live in vancouver, bc, that knows were i can find a p30: 92-95 OBD-1 DelSol DOHC Vtec Si
- SLEEVES
- D16z6 into an EK 96-00 chassis. Little detail questions.
- HELP! car wont start- believe it to be fuel problem
- Dual adjustible cam gears
- air conditioning/fan
- civic a/c question
- Suspension on Ek...
- Rain blows up my headlights - WHERE ARE LEAKS USUALLY AT
- 96 four door tailight ?
- Intake Filter
- EG Civic vision corners
- My damn transmission
- rear bumper built in light??
- OMGzzz not another Car wont start Thread?!
- Which swap?
- AC question
- 99 si service manual
- Intake Manifold
- TRY TO FIGURE THIS SH*T OUT LS-V WONT START BACK UP
- tire rubbing on my quartepanel
- [HELP] ---------- 96 civic defroster (not-working)
- oil pan question
- Can a Transmission oil seal Cause my Axles to viberate?
- what to need for boost h22 civic...
- how do i tell if i have abs?
- question about seats?
- Steering Wheel Hub
- question
- b16 rebuild
- Heater Core problem??!?
- del sol with ek9 fog lights???
- gsr head vs b16 head
- window will not go up all the way
- 97 Civic DX baseline
- what to choose
- is it ok to ask for stuff for sale..?
- cable tranny with hydro clutch
- '94 civic brake light troubles
- NEED CARFAX ASAP BEFORE I BUY THIS CIVIC
- center console
- looking for...
- quick swap question
- 1999 acura EL 1.6 question
- I Need a link to HID conversion How to
- Intake Manifold
- what rear seats do you have in your coupe?
- ***OK BUYING A B20B MOTOR: FEW QUESTIONS***
- Need to paint in order to sell?
- ek hatch problem
- Ignition Timing Problem
- is this intake manifold any good??
- Suspension Question
- Type R intake in 2000 Civic Si w/B16a2
- jspec 96 r motor in e b18c
- City light sockets?
- Engine Worth my Money
- Best cams to use w 75 shot
- my deck was stolen! have questions.
- Aftermarket deck into 97 civic ex.
- EM1 door panel removal.
- Titanium Shift Knob??
- auto to manual, fluctuating idle
- Chipped
- Need Pros & Cons, Replica Foglight Output
- Obd1 b16a into 0bd2a car- need dizzy info
- Compression clairification
- VSS question
- cant find this anywhere... the exterior plastic on the Bpillar
- Quick head question....
- Computer Prob I THINK??NEED HELP
- torque mounts es bushings
- I need this piece :(
- LEFT WINDOWS OPEN!! It was raining this morning......
- want to put h22a in eg, possible?
- LS Throttle Cable
- 99 Si rear sway bar on a '93 Coupe
- when i can use block guard and why?
- Painting Engine Bay???
- what mounts do i need to buy?
- shifter problems
- New to the Fourm
- PIC Request of Razo Competition Pedals.. i need to see the hardware behind the pedals
- code 43(fuel supply system), where to start.
- d15b 3stage or d16a9
- question about coupe panels in hatchback
- How should i get these dents and scratches fixed?
- Tsudo exhaust (evo2 rep) on EM1??? Anyone tried one??
- Please help!!!! electrical, alternator problem.
- Gsr Mounts Q... ?
- Service Connector Wiring
- LOSING POWER when kicking it down
- can i use this cat w/OBD2?
- hasport mounts..?
- What the hell is wrong with my turn signals
- Another Mini Me Question
- wiring vtec to d16z6
- high RPM problems
- Speedo stopped..no VTEC, then tach went..now alternators bad? HELP.
- 99 EK Right Handed Conversion
- TURBO OR NO ON A D16Z6??
- Problem with my CLUTCH...PLEASE HELP!!!!!!!!!!!!!!
- ACG-S Fuse
- GSR Mod
- Phillip screws on Rotors Necessary?
- WTF??
- amber aux bulbs for del sol
- Where to get Decals?
- What tire pressure to use?
- whats the usual compression test result on a jdm gsr b18c?
- insearch of b16 bare head or b18(gsr)
- Spoon caliper SW388 15 inch..
- Help with quality of a 2000 Civic Si
- Went drag racing , broke rear gearbox bolt points...can be rewelded ?
- O2 sensor
- high beams work low beams dont
- quick question..si cluster in EK w/o problem?
- What would you guys do?
- any here use the silver stars headlight bulbs?
- major coolant leak/overheating after skunk2 IM swap
- 92 95 dx manual door panels!!!!
- sleeving block??
- timing ?
- Mounting Issues
- question about ex motors
- Prelude AWS on EG
- New to EG's...need help!
- Axle Prob
- 98' civic hatch
- -Searched and no Help- Weird Fuel Injectors Noise/Tapping!?
- rear disk break conversion?
- the gentlemen of teamrice.org
- No Power to TPS HELP
- EG LIPS/Interchangeable parts
- what is the stock fpr set at
- rear disc swap w/ '99 SI prop valve ok for ABS?
- Abrevviations
- d-15 idling at almost 4 grand at times :O:O:O???
- Searched and Checked FAQ. Write up for slow window?
- Which head for my B18
- NOOB
- Head Bolt Problems on mini me swap
- d15b crank position sensor problem
- Help
- Broken Heater, maybe valve/switch thingy? lol
- 93 civic si power window conversion
- Finally almost finished with my kevlar hood! Woohoo
- Anyone put an EM1 cluster in their EG?
- man am i happy with myself right now : )
- Throttle Cable Question!
- rear wiper problem
- how do i get off of a trial user!!!!!
- B20 MOTOR - adjustable cam gears..
- EG Rear Disc Conversion
- prelude seats in EK
- 96-00 Civic HID retrofit
- Searched -- No avail... Engine light came on, no codes.
- Chicago mechanic where to go?
- Can integra steering rack and column be used with out power steering?
- Civic d15b7 wont start! my starter is blown, replaced it and still no good! HELP!
- exhaust choice help.
- JDM Sites
- kw hid kits are they any good are they bad what????
- 93 del sol gsr
- Sunroof problem
- seat problem
- venom 400 module
- Water pump...help me out ASAP
- Cusco EJ1 cage??
- WTB.. SI LIP???/.
- b16a2 ouestions and advice
- What are these? pic*
- vtec solenoid wire
- tapping
- Question about D16Z6 head gasket - replace, or go for temp repair?
- Question about 96 DX/99 SI coupe...
- 92-95 HatchBacks/Bubble/Coupes PiCS
- Z6 swap????
- Need some help with d-series head bolt torque specs and bolt pattern...
- will p0108 and p1337 cause bad gas milage??? "please help me out"
- finished B18C in EG swap, but have loose connectors...Help !!
- IAC sensor?
- AEM Big brake kit?
- Wheels wont come off!! HELP!!!
- replacing valve gasket on d15b7
- VALVE COVER
- Need some quick answer out of manual
- quick short shifter q
- VSS code 17 new VSS
- passenger side airbag into 93 hatch
- I need asap sorry for the WTB in this section
- rpms moving up and down below 1000
- quick question abaut a trunk
- looking for motor in virginia
- quick exhaust question
- eg k series question
- auto tranny interchange
- compression test gsr motor
- sideskirt removal
- Manual to Power Window/Lock Conversion (94 DX 4DR)
- integra instrument cluster fit into ek?
- help! 98 civic runs like shit
- integra sun roof is the same as the eg civics
- duck bill wing
- changing to BC spec II exhaust
- ok i need help
- 99 core in 96-98 Civics
- comptech axleback from dc2 fit on em1?
