View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Clutch Help
- are these tires good for traction with boosted hondas?
- BUILT IN CAT????
- New Brakes Opinion...
- How much would you pay for a parts car...
- Projector headlights...
- coolant Question
- b18c5 into EK- starting issue
- HUMMMMMM??????
- Need help with paint
- NEED HELP....on swap in a 96 civic ex
- 00 Civic SI Fuel pressure!!!!!!! HELP!!!!!!!
- walbro 255 fuel pump
- D16Y8 Adj Cam gear timing
- Check out what happened
- Looking for info on adjusting steering rack
- EK 9
- 1996 honda civic ex
- NEED PIC, SEARCHED! 5th gen OEM dash plug
- Power folding mirrors diagram
- 4 x 100 Itr brake swap
- Still have braking problem after replacing rotors and pads.
- Anyone Have The City Lights. They go around the bulbs and fit in the socket?
- Need a shop that swaps B16 to K20 motors in or near SAN DIEGO.
- what u think?
- water leaking
- which would be easier?
- OEM CTR WING ???
- Tranny chatter
- HELP with piping problem!!
- Throwing a code 41.... quick question
- o2 sensor problem need help !!
- Quick Question (Wiring for 94 Civic For Radio)
- Another EG Cluster Problem
- 99ek with harness trouble
- auto/ manual mount
- fuel problem help
- question..b4 i buy it
- IACV bad. What's the cause ?
- is there any DOHC motors for a 92-95 civic automatic?
- ef seats into an eg
- whats the difference between HX and EX?
- My list ! Want some opinions !
- good parts sites?
- need help with o2 sensors on cx
- somethings up with my sohc turbo
- v2 intake
- HELP! P28 Ecu question using JDM motor/A4 to D6 Wire
- removing air bag system out of a ek?
- Wire Experts: Map and tps cut on harness...my extra plugs different wire colors
- what kind of headlight bulbs do civics use. well i mean are they all the same from one year to the n
- interchangable oil pans ?
- removing front bumper 00 civic
- which camber kit?
- srs light on 1995 honda civic
- Should VTEC engage earlier?
- where can i drop off the engine that i dont use?
- how many holes in a ek firewall ?
- new clutch install problems... need specs
- Possible Idle problems?
- what are the torque specs on d16z6 valves.
- hey
- Custom EG/EK 3 point front upper strut bar
- Bouncing Needle NEED help ASAP
- Link to Side marker installation?
- dyno test...
- a/c swap....
- looking 4 a used engine
- EG Cluster Problem
- ef pedal assembly in an ek?
- Anyone rocking Megan Control arms?
- jdm itr non-srs wheel with cruise control?possible?
- wat could it be?
- coilovers makin noise!!!!!!!!!!!!!
- d16z6 d17 crank
- del sol rim size?
- skunk 2 retainer locks
- D15B Dizzy?
- 1/4 times
- Clutch prob...i dunno man
- del sol k20 mounts
- b16 compression test
- Do JDM headlights use different bulbs?
- an introduction
- standard midpipe eg hatch same as eg coupe?
- Probs with 94 Del Sol Auto tranny M24A me thinks
- ECU small upp
- Changing pistons! help!
- ls rods in my Z6.. HELP thanks
- 97 ek intake manifold
- the ebay ztd clutch ?
- CEL on getting P0420
- Why are there no curb weights listed for 96-97 del sols??? anywhere...
- Power Door Conversion
- '92-95 civic si caliper piston size
- h22 tranny
- Y7 to Y8 intake manifold QUESTIONS BEST ONE YET, with PICS!
- sway bars
- newb Q bout dizzys
- Ek Multiplex Box Location?
- Finally did my 'Fender Swap' - how-to DIY type post
- OEM FLOOR MATS?
- New ECU, now it won't start!!?
- 5th gen JDM EG6 SiR-II cluster... problems with bulbs blown out
- hey guys a little help please
- stupid question tougeing automatic or manual
- 93 si really fast
- Progress on BAR'ing my car.
- Is there a guide on how to replace a ignition switch on a 93 civic ex coupe?
- Help knocking noise coming from head.
- Does anybody Kno.......
- quick tranny ?
- rsx brake booster&mc in a 92-95 civic
- Rusty rotors?
- anyone ever bend a core support?
- Advice on used KYB AGX struts
- How to stop Shift knob vibration?
- exhaust question??
- Cd Player Codes
- Ls vtec????
- my tranny is acting funny on me...
- strange: car working for a good month and now won't start!
- integra catback on civic?
- i need a b18a or b18b short block
- PA State Inspection help!!
- Going through alternators like candy - need ideas
- tranny problems
- no fuel coming to oil filter at all
- MAJOR QUESTION!!!!!!!!!!!!!!!!!!!!
- cracking noise from the back?
- Engine paperwork
- hasport mounts
- rsx interior in a ek coupe?
- how to do a b18c5 swap
- Idling Low
- B20 swap pros and cons vs. B18
- Need in Socal.....a 96-00 Civic Hatch for test fitting a part
- OBD testing for emmsions.. ohhh nooo
- Ek Hatch Rear wiper delete part #
- new nrg slim hub !
- CAM
- whats that link, DIY amber climate control? For 98-98 civic's!
- TDC 92-95 same 96-98
- Who's done a Fully Functional S2000 Cluster in an EG with B series?
- Timing belt or tensioner problems...
- Checking ECU codes for 99 Civic
- Dropping in a b16a1 into a 94 cx hatchback,will a obd1 94 LS distribtuor work with a obd0 b16a1 engi
- which spark plug wires out of these are best?
- 92 civic ex1.6L vtec swap IGNITION TIMING PROBLEMS!!! HELP!!!
- Custom Hand made Air/Brake Intake EG6
- Comptech Catalytic Conv.
- 1994 eg cx to si swap, 02 sensor change
- please help me out ASAP! need to know fitment ASAP before i pick something up TODAY.
- Honda Help = 750.00 Exhaust! WHA?
- allignment help
- Wierd starting problems
- check engine on?
- DO YOU REALLY LOVE YOUR HONDA?
- 240k on a civic
- funny story
- "Need some advise to built LS TURBO?"
- Which quaife LSD do I need
- Magnaflow muffler on turboed EG???
- Problem Starting
- motor swap 98 d16 to 95 hatch back
- Whats the color or my car? No paint code!
- I think I got an oil problem...
- antifreeze reservior
- LF: Website that show wheels/tires changes
- Code 41 frustrations...
- plug wire popped off at 7.5k, ran like wrx for a block, then died, PLEASE HELP!
- Speedometer problem
- how do you install traction bars on an EK??
- his my head ruined??
- how fast in the 1/4 mile?
- How do I replace the quarter window moulding?
- cap and rotor?
- 92-95 civic wiring diagram pleaseeeeeeeeee help need asap
- selling ek shell
- fuel.
- Trouble with fitting JDM EG Fog lights
- CEL code 90 - EVAP System: CVS Valve and Canister Problem ????
- n/e one have a b20vtec in a delsol and how is it.... n/e good times at the track???
- delsol???n/eone have a b20vtec in there delsol???and whats your time at the track???
- Password:JDM fogs compatable with OEM wiring?
- whats the difference???low impedance and saturated???
- crank pulley torque specs
- lifted hood???
- Does CEL10 (IAT) affect idle
- running vtec
- How to tell?
- emissions help! throwing 13 codes.
- Aftermarket B18 crank pulley on a d15 engine
- b16 head package
- Help with eg hatch
- Show-Off your EG Ferio's
- 50 Shot on b16 civic SiR , ur views?
- ignition problems check all...
- Problem with other civic
- d b18 swap vacuum hoses
- Steering and radiator issues.
- HELP!!REAR BRAKE ISSUES!!!
- Can you fit 6.5" speakers in the rear deck of a '95 civic?
- Water pump question?
- pin out question
- **So Cali Cats I need your help!**
- 96-98 square foglights on del sol?
- OBD 1 Chip
- PLEASE HELP: My cylinder head swap won't start :(
- HELP! Alternator Issue, need part number searched...
- Did DX to EX cluster swap..
- dilemma
- ***SOHC ITBs***
- cel serive plug location
- What to look for in a used Clutch?
- exhaust backpressure by header?
- car turns off
- How safe is the Del Sol?
- Dimmer wire on del sol clock???
- Civic Advantages?
- my hood is fing stuck
- posted earlyer about b16 run with out oil and it not starting
- adjusting a del sol si auto tranny shift points.
- vtec controller?
- Is there a write up on how to install an after market fuel rail?
- Wiring for Honda Cd Player
- How many lines to/from a/c condenser '00 Hatchie? gotta plug 'em...
- !!! Pronto! 4 door ej (99-00) headlights same as HB Stuck in dark hafta go 2 work !!!!!!
- speedo is going nuts "already searched "
- BAD COIL?
- Civic CX Head Issues
- When do you guys shift?
- Throttle Body Help!!!
- Normal to burn oil when VTEC kicks?
- HELP! question about brake master cylinders! searched but no answers! HELP!
- headers?
- Pics of my ride after the wreck
- which kind of timing belt do i use??NEED HELP PLEASE
- ANYONE RUNNING B20 TURBO?
- weak light in my reverse gauge...please help!
- FS: EK/Si parts
- light weight?
- fog lites on 96-98 pics?
- Attn: EK k kay Wanted: STOCK Exhaust Manifold-Catalytic Converter for 99 Civic Coupe DX-Southern Ca
- headers...
- coilover help!!
- Anybody using the JDMshit Hydro - cable kit?
- ticking sound when cold...rod knock? valves?
- stall 99 htchbk - relay, distr cap, or fuel ??????
- Compression and level of octane affect knock?
