View Full Version : Honda Civic / Del Sol (1992 - 2000)
- what cluster will fit my 95 DX??
- 00 civ braking issue?
- ckp sensor code problems on 96 civic sohc swap
- Replacing rear wheel bearings?
- d16z6 help with choosing cams?
- Quick question ...
- I need help ????
- Antenna question (I've searched)
- 97 civic ex downpipe issuse
- power windows issues
- d16y8
- Where are people getting these?
- Wire Tuck help 95 del sol
- cabin harness swap
- Has anyone done this to their car?
- Hood Relase Latch Replacement
- Ac help
- will 96-98 sir bumpers fit
- d15b swap problems cranks but wont start!!
- New to honda-tech
- is it hard to change an oil pump?
- Part number help (or direction)
- Swapping EG Power steering rack to DC Power steering rack
- PasswordJDM Race-proven floor plate
- Problems with putting in a new Deck?
- Newbie (uk)
- car will not start
- 1999 hinda civic si
- car shakes...
- Tming belt/WP estimate
- need some tool advise
- Noise from the rear after rear disc installation
- side marker issue
- To some dum exhaust question?
- New to the Forum Hello
- 1998 civic rack and pinion and 1994 del sol si rack and pinion
- 98 Honda Civic CX A/C Not Really Cold?
- 94 eg gsr needs help.. its cutting out
- Need Troubleshooting Ideas for a supercharged D16z6/y8
- engine harness HELP
- bent rear lower arm bracket HELP
- Weekend project. Front lower control arm bushings. Just wanted to share. PIX inside
- will a b16 obd 1 harness work in a 94 eg w a 94 gsr swap
- VTEC spool solenoid & vtec pressure wires switched around ?
- vtec pressure switch
- oil pump gasket
- 99 Civic SI Jackson Racing bypass valve?
- What can thi setup be capabole off ? SHIME IN
- car dies when trying to rev
- Performing a few more mods, EX trunk light and dome light
- side mirror question
- thumping noise when slowing down.
- ITR/CTR cams vs. turbo cams?
- 92-95 4dr civic door handles
- Boost Or Swap
- Stripped studs??
- 98 cx hatch ls swap idel problem
- Header and oil pan....
- HID Kit for Eg
- Koni Yellow's
- burning oil bad
- power door panels
- Car wont start now, no fuel, no spark
- just installed skunk 2 coilovers and have some questions...
- 95 Civic 5 speed now has high vibration at 3k....
- PRE WIRED FOR V-TEC???
- Question about ECU Chipping don't know squat...
- Ls/Vtec swap in civic
- My first eg8 has to go sadly.
- Ls/Vtec swap in 99 civic
- GSR discs and calipers on civic hub
- Idle Drop At Complete Stop And Car Dies
- m2b4 into an EG hatch??
- bling'n LCA's
- Skunk2 camber kit problems
- My vtec solenoid does not have filter screen
- How often do gas caps go bad?
- "headlight on" alarm
- wat motor oil are you using in your b20v?
- Part number help
- tranny problems
- FITV differences between B7 and Z6..
- Help removing AC belt - Having trouble with left torque mount
- new throttle body, new idle issue
- mini me question
- Lost my key... can Honda make a new one?
- em1 si help
- Need Help/ Car wont start!
- Help with CEL codes/ troubleshooting
- EK Water Drainage
- wire tuck
- Need Help Finding a Thread or a Post!!!
- squeal on startup
- eg cluster in to an ek..?
- my 1997 ek9
- eg k20 project
- 00 si srs question
- 8 inch booster vs 9 inch
- help on headgasket
- Cat-Back for Civic Coupè
- d16y8 head with d16y7 cam/rockers???
- Can I use 95 OBD1 GSR Engine Harness on my 95 Civic DX?
- HELP!!! Headlight alarm malfunction
- Chipped, socketed, mugen, spoon, WTF help please
- transmission issues?
- ls 5th gear in gsr tranny
- specfic clutch needed? (d15b2 motor, d15b7 trans)
- Color and size suggestions for my captiva blue eg
- A/C in 94 Civic EX
- Engine ideas for around $3500
- i need help with idle problems 95 civic d16z6
- 93 eg8 starts weird sometimes
- 95 Lx Disc brake conversion ... help plz
- coolant leak
- ls/vtec problems
- motor swap. d16y8 - b18c1
- Need a Picture: 96-00 Civic w/ Cruise Control vacuum hoses
- car wont star weird problem
- Recaro Type R style seats with Blue stitching
- civic b20 axle problem
- Clutch problem
- gimmie the goodss
- jdm motors
- Engine Bay nuts and bolts have had enough. Replacement options
- Different Ride Height On A EG Hatchback.
- Car died
- b16a2 leaking coolant from intake manifold? need help
- 99 civic code P0131
- cruise control vacuum line question
- Fix It Ticket >.<
- 97 civic IAT sensor CODE!!! HELP
- CODE 43: Fuel Supply issues car runs like junk
- Sidemarkers
- For Sale 93 Del Sol w/ '00 civic si front end
- 1993 Del Sol S - stalls coming off idle and very hard to start.
- I did it.....I tackled my engine bay...
- PVC 2000 Civic DC - Conflicting Information
- Automatic Transmission "HELP" needed please.
- Godawful vibrating noise in EJ
- Electrical Issues?
- started up b18c1
- D15b2 - no spark after pulling spark-cable
- How to check your wheel bearings?
- clutch help
- Headlights restoration
- car wont start
- My H23vtec
- cant find a lost motion assembly
- 98 Civic Aftermarket Exhaust
- head gasket, rods everyting!!!
- B16 issues
- 92-95 Civic OEM keyless entry system JDM?
- Code 23 and 43. going on vacation need help asap
- d16 compresson numbers????
- T1R EM1 Exhaust
- civic requires me to pump the gas pedal and crank it to run it
- Blox Throttle boie problems
- prop valve findings
- JDM ITR header fitment
- Same car, New Issue. High Idle and Overheating.
- About P28 ECU (G01-G02-G03)
- I need a new eg shell...
- civic ex, tachometer jumps, problem?
- Right side headlight low beam won't work!!!
- gsr rear sway bar install on a 99 civic ex
- missing collar on z6 head. where to buy one?
- zex59300 cam w/stock valvetrain???
- stupid rattle.
- best engine swap for a del sol?
- IACV harness connector showing low voltage
- Idling Issues
- main relay harness ground
- noob question
- cx and hx
- si steering rack
- Driver Side Window Problem
- NA injector upgrade?
- 98 civic 96 gsr motor
- weird wireing problem.. PLEASE HELP
- d16z6 compression
- 92egminihatch's build thread (no 56k)
- GSR front and rear disc conversion HELP!
- Electrical help ASAP!!!
- b16a2 header 4-2-1 or 4-1???
- Headlight and Taillight Problems!
- New to B Series Looking for info
- Painting EJ1 Coupe upper interior trim black.
- help with gsr part numbers
- Is Omniman's 200whp B16 DVD any good?
- Looking At My First CRX Del Sol...
- Civici SI Cluster
- difference in ICM module for distributor
- Thumping noise from drivers side tire. Caliper?
- electrical/grounding issue
- what head gasket to use?
- Wierd CEL!
- Need Help (99-00) Front End Conversion
- How to hookup throttle wire in GSR swap
- 0bd2 p75 instead of 0bd2 p28??
- !!!!97 SPEC ITR SWAP INTO EG *PROBLEMS.!!!!
- STOLEN EG6 SI INLAND EMPIRE
- Quick Release and Steering Wheel for EJ8
- MAP+Turbo=idf
- B18C1 EG ECU question
- B16B swap into a 94 coupe?
- HELP ON A HEAD GASKET CHANGE ASP.
- Air Conditioning/Belt problem
- Found out why my rear was cluncking and sqeaking. PIX of 13 years of neglect inside!
- B18B in my EM1
- Fuel gauge improperly working After Walbro
- SI brakes on a DX?
- how do u remove door handle
- Transmission problems
- hard brakes need help
- Power outlet popped out, need answers!
- b18 integra ?
- selling my 95 EG
- Oil Pan Gasket & Pistons
- Need help with 96-00 civic fog lights....
- Possible EG purchase??
- mugen ek wing fitment
- turbo ls hatch problem
- To catback or not to catback
- Please help me pick out a bike rack
- help with del sol stock wheel stuck on hub
- White 1998 coupe stolen 5/20 from cerritos college student parking
- Need help with an over heating B16A
- Front bumper
- em1 drive shaft problem
- help ! my car wont go past 3k rpm
- what rear seat doesnt leave any gap on a EG hatch?
- Back In
- Swapping motor NEED OPINIONS
- clifford alarm
- Bad mystery problem! Help!
- Suspension Suggestions
- eg spare tire question
- 93 cx ecu wire harness compatibility question
- AC for b18c1 in EK hopefully this ends all questions about this
- 1996 civic has a funny jerk
- Suggestions on rebuilding my b17
- whats the part between the brake light and the back bumper? how do u take it off?
- Anyone ever heard a B18C ring?
- B18a in a 92 civic
- cleaned throttle body, TPS sensor not put back correctly? please help
- Dash harness??
- brake light not working on my EG hatch
- manual rack rebuild with Quailfe stuffs
- ek9 side panels
- '93 Del Sol Motor Rebuild?
