View Full Version : Honda Civic / Del Sol (1992 - 2000)
- What is needed for a quick release steering wheel??
- My gas tank cap doesn't close all the way?
- WTB: In Seattle area 1 stock steel 14 in rim -6th gen steely
- CHECK ENGINE LIGHT ON BUT NO CODE.......
- cluster light doesnt work
- skunk2 pro s question
- Got the wrong part number, 96 ej hatchback dx, help...
- ac in 96 hx?
- headlight problem 97 ek coupe!!!!!!!!!!!!!!!
- Do you have a copy of a 2000 Civic US or Canada brochure?
- HELP>>>car wont start!
- Dizzy O-Ring..anybody know about this?
- 99-00 civic si factory mounts..
- Hesitation when in VTEC, 2000 Civic Si.
- Quick Question: D16Z6 Exhaust Manifold Fit on D16Y5?
- H22a with ITB's question
- ECU help
- 2000 coupe owners..does this look correct??
- Removing Power Steering
- Help!!!
- red honda badges for the eg6
- help!! my civic cuts out at high speeds?
- help....
- d16y8 stutters a bit at lower RPMs and gets fine upper RPMs
- Random misfired code
- Clutch Lock saves the Day!!!
- del sol suspension
- Fog light help
- Hydro clutch on del Sol
- y7 to y8 IM swap...Please help
- why oh why is it
- 92-95 civic si colors
- repair cost
- How much damage can water do to the engine?
- car wont rev past 5500 got cel code 6 &7 help
- a question regarding to having a cold air intake in bad weather.
- Why does my Ignitor Keep Dying?
- Parts question
- dizzy o-ring replacement
- blown 7.5 fuse...
- 92-95 cx.drive side mirror???
- car cuts out after 6500 rpms!
- How hard to install wiring harness?
- What does the whole EJ-# mean?
- prelude seats in my hatch
- EK bumper question
- Tuning Shops in Midwest Area.
- exhaust on my hatch after b-swap
- whats broken???
- Ignition problems - 1994 Civic SI HAtchback 1.6 L
- need lil help gears
- any differences in the EK Hatchbacks during its 6th gen years?
- d15b into 93 eg si in place of z6 motor, some wiring questions and a "Car wont start" thread
- question on EG JDM center console
- Anyone bought these headlights?
- Brasso better than Meguiars and Mother's??
- how to install a jdm bumper pole
- Harness preference
- anyone ever pull out a iat sensor that was melted on the end?
- 93 DX airconditioner ground?
- B18A1 What to do?
- d15b7 $
- SOS!!!!!!!!
- Exhaust Question
- power window
- what headers should i get
- 99-00 civic si dc sports header for sale or trade
- idle prob
- Del Sol Si need help with a MIL/Engine Light... Help..
- 94 hatch, missing plastic clip on rear glass
- differences in 96-98 and 99-00 2 door trunks?
- Stuck Sparkplug!!!
- What Seat Rails Do You Use To Sit So Low???
- holy shit help
- B18c JDM GS-R OR JDM TYPE-R???
- Transmission/shifter bushing woes.
- d16y8
- GSR ECU
- How much did you pay for your GSR SWAP
- Where can i buy a carpet kit for EG HB
- Alarm decides to go off today
- Remove Rear Drum?
- How to clean headlights?
- Tachometer help
- 98 Civic H/B Front Speaker Depth
- wire up techometer
- Battery voltage drops to 12.5 after driving for a little bit.
- what type of oil for SIRII w/ lsd tranny?
- 98 DX Hatch Sway-Bar Upgrade Recomendations
- Need help..............
- wtb 99-00 si (sir Canada) rims
- weird Chugging and pinging.........
- s2k radio in my 99 coupe!
- header install
- Replaced fan switch, fan still doesn't turn.
- RC Air/Fuel Hauge Wiring
- EK9 Prelude
- EK coupe floor mats in a hatch
- Easy Question : P06 Manual and Automatic ECUs, compatible?
- ignition help (search came up empty)
- question about my 93 civic sedan
- car alarm messd up?
- Loose Rocker Arms on my B18B?
- 105300 cam in my Y8 are teh valve specs still teh same?
- How to improve a/c
- B16b 93 Civic, worth it?
- Belt noise? Can't figure this one out
- header help on a D16y6
- Type R springs on EJ1 how much it will drop?
- Water is getting inside civic HELP! Smells like wet cats!
- BIG BIG PORBLEM. GAS IN OIL + NO START+ BROKEN CAM!!!!! WTF!?!?!?
- Car crash and motor stopped.
- WERE DO I MOUNT THE AIC SENSOR?
- best brand of lowering springs for the buck
- question...
- Intake manifold pop/bubble
- I Need Help!!!!!!!!!!!
- i just got turbo-charged for under $20! the turbo sound is sweet!!
- JDM city lights
- Help
- EBAY DOOR VISOR
- my dash lights don't work!!!
- where can i get a the bolt/plug to plug up o2 sensor hole
- o2 sensor????
- heater not blowing out hot air...
- POWER WINDOW CONVERSION HELP!!!!
- my car has a built in kill switch at night!!!! help!
- Ding King?
- Timing belt Writeup? Should I do it or is there ones allready out there?
- front and rear strut bar. noticable difference
- My How-To on datalogging
- Lo Jack...
- eg rear windshield handle
- flywheel torque specs?
- EM! question??
- Throttle Body spacer
- B16 Swap + ECU
- power lock question....
- Check out this video.
- Few Questions: 94 LS into 92 hatch
- 1999+ SI muffler any better than EX LX
- how much for car
- Is 95 civic dx brake booster and master same as a 97 BB and MC?????????
- hi flow cat.
- Help me find studs to put a Z6 on a Engine Stand!!!!
- Need to find an exhaust.
- vtec head swap
- sputtering coupe needs some troubleshooting too.
- What is the perfect setup on a VAFC (Apexi Vtec Controller)
- 97 Civic makes loud noise when clutch fully surpressed, brake light comes on
- sun roof won't open can anyone troubleshoot?
- gauge cluster not lighting up
- 5 Lug Essentials
- My civic has a water leak...
- Headlights shutting off randomly while driving...(searched no help)
- AEM fpr question
- installing lowering springs
- FOR SALE
- eg springs and ride height.
- O2 Sensor (98 LX)
- low warm idle and choppy acceleration at low rpms.
- Power to Manual rack conversion (GSR Rack)
- Car wont start need help !!!
- Steering Wheel Options
- for sale!!!! a 1994 del sol. beautiful condition. no rust.
- are h1 bulbs better than h4 stock bulbs?
- Lowering spring
- Help with no pedal pressure *searched already*
- dimmer switch harness for cluster
- driver side window
- ecu question
- slave cylinder?
- 4 wire 02 sensor question.
- NEED HELP GUYS !!!!!!
- What is a quick and easy way to tell if my distributor cap is bad?
- look at my ek!!!!!
- Burning an assload of oil
- Carbon fiber hatch install questions. Please help.
- From CRX to Civic Coupe....Suspension knick knacks and clunks
- Rims For Sale
- Question!!!! On a Integra center pice in an eG?????
- D15B7(92 dx civic) clutch same as D16Z6(del sol)?
- B16B collector size
- exhaust
- IAB Sensor on 01 GSR engine in 99 Si
- B18B IACV fit on d16z6 manifold?
- I think its my injectors or tps.
- 95 lx question.
- typer r pedals pads
- pic request: splash guards on ek
- Ek9 vs 2000 SI stock strut bar differance?
- trying to remove ecu.... help
- 2001-2005 FRONT SEATS IN A 1992 HATCH
- Anybody else idling at 0 rpms?
- slanted steering column?
- help?
- What HID Kits would be good for a 98 civic?
- 1300rpm rattling
- Poll Type Question : Which Enigne is the best to have for turbo and why?
- Del Sol dual core radiator
- Installing Steering column- Searched
- boosted b16 air/fuel problemos
- S20 TRANNY
- quick question about gsr into civic hatch
- Good affordable parts for 97 EX
- Whoom whoom whoom....WTF?!?!?!
- where can i find...
- motor shuts off after complete warm up
- car shakes
- Brake Upgrade, Brake Lines and Installer Questions
- Broke my differential last night at the track.
- which power steering bracket is the rite fit.....please help
- Axle Issues ?
- pwr window swap in ek dx
- does the ek9 mugen intake fit an eg?
- Help me please
- '95 Civic Ex Power window problems
- '95 civic ex power window problems
- 99 hatch swap
- eg dash removal
- Broken Bolt In The Rear LCA!!!
- Swap a S2K cluster into an EG???
- 96 civic automatic to 5 speed...
- Rear strut bar question.
- Random misfire on cylinder 3......cel 73....no compression
- SI interior in 97
- slight problem i ran into
- EM1 Takes like 10 turnes to start the car after putting gas in
- Spark plug questions? is my engine ok?
- no pressure to the clutch help anyone
- best valves for skunk2 Pro camshafts!
- dealer or jdmland?
- need help
- IAT Sensor won't fit Skunk 2 Intake Manifold, any idea?
- Automatic Transmission and Linear Solenoid.
- Shift Linkage Differences
- d16z6 compression ???
- where is a good place to sent out my head
- Helms book
- whats the cross reference for b15b? ready to drop in the motor!!! searched
- Might be useful to those who can not seem to "secure" their car
- Horn used as nitrous activation
- reverse lights not working.
- putting EX door panels in non-power car...?
- redline 7000 on jdmb16a
- help!!!! obd2 b18c5 into obd1 eg
- Tranny work
- How many posts?
- Building a Z6/y8 hybrid, got some questions.
- Tilton Clutches?
