View Full Version : Honda Civic / Del Sol (1992 - 2000)
- EG shakes at certain speed..
- eg6 shell for sale
- oil pan gasket
- 95 water pipe question
- Integra calipers on ek knuckles
- tein s. techs sit higher in the back
- Civic VX 92-95 Engine Question
- Rota Grid Honda Center Cap Swap
- 93 Honda DX
- 00 civic si startup idle problem....
- M/T Bseries Swap: Which Rear mount for Dx chassis?
- fuel pump problems
- Anyone have pics of a blue EG sedan with white wheels?
- Look what i got for 50 bucks
- What B-Series Tranny is this?? Cable or Hydro?
- D16y8 distributor on a D16z6?
- skunk2 pro vs itr/ctr intake manifold!!!
- EJ2 Oversteer H-Brace vs. F Lower Tie
- 3rd Annual Yerba Buena Car Show
- $1000. What to spend it on?
- Battery Light Came on, No power to alternator WTF!
- Need your alls opinion!!!
- 96 OBD2 GSR Swap
- suspension help
- Honda Performance Shops
- cooling fan issues
- 1994 Honda Civic DX w/B16A Swap - JUST PICTURES
- Fuel+spark+ cranking over motor='s not starting?
- block girdle question
- 94 starting problems ..just click once
- What kind of rims?
- Head question
- Ls Swap into 93 EG
- CTR EK9 hatch spoiler tilt brackets.
- P28 ecu
- Del Sol Engine swap questions
- Noob Question #2
- D15B timing belt cover: Will VX work?
- D16y8 vtec not working need help plzzzz
- generics
- gsr disk brakes
- front clip help
- Smog for swapped motor
- eibach meet repost
- Can anyone help me identify these rims?
- iacv??
- Electrical issues with 96 ex coupe
- electrical problem
- Removing a/c
- battery not charging
- 00 civic DX head swap to EX VTEC ?????
- 2004 civic cluster in EK??
- Civic swaying problem
- Post EJ1 Rear Window Visor Pics, and where to buy them!!!
- I am looking for a coupe, but which year?
- intake manifold affecting my power band?
- B16 Idles real high
- rsx dash in civic????
- what rims are these??
- FTPS Help !!!
- del sol acting funny
- Suspension Help
- h22a types
- need specs for bell cams 1997 civic
- floor harness 4 p. windows help me
- EK St rear sway bar help!
- PLEASE HELP, CAR WONT EVEN CRANK????
- 1996 Civic Not Starting
- How do i flush my raidator?
- front speakers, coupe
- E-Brake Lines Question
- d15 vtec E ????????
- my speedo keeps cutting out!
- Wind
- P06 ECU start a GSR?
- EG headers on an EK
- what kind of rear rotor is this?
- ek cluster
- Major Oil Leak
- New to Honda-Tech
- Problem with replacing motor
- Steering Noise
- Blower motor is psychotic!
- Engine bay clean up
- 94 civic headlight blown (driver side)
- Air Sensor Issue
- Noise differential diagnosis..
- 96-98 Civic SiR Lip Replica: Need review
- temperature control switch
- New Here and Have Questions
- ignition starting problem - eg.
- What is the best option for a totaled car...
- How to install autometer water tempature gauge 96 civic dx
- Coolant bleed help
- Stolen Red 1994 Honda Civic Vx hatchback Mpls, MN
- I Just got a New CX Hatch!
- eg or ek?
- clunking noise after i shut car off
- S2k cluster in EK
- Help need some pro advise on my d16y8 conversion
- Need help on aftermarket heater/blower
- HID highbeam
- no fuel or ignition
- h22a1 rebuild question
- All wheel drive 92 hatch?
- Wheel offset question
- Beaks Lower TIE EK
- main relay question
- smoking start up
- SLAM IT! The right way
- Battery drains
- Red colored bulbs for brake lights
- SRS light on, horn doesn't work
- Mugen Replica Wing Mount Question
- 99 civic d16 Timing Belt Tensioner, My belt is too tight, please help
- c.e.l. 41
- ek owners- got a 7" screen in the dash?
- removing door panels...quick question
- 2000 civic si making strange sound please help, suggestions needed.
- Civic and 1.6 EL Climate control Pinout.
- need some schooling on Exhaust.
- reccommend a muffler???
- D16Z6 stage 2 cam
- Is this normal?
- suspension help
- no power to guages or radio
- H22 in Eg Sedan shutters/Vibrates. I have a hypothesis Please give input.
- 99-00si suspension work on 98 ex?
- my 97 civic coupe[[New to honda-tech]]
- im neewbie ,, anyone here from north cali
- FS/FT: magnesium del sol si rims
- ITR motor in Ek hatch opinions..
- What kind of oil should I use in my rebuilt LS swap?
- axle c clips
- D16z6 ecu question
- 95 Civic w/ b18c1 need advice an opinions
- ignition ?
- help please do i need a tork wrench ?
- 92 hatchback brakes
- helpp car keeps dieing on me
- cel on, no code WTF
- P0132 Code
- thinkin to sell EG6 SiR seats - how much??
- rear camber question.
- Is it time to replace my Inner tie rod ends?
- Does anyone keep their windshield washer system and cruise control question?
- From Camaro's to Civic's...
- will hatch front basket work on sedan?
- Do they use condoms or do they just go in bare back?
- EG9 Exhaust Questions...
- need of trouble0-shoot
- Will 2000 civic si rear seats fit in 1996 civic dx
- HID RELAY ?
- 00 OEM EK Hatch vs. 96-00 Seibon Fitment Question?
- new to this forum
- helllpp civic roll cage autopwer
- honda hx rims
- HELP PLEASE Fuel Hose's wrong Race in morning
- What kind of short ram air intake will fit a h22 del sol
- Whats this cable?
- wiring help!!
- Uphill difficulty.
- Battery Replacement??
- Boosting my D16y7 do I need this stuff?
- Giving some zing to my D15B7
- Having troubles with my Rex help please
- Car not starting after fuel injector install
- Help:advice on BLOX stage3 cams
- d15b head on d16z6 questions
- New To Honda Tech & Honda'z Period
- Electrical: brake lights on parking light circuit
- white smoke normal or not
- Timing belt not tracking straight......
- Swap tutorials/ Motor mount install
- Overheating
- Has anyone ever bought from them?
- extending oem fuel pressure hose
- tax return upgrades to the coupe
- 1990 Civic DX 1.5L
- Honda NOOB Here!!!
- How many previous owners does your car have?
- worth 5k??
- Another Si hit....
- D1z6 idle problems!!!
- need help with pcm relay
- Fast Blinker Problem on all sideson a 98 civic coupe, I Searched!
- 96 ls swap is bogging down help
- D16 WIRING HARNESS
- douche or not.
- code 22 and speedo not working
- Erratic jumping idle on my 94 Civic Si...
- ?? 97 Civic - ODD NO START SOMETIMES - no spark or fuel??
- Brakes don't work - 98 Civic DX
- Compatible HX Catalytic Converter
- Need help Cluster lights went out on my 2000 civic
- about to buy a lsvtec eg hatch, appreciate your help
- Can you disable the AC from automatically coming on with the defrost?
- EK/EM1 Foggys on EG/EJ?
- Door Panel Insert questions
- 215 wheel fitment on my eg hatch?
- Injectors
- Cant get roof off Del Sol
- Mileage?
- Friend's B18C1 blew..need disgnosis
- Upper coolant hose flattens out like a pancake after turning off engine...?
- Questions about a problem with my type r trans
- what is this part?
- climate control
- Y8 IM Swap Write up?
- if a eg is having rust on front fender....
- Best Color Carpet
- 00 Si turbo or SOHC Ek turbo
- Im thinking about getting a front lip, which one though? mugen, ctr, or type r,
- Failed smog... help!
- Is there a difference between manual and automatic throttle bodies?
- Buddy Club Exhaust ????
- clifford alarm system
- Car won't start, battery slowly being drained...
- Black Window Vents for Coupe?
- I Need all of your Opinion
- 94 H22 EG HATCH BUILD
- AC Compressor help. What Fits?
- Remove intake manifold to replace head gasket?
- B16 swap but check engine light is on
- b16 cable tranny dilemma
- gauge pods
- does a integra cluster fit my EK?
- B20z2 With B18a1 Intake Manifold In 95 EG Question
- 96-98 MUD FLAPS ON 99-00 COUPE
- in need a h22a civic guru
- D15b Help....
- what brand of ecu adapter ??
- foglight switch?
- my B16 swap has funny idle+more
- Name this part?
- what is below the fuel filter on a 94 EX
- Fluidyne Radiator?
- Cable Tuck?
- USDM Integra Type R Seats Whatn do u think
- b16 header fitment
- Need Help Identifying a Part
- Need Del Sol help asap.
- H23 non-vtec engine
- Will a 98' JDM CTR steering wheel fit an EG?
- need help quick, parking lights stuck
- 96 Civic EX exhaust install.
- Numbers search
- Beaks Products -- Test Cars Needed
- cluster probs so have ques
- HELP WITH SIDE MOLDING CLIPS!!!
