View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Auto Vs Manual Engine
- D15B or D16z6
- dropzone gen 2 review
- Type S cluster into Ek
- Oil Pan Install Help
- idle issue
- REAR DISC CONVERSION QUESTIONS!!!!!
- Mini me using p28
- HELP! ASAP!
- Idling diagnostic? Help!
- keep bumping this to the top till its solved thanks?
- WHAT ARE GOOD MUFFLERS FOR EK's
- Front lower tie bar fit on my civic with h22a swap?
- JDM Headlights Bulb Replacement
- fuel injector q?
- swap swap swap
- 93 civic with b20 vtec dont satart
- cam gear
- Clear or Yellow fogs?
- trouble with D16Y8 mani swap
- Ebay For Parts? How Bad Is This?
- basic parts for my b18c swap in EG
- 89' integra pistons
- THE absolute most quiet exhaust
- what throttle cable to use?
- '97 HX Stalling at stoplight
- Can a 2000 Si run a +37 offset?
- 99 civic EX problem. not sure what.
- help please...
- 68mm tb too big for b16?
- My window keeps falling off its track
- 1998 Civic Coupe to B18c swap - Quick AC question
- >POLL Cold Air Intake or Short Ram Intake
- Wood grain steering wheel
- AEM cold for VIS carbon hood
- h2b ok, but f20b or h22a?
- '99 Civic loud squealing
- HX/VX rims`
- Transmission Problem
- HELP!!!NO FIRE NO FUEL
- need help!!!!!!
- Valve Change
- 1994 civic auto to manual b18 swap. wiring help!!
- 1999 civic si Wont start after break in
- stage 4 6 puck.?
- SRS not letting you hit VTEC??
- injectors
- coilover question
- Type R cluster in 2000 civic?
- I KEEP FRIYING MY ECU PLEASE HELP...
- 94 EG Hatch/B18 Swap Axle keep popping out, help!
- can u change your trans. from cable to hydro?
- vtec engine choice
- Turbo d16 bogging hard when at WOT
- 1997 Honda Civic EX 2 Door
- Rubbing sound in passenger side wheel well
- swap now smoking need help
- Del Sol engine swap question
- 96-98 trans on a 95 SI motor
- Which throttle cable?
- Almost an EG/Lip Advice
- front radiator support
- kill switch help
- B16a rocker arm damage???
- 92 civic eg wont start
- suspension tuning/specs?
- Camshafts question....
- Tire Size
- EG b18c5
- WANTED!!!!! SERIOUSNESS ALL AROUND!!!!!
- Will C.E.L pass smog?
- tranny inspection plate
- cold start...........idles up and down
- Rear Speaker Cover Question???
- OBD2 B18c1 in a 93 EG Hatch, question
- gsr eating gas
- ...looking to buy new front end...
- is it worth fixing up or should i look for a new ride?
- Honda touch up paint? Please help me out!
- quick stock head unit question
- whistle
- Clutch Line Leaking at Slave Cylinder
- d15b8 swap questions
- Opinions on which motor? B18c5, b18c1 rebuilt to itr specs...
- mini me..b7/z6 head - smoke, pop, engine went dead
- So I took the plunge.
- Honda Check Codes. So Many
- What did you do to your civic today?
- Not your average PO505!
- Bad Clutch?
- Who likes lips?
- HELP! removing the inner pipe od a D16y8 header.
- thermostat question
- 99-00 si harness??
- quick window regulator question!! help!
- Noobie from OH-IO build thread...
- How does driving with out vtec feel?
- Looks Interesting: HighEnd Tri Y Header Civic 88-91 92-95 96-00 D15 D16
- Need help with D15b7
- Honda Civic Ex 96-00 Oem Carpet
- my b18b and stuff
- 99 civic swaped Ls vtec need help
- [DIY] 92-95 JDM/EDM Honda Civic OEM Front Tower Strut Bar Install
- EK leaking in the rain, anyone have this problem also?
- Need help with EG full nose mask installation
- Quick ac question, running with no belt.
- need help mph gauge not working
- Gotta love uninsured people who slam into your car....
- 00 honda civic lx wont start have b swap
- Replaced Front Brakes, theres still a squeeking noise? HELP
- d16z6 running to rich help plz
- Civic DX, CX ever come with sunroof?
- how to install aem tru time cam gear?
- tranny clutch kit question?? wich type to go with??
- EG hatch fog lights, are left&right the same?
- Trans cooler on my boosted auto ex?
- Clutch help needed asap!!
- 1.6L D16 Intake MAnifold onto a D15z1 motor
- Exhaust Rasp Help
- is it screwed?
- Window Problem
- relay pinouts
- Help! Idle up & Down + No Heat
- Black Buildup on Bumper Concern
- Main relay random clicking with engine hiccups / stalls + CEL
- I WANT TO WIRE UP VTEC PLEASE HELP
- piping fitment on 2000 ex from 2000 si coupe
- JDM D15B with LSD... Auto only?
- Help b16 wont start
- fuel gauge question
- My new EJ6
- True WHITE LED or Bulb for license plate lighting
- i changed my transmisson fluid
- Ya'll dont know shit
- Swap/converison Service
- delete
- auto to stick swap
- clutch/brake fluid leak?
- anyone have ideas on power steering for a F swap?
- d15b8 oil pan
- 97 hx starter not getting any power
- instrument clusters??????
- B18c1 bogging out
- ecu question
- NEEd help PLEASE
- wiring harness question
- Please lmk How much you pay for this 92 si
- overheating problem
- Ek manual steering rack + subframe
- Seeker Wing
- H22a OBD1 to OBD2 ?
- After removing black box pvc
- Searched* firewall plug p/ns
- 95 civic speedometer problems
- Car slowing and lunging, it was not the brakes.
- 99civic no spark
- z6 ram intake bigger injectors
- swapped gsr into 96 ex overheating
- 99-00 climate control conversion in 96-98 problem!!
- Power steering for b18b1 swap
- FINALLY GOT MY BLOCK DONE!!! CHECK IT OUT!!! LOOKS PRETTY
- low vechile question
- Some basic questions.
- 92-95 si clock..
- d15b7 crankshaft
- driving lights.
- climate controls mixed up..
- Beating on your motor?
- anybody hear or Ever Use COMP CAMS??
- Vtec Mystery - B16a in 94 Dx hatch
- 94 EG Cooling Issue, Only Car need to get to work
- Craigslist Motor?
- 1993 del sol vtec solinoid leak help
- Please Help: '97 HX MT Misfiring bad
- d15b7 to d16z6 swap question
- Cruise Control Honda civic
- D16y7 timing belt
- Steering rack question.
- whats best>?
- TireRack Steel Wheel Covers
- auto to manual 92 -95 civic
- RPM Drop..h22a..ek
- Installing spoon wing on a 96 ek hatch??
- Cam Seal Leak -- Aftermarket vs. OEM?
- LS/b20 rod journal size... Need help ASAP!
- 92 eg6 VTI from Portugal
- 93 civic cars shuts off NEED HELP!!!
- built AC pump
- EX Leather Conversion
- ZC sohc/D16Z6
- Pulling b16a2 Head
- 00 dx motor into 97 ex shell
- How much could I get for my car? "Pics included"
- need help, alignment problems and...more??
- The virginest Civic 99
- Will EK SI coupe taillights fit on my 95 EJ2?? i want them :-)
- new lca's installed, and soft hand brake???
- D16 SOHC VTEC swap into 95 Civic HELP!
- Compensator arm dilemma...
- B18A1 in ej?
- want to buy this eg today but need to know wats wrong
- 1993 cx rear disc conversion help
- Suspension swap/Sol-Civic
- radiator drain plug question
- Snapped valve cover stud
- Rebuilt Motor Wont Start
- NEED HELP O2 SENSOR WIRING
- Removing rear engine breather canister
- H22 OBD2 in a EK Coupe
- Random low idle on cold days
- Fujitsubo Cat-Back Stainless Steel Exhaust
- Car Running funny
- gsr cloths in an eg..
- DIY: Fix squeaky clutch
- *No Vtec* 90 psi to sending unit and 25 psi vtec pressure port
- HELP! Passenger window won't roll down!?
- honda civic fitments
- help with power to ecu
- Change Head Gasket!! HELP!!!!!
- NO Spark? I have searched. please help.
- integra cluster in civic
- Rear brakes swap
- Should these plug just be sitting out?
- need help taillight
- Civic Jdm B16 swap, Idle issue. HELP!
- CTR B16B in 95 EG6?
- Energy Suspension bushings
- Stage 4 clutch in Stock motor?
- Fresh build doesn't start!
- Civic seat rails vs. Integra seat rails
- Ek9 Clip
- injector fittiment for D-16
- ***Coolant draining question****
- How can I disable the factory keyless entry
- Civic hx tune
- i have no ac on my ek need help to install the right parts
- Need help Identifying a part...
- easiest 11.1 inche brake upgrade for EG/EK's
- Distributor timing
- Signal switch/headlight problem. please help me
- car not starting...
- Help with setting timing on head.
- 96-00 Gauge Swap
- Tein S-Tech
- fog light help depo eg model
- Are midori hatchbacks rare?
- Which Clutch to BUY???
- civic d series spoon header?
- b18a1 question
- Need muffler recommendation for eg
