View Full Version : Honda Civic / Del Sol (1992 - 2000)
- zc motor and lsd tranny 5 speed
- For those breaking rear strut bolts.
- where can i buy this part of the foglight for eg (pic inside)
- obd1 or obd2
- sold my turbo db8, picked up 96 ek
- dash lights on eg hatch on and off
- Simple question from a 92-95 civic
- carbon buildup on top of pistons, best way to remove?
- Power steering into Civic DX?
- oil catch can question
- does anyone know how to get the new nissan maxima headlight color on a Eg civic?
- civic automatic shifter bulb?
- Specific Tuning Question...
- dropping tranny
- rear lip rattling due to muffler
- Swap info (Please sticky :-)
- Help with d16z6
- Modding
- DIY: tail light gasket for EK hatch WITH printable template (no more water in trunk)
- Outer door molding replacement?
- REAR DISC CONVERSION ON EK HATCH NEED HELP.....................!
- Need help , figuring out ecu problems
- Coilover Springs...
- crx rear discs on 99 cx
- fog light cut-out template?
- Honda parts
- How many Swaps in the Same Shell??
- car got broken into today
- EG or 240sx
- Password:JDM's carbon fiber power chamber intake
- ac/ps question
- D hybrid transmission from hell
- Performer X vs Victor X
- Yes or no?
- CEL--- Right After PASSING Emission Test
- DIY CTR headlights?
- motor ?
- Tuning a stock vehicle
- Non-Si black EG hatches
- foglight wiring to parking lights?
- KNOCKIN SOUND coming from front left wheel
- NEED HELP FAST!!!
- keep ls head or go ls/vtec? (nitrous build)
- Need Help. B16A OBD1 intake manifold on OBD2 B16A2
- Spinning
- civic tranny fitment
- Basic signs of a blown head gasket
- oil leaking
- Replacing the rings on my ls/vtec
- any d-series axles will work on d16y7? simple question
- Speedo/Rpm Cluster Prob and Check Engine Light
- d series
- Sway Bar question on Dx Ek hatch...
- noob ecu question.
- Last Nights Brake Down
- auto to manual d16 ek???
- How to obtain civic Si OEM Stereo code?
- Help on swapping engine
- power to cd player fuse diagram ??
- rubbing issue
- true life street racer mtv show
- Si Rims
- ek squad
- Weight of itr jdm 4-1 Header
- Gas?
- what size rotors? 240mm or 262mm?
- Power inverter install, anyone do it this way?
- Any Hope On lowering on 18's?
- GSR aluminum radiator in 93 EG
- Tuning Leaded vs Unleaded fuel
- 5 lug rims
- Novice DIY mechanic (me) going to attempt Timing belt change, need clarifications
- clunking noise....
- centerforce or exedy
- Exhaust issues w/ new RS*R
- Quick Q... are oem si and ctr grille the same???
- question about ek and ep3 cluster
- Chipping a P28 - Anyone have mouser.com part numbers?
- tranny case help!!
- help with my blinker/corners
- Saving life of hood
- B18 header on a B16... QUCIK question!
- TYC one piece projector headlights on eg6
- Converting to Integra 1" master cylinder
- do i need all season tires???
- Crank Angle Sensor problem. PLZ HELP!!!
- My Car's Lights and RPM gauges going Crazy
- Car was STOLEN last night in springfield ma
- Vis CF hoods
- anybody got and ek9 for me????? need really bad....
- Vis or Seibon
- Water nozzles
- 1993 Del sol... questions??????
- Roof rack for 96-00 civics?
- d16z6 swap running rich.
- Simple hotup of a D16Y4 engine?
- gsr tranny?
- help need help on stopin idle n surge on a d15 wit comp cam
- Some please guide me how to take out an engine.
- how do i reinstall cam gears and timing belt
- HELP!!!!
- mini me or full swap?
- Anyone know how much a d16y8 mini-me swap on a d16y7 is o.o;;
- megan short shifter anygood?
- 2000 Civic Si Overheating??
- Car runs better cold
- SRS LIGHT IS ON AND IS VERY ANNOYING
- 2 quick tire questions (tire size questions)
- How to bend back radiator fins ?
- Shifter Woes
- EZ out?
- looking for ek right hand drive front clip......
- VAFC 2 problem
- riding clutch??
- clutch help???
- removing abs?
- endlinks
- 96-98 Civic grille question
- short shifter installed =)
- Turbo and A/C?
- i dont know anything about cars!...need help with windows!
- lost my wheel lock keys for rays lugs!
- full race traction bars problem!!
- 92 Civic swap
- 92 si Driver side shocktower plug pinout, HELP!
- integra dash
- 92-95ex swaping94 gsr?
- horn doesnt work
- how long am i going to be a noob until someone fixes this? my 2nd noob stage wtf!
- turbo edit / engine management
- nsx frnt brake conversion on my eg
- help! HID's in my ek
- WHITE SMOKE! (HELP)***
- advan supers no an ek hatch....?
- CAN ANY1 HELP OUT WIT MY SIDEMARKERS
- Chassis Names
- Which OBD 2 am I?
- post your hot cars P.A
- EG9 converted to eg6 front end ?
- EX harness removal
- did they ever make a carbon kevlar spoon duckbill spoiler for a 96 hatch
- My car got flooded....=(
- What Seats Bolt into the Del Sol without modification
- 98 hx obd2->ob1 conversion harness
- d15b7 ideling problem!!!
- vibration at idle
- 00' civic SI ECU???
- 00sir em1 brakes
- Pics of 99-00 civics?
- squeaky clutch??
- throwout bearing question
- [Ideas and Suggestions] Sealing the inside of the rear fender.
- city lights
- Is this a Wheel Bearing problem?
- what spring rate should i be looking for a tein coilover setup
- MSD ignition in an EK
- B16A2 Block
- MY CARS IN AN ANGLE??...CHECK IT OUT
- How to keep cruise control after manual swap theory?
- Just changed coolant..... now engine temperature is erratic
- input on the t1r spl street muffler
- tranny problem..
- Will HKS Hi power scrape on lowerd cars?
- drivetrain makes funny ticking sound
- help with sidemarker on ej8 plz
- Which generation of Skunk2 Arms are these:EASY QUESTION!
- P1399 and P0135 Codes....
- Transmission issues......again!
- Identify this part # please!!!
- low idle!!!
- Rebuilding Master Cylinder, where to get seals?
- Can I use this ignition switch harness???
- Do you need headlight harnesses to hook up HIDs?
- i need 93 civic rear body parts
- dsm 450's in a 98 hx
- will a 99-00 civic si harness plug and play into a 2001 JDM TYPE R ECU?
- slipping clutch??
- wearing clutch??????
- EJ8 Rear Quarter Panel Extension?
- skunk2 shiftknob (dumb question...searched)
- Weird Smell and Car Pulls Help!
- How many Synchromesh Quarts?
- ebay special?
- My Cluster Is Possessed
- y8 intake mani on z6 head HELP PLZ IMMA KILL MYSELF
- Whats wrong with my horn? OEM Steering wheel, NO SRS light
- Problems with my speed sensor and my temp gauge HELP!!!?
- Where to get race-only direct ram intake?
- ES TUNING Muffler, Good or Bad?
- ***Good news for those of you with a 1995 or older car***
- USDM vs JDM lower control arms....Help solve the dispute if you can.
- fuel injectors not working????
- Needing Help to Start My Car
- Anyone used the OBX Radiator hose kits?
- D16 valves spec question
- stripped nut on rear disc break
- Bride Seats
- Still no solution to why my car won't start. HELP!!!
- changing the gauge cluster lights!!
- what interior swaps are availble for my EK?
- Casting Call: JDM Enthusiasts In San Diego County Needed For Video Documentary!!!!
- Support Beam needed?
- CEL Code 17 VSS Questions
- coilovers
- Gsr Wire Harness
- ARP wheel studs
- Who's runnning nitrous on d16?
- power fc all motor build problem
- 96-98 Keyless Entry, Different remotes?
- overheating problems
- how to hook this up?
- where i can buy like this headlight???
- My 93 Civic EX 4dr GSR SWAP
- wHERE I VEHICLES FOR SALE PAGE
- b18 EG exhaust/header
- 1.5vtec ref??
- EG6 Parts for Sale!
- b18 eg header/exhaust
- is the ex cable reel the same as the dx cable reel?
- Rims bent and now car drives like a turd..
- b18c1+HKS hi Power
- stock 92-95 civic steelies
- intake manifold problems
- fitting started leaking after turbo install
- i need a new trans, how hard would it be to go all wheel?
- 96-00 splashguards?????
- wiring window wipers to a switch
- vaccum leak....?
- size of nut on suspension fork?
- Sticking Clutch in First Gear.
- Interior
- vtec cel but wired right .. any thoughts
- 1999 Honda Civic K-Series Clutch Problem
- Help Installing a center console from 94 integra to 92 civic
- Need a d16z6 auto to manual mount.
- Difference in coupe and sedan side mirrors?
- 92 civic dx zc motor and lsd tranny 5 speed
- D4 Light On The Dash
- What is the best Alarm System Out There?
- Misfires or what?
- just a few questions
- GSR Block for Sale!
- need your opinion
- price on k20 complete swap!!!!
- Where to get ARC splitters for ek hatches??
- Heater question
- hey guys im new what should i do to my 92 civic ls??????
- how can u quote some one in the forums
- Problem with car makes clicking sound when drive HELP!!!!
- Cheapest DOHC swap for a 98 Civic DX
