View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Direction
- B20 Running Poorly
- Del Sol radiator question
- Buzzing coming from the fuel relay and dash going crazy
- H2b s2000 crank pulley issue
- How to verify timing if I messed it up while changing timing belt?
- 2000 civic si
- EK vs EG manual steering rack question
- 1992 eg hatch right skirt
- Id just like to confirm...Del Sol B15 to B20B
- Worn clutch pressure plate?
- Auto to manual wiring
- Just bought. 1992 civic dx
- Loss of steering returnability
- Auto to manual cluster ??
- IACV small Vs. large opening
- Iimmobiliser engine swap issue
- Pre-install Koni/ground control suspension, Gap between springs and top hat, safe?
- 99 Civic DX (d16y7 w/ 5speed man) with T3/T4 turbo kit issues.
- Low fluid in clutch reservoir
- 97 Del Sol Si boosted build. Progress and questions.
- EK Civic Door Wiring Harness, Hackjob Wiring found, need some help.
- Honda civic p06 ECU Q31 burned.
- Will EK coilovers fit my EG ?
- d15b vtec coolant drain plug location?
- Story Time Folks! (Warning-really long thread)
- Manual Swap Clutch Free Play
- Not Shifting after Clutch change
- B20vtec random bogging issue.
- Engine and trans swap
- CV axle seals, new ones needed change axles?
- Help with P0740 code on 2000 Civic Ex
- Carbon Fiber hood for a Civic VX?
- Auto to auto help needed 2000 civic with b18b1 01’ motor
- How to get A/C in 1998 DX b16a2 swap.
- D16A general diagnostics and compression
- EK coupe leaking fuel. Help please?
- Flywheel dust cover part number
- Block swaps and tunes ?
- Built motor b16 no VTEC power
- Fuel Line Help
- 1993 Honda Civic eg6 si-r
- Check engine lights
- EK9 Steering Wheel Common Fault - Advice please!
- B16 swap on a 1998 Civic Ex EK coupe
- Copart Rebuild: 97 DX Sedan
- Transmission not shifting into gears while running
- Missing Del Sol Aux Light Sockets
- 1998 civic B16A2 no a/c no speedometer
- Racing Seat Install 99 Civic
- Best engine swap for 97 civic hx
- Ignition timing
- '96 crank, but no start
- Quarantine Re-Paint
- Odd TPS Issue d16
- D15B VTEC 3 STAGE en Honda Civic 93
- unknown fuel wires
- Possible Vtec Solenoid Malfunction?
- 1995 civic two unknown connectors in passenger floorboard
- 98 civic Ex coupe question
- Civic 99 ex problems
- P2P connector?
- 96 civic with b20/ls trans swap issue
- EH9 auto to manual wiring questions
- 00 Honda Civic
- B-Series head work - Opinions?
- 5th gen - Please help , where this dash connector goes?
- 94 ej1 - swapped D15b2 - Doesn't start
- 1996 Civic CX 1.6L I4 SOHC MISFIRE!
- Civic VX manual steering rack
- Front strut bar
- Rear Ctr 5 lug conversion
- Ticking noise
- Installed Header, Gas Mileage Plumeted
- 95 civic buildup (low budget build)
- ECU
- evap purge valve (canister) leaky
- Del Sol "glass" top
- Help!! No check engine light when I turn my key on accessory mode
- Track Car Build
- Del sol hood
- Stripped head bolt 99 civic d16y7
- Possible blown head gasket ?
- Drag radials
- 1995 Honda civic dx sedan
- Help! 98 Honda Civic ignition prob!
- Smokey D15Z6 - solutions??
- Squeaking noise in the front when turning the wheel
- Auto to manual no crank
- Starts with start fluid but keeps running
- 93 Honda Civic DX - Surging Idle
- HELP: d15z9 with P2a-7 head.
- Cluster swap?
- Cylinder Support Systems
- Plz help p28 jumper issues
- D Series Transmission- Seeking Information
- 92-95 Civic Hatch Door interchangeable with coupe?
- B18B1 lsv questions??
- Need some info on part names (D16Y8)
- Oil leak for 99 EX
- Low compression from cracked manifold??
- Motor mount recommendation and vibration concerns.
- Random water in floorboard?
- 195/65R15 tires causing bad handling?
- New clutch issue
- ‘99 Civic LX engine advice
- Cylinder 1 and 2 have moisture 99 civic
- Looking at wheels for my EJ8
- lsvtec swapped 93 civic hatch won't idle
- 95 LX D15B7 - What to do to make the car more fun?
- Eg civic with kswap tachometer won't go above 7500 rpm
- EH9 Auto to Manual Questions
- Stalling and starting problems. Need help
- 2000 Civic LX Sedan Automatic Transmission Compatibility
- Bad ECU?
- ‘00 Civic Randomly chooses when to prime and crank
- D15B with P2J-5 stamped 95 on rs
- Need instructions on accelerator pedal assembly removal
- 93 del sol idle issue/ misfire?
- What thread chaser for head install?
- Ecu, main relay, fuel pump check engine light issue intermittent????
- Help Civic 95 lowerdash
- 94 Civic Hatch Floaty Steering?
- '99 Honda Civic Hatch DX - climate control lights
- Not sure what seat these are
- Temp Gauge Fluctuating
- 99-00 si dash harness vs 99-00 ex
- 97 ek was b20 swapped having ecu problems
- Having trouble with eg.
- Yet another no start thread
- Help Civic 1995 license plate panel change
- 10.1cr b16a turboed
- Continued CEL's from transmissions
- input shaft bearing name 93
- IAC error, doesn’t want to idle above 800rpm
- Steering wheel play
- Ek9 rear sub frame to replace an em1 rear sub frame
- 92 delsol transtop problems.
- Crazy wipers
- Daily driver suspension
- My 2000 Honda Civic EX OBD port not powering OBD scanner
- Any Honda groups in tampa
- Looking for a Crome turbo base map?
- Ac idle issue
- Oil pissing out back of engine
- Help with B20 Power Steering
- Mysterious Coolant Leak
- Will a b20 ps pump work on lsv in civic
- Daughters 2000 civic misfire, confused!!!!
- Sunroof Issue
- 1992 vs 1997 build year
- Turbo filter?
- Cylinder head chatter and P0325
- Roof seals/gaskets
- 96 Civic - Gsr swap wont start!
- ignition timing adjustment with obd2 scanner?
- B18c4 K27 Turbo Potencial
- Discuss
- Wiring harness problems
- No egr valve will effect fuel mixture????
- Cannot go WOT from pedal
- bypass coolant heater line to valve cover breather line
- What better for front seat
- B16a2
- Rear lower control arms question
- Fuel and idle
- Accord seats in ek
- VSS wireing to ecu HELP
- This much slop in shifter? (98 ek hatch/b18c)
- Need help diagnosing a no start (b18c1)
- EK9 Parcel Shelf Repair/Reupholster
- Speedo working ocasionally
- 2000 Honda hatchback dx coil overs
- Rebuid/reinforce interior door panels
- Help me find my first project car?
- No crank no start
- 2000 civic ex EGR valve location????
- newb, engine swap questions
- Austin TX Help Needed! Want to test working parts
- Mb6 fuel tank replacement
- Whats involved in b18b1->b18c1 swap?
- 93 Del Sol - B16A Gen 2
- P0170, p0505, p0172
- 1997 civic automatic transmission fluid type
- What Oil Pan for B20z2
- Gas tank help
- Crank no start PLZ HELP!!
- Radiator spitting out coolant while bleeding
- '00 EM1 SiR VTEC not engaging/ECU Questions
- EG hatchback leaking water.
- Does anyone know what this wire is for?
- Missing nuts on b series vtec valve cover
- what are del sol owners doing about rear roof weather stripping
- 92 Civic Auto Trans issue
- D16y7 to d15b7 camshaft swap. Will it work?
- Is this coolant good for D Series engines?
- 1998 honda civic speed driven transmission gear problem
- DIY Bluetooth module
- Axles for 300whp
- Tapping after head gasket replacement on 2000 Civic HX
- 95 Civic DX D15b7 Engine Crankshaft needing Specs ,oil holes
- no start when hot after being in storage
- EM1 Silicone Hose Kit Fitment Questions
- Urgent help plz
- B plug pin out - obd2a Civic automatic engine harness
- Help choosing sway bars
- Car Bogging down at 100% throttle
- B16a2 vtec not engaging
- Question about B Series Transmission rebuild
- Steering Wheel Setups?
- Relocating interior power lock switch?
- d16 turbo build questions
- 1999 Honda Civic LX passenger wheel vibrating
- Noise on startup, smoke from belts
- Integra steering pinion on 96 Civic non p/s rack
- 96 EX Water Pipe difference
- 2000 civic b16 swap need help and this one is going to be a ruff one
- Junction plug for resistor box.
- E brake cable removal
- EG Conversion Hood Install Help
- Mice entering 1994 vx
- B series
- Vibration at Speed '99 Civic Si/Ex (Can/US)
- Overheated engine, what should be replaced / inspected?
- help door latch on 98 civic
- question about steering rack, manual vs power
- 95 civic auto atf leak
- Where Do theY Go???
- 92 civic gauges dont work.
- Surging / bouncing Idle
- Civic VI gen hatchback EJ9 windshield washer pump
- D16y7 to D15B Swap non vtec, need ecu advice
- 1993 Honda civic coupe, b18b1 swap
- 1996 Honda Civic EX Headlight bulb retaining clip screw
- d16y8 ignitor part change?
- Looking for hard brake line for my 1999 Civic Si
- Gas smell on oil/Smoke at high rpm
- 96 CX bell housing on an S40-B000 Ex trans?
- No crank, no start. What am I missing?
- RPM Gauge Question
- Marketplace access? How?
- No crank no start issue,
- 96 honda civic P1300 code
- Need help fixing my 93 del sol 1.6l 5spd
- Turbo Civic 98 D16Y8 on STOCK INTERNALS
- 98 civic LX Automatic - Dies and will not shift from park
- EG/DC2 driver's strut tower plug pinout
- 95 civic coupe nothing happening when turning on combination light switch
- H2B question
