View Full Version : Honda Civic / Del Sol (1992 - 2000)
- bad block????
- HELLO! New hear, have some questions.
- clutch gay-ness
- Where can i find 99-00 Fog Light Trim?!?!
- b20 specs?
- where did you get you HID's ?
- new member here are some pics of my ride
- 1995 EX sohc vtec, engine went.. BOOM
- Piston ?'s for a D16Y8 Turbo
- OEM Flywheels - d Series ?
- lowering coupe, suggestions?
- jdm obd2 ?
- A/C issues...help!
- Anyone running Tokico blues and H&R sports? Opinions?
- ABS dynamic front lips?
- stock wheels on extended studs
- HR Sports for an LS fit 94 cx hatch?
- easiest way to get 4 wheel disc and stay OEM?
- 94 civic cx hatch...cable or hydro?
- Now ive done it....
- B16's with nitrous in EK's----What do you run?
- how can you find a vaccum leak?
- Power Window Problem
- KICK ASS 6th gen hatch video... 56k? files too big I think...
- Skunk2 Front Upper Control Arm Bushings
- people with oem optional audio consoles.. what do u do about cup holders?
- Reducing weight in EK...
- building a y7.. but y8 intake.. what gasket !
- need help! oil control jet problem.
- sohc vs. dohc
- front lip ?......
- B17 CRANK and 00 si tranny please help
- JDM obd2 b16a less the spool valve oil switch and CKA sensor?
- Rear upper strut bar install questions.... (pic)
- how many miles do YOU have on your b20/vtec?
- ... hid... street legal...
- To those w/ ACT Clutches...
- Fender
- Would these slicks work ok?
- b16a2 swap price
- *****please help, vtec not engaging.*****
- SOHC Turbo Numbers?
- Tranny/ShiftLinkage TECH Question! (SWAP)
- 92-95 civic rear tranny mount same as 94-00 teg?
- Pipe diameter for aem cold air for 96 d16y7 dx
- non vtec ecu on d16?
- delsol nitrous users...
- !!!!!PLEASE PLEASE HELP!!!!I ???? Code Throwing Questions????
- Stolen HT Car Recovered Intact by Fellow Members!
- d16z ecu??
- b16 sir2 or b18b?
- Just a Heads up....kakimotor catback exhaust for EK (link inside)
- I have a list of serious questions for my 99 Si.
- lug nuts for si rims?
- DC sports header
- B series Engine mount question
- tail light dont turn on
- H&R Springs with KYB-AGX shocks for my 97?
- help with changing rotor!
- 95 engine swap
- huh???
- D16Y8 modifcations, will this work?...
- Need your guys help/ Civic won't staruys tried to jump it, t, no power at all.
- Magnetic drain plug
- Indiglo guages in a 95 civic
- What Color should i paint my 92 hb
- H4h (JDM Headlights) HID kit...
- Hondata
- 99-00 Civic EX Question
- Calling all you D series masters
- PS/AC And A Swap
- CT. people with black si.
- Broken Fog Light Relay
- Instructions on how to build a homemade sub box
- which type of subs should i get for my hatch
- Is my hub and bearing whats causin my problem?
- Es sports muffler or WS catback system?
- My question needs an answer??? In need of wisdom....
- tail light question....
- What company should i go with??
- New Honda Accord Comercial!!!!
- d16y8- is there a non-vtec model?
- Quickie: DC (JDM 4-1) flange...
- head light question.
- Where's the alternator fuse on my EH???
- Please Please !!HELP!! Please Please
- Which Drain Plug is Which???
- Leaving stock catback on F/I car
- !!HELP!!
- GSR front subframe brace on 92-95s w/ P/S?
- best exhaust for 93 hatchback
- need help on motor swap
- JE cr-vtec pisons in an 84mm gsr?
- Comptech Intake?
- I know you guys hate these....Which one?????????
- ? ? ? What was the best Model / Color / Year Civic ever created ? ? ?
- Del Sol rims - how to clean center caps????????
- Will Recaro SRD work with Tenzo R rails? and bracket
- Anybody else have been without your civic for a while?
- what the crap!?!
- Y8 Cam vs. D16 cam
- Exhaust help needed
- Ecu code 1?
- 2nd gear popping out
- Steering wheel vibration at 70mph+
- what size wheels?
- Do 1997 civic's have the big reinforcement beam under rear seats???
- New to B18B(just got a civ with B18B) What is good?
- Install a stolen engine?
- F1 mirrors for EG
- Pics or Part #'s Needed for Ek rear seat parts
- for all of you with engine swaps.
- How much for a 98 Ls motor go for???
- emergency torque specs!!
- Anybody know where to get a 99-00 civic front bumper for cheap?? Websites??
- dc header for a 97 sedan and stock type r exhaust
- who has or used to have the camo EK that was in Honda tuning once?
- New Techlogex shirts introduced (Tom approved)
- Which one is the fuel sensor in hondaautomotiveparts.com?
- 00 civic Si VTEC oil pressure switch.
- Manual conversion or Engine Swap
- Quickest/Cheapest Way to Have a 13sec EG
- what exhust is just right?
- parting out my old y8
- how do you know if you have "spun a bearing"
- How to you remove back seats?
- anyone have a how-to on taking out a y8 tranny
- Disabling SRS
- TDC mark on crankshaft pulley..
- 95 EX sohc Vtec, oil light keeps coming on?? help
- Wiring nightmare on EK...HELP!!!
- ITR LSD Worth Buying?
- Mugen MR5
- 94 Accord Steering Wheel On 92 Hatch?
- Edelbrock Turbo kit for Y8's
- Rear Defogger not working, which fuse to check?
- car sound cat?? do u recommend one
- gsr sway bar, front & rear
- Hid
- What is the best D-series setup? (intake manifold, head, tranny, ecu, etc.)
- my car is not running i need help!!!!
- Dyno Chart of hatch w/ d16z6 all motor and NOS
- Suspension?
- LS Cluster in 94 Civic Hatch
- h22a ek
- Check out my EK
- what b-series engine fits in a 98 civic without buying any motor mounts?
- jdm lip paint or no paint
- Aem V2
- precautions when installing airbags?
- hard core site !
- aem by pass valve
- where to install gauges on EG???
- CEL-10 on my GSR swap. Is the IAT neccesary?
- Which Spring?
- Tein suspension question
- obd0-obd1 trouble shooting ??
- blowing ECU fuse (under hood) like crazy... why?
- tranny or moter
- Instaling an ek airbag...
- Orange clean
- 92-95 euro clear headlights and HID?
- D16 Cam & gear...
- HP gains w/ CTR cam, Skunk2 cams,and a V-AFC
- is 91 alternator same as 1992?
- install directions on vision corners
- Rota C8 wheels with gorilla 12x1.25 or 12x1.50
- 96 hatch w/ 96 GSR engine and motor mounts
- Body Work
- lookin for h22-ek mounts
- ek fog lights in a eg??
- suspension Q's EG to EK
- 99 EK.. stock motor sucks any suggestions?
- tranny fluid for 98 ex 5spd
- question about my intake manifold holes....
- EG/DC/EK upper shock mounts????
- Tech question D16z6 head
- Does LCD backlight of Si stereo stay on even with headlights off?
- What Color is CTR Yellow?
- del sol brake upgrade ? help
- Newly installed ecu....having some problems...please help
- What engine does a stock 94 Civic hatch dx come with?
- calling all hydrolic tranny experts.....
- Sir Front Lip, Rear Lip, Sides for (92-95 Hatch)
- How to take a d16a6 apart
- need help removing airbag...
- speakers on a gutted hatch?
- strut install?
- ctr rear sway bar on 99-00 si
- weather stripping?
- Are 88 dseries flywheels interchangable with 92-95 dseries flywheels?
- Service Manual for all Hondas?
- does this happen to u guys 2!!
- need help with civic axles
- Power Windows/Locks on my EH3
- 1995 CX or 1994 Integra GSR Shell
- Swaping EG dash, how hard?
- Speedmaster 11lbs rims for $380
- could clacking valves cause a knock sensor CEL????
- People with bad a paint jobs!
- help removing bolt from lower strut mount
- need help install ITR guage on ek cx hatch
- 92-95 zc?
- Turbo D15 sohc vtec?
- Rear swaybar help
- Tell me something...
- back seats please read
- 1990 awd talon 5speed with alot of money put into it
- What would you do?
- Anyone tell me whate make these shocks might be
- Bumpstop affects drop ? H&R Sport....
- I'll pay $85.00 shipped for a civic eg CX/VX fender!
- From experience. Does the Apex'i N1 Universal muffler sound good?
- 195/55/15 on EG??
- installing INLINE fuel pump (d16z6)
- !Help! timing? plug wire mix up! d15 sohc
- Interior light won't turn on, which fuse to check?
- Code 23, does it kill Vtec??
- Anybody ever put a EK cluster in tehre EG?
- Kumho Ecsta 711 discontinued
- tire size
- guage cluster problem
- HOLLEY TB Trouble, and that DAMN TPS!!
- Plastic cover for SOHC engine?
- EK (9) Civic Reverse Lights Malfunction.
- How do I remove A Pillar?
- getting 60 miles/tank of gas!!!
- Are Neuspeed or H&R Race springs too much for Tokiko Blues?
- spark plug order
- Identify this hole. . .
- speed shops in clearwater area
- anyone have a d15b7 alternator laying around????
- if i swap my tranny to a si will i have to change the ecu or anything, its a vx
- Integra GSR Dash
- well a 92-95 honda civic exhaust kit fit on a 4dr civic...
- HELP needed STOLEN car
- wiring diagram for gsr cluster in eg
- did any of u guys oder things from modacrap....
- D16y8 HEAD auto/manual........
- So I went to get an alignment...
- installing RS-R exhaust...
- My B20 into EK parts list (from hybrid forum)
- PLEASE HELP RUN CARFAX!!! I really need it 1j4gz58sipc691971
- How can I chirp 4th and 5th gear?
- RS-R Invidia Exhaust opinions
- Best repair manual for a Civic?
- Traction bars, do they work?
- Need Header Testing help
- Best Site for Wheels
- 1998 Civic LX Black Smoke question
