View Full Version : Honda Civic / Del Sol (1992 - 2000)
- USDM P30 ECU REPAIR
- Can Anyone Read This?! Part 2
- drop question....
- Clutch?
- JDM B16 swap into a EG
- b16a2 intake manifold vs. type r intake manifold
- fuse panel help
- wrong section? idk but am i the only one with the advertisments
- turbo question
- VAFC
- help with 5lug conversion.
- I need help with my car :(
- rebuilding a gsr
- what is hp on a stock 94 eg hatch?
- My car sounds like it has asthma?!?!
- del sol question
- strut bar
- hooking up da vtec
- ? about itr cams ....xs power????????
- simple question, estimated cost of a OEM rebuild on a Y8 bottom end
- 2000 EX and SI differences
- integra sway bar on eg6.
- d series trans upper mount bolt size?
- boostin
- B20 Swap In......4Dr EK!!!
- Car starting.. not staying on.. HELP!
- Meltdown!
- b series automatic?
- Clutch feels a bit different? Is it on the way out?
- ek wing
- recommend me a quiet exhaust/muffler set-up
- H22 Heads look heree
- Cams and bore
- trailer arm bushing question
- Need help 93-97 del sol parts
- if running rich then....
- jdm cluster
- 4 Doors Cat-Back Question...
- 94 honda civic engine swap D15b Vtec HEADer Pipe NEED HELP
- Knocking while turning....
- power windows
- Engine Swap Help!?!
- axles
- spring rates
- dc2 dash in 92-95 eg
- p06 ecu question. real quick!
- cracked valvecover?
- i am noob
- Sir swap into a 96 ek
- Injectors Question..
- 94 Civic battery light comes on
- B16 vac/boost gauge ?? erratic at times
- b18 civic cable tranny
- Honda EK
- what are these?
- A question about Pedals...
- A/C Fitament Issues
- Is stock oem eg dx intermediate pipe 2" or smaller ?
- 96 ctr sway bar into 92 EG6?
- Has anyone passed emissions with a mini me head swap?
- blown motor need opinions
- 93 del sol overheating
- wut could this be.
- wiring for neutral saftey switch
- Startup / Idle problem
- noise after tune up on d15 94 eg
- h22a swap in a 95 civic
- 1992 Civic **STOLEN** Keep a look out for it please
- removing silicone
- Can anyone clear this up?
- Control Arm Torque Specs?
- Installing a b16a
- clutch master cylinder
- check engine light on 96 ek
- Muffler Only
- WHAT CAMS FOR MY EK H22?
- 95 civic coupe h23/h22 project
- NEED HELP WITH FUEL LINE.
- Buddy Club P-1 SF 16" Weight?
- 99-00 civic Si(SiR) front sway bar fit 96 civic cx hatchback
- Pistons....
- what iis the paint code for championship white?
- Pistons.....
- Transmission failure
- LS TURBO?!?!
- d16z6
- RSX Radiator
- Do not order from tunerzimage.com
- need help identifying these pistons
- Idle surge + running funny at times
- ecu died
- blox dual valve spring and retainers?
- ecu Issue
- Splash Guards...
- need advice
- Anyone here replaced an expansion valve?
- opinion on a h22 swap in a sol?
- Hydro to Cable...searched.
- b18b ls project....
- urethane???? abs???
- swap questions!!
- Swap Info
- a/c compressor relay location on '97 Civic
- del sol pics
- wierd sound from trans
- Boggin Ls.....
- D16y8 NA build ideas
- hthey whats up guys im new here.....
- Build thread : d16 all motor w/ nitrous...dont hate on the sohc
- re-spray??
- usdm vs jdm b16 header obd1 vs obd2 (need to stay oem!)
- Tranny leak?
- Front caliper and pad difference
- trying to identify the head on my motor.
- heater help please
- weird climate control problem
- god this may be the only thing i regret
- 92-95 Civic Leg Room
- New member, Proud new owner of Efrex's 93 SiR EG6.
- budget turbo
- shocks/coilover from DA fits the EK?
- 92-95 coupe front end on a 4DR
- install spring/shocks myself or take the car to a shop??
- Input on building a custom trans with oem parts
- Mini-Me Swap, z6 or y8?!
- anyone have a wiring diagram/instructions for a b16a wiring harnesses??
- b18 turbo,gsr turbo or build my b16a2 turbo
- WATER COOLED TURBO ?
- tranny noise
- help with tail light question
- First Honda Here
- short shifter
- building for boost on d16z6
- power doors ( search didnt help much)
- Fog lights! help!
- sr20 for an ek coupe
- taking out a gsr....with questions
- center console swap.
- z6 tranny fits into ek?
- Eg hatch with a weird problem!!!
- I can honestly can believe that this would happen to me.
- WANTED TO KNOW!
- CEL Knock sensor
- were do i find an ecu
- when to change timing belt?
- Upgraded Internals?
- please give me some advice
- Passanger Door Removal
- Help Please!!!!!!!!!!!!!!!!
- Motor Just Died ON Me!!! Need Help!!!
- b18c1/ b16a2 question
- help me with my decision
- b18 block b16 head
- TRANNY PROBLEMZ
- New to Forum, Looking For Cat Converters. CX VTEC Swap Q
- idling problem. Civic 96 lx. stock.
- Domani Front End Conversion
- Gauge Cluster Lights not working
- what swap is best
- Possible motors to replace my d15b non-vtec
- what is this???
- how do i know if im running to lean or rich
- turbo exhaust
- auto/manual speed sensor?
- p2p ecu
- Steering Wheel Issues..Need Help ASAP!!
- D16 turbo cams??? know any
- loud exhaust
- extra sensor...black/yellow and red wire
- what mounts do I use
- iacv or hondata control module possible bad? please look!
- Car Feeling sluggish..not a nub
- 02 sensor
- NEED HELP!! OBD1 motor into a ek
- Honda Civic 99 SiR with b16a jdm swap. blowing out oil, need ideas
- will this fuelrail work??
- H22 swap del sol - AC/PS?
- EK lower chassis brace (pics) will it rub on my header???
- '95 Del Sol - Right Front Fender creamed - where to get one, how to put it in?
- p2j schematics anyone???
- Rear suspension!!!
- Im so lost.. car wont start.
- Tps throwing cel?
- where to find an eg guage cluster...?
- 98 civic need to reset the computer
- question about muffler tip
- need help with climate control
- Fuel pump not priming
- b16a emissions
- Injector box
- iac and throttle body dillema
- What is wrong with with my girlfriends
- LS/VTEC compression? + white smoke at high rev
- MAJOR ELECTRICAL PROBLEM
- EG DX door actuators?
- honda guru needed
- mugen front lip
- WOULD D16Z6 CAMS AND ROCKER ARMS FIT IN A VX HEAD?
- Axle trouble
- CO problems
- k20 swap for 95 rhd civic sir.
- Anyone Can Read This?!
- car goes to 130 in 4th, shift to 5th and hits governer
- cant find the pistons right for me
- Tips on reapolstering (sp?) the door panel of a 95 honda civic
- leaking oil ?? cant find the source
- what is needed in a 96-00 civic conversion to a acura el front ???
- Power window/lock/mirror conversion
- Clutch problem!!
- what is the difference in Omni slip on coilovers than Skunk 2 Coilovers? They are basically the same
- ??? ab 4x114 96 ITR Disc Brake Conversion on EG hatch
- need help with this question....
- more problems
- Fresco Green Pearl????
- B16a2 Question Once Again
- LS-GSR headgasket??
- 99 ex exhaust
- clutch question...
- Emission Problems
- Need help putting A/C Into 94 Eg with ITR Motor
- Can I time my motor or do I have to pull the crank pulley
- 97 Civic HX SRS light on and horn doesn't work
- Seatbelt leak?
- B16B to EG6 swap
- tokico quality? and espelir?- am i gettin jipped?
- BRAKES ~!!!!!
- Car wont start. Have fuel and spark
- *Building Motor* Need Help
- B16a hatch idling funny/ poor gas mileage
- SOcal Shops?
- 5 lug-RSX s 17's on EG
- Kocking noise? (1993 Civic DX)
- throttle body sticking after rotor pulley swap...help..
- 92-94 civic prop valve
- B16 wiring harness fit d16y8?
- halp! 92 lx main relay issues
- LOOKIN FOR 96 EK HATCHBACK PARTS
- what size m/c prop valve for wilwood 12.2" fronts/10.9" rears?
- Help with tail light wiring
- b16a at what rpms does vtec kick in?
- yonaka itr header (need corresponding flange for cat to bolt on)
- engine problems - vtec spool solenoid valve, o2 sensor 02 sensor heater, fuel supply.
- need help fast/ ordering stuff today
- gauge cluster in a 92-95 Civic Cx
- Zex Cam?
- Hey quick clutch question
- ***07 Civic Si Seat will fit to 96's ?***
- Need help wiring Alternater. OBD1 harness-OBD2 alternator.
- Replacing rings and their chain reaction.
- GSRcams
