View Full Version : Honda Civic / Del Sol (1992 - 2000)
- New civic, bad suspension, cold idle, and sticky gas pedal
- You're Gonna be SO JEALOUS 100% SURE OF IT!!!
- NEED help with mini me swap!!
- car is bogging when im flooring it
- Anyone with an NRG short hub on an EG
- EG w/ b18 injector help
- just blew a fuse
- Is my TPS done?
- p28 auto/manual identification
- i need help for a b18c1
- Honda Canada Parts search?
- a/c troubleshooting
- d16 compression?
- Need help on why turbo eg hatch stalls
- tranny problem
- Distributor troubles
- em1 with b20 block, someone tell me.
- Rechargeing Ac Question
- H22/H23 T Bracket question.
- Quick question.. Will an auto tranny torque mount work on a 5sp b18b swapped civic?
- KONI YELLOWS
- 99 2000 Civic Keyless Entry question
- Drop springs question
- Electric windows ALL won't roll down on 1994 del sol s
- Paint and windshield
- i want some more power!!!!
- Alignment issue on lowered EK hatch
- Axle Problem with Pictures - Bad Auto Zone Axles?
- both -&+ labeled on coil are hot (+)
- 92-95 hatch lift support removal
- Buzzing and rasping noise coming from new exhaust. How to get rid of it
- Help Needed ASAP P08 head gasket vs P2j
- Drop Engineering Mounts = Installed!
- back fire? rpm's bogging down?
- 95 civic hatch with b16a. idle help.!!!!!!
- 97 Civic LX - power windows and locks won't work
- SI 2000 rebuild system
- whats the fuel pump wire?
- 97 si a/c question
- 2' lowering springs
- JDM H22 swap into 98 civic coupe...HELP!!!
- 98 civic disaster
- turboed civic burns oil
- 99 CIVIC SI
- EG EK pedals are the same?
- Turbo questions for d16z6
- PB&J MADE MY CAR NOT START. HELP ASAP
- In a rush. Need help asap.
- Civic SI 00 CEl code 45 / 67
- Desperate for help- wallet inside jammed 1998 Civic DX glove box-latch won't open
- Trunk Lid Carpet?
- Creaking noise when steering...
- 2000 CIVIC DX CYP & Misfire Woes -- Really need help!
- can an oil pan from d16y7 fit a d16y8?
- Stiff Shifter
- New member - Project vehicle
- Universal Exhaust Silencer?
- car squeaks a little when i start it.
- lip fitment.
- Brake Diagnosis
- what ecu for mini-me?
- state ref?
- ISO: Your ideas on GSR build
- motor
- D16z6 head on D16y8 block
- Polyurethane manual rack bushings?
- wtb z6 supercharger
- B20B?
- No more heater core...loop or cap?
- rear end sqeeks
- Front LCA Bushing removal help.
- Head bolts 97ex vs 95dx?
- best place to buy lowering springs?
- coolant setup on h22a
- 99 4 door lx wont start,only got flat tire?
- oil leaking
- How do I get a car glisten? ( paint )
- Del sol d16z6 axle help
- Help with new project
- Best way to replace a door lock?
- Front Motor / Engine mount bolts just spin
- 1994 Civic LX sedan - 2" hole in bottom of in transaxle housing - possible to fix?
- looking for 2001 CDM red rear seats
- ECU and Knock Sensor Combinations
- 93 CIVIC 1.6 SOHC Rev Limiting at 3500 RPM and misfiring-HELP!!!
- Passing emissions by just pulling a intake manifold hose?
- B16 has no spark but power to dizzy
- 96 Civic Hatch Power Door Locks Not working
- Where can I find some SAE 90 Gear Oil?
- eg hatch built turbo b16 kinked oil return line :S
- New Problems: just learned I have an EX with a D16Y7. Don't know what parts are what.
- Front Wheel bearing issues??`
- NEED HELP PASSING SMOG
- General Maintenance Q's About 92-95 Civic?
- Rubbing noise when driving
- Switching From D over to B-series
- interchangable parts?
- Please Help: 1997 Honda Civic Hatchback Jerks in 5th Gear on Freeway(3000 rpm->0 rpm)
- help with headswap on my d16...
- Swapped ECU's......car doesnt start....
- strange lean issue, thinking map or tps..
- Canadian Steering Wheel Installation HELP
- D16Z6 swap - What do I need before it goes in?
- swap transmission auto to 5spd parts
- CEL code 13
- b16a2 hesitates when vtec hits.......
- vibration during acceleration
- Does it sound like i need a new clutch or transmission?
- anyone scrapping with this wheel and tire size setup??
- B18c gsr swap wiring issue
- What rings for turbo b16?
- Testing Radiator Fan
- mini me swap problems. help anyone?
- synthetic oil in a d16?
- Electrical problem with cooling fan
- three wire to two wire plug
- what is this???
- del sol turbo help!
- can 17x7.5 17x8 wheel fit on EG??
- gauge pod setup.. help?
- 97 civic passenger seat
- should i angle exhaut tip???
- crank pulley
- CEL 5 MAP - manifold absolute pressure sensor
- Racing Harness question!!!
- Will 1996 civic coupe rear seat belts fit into a EG hatchback??
- clutch slipping..please help!!!
- tires to fit my del sol (205/50R17)
- Y8 with Z6 head
- why do i keep smellin burnt clutch?
- window tint
- Bought a civic and having problems
- will p75 run a d16 for a bit
- Multiple Problems
- EH2 front end damage
- now in appearance forum
- Exhaust piping recommendations--HELP!
- Losing brake pressure on gentle pedalling.
- ....Brake Light Stays On....
- civic idle problems...
- WHAT IS GOING ON WITH MY CAR.. PLEASE HELP
- 92-95 center console light
- d16y7 Misfire - out of ideas.
- Integra Rear Discs on EK: Master Cylinder Question
- Voltage problem! Help!
- CR-VTEC in 97 Civic DX hatch, major problem
- d16y8 ac compressor
- Re-torque head gasket???
- car not revving pass 7
- 97 dx ram air vs. modified air box question
- ej1 not starting up?
- Reading CEL code manually
- Idle Control Malfunction and Knock Sensor on. Cause and Effect? Need Help
- Fuel MPG - D15B7 or D16Z6 better?
- NEED A QUICK OPINION
- need help on getting coilovers/springs on 94civiceg
- Windows and Gauge cluster not working ??
- Can anyone help me out.. Pics..B18B
- Problem with my hatch, Stalling and not wanting to start back up, **Video**
- need opinions on buying ek9 with b20 swap b16 head type r gear box is that a good buy
- what radiator tube to buy
- what kind of axles?
- Vacuum readings during idle...
- oil pan gasket ??
- 99 civic si, overheating problem, Help!
- DIY For 1997 Honda Civic Dx Power Lock Converison
- 97 Civic EX Swap OBD help
- Front Hub Bearing Removal?
- ABS not working?? (CRX EG2/ CIVIC delsol)
- Wiring Harness Questions
- Can anyone tell me why my car has these features....
- D15B Swap ( Jdm Engine)
- Low idle speed when warm
- Torque Convertor Torque spec question
- 98 honda civic si(canadian) with b18b motor mount inserts
- weird acceleration feeling
- Headlight styles for EG hatch
- ZC swap
- Need to replace pulleys...
- HELP !! Speedo and tach quit working after changing harnessn
- Hard Steering! Rack and Pinion??
- how to tell if manual tranny fluid is low?
- B18b1 wont hold cold idle
- need sugguestions?
- brake problems need help asap
- brake lights
- d2 dampers from eg will they fit ek
- camber kit ?
- Car won't start
- best setup to get max hrspwr and torque and still be a daily driver
- speed sensor problems can anyone help
- My honda has no map sensor...what the hell?
- JDM D15b VTEC
- Just bought a 1998 honda civic si(canada) with 1997 acura ls motor
- eg dx smog question
- Harness compatibility
- Civic and del sol struts
- Odd accleration problem
- LED License Plate Bulbs
- D15B7: Smog Test Fail: EGR Functional?
- D16Y7 ENGINE. coolant escapeing from resovor log adding coolant 3-4 day. need help!
- Question: Max hp for turbo daily driver
- IAC problem
- clutch slipping?
- Car not starting
- Have a few questions regarding my EG Hatch
- B18B debates as to what to do with it. Suggestion....
- GSR shifter on B16?
- My intro and some body fitment questions
- Blackworks Racing Performance Aluminum????
- NRG Seats & Brackets
- My super dope EG hatch
- jerky throttle and cel for iacv
- My intro and N/A H22a5 ek swap :D
- Integra Dash in a 97 4dr civic
- Denji HID/H3 help!!
- Suspension Help
- 1997 Honda civic Axel seal leak
- What the heck is this hose for? Stock D16Z6...
- idle problem after engine swap
- Help blue smoke a lot! 93 Civic DX
- 97 ex civic coupe lock actuator issue.
- wayy too much rattllleee...
- Password Jdm CF intake
- popping out of 5th
- dr20 wheel locks
- NEED HELP ASAP! BUSHING FOR EG!
- Ground wires
- spark plugs?
- Help with installing SRI on 2000 Civic Ex D16y8
- classics or newer
- cluster swap problem
- LS vtec build
- confused
- CEL blinks, Speedo revs, car wont start
- carbon kevlar parts eg hatch
- replacing axle, do i need to change oil?
- spark and pressure but no spray!
- 94 civic engine swap
- Seeker Wing troubles with Alex Brackets(replica) EK hatch owners help
- Where to buy new honda alarm remote
- power steering, rearend
- Bleeding Clutch Problem......I'm Stuck...
- gsr, what is this, and can it be removed?
- B20 engine Sleeves Upgrade???
- I tried search first
- Automatic transmission fluid change help
- skunk2 suspension on 95 civic coupe question?
- TPS Plug No power
- Headgasket...
