View Full Version : Honda Civic / Del Sol (1992 - 2000)
- high rpm prob
- really need help
- can i put the wheels back on with no tranny?
- clock resets to 1 every time car goes off?
- HELP!!! H&R springs way too low!!!!!!
- THe real facts about H22 EG Hatches
- Hi all have a Q?
- Car shuts off when I turn my blinker light on. Please Help.
- please help d15b8 with b7 head
- A/C install
- 96 civic with 300k
- Poll b16a2 or b18c1 ...????
- Alignment in Atlanta
- Brake booster and Cylinder
- apexi noir/ rs*r exmag??s
- well work pays off (lots of pics maybe to many)
- head milling?
- Brake Line !!!!??!!HELP!!!??!!!!!
- where to install a thrust bearing on b16?!!!!!!!!!!!!!!!!!!!!
- E-Brake will not disengage after repeated abuse.
- 95 gsr cat-back on 00 civic coupe?? need to know soon
- OMNI COILOVER SLEEVE??
- '95 Honda Civic EX - cooling system hoses, got 'em all now?
- b series and d series difference in clutch? will they swap?
- Water leak in the cargo area. Any suggestions?
- s2000 throttle body on b16
- Gsr smokes in high rpms.
- NEED HELP WITH DIZZY!
- Playing in a puddle of water
- e brake light??
- TPS CEL. Help
- 2000 fenders and hood????
- what do i need to fix? steering problem ...
- Z6 Upper radiator hose mount
- Advance PMTR build in my EM1......need help...thx
- idle problem
- 93 dx code 43 UPDATE
- What blow of valve and flange to get for greddy turbo kit?
- RHD conversion. Car turns one way but not the other? PLEASE HELP CAN'T MAKE LEFT TURNS!
- thottle body
- EK Power Steering Bracket Question?
- anyone know aem's honda fpr thread return thread size?
- How do you install the valve cover bolt seals?
- Master Cylinder and Brake Booster
- Will give EK away for $5,500 Please take off my hands.
- Just bought a '00 Si, what is interchangable?
- d16y8 or d16z6
- i got a lip
- NEED HELPP ??? ON MY B16 SWAPP
- To trade or not to trade my EG2. . .
- 94 Civic CX SPUTTERING
- valve cover problem
- Does anyone know a shop in San Francisco that does B18c1 swap?
- Horseshoe clip removal > Drum Brakes 96 Civic
- edelbrock turbo kit
- help on 95 ej1 brakes
- How long can a tranny sit?
- HELP HELP HELP
- Oil pan question?
- Steering Column
- sohc throttle body how much??!
- suspension???shat!!!
- idle rises when stepping on brake pedal
- sir2
- cool idea
- 92-95 Civic Cabin harness compatibility
- Where is Socal (LA area) to get EK Civic DX A/C repaired?
- Targa sealed shut!?!?
- AC Compression Belt
- B16 intake on D16?
- Need some help again....
- can a blown head gasket cause burning oil?
- tri-y race header
- 99 civic 4 dr b18c1 w/lsd swap for sale $7k 40k miles new suspension
- Megan Rear Camber Kit
- where do you tap in accessory power?
- My exhaust fell off
- 93 dx cel will only come on while driving
- She will be missed... But a new project awaits...
- ctr/itr 15" wheels asap.
- Temp Gauge
- why wont my Car start?????
- 2 codes 6 and 7
- SUSPENSION
- 2nd Opinion
- CLUNK WHEN DISENGAGING CLUTCH / SHIFTING
- avid or energy suspension
- coilovers...
- Opinions wanted
- Where Is A Legit Place To Buy These Rims?
- A'Pexi Power Intake
- Code #6 ect need HELP!!!
- sohc tranny making noise[ bone stock dd]
- NEED HELP WITH MY B16 SWAPP
- OBD1 Civic (1995 DX with a P06 ECU) getting a OBD2 GSR Engine...
- Oil Pumps?
- del sol window/ roof squeak. i have a pic of what squeeks
- motor oil level question.
- will itr pistons work on b16 rods?!!!!!!!!!!!!!
- unsure on a blown head gasket
- how to take off on 96-00 civic window moldings?
- 96 civic question
- Removing drivers airbag and keeping passenger airbag functional on an eg?
- Want to reduce 92VX ride height at front. It's now 1" more than my 94CX & 95Si.
- Skunk 2 throttle body sticking
- Pistons?
- zc sohc engine
- Civic Overheating
- iat sensor
- engine ping preignition detnonation help
- another car won't start thread....
- bent subframe?
- hey, header and exhaust question...
- tranny and ecu problem
- Smoke?
- intake air temp sensor
- Will my 1992 civic Cx passed smog with d16z6
- D16z6 Problems
- 95 ex/si transmission question...
- z10 oil cap breather clearance
- e brake cable size. HELP ME!!
- state ref question
- 96 sol fog lights?
- EX VTEC HEADER!! HELP!!
- No Spark
- top radiator hose ripped
- ek motor harness
- B16 pistons in a B18 motor....
- Alternator Question
- thirsty radiator
- sohc vtec D16Z6 problem plesed HELP
- Stripped suspension nut...Cant find a new one
- D16z6 timing
- How to race a automatic?
- integra muffler
- d16z6 Problem please help
- 93 civic dx w/ z6 swap
- Head swap question?
- cluster question
- Vtec experts please help with d16z6 vtec problems. I have read the troubleshooting faq.
- OBD2 Distributors, is there a difference between A&B?
- TPS help
- eg srs ecu location???? help
- transmission swap
- p73 ecu in my ek
- Installed a bigger throttle then idle surging?! Different design?
- Whats it worth? Civic VTI-S '99 35k
- Anyone with 99-00 SI spoiler
- 4 point roll cage
- Omni
- Sensor questions
- hood fitment issues.. pls help..
- will usdm type R rear seats fit in em1?
- Battery Light
- proper way to convert front end
- front end conversion from sedan to coupe
- Fuel Pump doesn't always priming ??
- Is it worth it??
- Common Problems, Recalls and Service Bulletins for '92-'00 Civics and del Sols
- Adjusting/Replacing Alternator Belt
- Shifting Techniques
- Civic engine swap
- Wierd Fuel Supply Problem CODE 43 HELP!!!!!
- Speedo is possessed???
- Are your 92-95 Civics loud?
- HELP PLZ :S
- eagle rods hitting girdle? d16 zc motor build
- D15b o2 sensor...
- quick question need help
- Rear seat conversion
- exhaust question
- Howl/ Light squeal from engine bay
- How hard is it to put EX cluster in a DX?
- camshaft
- Rim Sizes
- over heat problem
- stock color 4door
- oil filter
- how to replace throatal possitioning sensor
- tach needle not moving, use to bounce sometimes but worked fine....possible ignitor aka igniter ?
- Oil Leak? on D16z6
- d16y8 turbo?
- ecu fuse keeps blowing
- 1997 Prelude Seats
- D15b tranny indification...auto or 5spd????
- ITR front sway on a EG hatch?
- big problems
- distributor question
- lookn for a civic automatic in Boston Ma
- CLuster removal leaves ????
- HELP!! VAFC2 wiring em1 B16a2
- Car wont start after warmed up.
- d16y8 egr????
- Creaking noise that has me stumped
- Needs some help......
- cars runs but idles weird...help!!!
- car not starting
- d16y8?
- Exhaust Qs, opinions wanted. EG HB w/ B18 swap.
- stripped fuel rail
- Initial rebuild start up problem. Have searched.
- Engine Vin
- offset, pls help
- my car 95 civic DX wont start
- LS swap, Throttle cable?
- Turbo B16 gas mileage
- CARBON KEVLAR PRODUCTS??
- H22a 1/4?
- How much should a Z6 bare block cost?
- B20B Questions
- Looking at building up an engine.
- Civic 92-95 EG6 JDM rear spoiler problem
- tranny is missing some bolts!!!
- what is the name of this bumper?
- HELP! About to buy 94 Civic EX with GSR swap, QUESTIONS!
- Engine startup after 4 years
- brand new Venom intake and g sport fuel rail?
- A/C BRACKET FOR B SERIES IN EG
- 99 si cluster issue
- 16x7 +36 or 16x8 +35(fitment ?)
- Tuning question, injectors to big?! Help!
- Front lower sway bar for 1996-1998
- Weird idle issue
- Looking at a 93 sedan, what should i keep an eye out for?
- anyone looking for a VTEC controller?
- 92 Civic LX - driver's side window won't work
- WHAT THE F IS GOING ON WITH MY CAR HELP
- zc motor swap into a 95 civic....?
- CTR check engine light blinks at redline
- will oem side skirts from a 92-95 coupe fit a 93 hatch?
- used itr cams
- engine noises
- Battery Issues. (dead battery after it rains only...fine otherwise ) HELP!
- Passenger Window Actuator
- Quarter Panels anyone know were to get them online ?? 92-95 hatch
- Changed oil but didn't change oil filter
- starting problem
- piston rings
- Pin-Out - C101 or C303
- 1992 honda civic dx-not sure if distributor is going
- Please Please help, no speedo, no odom, harsh shift, d4 flashing, not vss or ecu/pcm!
- 98 EX to b16a2 swap
- Lug Nuts
- Power gains from NA
- EG Civic Sedan Interior Question
- NEED MORE POWER ON MY LS
- quick question: idle problems.
- Wheel and Tire size for 98 DX Hatch
- extremly slugish
- how do I install coilovers on my 99ek????
