View Full Version : Honda Civic / Del Sol (1992 - 2000)
- SOHC TURBO DYNO : BOOSTEDED9
- EG hatch/sedan taillight help needed
- HELP: New 02 sensor, still CEL 1 <== Steps to trouble shooting CEL 1 inside
- RPS street clutches?
- Need HELP on EK front conversion on del sol
- TEIN FLEX - need some info please.
- gauge cluster problems
- OEM style FAL fan? or universal? is the OEM style worth it?
- EG & DC low cost ( relatively ) triangulated strut bar option
- wiring harness help!!! pics
- Any insight from Axle Gurus
- HOW DO I MAKE MY OWN STURCT BAR
- question about power windows
- Exhaust Compatability
- rust problem with my ek could use some advice
- 225/45/15
- New and LOoks for Free Mods???
- how much do 99-00 civic si stock wheels weigh?
- sohc performance pulleys?
- Exhaust question for a 98 civic ex
- type r or b16 boost
- si to dx intake manifold
- Volk BT-C weight
- obd2 obd1 wiring problems
- 92-95 civic Si question
- Act Streetlite flywheel for 99-00 Si, Worth it?
- IM vaccum line question?
- No start after OBDI changeover! Please help
- HOW do i make all the blinks stay on with parking lights, and blink with the blinkers
- rear main seal question ?
- Looking for a hi flow cat
- What would cause an automatic car to turn off when put in reverse?
- Help Please (which alternator)
- Please Help
- question about throw out bearing
- 92-95 civic front end difference?
- steering wheel moving left and right when, minimal shaking at freeway speeds
- Honda fluids and parts.
- throwing a CEL and i cant fix...help!?!
- B16 is sorta screwed up, and need some help...
- Where can i find a used B16A2
- BENEN INDUSTRIES QUESTION
- overheating problem please help
- Clutch question
- turbo timer problems
- GETing my motor!! yay ...have a few questions?
- noticed white smoke today out the exhaust
- main realy
- s2k wheel into ek:How to wire airbag?
- Eibach Sportlines on my Del Sol
- Brakes Locked up, help me please.
- Ignition Coil Wiring
- Threw a rod...Now what???
- What kind of motor mount or insert is in this pic???
- LS into EG
- Difference between code 1 and 41
- tranny is screwed give your opinions
- I HATE jacking up my car. i think i bent my subframe!!!!1
- Has anyone done a Integra nose onto a EG on here?
- Will the following parts fit on a Del Sol?
- Civic DX AC Wiring Question...?
- d16y5 valvesprings
- installin horn wire for the momo hub
- Skunk2, Aebs, Itr manifolds which is better HELP !!!!!!!!!!!!
- PHILLY question ????impulse??
- New Dude..
- Help with Civic HX and EX Harness
- BAD CAT post #2
- civic 00 swap info,i need some help plz
- Car running way lean help
- need help with idle
- Test pipe fitment question help!!!!
- dizzy help
- buy my car!!!!
- Hey, new girl here, turbo help please.....
- exhaust question?
- what is the difference between these headers?..
- Anyone know how to modify a h4 blub into a H4H!!!!! NEED HELP ASAP?!?!?!
- Sway bar question
- Water leak inside door??
- where can i find Falken Azenis fast?
- What do I need when I swap out my B16 in the EG6??
- my dashlight fuse keeps blowing help
- squeaking when braking and turning left ... possible rotors?
- Legalbility of rs-r gt2
- a question about tail lights..
- Brake Light Assembly for Civic Coupe
- anyone can tell me what boot is this?? thanks
- D16y8 tranny problem...HELP
- Steering Rack ratios?
- So I traded my crx for a del sol...
- anyone know where i can get this kit from?
- Skunk2 Intake Manifold Question
- How modify 93 civic dx to power door lock! thanx!!
- Location of SRS service connector on 99-00 Civics...?
- can i switch my strut and spring from eg to ek
- need help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- anyone running with full race turbular manifold on thier eg
- Surging idle help....
- Brakes are p@*sing me off!!
- Valve adjustment questions.
- URGENT PIC REQUEST/INFO: Autopower Race Rollbar in EG
- fake mugen lips!?? for ek9
- How to port match Intake Manifold? *Already Searched*
- no spark ( HELP PLEASE)
- Hi :)
- steering problem
- difficulty of mani swap
- Which tranny has smaller gears z6 or y8?
- Gauge help
- d16y7 with z6 head into 92si
- :Need Help On Purchase for Engine:
- NEED QUICK ANSWER - Fuel Pump Help
- What is the best place to buy OEM calipers, pads, and rotors
- 99 civic fog lamps
- Noise from engine somewhere?
- What muffler will fit my stock dx hatch?
- Has anyone used EBC Sport Rotors (Drilled & Slotted)?
- general maintanence / tune-up
- SIR-II Swap Problem
- White smoke...what is it?
- Carbon fiber hoods and b-series engines on my eh3
- wheel question
- THE ULTIMATE SETUP!?!?!?!?!
- My 98 Civic DX HB stalls occasionally....why??? Need help!!!
- going to swap motor on my civic soon
- strut bar question????
- where can I get a d16z6 rebuild tutorial?
- d16y8 vs. d16z6
- List your top speeds! EG/EK
- idle emissions tests are not accurate
- please help...D16Y5 HX motor into EG...
- Quick ecu question...
- Having some trouble with my rear brakes.
- HOW TO MAKE YOUR EG6GSR FASTER?
- quick brake question for eh2
- Windshield Wipers
- Need help with installation
- Why do you like your civic?
- CEL after i get on the throttle.
- idle problem.
- Engine Check - Help?
- OMG I think I'm gonna puke....
- IAT / Primary 02 Help
- 99 cx hatch gauge cluster
- 99 Civic EX Swap to SIR II Problem!!!
- EG rear disc conversion?
- What is the size of the bulb?
- CR-V 5-lug
- dragonglow products nitrous kit and chip.
- which struts for groundcontrolls?
- vertical doors:do they seal like factory and which brand is the best?
- quick questions d16z6's have how many o2 sensors
- WANNA DO AN MPFI SWAP
- Door sagging 95 civic ex coupe
- electric supercharger question
- Tranny Question
- Yo what look at my lil b16
- engine running crappy when hot
- Del Sol radiator
- improving air flow to radiator and a/c condenser
- HELP
- A silly question about motors
- Fuel pump, filter, or line?
- a/c condenser fan for 92 and 95 civic
- tps
- Help....ITR guage cluster in my EK??
- 7th gen rims
- newbie help clutch
- HELP ME PLEASE!!!!!!!!!!!!!
- how do u take the o2 sensor out?!?!
- anyone running the Magnaflow Magnapack (resonator) ?
- Sparco Horn Piece will not fit momo hub ring....?
- Hayame's official release for fit problems on current generation Civic and RSX
- Very weird problem with my 97 Civic HX....please read
- Rear strut replacement 95 Honda civic
- question about removing back springs
- Del Sol B or C pillar bar
- need honda part number, or some help
- loss in horsepower due to altitude?
- check out meets from israel
- HAVE MONEY, YET NO ONE has motor?
- Help me identify....
- JDM b16 having the same problems as my old B16a3
- (3days and the car still gargles) damn rain
- Q: Arizona emissions laws
- HELP ASAP!
- Can someone recommend me a site to purchase a 2001 Civic Lip kit.
- ? switching transmission weapon r vs aem
- b18b swap???little help please
- please help electrical/ battery alternator Qusetion
- putting an F20B in to a 93 civic and have some questions
- which antenna is real
- bio pics
- Has anyone busted their rear engine mount?
- power steering belt part # b16 w/p2t pump
- distributor wire order for DX motor
- help with skunk2 cam timimg
- whats the best head gasket to use on a d16?
- any d16s laying around....need cash?
- obx fuel pressure regulator installation
- SAGE RACING, eg lca's too long?
- Air Box help need ASAP
- Replica Mugen Intakes for EG?
- whats the difference from these kinds of a/c..
- Will a gsr ac fan fit on my civic??
- passenger side window says no
- fitment issues with jdmshit lip??
- auto tranny won't shift!
- I'm getting f'up Tire Wear!!!?
- airbox differences
- Does anyone know the CC's of D16 head?
- Transmission Problems
- XS GTR Intercooler or apexi gtr intercooler in a EG (fitting question)
- FAQ: AEM CAI install (pic intensive)
- LCA QUESTION *URGENT*
- Vibration in the Steering Wheel
- YES!!!! How to wire a k20a into EG !!!!! pnp Harness!!!! THANK YOU HONDATA !!!!!!
- Apexi World Sport Coilovers
- CAr Starting Weird?!
- How Do I Get My 99 Civic Front bumper off??
- OBD2-OBD1 conversion in an automatic?
- floaty steering, and a locked steering wheel
- Does anyone have any pics of Duckbill spoilers?
- Aif Fuel Ratio Gauge
- RIP 94 civic
- Rev Limiters
- curious to know
- strange noise when warmed up
- hatch rear seat question
- if you had to change your rotors?
- HOW MUCH DOES MY CAR WEIGH????
- wiper switch bad? need advice!
- JDM EG Bumper Pole?
- What CR should i have for my setup
- My new game: "Guess my headgasket!" SOHC vtec 4 layer???
- Bouncing Gas Guage...Help...
- Estimate on Windshield replacement?
- How to Check if the Civic is having LSD Gearbox???
- Need opinions and advice 94 civic coupe bolt ons
- wideband o2 ?
- best times for stock swaps in ek
- wanna do b16 swap for me???? I'LL PAY!!!
- Wheel Bearing
- Ok well, I am about to get a hatch...
- question for koni yellow users (eg)
- ***FOR SALE*** ITR CAMS TYPE R CAMS, REALLY CHEAP, OR WILLING TO TRADE
- ***WANTED *** 92-95 JDM CENTER CONSOLE, WILLING TO TRADE..JUN SKUNK2 TODA
- new radiator problem
- Stripped tranny bolts! Grrr......
