View Full Version : Honda Civic / Del Sol (1992 - 2000)
- Q!! about CTR (22mm) Rear sway bar...
- a/f wiring question for ls ecu
- Just installed Pivot super earthing system
- Si head
- kustom k&n filter
- Red Reverse Indiglo guages
- are all del sol radiators dual core?
- To Buy crower cams for B18b or not to buy???
- JDM CTR 5 lug the same as USDM ITR?
- throttle body and intake manni swapping
- Need Help with OEM style FOG LIGHT installation EG , EH....PLUGS???
- accord radiator in civic??
- CEL 41
- WTB link
- Is there any books on engine building? (Done search, came up with nothing)
- Does this sound right?
- have $600, need help???
- MOTOR MOUNT quest. please help me
- Anybody using a JG SOHC motor?
- update on my car.
- Blinker problem, won't work
- I'm a newbie with a few qustions/
- whos else makes these wheels
- 1992-95 Honda Civic Hatchback Chassis
- How much are you willing to spend on your civic?
- ZC internals in a d16y8?
- Advance or Retard
- Timing Question
- New pics of my car...got my bumpers painted finally!
- Blew a fuse?
- How much HP does my engine have?
- JDM Integra Front End Conversion Kit or Parts Need
- mugen thermostat ????? i dunno so i go to the pros
- 96-00 EJ6 exhaust question
- new weight reduction website
- Rear drum to disk upgrade on EG
- What's your favorite pedals?
- D16y8 vs d16y7
- Let's compare rods... :crook:
- brembo blanks?
- Torque wrench question
- usdm f22(accord ex) in civic?
- What are these rims ? HELP!
- Thanks guys! :)
- greddy turbo for hatch with ex motor?
- buzz in exhaust, what causes it??
- my car =pos
- cheap upgrades?
- EL tranny vs. Si Tranny: help!
- What's the Redline for a 94 GSR motor?
- JDM ITR knob vs. skunk2 shifter
- Jimfab jim fab motor mounts?
- My car was stolen!!!
- Something blew at high speed and no key for my lugs to top it off >:0
- which is better b16 sol, or ls vtec integra???
- HELP!!! i dont know what model civic
- 92 civic si
- ***'92 EH2 Power Lock Conversion....Tech Question***
- vtec head
- cold air intake bypass valve. worth it? opinions needed
- Does anyone know any companies that make something like this...
- What kind of cat r u running?????
- itr engine: si intake hose and box? or SIR only?
- a Skunk2 Megapower
- What to do with a bent/crushed AEM CAI and worthless Short Ram?
- *56k'ers - Photo Warning* Body panel/body job experts advice needed
- 5th gen 'eg' hatchback what size muffler
- spare tire dissimilar, problems???
- owners of kyb agx's
- 96-00 intake manifold ?
- D-series?
- Signals not flashing? Please offer some advice.
- To TaKE OF A GRILL! do i need to take off the bumper?!!
- Bulb Sizes for 99 HB
- fuel pump removal
- -- engine bay pics -- need suggestions on how to clean up --
- Intake Manifold
- WANTED::Your Reviews on 92-95 Civic Hatchbacks!
- Modding a B16A(USDM) EM1
- Pictures of 4 door 92-95's
- Piston Rinng Sealing Question.
- Stripped oil pan threads. Solutions anybody??
- Wheel stud removal
- fenders
- Are you sure!?!
- Dropping my car. Suspension Questions
- rear window glass question
- haha...went to see price on 'teg crossmember brace
- main bearing caps ???
- I was sent to the Ref, I need your help to pass?
- oil pressure gauge problem
- How much would a timing belt, serpentine belt and water pump cost? (just parts)
- guess wut gear???...
- Will a 99-00 Civic Coupe Rear Bumper fit on a 98 Civic Coupe?
- NEED HELP Doing rear disc conversion ASAP
- Compression?
- Pricing on 92 VX
- ot: Next Meet: Engine Building Seminar
- OT: Well look what I got to replace my old hatch!
- GSR stock strut bar on EG fitment with B18 motor???
- Turbo & N/A / Traction
- Expert advise needed: 1st gen. b16a - 92 CX - Help!
- 92vx swap Q.
- d series 4-2-1 rs*r header
- 1/4 mile monster!
- just got a b18c1 bare block
- MSD Cap Application
- a/f gauge question
- Clutch Hardline Install
- Which is the best magazine for hondas?
- 14" Del Sol wheels (thin and fat spoke): how much do they weigh?
- ECU pinouts please
- Cost if a VSS
- Eibach Prokit from 00Si on a 95 DX hatch?
- FS: 99 Hatch Climate Control, Si Boot, Short Shifter, CTR knob
- Radiator Upgrade
- 93' 5 spd civic for sale
- ys1? please help
- 4th Gen Si and 5th Gen VTEC Calipers on Civics.
- Will a intefra type r wing fit my 200 civic si?
- quarter mile time for a cx
- Need tips in how to beat h22
- looking for99-00 stereo center console?
- Honda Access door visors...
- Will it bolt up?????
- Has anyone seen or used one of these bars?
- Damn 4x4'ing it after ITR Suspension
- want to investigate to make the ultimate project car
- KYB AGX owners....read this
- price on a 97 dx hatch?
- Just got my spoons, 205 50 15's or 195 50 15 Falken azenis
- JDM headlights for EG, will not fit EG with an H22 motor?
- Which Sways will fit?
- jdm A Sports fender brace install on EK
- Rebuild or Swap??
- cooling fan
- Coupe engine transfer to Hatchback?
- CX and EX wire harness
- what cams 4 b16a
- b20z oil pump question
- What do you think about Nakayama Rims
- Caught some thieving fuckers!!!
- help- clutch slipping prior to gear engagement
- Green Key in an OBD1?
- Red Konis w/red ES bushings for my Si? Opinions please!
- mini-me swap???
- help fast !!!!!!
- help
- JDMshit.com
- New to Honda-Tech
- hp question
- LCA question
- I just ordered my teins!
- pulley
- running too rich..........
- throwing code 3 - map sensor defective??
- dx cluster swap with si cluster???
- radiator install
- 00 civic SI front sway bar question..
- Here are my option, which is best?
- When i Rev high, i hear a noise coming out of the head
- removing AC controls from EK --- please help
- bypass airbags
- SOHC turbo ....
- Slight grind in my ex/si tranny?
- Checking tranny fluid in D16 and changing it?
- Lug nut , cross-threaded. WTF!!!!!!!
- Classy-sounding Exhaust for EKs
- Turbo 101 ( teach me ) WHAT IS NEEDED... WHAT IS COST... Kit or "Home Made"
- Stripped the upper tranny mount bolt holes. Now what?????
- Brake Tech: Steps to replace warped Rotors.
- b-series thottle body on d series
- Ls block, with GSR internals...
- hiya, new member from the uk
- 2003 Civic Si Cluster *56k safe*
- EK hatch with GSR struts. Will it work?
- Y8 auto head with manual intake manifold?
- Need responses on my 1/4 mile times and help.
- GSR tb + y8 mani?
- ITR pistons in GSR?
- How to bleed the clutch.....HELP NEEDED FAST
- before and after pics of my 95 coupe
- Jesus help me with this timingbelt PLEASE!!
- Cam ?'s
- tired of all these 20" spinners all around my area!!
- steering wheel install...removed 19mm bolt...now what?
- Annoyinh brake squeakage problem...
- Does the 5Zigen Border Speed Exhaust Angle ???
- New replica MF10's?
- Tokico Illuminas
- Apexi V-AFC
- all EG a/c compressors the same?
- timing belt broke... valves????
- Is there any differences in the coupe and the hatch?
- B18C Engine arrival and first work pics....not for 56k
- LS/Vtec
- Proportioning valve help..
- cluster or on dash tach?
- Good Price for H22
- skunk 2 f/r strut towers?
- 98 civic, cracked outter part of taillight. . .quick question
- KYB AGX Civic question
- what is reasonable
- HELP!!!! one side lower than the other
- which brakes?
- which exhaust?
- Looking for new suspension for my EJ1, please help me choose
- which seats?
- Mini me questions
- which wheel?
- Vtec
- ek drop question.
- Tekniq snap-off wheel:horn
- multiple cams question
- Where to buy superchargers??
- Sucessful Valve Adjusment
- Z6 cam in Y8 head.
- Help with ssp wheels.
- Attention: CANADIAN Si coupe owners
- Clunking sound from the fuel filter ??
- 93 civic for sale
- Swap time... and suggestions wanted... B16A2 vs. B18C
- Looking into buying an EG hatch, have some questions
- changing the oil for my car...
- tryin to find a k20 engine to put in to my 02 civic and any other parts that i can find
- d16y8 in del sol...PLS HELP ASAP!!!
- Need H/T Advice/HELP! EG Hatch stolen, found (sorta)
- low CR head gasket options and results?
- Front upper suspension mounts?
- Hey Guys Anybody with 1.5 drop with 15's have any pics? THANKS
- roll cage for a Del SLOW?
- Will it work?
- Hopefully I can get some help from the civic guys
- TPS problem. I can't stop the cels. Could it be bad???
- DIY Put an Integra radiator into a Civic. (2000)
- quick stop for brake help........
- track times for first gen b16 in a cx?
- H22 swap in Civic SI 99. Hows it handle?
- sparco 3 or 4 point harness?
- OEM Fogs...
- ITR motor build Update *56k suicide*:
- New project car+Honda Newbie=Lots of questions
- New Rims Tell me what you think
- spoon or trust airnixII drop-in filter?
- ***'93 EG Power Window Conversion....Tech Question***
- Does Anyone Have a 92-95 Civic Hatch For Sale ?
- B20 questions
- civic vs celica
- motor swap
- Hybrid EG Hatch ETs?
