View Full Version : Honda Civic / Del Sol (1992 - 2000)
- when will the del sol discution end? vote now
- Bumpers
- VX Questions
- what causes oil in spark plug tube?
- H22 Radiatior Question
- 92-95 code newbie ?
- SRR rear suspension pieces
- important shit about SI owners and their Ground Controls
- quick release steering wheel hubs?
- ?del sol seats in eg
- 4 door civic type R...
- will a 6th gen coupe muffler fit on a 6g hatchback?
- what NGK plugs should i get?
- question about headers on a hatch . . . again!
- bleeding brakes w/ABS???
- Just need some help
- es oval muffler brackets etc
- jdm civic mirrors maybe even integ mirrors...help needed
- where can i find
- How many wires is on the secondary o2 sensor for a 96 y8 auto motor?
- Where can I buy a powercore header for a 1994 civic ex?
- $1,000.... what would you do with it?
- **Remote Oil Filter**
- Radiator hoses for a B-series
- WTF My car is overheating
- What tires are good for all season?
- 2k civic bseries motor mounts?
- well....i did some math last night and...
- Meet
- I want to know everything there is 2 know about an LS swap
- how many miles before changing tranny fluid?
- what happened to that gear
- vafc base setup
- need opinion on civic....
- Jackson Racing on SOHC
- my instrument lights went off? can't see $hit at night. pls help...
- GS-R or H22
- 200 civic front end on an EG??
- do you think an LS tranny is usefull?
- Helms Manual
- does anyone have the JDM SLIM SIDE MOLDINGS installed on EG
- Iginition Rotor
- Car Clubs
- post your setup and 1/4 mile times w/ your 92-95 hatch w/ b18c
- Buying Used Coilovers
- CAI Question
- having trouble chirping second in my d15b sohc vtec.
- I have a question..
- Will any mods need to be done to hookup a b16 in a 92 VX?
- integ LS motor tranny ecu into eg hatch 92-95
- what kind of swap should i do to the del sol
- Quick Question...............
- Will 99-00 Si A/c Bracket fit in EG B16a Chassis, or do I have to get the delsol VTEC one?
- Lug nuts
- Del sol Coilovers
- Turn Signal Problem After Momo Install
- 4 to 1 or 4 2 1 header?
- Need quiet "universal" muffler, any ideas?
- HELP engine wont start
- sun roof?
- anyone have trouble with ur odometer?
- canadians help!
- Civic EK....options for roll cages?
- 92 civic 4dr rear disc brake???
- are 00 stock Si springs lower & better than stock 00 LX ones?
- h22 or b18c?
- High speed stability??
- integra wiring N civic wiring (help)!!!!
- B16a, p28 or p30?
- What's the going rate for 99-00 CTR headlights
- Jg\edelbrock intake manifold blanks!
- A/C compressor?
- 94 del sol headlights?
- Civic Nation Commercial
- Stolen Today: Black EG h22a/Volk Ce28 wheels...
- What are some fast times in sohc hatchs
- Who here is ghetto
- FS: EG b18cGsR HyBRiD WiDEbOdY
- Where can I get an aluminum AC bracket for a B16?
- Toda A's Vs Skunk2 Stage 1's???
- Something is wrong with my IDLE Help!! Help!!
- New civic ex posts???
- what to do about my supercharged del sol
- rota colors?
- At it again...Harnesses....
- my new toy
- B16 or Ls in a 92 cx?
- for all honda civic people
- Steering trouble
- Radio wiring
- D16Z6 head on D15B7
- area 51 website
- 1/4 mi times for my B18B
- want to have fun with theieves
- dude i need to get to track look at this
- o2 wiring question
- 99 civic axle back exhaust the same as a 93 civic?
- Difficult cold starts
- Intake manifold question
- Jdm claus came late this year
- 13's on a d16z6
- CV boots and rats
- which clutch exedy or ACT???
- Where to find EG hatch wiper arm?
- dual tips
- Couple of suspension and brake questions...
- Bronze Volks Gramlights and Bronze Rota Attack.....????
- Help! Wiring problem
- 96 coupe exhaust??
- s2000 seats?
- Short shifter questions
- Anyone interested in a lease takeover
- Worn Rotor?
- ITR Block...
- fillcoolent ?
- gsr brake swap question??
- Black Interior?
- where to get aem v2 cheap?
- ALREADY Searched::: GSR axleback on an EK.
- What size tires on new Rims?
- Ok my buddy has a 1999 civic si. need your help
- Changing Brake Rotors + Pads...
- Getting A JDM Cluster
- b18c1 vs b16b
- Question about a user on this websites setup
- What do you think about this car? (56k watchout)
- 96-98 / 99-00 Radiator Support questions
- something better than A-pillar gauges?
- ITR rear seats in to ek coupe
- EVERYONE!!!!! please WATCH OUT for your car...... theives....
- Buying a used 91-95 Civic
- Alignment Question
- where can I get a set of factory fog lights for my 94 Eg6?
- 96 Civic Sedan LX - Primary O2 Sensor Heater Location
- Anyone Ever changed your rear dust shields? (pics inside)
- Post pics of black housing headlights on yellow EK's
- sir front lip question
- Engine is idling weird... how to fix?
- Help with Essay.
- what would happen if i rana high cam on both sides?
- del sol stock hood weight?!?!
- b20vtec build
- pOLL - what engine to put in a civic
- EdelBrock Turbo kit for D16y8
- distinguishing shox?
- $138 for OEM fog lights?
- 5 speed convesion for my 98 civic
- some pix of my car
- no more cruise control....help
- best header for civics?
- Power Gains from Skunk2 Stage 1 Camshafts and AEM Cam Gears
- Specials, Clearance, and Used Items. You won't be disapointed !!!
- times for hondas??
- Where To Buy Coolent Temp Switch?
- How do I check if anything is wrong with the CV Joints?
- Ek sedan Pic request!!!!!! rota wheels
- Good So Cal Shop for 96 Civic Exhaust System Overhaul
- badges
- Type R control arms?
- help with itr rear swaybar on 00 Si
- Who would like to see Crane Cams dyno tested?
- yo where is that thread where that dood had his hatch full of stuff like a bunch of stuff
- Installing a hitch on 2000 hatch back
- EG coupe rear seats same as EG hatch?
- map sensor
- 15x6.5 or 15x7 on EH2???
- user name pics
- What brakes will fit under 15" Rota RNR's?
- Header bracket broke
- Good or bad deal? $295 for Z6 engine, grinding tranny, ecu, harness
- Trying to find parts website...
- How long do ACT HDSS Clutches last?
- what is this for on my 2k civic ?
- Leather GSR Seats???
- What do I have to do my B16A in order to make it equal to a B16B?
- how much to resleave a b18b?
- flywheel discussion (come join)
- Less exceleration.. HELP!!!
- Spoon Bars....
- Blinker doesnt shut off when I turn???
- Before and After EH2 pics. Nothin special. 56K, pull up a chair.
- Has anyone done a rear disc conv on a slo?
- Where can I find a true short shifter for a Del Sol Si?
- Where can I find a Del Sol VTEC(B16A) rear sway bar??
- 16 gauge wire big enough for injectors?
- Kinda OT: Any civic owners keep their car's in storage?
- how do you post pics?
- installed manual steering
- Brakes Broke
- Time to get rid of my Money Pit.... How much do you think I can get?
- d16z6 problems
- how to remove the rear window in a 94 coup
- HELP 70mm BBK throttle body for a 95 civic
- 96 Civic - Check Engine Light
- 95 Civic 4-door Sedan Suspension Questions
- Moderaters Help
- the grill...
- B series R/S ratios
- nessesary smog equipment?
- YOu Can Run 13's on a budget swap!!!!
- best turbo platform B18c5 or b18c?
- should i trade out my crx for an eg
- Cam ? please help
- i saw this in the march issue of SCC
- USDM B18c5 or JDM B18c5 ?
- Ignition Setup make a big Difference?
- question about swap!
- B20 or H22 for '95 civic EX coupe
- After replacing brake pads?
- car kinda overheating....any suggestions?
- hatchback owners I NEED YOUR HELP
- Looking into buying a 97 Hatch....Please throw me a couple pics...
- **need help selling prelude stuff for EG stuff look inside
- Problem getting out of park in 93 sedan w/ auto b16a swap...
- Which would you rather pick GSR Front seats or Del Sol?
- gauge mount locations
- jdm vs usdm
- My Cool Shit
- Oil from engine.. whats wrong?
- JDM EG6 folding mirror wiring diagram
- Anyone have a HID kit wedged in some CTR Headlights ?
- how come more people dont go the h22 route???? i must be missing something....
- I think im getting screwed
- Ahhhh, what to do, what to do?? Frost white or Champ White? help!
- JDM audio console
- where to get engine swaps
- I need to know what Fog's these are.
- I thought d16y8's only came in 96-00 Civic EX's??
- GA delsols I need help ASAP
- its here, Finally PICS.
- Picked up my $1200 EK today
- LS auto vs. LS Manual long block
- will the cam gear from a non VTEC 92-95 head work on teh d16z6 vtec head properly?
- photoshop my ek!!!!
- wrong bif my timing belt jumped a tooth on the cam gear could it cause a stumble in accelleration?
- are the metal head gaskets reuseable?
- Difference between 9003/H4 ?
- don't take life for granted....
- NEED HELP!! with o2 wiring conversion.
- EK spoon intake arm finally installed! =P
- Question will a d15 cam fit on a d16???
- Service Manual
- Question On Mods:::
- help with my sparco torino's
- engine wiring harness question
- F.S. b16a2 engine swap
- Clicking noise when moving slowley in First gear...
- Does anyone know what lip this?
- Want to put some S2000 seats in my 93 Del Sol
- EBC slotted rotors
